  4. eusec Adapter startet nicht
    5.2k
93 Beiträge 4 Kommentatoren 13.6k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @kuckuckmann sagte in eusec Adapter startet nicht:
    Zeige mal bitte die Full Ausgabe von
    iob diag
    Kuckuckmann
    @glasfaser
    Volle Ausgabe
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : microsoft
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
    20:49:51 up 2 days, 21:29,  1 user,  load average: 1.59, 0.92, 0.63
    CPU threads: 1
    *** Time and Time Zones ***
                  Local time: Mon 2023-09-11 20:49:51 CEST
              Universal time: Mon 2023-09-11 18:49:51 UTC
                    RTC time: Mon 2023-09-11 18:49:51
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.9G        3.0G        433M        0.0K        470M        683M
    Swap:           974M        550M        424M
    Total:          4.9G        3.6G        857M
            3931 M total memory
            3027 M used memory
            1894 M active memory
            1383 M inactive memory
             433 M free memory
              87 M buffer memory
             383 M swap cache
             974 M total swap
             550 M used swap
             424 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     394M  516K  393M   1% /run
    /dev/sda1      ext4       11G  9.7G  570M  95% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     394M     0  394M   0% /run/user/1000
    [Fri Sep  8 23:20:02 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Sep  8 23:20:03 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.6G    /var/
    969M    /var/log
    953M    /var/log/journal/4cf52e6cb9a74dffa88003229bef874a
    424M    /var/cache
    Archived and active journals take up 952.2M in the file system.
    /opt/iobroker/backups:
    182M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    894M    /opt/iobroker/iobroker-data/
    451M    /opt/iobroker/iobroker-data/histroy0
    324M    /opt/iobroker/iobroker-data/files
    91M     /opt/iobroker/iobroker-data/backup-objects
    56M     /opt/iobroker/iobroker-data/files/telegram.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    13M     /opt/iobroker/iobroker-data/histroy0/20230910/history.WaschmaschieneWh.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
     Installed: 18.17.1-deb-1nodesource1
     Candidate: 18.17.1-deb-1nodesource1
     Version table:
    *** 18.17.1-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
        12.22.12~dfsg-1~deb11u4 500
           500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        12.22.12~dfsg-1~deb11u3 500
           500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.0
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.amazon-dash.0            : amazon-dash           : ioBroker                                 -  enabled
     system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
     system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
     system.adapter.bluelink.0               : bluelink              : ioBroker                                 - disabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
     system.adapter.chromecast.0             : chromecast            : ioBroker                                 - disabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
     system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
     system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
     system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
     system.adapter.firetv.0                 : firetv                : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
     system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
     system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
     system.adapter.jarvis.0                 : jarvis                : ioBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1889, bind: 192.168.1.7
     system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 - disabled
     system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
     system.adapter.parser.0                 : parser                : ioBroker                                 - disabled
     system.adapter.pushover.0               : pushover              : ioBroker                                 - disabled
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
     system.adapter.sayit.0                  : sayit                 : ioBroker                                 - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
     system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
     system.adapter.simple-api.0             : simple-api            : ioBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
     system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
     system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1892, bind: 192.168.1.7
    + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
     system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
     system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
     system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
     system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
     system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD34F8-if00
    + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.1.225:8888
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.10.1   , installed 6.10.0 [Updatable]
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
    Adapter    "awtrix-light" : 0.8.0    , installed 0.8.0
    Adapter    "backitup"     : 2.7.0    , installed 2.7.0
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "device-reminder": 2.0.1  , installed 2.0.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.0.0    , installed 4.0.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "eusec"        : 1.1.2    , installed 1.1.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "firetv"       : 2.0.2    , installed 2.0.1  [Updatable]
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 2.7.4  [Updatable]
    Adapter    "notification-manager": 0.1.1, installed 0.1.1
    Adapter    "openweathermap": 0.4.3   , installed 0.4.2  [Updatable]
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "parser"       : 2.0.5    , installed 2.0.5
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.11   , installed 2.4.11
    Adapter    "socketio"     : 6.5.3    , installed 6.5.3
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.1    , installed 6.1.1
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wled"         : 0.7.0    , installed 0.7.0
    Adapter    "ws"           : 2.5.4    , installed 2.5.4
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        9197
    States:         7883
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Get:4 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (6928 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12541      391/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       1220256    26614/io.shelly.0
    tcp        0      0 192.168.1.7:1889        0.0.0.0:*               LISTEN      1001       1220166    26583/io.mqtt.0
    tcp        0      0 192.168.1.7:1890        0.0.0.0:*               LISTEN      1001       1220167    26583/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1219414    26421/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1219407    26421/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10749      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12552      391/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10757      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1219547    26439/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2351794    42768/io.web.0
    udp        0      0 0.0.0.0:56412           0.0.0.0:*                           1001       1220765    26734/io.broadlink2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1221387    26864/io.wled.0
    udp        0      0 0.0.0.0:56793           0.0.0.0:*                           1001       1220764    26734/io.broadlink2
    udp        0      0 0.0.0.0:54945           0.0.0.0:*                           1001       2290118    26734/io.broadlink2
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12304      348/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10752      1/init
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1220761    26734/io.broadlink2
    udp6       0      0 :::111                  :::*                                0          10762      1/init
    2023-09-11 20:42:17.291  - info: host.ioBroker iobroker host.ioBroker Deleting 1 state(s).
    2023-09-11 20:42:25.499  - info: host.ioBroker iobroker
    2023-09-11 20:42:25.502  - info: host.ioBroker iobroker removed 39 packages in 8s
    2023-09-11 20:42:25.505  - info: host.ioBroker iobroker
    2023-09-11 20:42:25.512  - info: host.ioBroker iobroker 115 packages are looking for funding  run `npm fund` for details
    2023-09-11 20:42:26.598  - info: host.ioBroker iobroker exit 0
    2023-09-11 20:42:28.034  - info: admin.0 (26439) <== Disconnect system.user.admin from ::ffff:192.168.1.8 admin
    2023-09-11 20:42:39.873  - info: admin.0 (26439) ==> Connected system.user.admin from ::ffff:192.168.1.8
    2023-09-11 20:43:32.303  - warn: web.0 (42594) Terminated (-100): Without reason
    2023-09-11 20:43:32.882  - info: host.ioBroker instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-09-11 20:43:32.882  - info: host.ioBroker Restart adapter system.adapter.web.0 because enabled
    2023-09-11 20:43:34.006  - info: host.ioBroker instance system.adapter.web.0 started with pid 42768
    2023-09-11 20:43:35.797  - info: web.0 (42768) starting. Version 6.1.1 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 5.0.12
    2023-09-11 20:43:36.029  - info: web.0 (42768) socket.io server listening on port 8082
    2023-09-11 20:43:36.036  - info: web.0 (42768) http server listening on port 8082
    2023-09-11 20:43:44.883  - info: admin.0 (26439) <== Disconnect system.user.admin from ::ffff:192.168.1.8 admin
    2023-09-11 20:43:50.071  - info: admin.0 (26439) ==> Connected system.user.admin from ::ffff:192.168.1.8
    2023-09-11 20:45:00.093  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 42786
    2023-09-11 20:45:01.969  - info: dwd.0 (42786) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-11 20:45:03.345  - info: dwd.0 (42786) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-11 20:45:03.909  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-11 20:50:00.151  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 43944
    2023-09-11 20:50:02.639  - info: dwd.0 (43944) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-11 20:50:04.351  - info: dwd.0 (43944) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-11 20:50:04.910  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Summary
                        v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-15-amd64
    Installation:           microsoft
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                           /usr/bin/npm            9.6.7
                           /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.9G        3.1G        373M        0.0K        494M        642M
    Total:          4.9G        3.6G        797M
    Active iob-Instances:   27
    ioBroker Core:          js-controller           5.0.12
                           admin                   6.10.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                9197
    States:                 7882
    Size of iob-Database:
    2.6M    /opt/iobroker/iobroker-data/states.jsonl
    NSPanel Dokumentation im GitHub Wiki:
    • K Kuckuckmann
      @glasfaser
      Volle Ausgabe
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 1
                   NTP service: active
               RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
              3931 M total memory
              3027 M used memory
               433 M free memory
                87 M buffer memory
               383 M swap cache
               974 M total swap
               550 M used swap
               424 M free swap
      *** FILESYSTEM ***
      /var:
      1.6G    /var/
      969M    /var/log
      424M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9197
      States:         7883
      Pending Updates: 0
      Summary
                          v.2023-04-16
      User-ID:                0
      X-Server:               false
                             /usr/bin/npm            9.6.7
                             /usr/bin/npx            9.6.7
      MEMORY:
                             admin                   6.10.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                9197
      States:                 7882
      GlasfaserG Offline
      GlasfaserG Offline
      root
      ... lass es bitte sein !
      Guter Ratschlag !
        root
        Guter Ratschlag !
        Kuckuckmann
        @glasfaser
        Ist der Adapter bei Dir gestartet?
        • K Kuckuckmann
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          @kuckuckmann
          siehe Screenshot , die ich schon gepostet habe !
          Ja ... mir fehlt halt nur ein Passwort oder so .. , da ich kein eusec habe , kann ich nicht weiter Testen.
          Laut deinen Angaben , werden nur wenige Paket installiert , bei mir waren es
          224 packages
          Deinstalliere alles und dann neu über :
            Kuckuckmann
            Ja bei mir sind es immer nur 133
            Ich mache es gerne noch einmal. Ich glaube aber nicht, dass es diesmal anders sein wird.
            Kleiner Moment
              @kuckuckmann
              224 packages
              @glasfaser sagte in eusec Adapter startet nicht:
              224 packages
              Sind die 'looking for funding' Pakete, nicht die mit dem Adapter installierten.
              Btw: Installation schaut bei mir auch so aus. Fehlt bloß ein Passwort.
              • K Kuckuckmann
                Kleiner Moment
                GlasfaserG Offline
                GlasfaserG Offline
                @kuckuckmann
                Du kannst auch ... eine bestimmte Version installieren , oder einen upload machen dann wird nochmal alles geholt
                  Kuckuckmann
                  Ich hab den verdacht, dass dieser eufy-sec-client nicht richtig installiert wird. Das würde auch die ausgeloggte Meldung erklären, dass dort was fehlt.
                  • K Kuckuckmann
                    @kuckuckmann
                    Nein:
                    ├─┬ iobroker.eusec@1.1.2
                    │ ├─┬ @bropat/fluent-ffmpeg@2.1.3
                    │ │ ├── async@3.2.4 deduped
                    │ │ └─┬ which@2.0.2
                    │ │   └── isexe@2.0.0
                    │ ├── @cospired/i18n-iso-languages@4.1.0
                    │ ├─┬ @iobroker/adapter-core@3.0.3
                    │ │ └── @iobroker/types@5.0.11 deduped
                    │ ├─┬ eufy-security-client@2.8.1
                    │ │ ├── @cospired/i18n-iso-languages@4.1.0 deduped
                      Kuckuckmann
                      schrieb am zuletzt editiert von Kuckuckmann
                      Ausgangslage:
                      host.ioBroker
                         2023-09-11 21:12:16.497	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.ioBroker
                         2023-09-11 21:12:16.497	error	Caught by controller[1]: Node.js v18.17.1
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: }
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: requestPath: 'eufy-security-client'
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:22:35)
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                      host.ioBroker
                         2023-09-11 21:12:16.496	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: ^
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: throw err;
                      host.ioBroker
                         2023-09-11 21:12:16.495	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
                        @kuckuckmann
                        Nein:
                        │ │ └─┬ which@2.0.2
                        │ │   └── isexe@2.0.0
                        Kuckuckmann
                        Wie kann ich den Tree abrufen?
                        • K Kuckuckmann
                          @kuckuckmann
                          cd /opt/iobroker/ && npm ls -a
                          Wie schaut das bei dir aus?
                          echad@chet:/opt/iobroker $ ls -la /opt/iobroker/node_modules/eufy-security-client/package.json
                          -rw-rw-r--+ 1 iobroker iobroker 2205 Sep 11 21:16 /opt/iobroker/node_modules/eufy-security-client/package.json
                          Bzw.:
                          getfacl /opt/iobroker/node_modules/eufy-security-client/package.json
                            @kuckuckmann
                            Bzw.:
                            Kuckuckmann
                            @thomas-braun sagte in eusec Adapter startet nicht:
                            @kuckuckmann
                            Die Ausgabe war Mega lang, ich hab es mal auf den bereich zum ├─┬ iobroker.eusec@1.1.2 begrenzt:
                            │ │ ├── async@0.2.10
                            │ │ └─┬ which@2.0.2
                            │ │   └── isexe@2.0.0
                            │ ├── eufy-security-client@2.8.1 deduped
                            │ ├─┬ ffmpeg-static@5.2.0
                            │ │ ├─┬ @derhuerst/http-basic@8.2.4
                            │ │ │ ├── caseless@0.12.0 deduped
                            │ │ │ ├── concat-stream@2.0.0 deduped
                            │ │ │ ├─┬ http-response-object@3.0.2
                            │ │ │ │ └── @types/node@10.17.60
                            │ │ │ └── parse-cache-control@1.0.1
                            │ │ ├── env-paths@2.2.1
                            │ │ ├─┬ https-proxy-agent@5.0.1
                            │ │ │ ├─┬ agent-base@6.0.2
                            │ │ │ │ └─┬ debug@4.3.4
                            │ │ │ │   └── ms@2.1.2
                            │ │ │   └── ms@2.1.2
                            │ │ └── progress@2.0.3
                            │ ├── fs-extra@11.1.1 deduped
                            │ ├─┬ go2rtc-static@1.6.2
                            │ │ ├─┬ got@11.8.6
                            │ │ │ ├── @sindresorhus/is@4.6.0
                            │ │ │ ├─┬ @szmarczak/http-timer@4.0.6
                            │ │ │ │ └── defer-to-connect@2.0.1
                            │ │ │ ├── @types/cacheable-request@6.0.2 deduped
                            │ │ │ ├── @types/responselike@1.0.0 deduped
                            │ │ │ ├── cacheable-lookup@5.0.4 deduped
                            │ │ │ ├─┬ cacheable-request@7.0.4
                            │ │ │ │ ├── clone-response@1.0.2 deduped
                            │ │ │ │ ├─┬ get-stream@5.2.0
                            │ │ │ │ │ └── pump@3.0.0 deduped
                            │ │ │ │ ├── http-cache-semantics@4.1.1 deduped
                            │ │ │ │ ├─┬ keyv@4.5.3
                            │ │ │ │ │ └── json-buffer@3.0.1
                            │ │ │ │ ├── lowercase-keys@2.0.0 deduped
                            │ │ │ │ ├── normalize-url@6.1.0
                            │ │ │ │ └── responselike@2.0.1 deduped
                            │ │ │ ├─┬ decompress-response@6.0.0
                            │ │ │ │ └── mimic-response@3.1.0
                            │ │ │ ├── http2-wrapper@1.0.3 deduped
                            │ │ │ ├── p-cancelable@2.1.1
                            │ │ │ └─┬ responselike@2.0.1
                            │ │ │   └── lowercase-keys@2.0.0 deduped
                            │ │ ├── https-proxy-agent@5.0.1 deduped
                            │ │ └── progress@2.0.3 deduped
                            │ ├─┬ got@11.8.6
                            │ ├── i18n-iso-countries@7.6.0 deduped
                            │ ├── mime@3.0.0
                            │ └── ts-log@2.2.5 deduped
                            ioadmin@ioBroker:/opt/iobroker# ls -la /opt/iobroker/node_modules/eufy-security-client/package.json
                            -rw-rw-r--+ 1 iobroker iobroker 2129 11. Sep 20:18 /opt/iobroker/node_modules/eufy-security-client/package.json
                            • GlasfaserG Offline
                              GlasfaserG Offline
                              hier liegt der Hund begraben ... aber ich finde gerade nichts dazu
                              • K Kuckuckmann
                                @kuckuckmann
                                │ │ └─┬ which@2.0.2
                                │ │   └── isexe@2.0.0
                                │ │ │   └── ms@2.1.2
                                │ │ ├─┬ got@11.8.6
                                │ ├─┬ got@11.8.6
                                │ ├── mime@3.0.0
                                Bedeutet, du hast den mal irgendwann 'daneben geworfen'.
                                Der sollte nur einmal auftauchen, wie hier:
                                echad@chet:/opt/iobroker $ npm ls eufy-security-client
                                iobroker.inst@3.0.0 /opt/iobroker
                                └─┬ iobroker.eusec@1.1.2
                                  └── eufy-security-client@2.8.1
                                  Kuckuckmann
                                  @glasfaser
                                  Ja genau, in dem Ordner fehlt der Unterordner Build mit der index.js - zumindest bei mir.
                                  @Thomas-Braun
                                  nicht bewusst. Aber ein paar mal schon installiert und deinstalliert.. Kann man das bereinigen?
                                  • K Kuckuckmann
                                    @glasfaser
                                    @Thomas-Braun
                                    Dafür dürfte der eine Ebene höher zu finden sein, wo das 'daneben geworfene' Modul haust.
                                    • K Kuckuckmann
                                      @glasfaser
                                      @Thomas-Braun
                                      Wenn man weiß wo es liegt...
                                      Schau per
                                      danach.
                                        Schau per
                                        danach.
                                        Kuckuckmann
                                        ioadmin@ /home/ioadmin
                                        • K Kuckuckmann
                                          @kuckuckmann
                                          Das ist nicht der vollständige login prompt. Nix weglöschen, nix 'zensieren', nix verändern.
                                          Den Adapter hast du mal ins home vom user ioadmin geklatscht.
                                          In dem Ordner
                                          npm ls
