  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Victron-Energy Adapter - will nicht - doppelte Geräte-ID?
    5.1k
50 Beiträge 3 Kommentatoren 7.7k Aufrufe 2 Beobachtet
  • Stefan FaltS Stefan Falt
    jetzt habe ich verstanden was Du meinst. Sorry.
    Doch kann er, aber da ist ja das gleiche Problem - doppelte ID - das würde dann nicht gehen.
    AFAIK der Adapter ließt einfach nur die Daten aus und erzeugt schöne Datenpunkte.
    host.bananapim5
    	2023-08-31 19:34:25.765	info	Restart adapter system.adapter.ve.0 because enabled
    host.bananapim5
    	2023-08-31 19:34:25.764	error	instance system.adapter.ve.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    ve.0
    	2023-08-31 19:34:25.186	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ve.0
    	2023-08-31 19:34:25.184	info	terminating
    ve.0
    	2023-08-31 19:34:25.182	info	Unload adapter...
    ve.0
    	2023-08-31 19:34:25.176	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.175	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.174	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.173	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.172	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.171	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.172	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.170	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.169	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.168	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.167	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.166	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.165	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.165	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.164	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.163	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.162	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.161	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.160	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.159	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.158	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.157	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.156	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.155	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.154	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.153	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.152	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.151	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.150	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.149	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.150	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.148	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.147	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.146	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.145	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.143	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.143	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.142	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.141	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ve.0
    	2023-08-31 19:34:25.140	error	Port Not Open
    ve.0
    	2023-08-31 19:34:25.139	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
    ve.0
    	2023-08-31 19:34:25.138	error	unhandled promise rejection: Port Not Open
    ve.0
    	2023-08-31 19:34:25.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    @stefan-falt sagte in Victron-Energy Adapter - will nicht - doppelte Geräte-ID?:
    Stefan FaltS 1 Antwort Letzte Antwort
      Stefan FaltS Offline
      Stefan Falt
      Wenn ich wüsste warum der 100 anstelle von 502 nimmt .... hast Du noch eine Idee?
      29kWp PV
      57kWh Seplos Batterie + 3xMultiplus 2
      1,4kW DIY Brauchwasser
      Auto aus der Batterie Laden für Arme https://forum.iobroker.net/topic/69356/keba-p30c-auto-aus-der-batterie-laden-f%C3%BCr-arme
      Brauchwasser erhitzen für Arme https://forum.iobroker.net/topic/76533/brauchwasser-erhitzen-f%C3%BCr-arme-mit-batterie
        weil du es eingetragen hast?!?
          Stefan Falt
          schrieb am zuletzt editiert von Stefan Falt
          @homoran Nicht dass ich wüsste. Wo könnte ich das wieder ändern? Irgendwie werde ich da im Netz nicht fündig ... 😞
          29kWp PV
            du hast mircdoch deine Konfiguration gepostet, da stehts drin
              Stefan Falt
              @homoran Naja, ich muss ja die Geräte ID nehmen (com.victronenergy.system), die der GX vorgibt, die ist eben 100. Oder habe ich was falsches verstanden? Darf ich fragen, was da bei dir steht?
              Was ist das hub4 überhaupt?
              29kWp PV
                Da steht doch port und nicht id wo du die 100 hast
                  Stefan Falt
                  @homoran Damn, da hast Du absolut recht ...
                  Wenn ich auf 502 stellt, kommt ...
                  host.bananapim5
                  	2023-08-31 20:47:15.882	warn	Do not restart adapter system.adapter.ve.0 because restart loop detected
                  host.bananapim5
                  	2023-08-31 20:47:15.882	info	Restart adapter system.adapter.ve.0 because enabled
                  host.bananapim5
                  	2023-08-31 20:47:15.881	error	instance system.adapter.ve.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  ve.0
                  	2023-08-31 20:47:15.300	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  ve.0
                  	2023-08-31 20:47:15.299	info	terminating
                  ve.0
                  	2023-08-31 20:47:15.297	info	Unload adapter...
                  ve.0
                  	2023-08-31 20:47:15.291	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.290	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.289	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.289	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.288	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.287	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.286	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.285	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.284	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.284	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.283	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.282	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.281	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.280	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.279	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.279	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.278	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.277	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.276	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.275	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.274	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.274	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.273	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.272	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.271	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.270	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.269	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.268	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.267	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.267	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.266	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.265	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.264	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.263	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.263	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.262	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.261	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.260	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.259	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.258	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.257	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.257	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.256	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.254	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.253	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.251	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.251	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.250	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.249	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.248	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.247	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.245	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.244	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.244	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.243	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.242	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.241	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.240	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.239	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.238	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.238	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.237	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.236	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.235	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.234	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.233	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.232	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.231	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.231	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.230	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.229	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.227	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.226	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.225	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.224	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.223	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.222	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.221	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.220	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.219	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.218	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.217	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.217	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.215	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.215	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.214	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.213	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.212	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.211	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.210	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.210	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.208	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.208	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.207	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.206	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.204	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.204	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.202	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.200	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.199	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.198	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.197	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.196	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.194	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.193	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.192	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.191	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.190	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.189	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.188	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.187	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.185	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.184	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.183	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.182	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.181	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.180	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.179	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.178	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.176	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.175	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.174	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.173	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.172	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.171	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.170	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.169	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.166	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.165	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.163	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.160	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  ve.0
                  	2023-08-31 20:47:15.157	error	Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.156	error	PortNotOpenError: Port Not Open at ModbusRTU.writeFC4 (/opt/iobroker/node_modules/modbus-serial/index.js:665:28) at ModbusRTU.writeFC3 (/opt/iobroker/node_modules/modbus-serial/index.js:651:14) at /opt/iobroker/node_modules/modbus-serial/apis/promise.js:48:31 at new Promise (<anonymous>) at ModbusRTU.converted [as readHoldingRegisters] (/opt/iobroker/node_modules/modbus-serial/apis/promise.js:39:29) at /opt/iobroker/node_modules/iobroker.ve/main.js:185:35 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.ve/main.js:157:24 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1174:38) at listOnTimeout (node:internal/timers:569:17)
                  ve.0
                  	2023-08-31 20:47:15.149	error	unhandled promise rejection: Port Not Open
                  ve.0
                  	2023-08-31 20:47:15.148	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  smartmeter.0
                  	2023-08-31 20:47:12.193	info	Received 10 values, 3 updated
                  ve.0
                  	2023-08-31 20:47:10.148	warn	[object Object]
                  ve.0
                  	2023-08-31 20:47:10.080	error	Your IP-Address 'http://192.168.178.44/' is not valid. Restart the Adapter.
                  ve.0
                  	2023-08-31 20:47:10.048	info	Number of PV-Inverters: 0
                  ve.0
                  	2023-08-31 20:47:10.046	info	config port: 502
                  ve.0
                  	2023-08-31 20:47:10.044	info	config IP: http://192.168.178.44/
                  ve.0
                  	2023-08-31 20:47:09.982	info	starting. Version 0.3.1 (non-npm: derAlff/ioBroker.ve#584088cddf3318ede48554ed97414f5ff79f460e) in /opt/iobroker/node_modules/iobroker.ve, node: v18.17.1, js-controller: 4.0.24
                  Aber die 192.168.178.4 ist valid, es kommt die passende Seite ... die Fehlermeldung wäre noch zu betrachten ...
                  Auf der 192.168.178.30 ist der BananaPi mit ioBroker.
                  29kWp PV
                    host.bananapim5
                    host.bananapim5
                    host.bananapim5
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    smartmeter.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    ve.0
                    192.168.178.4
                    im Screenshot ist es .44
                      192.168.178.4
                      Stefan Falt
                      @homoran ja, meine ich. ... 192.168.178.44 ist valid, es kommt die pasende Seite ...
                      29kWp PV
                        Stefan Falt
                        @stefan-falt Ich weis nicht was ich noch tun soll ...
                        29kWp PV
                          ich auch nicht.
                          vielleicht kann @derAlff helfen
                            ich auch nicht.
                            Stefan Falt
                            @homoran ja vermutlich. Vielen Dank für Deine Zeit ... ✊
                            29kWp PV
                              @stefan-falt ach 💡
                              hast du mqtt im gx freigegeben?
                                @stefan-falt ach 💡
                                Stefan Falt
                                @homoran Ja, habe ich.
                                29kWp PV
                                  @stefan-falt bliebe noch die Möglichkeit über den Modbus Adapter
                                    Stefan Falt
                                    @homoran Ich habe es ausgeschalten wie gezeigt -> keine Änderung.
                                    Da habe ich schon mal einen schnellen Versuch gemacht: Adresse 840 mit uint16 sollte die Spannung der Batterie geben .. ich machs nochmal ...
                                    29kWp PV
                                      @stefan-falt mach den ve aus, wenn du mit modbus draufgehst. und umgekehrt
                                        host.bananapim5
                                        host.bananapim5
                                        host.bananapim5
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        smartmeter.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        ve.0
                                        @stefan-falt mist, das les ich jetzt erst!
                                        unit 1 ist wahrscheinlich falsch.
                                        lösch den Fehler, dann siehst du wann der nächste kommt
                                          Stefan Falt
                                          @homoran said in Victron-Energy Adapter - will nicht - doppelte Geräte-ID?:
                                          Was ist ein unit 1? Der Fehler ist gelöscht.
                                          Den modbus Adapter habe ich erstellt - Fehlermeldung:
                                          modbus.1
                                          	2023-08-31 21:15:27.372	info	Disconnected from slave 192.168.178.44
                                          modbus.1
                                          	2023-08-31 21:15:27.319	warn	Poll error count: 6 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:26.260	warn	Poll error count: 5 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:25.203	warn	Poll error count: 4 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:24.144	warn	Poll error count: 3 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:23.081	warn	Poll error count: 2 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:22.022	warn	Poll error count: 1 code: {"errorCode":132,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
                                          modbus.1
                                          	2023-08-31 21:15:21.998	info	Connected to slave 192.168.178.44
                                          modbus.1
                                          	2023-08-31 21:15:21.302	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 4.0.24
                                          29kWp PV
                                          HomoranH Stefan FaltS 2 Antworten Letzte Antwort
