  2. English
  3. ioBroker general
  4. HELP - Can't login to iobroker admin page
    6.6k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
23 Beiträge 6 Kommentatoren 14.6k Aufrufe 4 Beobachtet
  • Federico GallinariF Offline
    Federico Gallinari
    schrieb am zuletzt editiert von Federico Gallinari
    HI, I've been using iobroker on docker for years, lately I noticed that an admin update had come out which however required a new node, and therefore a new instance (container) from an updated docker image.
    I backed up with backupit and then installed, but strangely the instance no longer started after the reboot.
    I thought I'd see it later, so I turn off the instance (container) and restarted the old one...
    Unfortunately, once the login screen arrived, I entered the username that is always used but it does not connect giving the wrong user or psw message.
    I tried to reset the password from the console (iobroker passwd admin) but it keeps crashing.
    I don't know how to get into the web interface anymore (ps iobroker seems to work but clearly I can't govern it anymore).
    I also tried restoring a backupit (latest) backup to a copy of the doker instance....again it crashes on reboot and nothing starts (page 8081 doesn't answer).
    In any case, I would first like to recover the old one by managing to enter the homepage.
    Grazie per il supporto
    • Federico GallinariF Federico Gallinari
      @federico-gallinari sagte in HELP - Can't login to iobroker admin page:
      what message in the log?
      please provide the output of iob diag full in code-tags
      Federico GallinariF 1 Antwort Letzte Antwort
        Federico Gallinari
        @homoran said in HELP - Can't login to iobroker admin page:
        iob diag
        I'll try running this command on container 2 where I do a backup restore, but I'm interested in the original container first.
        I never changed anything in that container, I just stopped it and restarted after stopping the new copy.
        Why doesn't it recognize multiple users and pw (they are present and active from the console)?
          iob diag
          Cannot see into your installation! please provide the output. this may help.
            Federico Gallinari
            this is the result on the last version of iobroker container after restore the backup of backupit done today.
            Job.txt
            ps
            iob diag on original container (older) does not provide the same result, it doesn't seem to work, if I run it I receive the iobroker [command] list.
              Job.txt
              ps
              Execute
              iob fix
              first, it will pull in the iob diag script.
                Execute
                iob fix
                Federico Gallinari
                @thomas-braun said in HELP - Can't login to iobroker admin page:
                iob diag
                This is the script result on the container that starts but no longer recognizes the user and password to connect to the web interface.
                https://e.pcloud.link/publink/show?code=XZtib2ZFNlQOtgNmwLCgsRHuFbxAb3M7hry
                  iob diag
                  @federico-gallinari
                  Please do not post the result externally. I can't open it.
                  Put it inside this thread.
                    @federico-gallinari
                    Federico Gallinari
                    @thomas-braun jobcopy.txt
                      @federico-gallinari
                      Sorry, I can't help here.
                      I don't know much about Docker or the user access restrictions in ioBroker.
                        @federico-gallinari
                        Federico Gallinari
                        @thomas-braun I hope the developer will give me help, and I even don't know why as I use restore from backup the container never finish to start...
                        It's really strange that there are no way to disable authentication with some console command.
                          Job.txt
                          ps
                          this is the result
                          please
                          @homoran sagte in HELP - Can't login to iobroker admin page:
                          I cannot (and won't) open txt-files on my mobile
                            this is the result
                            please
                            Federico Gallinari
                            @homoran tell me in what format
                            Samson71S Meister MopperM 2 Antworten Letzte Antwort
                              Samson71S Offline
                              Samson71S Offline
                              Samson71
                              @federico-gallinari
                              In Code-tags means text direkt here, not a separate file as an attachment
                              Markus
                              Bitte beachten:
                                Meister MopperM Online
                                Meister Mopper
                                @federico-gallinari
                                Copy the text and put it in here
                                Proxmox und HA ...
                                  @federico-gallinari
                                  Federico Gallinari
                                  @meister-mopper ```
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Architecture    : x86_64
                                  Docker          : v6.0.0
                                  Virtualization  : Unknown (buanet/Synology?)
                                  Distributor ID: Debian
                                  Description:    Debian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                  Systemuptime and Load:
                                   16:41:21 up 53 days, 21:18,  0 users,  load average: 4.88, 5.68, 4.74
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                  Mon Aug 28 14:41:21 UTC 2023
                                  Mon Aug 28 16:41:21 CEST 2023
                                  CEST +0200
                                  Etc/UTC
                                  *** User and Groups ***
                                  root
                                  /root
                                  root
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Mem:            7.8G        1.2G        776M         99M        5.8G        6.2G
                                  Swap:           6.7G        956M        5.8G
                                  Total:           14G        2.2G        6.6G
                                           7802 M total memory
                                           1222 M used memory
                                           2592 M active memory
                                           2814 M inactive memory
                                            776 M free memory
                                             16 M buffer memory
                                           5787 M swap cache
                                           6731 M total swap
                                            956 M used swap
                                           5775 M free swap
                                  *** FILESYSTEM ***
                                  Filesystem             Type   Size  Used Avail Use% Mounted on
                                  /dev/mapper/cachedev_3 btrfs  3.5T  1.1T  2.5T  31% /
                                  tmpfs                  tmpfs   64M     0   64M   0% /dev
                                  tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
                                  shm                    tmpfs   64M     0   64M   0% /dev/shm
                                  /dev/mapper/cachedev_3 btrfs  3.5T  1.1T  2.5T  31% /bksyn
                                  /dev/mapper/cachedev_3 btrfs  3.5T  1.1T  2.5T  31% /dkr
                                  /dev/mapper/cachedev_3 btrfs  3.5T  1.1T  2.5T  31% /etc/hosts
                                  tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/acpi
                                  tmpfs                  tmpfs  3.9G     0  3.9G   0% /proc/scsi
                                  tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/firmware
                                  sudo: unable to resolve host buanet-iobroker2: Name or service not known
                                  [Wed Jul  5 19:23:55 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                  [Wed Jul  5 19:23:56 2023] EXT4-fs (md0): recovery complete
                                  [Wed Jul  5 19:23:56 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                                  [Wed Jul  5 19:24:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                  [Wed Jul  5 19:24:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                                  [Wed Jul  5 19:24:02 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
                                  [Wed Jul  5 19:24:02 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
                                  [Wed Jul  5 19:24:08 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                  [Wed Jul  5 19:24:09 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
                                  [Wed Jul  5 19:24:10 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
                                  [Wed Jul  5 19:24:10 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                                  [Wed Jul  5 19:25:03 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
                                  TARGET             SOURCE        FSTYPE OPTIONS
                                  /                  /dev/mapper/cachedev_3[/@syno/@docker/btrfs/subvolumes/363f4e5c122f572e69aad35c01e382d4948df08bb3f1a71410f3cbcd5745332d]       btrfs  rw,nodev,relatime,ssd
                                  ,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=884,subvol=/@syno/@docker/btrfs/subvolumes/363f4e5c122f572e69aad35c01e382d4948df08bb3f1a7
                                  1410f3cbcd5745332d
                                  |-/bksyn           /dev/mapper/cachedev_3[/@syno/surveillance/backupDirSyn]        btrfs  rw,nodev,relatime,ssd
                                  ,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=282,subvol=/@syno/surveillance/backupDirSyn
                                  |-/dkr             /dev/mapper/cachedev_3[/@syno/docker]        btrfs  rw,nodev,relatime,ssd
                                  ,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker
                                  |-/etc/resolv.conf /dev/mapper/cachedev_3[/@syno/@docker/containers/5d5939354d5e1766174c9123f015f39319073954676dbda67fe3da22b5d1c977/resolv.conf] btrfs  rw,nodev,relatime,ssd
                                  ,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/5d5939354d5e1766174c9123f015f39319073954676dbda67fe3
                                  |-/etc/hostname    /dev/mapper/cachedev_3[/@syno/@docker/containers/5d5939354d5e1766174c9123f015f39319073954676dbda67fe3da22b5d1c977/hostname]    btrfs  rw,nodev,relatime,ssd
                                  `-/etc/hosts       /dev/mapper/cachedev_3[/@syno/@docker/containers/5d5939354d5e1766174c9123f015f39319073954676dbda67fe3da22b5d1c977/hosts]       btrfs  rw,nodev,relatime,ssd
                                  da22b5d1c977/hosts
                                  /var:
                                  38M     /var/
                                  35M     /var/lib
                                  18M     /var/lib/dpkg
                                  18M     /var/lib/apt/lists
                                  18M     /var/lib/apt
                                  /opt/iobroker/backups:
                                  1.6G    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  302M    /opt/iobroker/iobroker-data/
                                  179M    /opt/iobroker/iobroker-data/files
                                  72M     /opt/iobroker/iobroker-data/files/telegram.admin
                                  72M     /opt/iobroker/iobroker-data/backup-objects
                                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  29M     /opt/iobroker/iobroker-data/states.jsonl
                                  15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.
                                  44fe4a3f.chunk.js.map
                                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                                  7.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.52e68e8c.js
                                  7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.
                                  44fe4a3f.chunk.js
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v14.18.2
                                  /usr/bin/node           v14.18.2
                                  /usr/bin/npm            9.1.2
                                  /usr/bin/npx            9.1.2
                                  nodejs:
                                    Installed: 14.18.2-deb-1nodesource1
                                    Candidate: 14.21.3-deb-1nodesource1
                                    Version table:
                                       14.21.3-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                                   *** 14.18.2-deb-1nodesource1 100
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                       12.22.12~dfsg-1~deb11u3 500
                                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                  No problems detected
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  4.0.21
                                  admin:          6.3.5
                                  javascript:     7.0.3
                                  Adapters from github:   2
                                  Adapter State
                                    system.adapter.admin.0                  : admin                 : buanet-iobroker2                         - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alexa2.0                 : alexa2                : buanet-iobroker2                         - disabled
                                    system.adapter.backitup.0               : backitup              : buanet-iobroker2                         - disabled
                                    system.adapter.ble.0                    : ble                   : buanet-iobroker2                         - disabled
                                    system.adapter.broadlink2.0             : broadlink2            : buanet-iobroker2                         - disabled
                                    system.adapter.discovery.0              : discovery             : buanet-iobroker2                         - disabled
                                    system.adapter.geofency.0               : geofency              : buanet-iobroker2                         - disabled, port: 7999, bind: 0.0.0.0
                                    system.adapter.homeconnect.0            : homeconnect           : buanet-iobroker2                         - disabled
                                    system.adapter.homekit-controller.0     : homekit-controller    : buanet-iobroker2                         - disabled
                                    system.adapter.info.0                   : info                  : buanet-iobroker2                         - disabled
                                    system.adapter.javascript.0             : javascript            : buanet-iobroker2                         - disabled
                                    system.adapter.node-red.0               : node-red              : buanet-iobroker2                         - disabled, port: 1880, bind: 0.0.0.0
                                    system.adapter.nuki-extended.0          : nuki-extended         : buanet-iobroker2                         - disabled
                                    system.adapter.shelly.0                 : shelly                : buanet-iobroker2                         - disabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.smartthings.0            : smartthings           : buanet-iobroker2                         - disabled
                                    system.adapter.telegram.0               : telegram              : buanet-iobroker2                         - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.tuya.0                   : tuya                  : buanet-iobroker2                         - disabled
                                    system.adapter.vw-connect.0             : vw-connect            : buanet-iobroker2                         - disabled
                                    system.adapter.web.0                    : web                   : buanet-iobroker2                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.yahka.0                  : yahka                 : buanet-iobroker2                         - disabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                                  Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                  Adapter    "ble"          : 0.13.4   , installed 0.13.4
                                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                  Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                                  Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                                  Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                  Controller "js-controller": 4.0.24   , installed 4.0.21 [Updatable]
                                  Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                  Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                  Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                                  Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                  Adapter    "vw-connect"   : 0.0.67   , installed 0.0.72
                                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                  Objects and States
                                  Objects:        20797
                                  States:         14286
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                                  Reading package lists...
                                  Pending Updates: 134
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:9007            0.0.0.0:*               LISTEN      0          48655      -
                                  tcp        0      0 0.0.0.0:9008            0.0.0.0:*               LISTEN      0          48657      -
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          48651      -
                                  tcp        0      0 192.168.2.8:50001       0.0.0.0:*               LISTEN      0          91883      -
                                  tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN      0          95004      -
                                  tcp        0      0 192.168.2.8:49170       0.0.0.0:*               LISTEN      254178     93680      -
                                  tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          46305      -
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          26790      -
                                  tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         76297      -
                                  tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN      0          101657     -
                                  tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN      254178     94920      -
                                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          48653      -
                                  tcp        0      0 127.0.0.1:4700          0.0.0.0:*               LISTEN      0          46392      -
                                  tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          101396     -
                                  tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          44512      -
                                  tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          97180334   -
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       630459172  -
                                  tcp        0      0 192.168.2.8:49160       0.0.0.0:*               LISTEN      0          103720     -
                                  tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          48647      -
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       630464414  -
                                  tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          48649      -
                                  tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN      0          48317      -
                                  tcp6       0      0 :::9007                 :::*                    LISTEN      0          48656      -
                                  tcp6       0      0 :::9008                 :::*                    LISTEN      0          48658      -
                                  tcp6       0      0 :::80                   :::*                    LISTEN      0          48652      -
                                  tcp6       0      0 :::21                   :::*                    LISTEN      0          46306      -
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          26792      -
                                  tcp6       0      0 :::443                  :::*                    LISTEN      0          48654      -
                                  tcp6       0      0 :::3261                 :::*                    LISTEN      0          48106      -
                                  tcp6       0      0 :::5566                 :::*                    LISTEN      0          69508      -
                                  tcp6       0      0 :::3263                 :::*                    LISTEN      0          51483      -
                                  tcp6       0      0 :::3264                 :::*                    LISTEN      0          51485      -
                                  tcp6       0      0 :::3265                 :::*                    LISTEN      0          194226300  -
                                  tcp6       0      0 :::6690                 :::*                    LISTEN      0          97180335   -
                                  tcp6       0      0 :::548                  :::*                    LISTEN      0          47627      -
                                  tcp6       0      0 :::8581                 :::*                    LISTEN      0          117620     -
                                  tcp6       0      0 :::5000                 :::*                    LISTEN      0          48648      -
                                  tcp6       0      0 :::5001                 :::*                    LISTEN      0          48650      -
                                  tcp6       0      0 :::873                  :::*                    LISTEN      0          48318      -
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          25149      -
                                  udp        0      0 192.168.2.8:123         0.0.0.0:*                           87         29616      -
                                  udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          24112      -
                                  udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          24108      -
                                  udp        0      0 192.168.2.255:137       0.0.0.0:*                           0          627061447  -
                                  udp        0      0 192.168.2.8:137         0.0.0.0:*                           0          627061446  -
                                  udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          627061418  -
                                  udp        0      0 192.168.2.255:138       0.0.0.0:*                           0          627061449  -
                                  udp        0      0 192.168.2.8:138         0.0.0.0:*                           0          627061448  -
                                  udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          627061419  -
                                  udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          44511      -
                                  udp        0      0 127.0.0.1:41410         0.0.0.0:*                           254178     93681      -
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          117617     -
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          28567      -
                                  udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          25430      -
                                  udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          25429      -
                                  udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          25428      -
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          103723     -
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          91886      -
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     93683      -
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          49500      -
                                  udp        0      0 127.0.0.1:59356         0.0.0.0:*                           0          103721     -
                                  udp        0      0 192.168.2.8:55900       0.0.0.0:*                           254178     93682      -
                                  udp        0      0 192.168.2.8:55901       0.0.0.0:*                           0          91885      -
                                  udp        0      0 192.168.2.8:55902       0.0.0.0:*                           0          103722     -
                                  udp        0      0 127.0.0.1:51984         0.0.0.0:*                           0          91884      -
                                  udp        0      0 0.0.0.0:39988           0.0.0.0:*                           0          470725444  -
                                  udp        0      0 0.0.0.0:60868           0.0.0.0:*                           0          28569      -
                                  udp6       0      0 fd36:ad1e:b1f8:11e7:123 :::*                                87         35782      -
                                  udp6       0      0 fe80::211:32ff:fe94:123 :::*                                87         35033      -
                                  udp6       0      0 ::1:123                 :::*                                0          24114      -
                                  udp6       0      0 :::123                  :::*                                0          24105      -
                                  udp6       0      0 :::5353                 :::*                                0          28568      -
                                  udp6       0      0 :::59640                :::*                                0          28570      -
                                  2023-08-28 16:40:11.666  - warn: smartthings.0 (581) Could not perform strict object check of state smartthings.0.79c5970d-7cce-47db-b6e7-d5eaf4f8161a.status.ocf.mnmo.value: DB
                                  closed
                                  2023-08-28 16:40:11.667  - warn: smartthings.0 (581) get state error: Connection is closed.
                                  2023-08-28 16:40:12.089  - info: host.buanet-iobroker2 stopInstance system.adapter.telegram.0 killing pid 214
                                  2023-08-28 16:40:12.091  - info: host.buanet-iobroker2 stopInstance system.adapter.web.0 killing pid 388
                                  2023-08-28 16:40:12.091  - info: host.buanet-iobroker2 stopInstance system.adapter.smartthings.0 killing pid 581
                                  2023-08-28 16:40:12.154  - info: host.buanet-iobroker2 instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                                  2023-08-28 16:40:12.155  - info: host.buanet-iobroker2 instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.155  - info: host.buanet-iobroker2 instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.156  - info: host.buanet-iobroker2 instance system.adapter.geofency.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.156  - info: host.buanet-iobroker2 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.156  - info: host.buanet-iobroker2 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.157  - info: host.buanet-iobroker2 instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.157  - info: host.buanet-iobroker2 instance system.adapter.homeconnect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.179  - info: host.buanet-iobroker2 instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.179  - info: host.buanet-iobroker2 instance system.adapter.vw-connect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.235  - info: host.buanet-iobroker2 instance system.adapter.smartthings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.257  - info: telegram.0 (214) terminating with timeout
                                  2023-08-28 16:40:12.316  - info: host.buanet-iobroker2 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:12.360  - info: host.buanet-iobroker2 instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:13.769  - info: tuya.0 (331) terminating
                                  2023-08-28 16:40:13.770  - info: tuya.0 (331) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-08-28 16:40:14.354  - info: host.buanet-iobroker2 instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-08-28 16:40:15.359  - info: host.buanet-iobroker2 stopInstance timeout 5000 system.adapter.node-red.0 killing pid  161
                                  2023-08-28 16:40:15.867  - info: node-red.0 (161) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2023-08-28 16:40:16.438  - info: host.buanet-iobroker2 instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  iob diag has finished.
                                  Press any key for a summary
                                    @meister-mopper ```
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : v6.0.0
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=debian
                                    CPU threads: 4
                                    CEST +0200
                                    Etc/UTC
                                    root
                                    /root
                                    root
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                             7802 M total memory
                                             1222 M used memory
                                              776 M free memory
                                               16 M buffer memory
                                             5787 M swap cache
                                             6731 M total swap
                                              956 M used swap
                                             5775 M free swap
                                    *** FILESYSTEM ***
                                    1410f3cbcd5745332d
                                    da22b5d1c977/hosts
                                    /var:
                                    38M     /var/
                                    35M     /var/lib
                                    18M     /var/lib/dpkg
                                    18M     /var/lib/apt
                                    44fe4a3f.chunk.js
                                    /usr/bin/npm            9.1.2
                                    /usr/bin/npx            9.1.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    javascript:     7.0.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        20797
                                    States:         14286
                                    closed
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Docker : v6.0.0
                                    Is a old Image ! 👻
                                    is not compatible , different Version to nodejs/ node
                                    /usr/bin/npm 9.1.2
                                    /usr/bin/npx 9.1.2
                                    and this is very old .....
                                    Create a new Docker Container with Image 8.1.0 and with the Adapter BackitUp and afterward your Backup .
                                    https://hub.docker.com/r/buanet/iobroker
                                    @Homoran warum ist er im deutschen Forum sichtbar !?
                                    Federico GallinariF HomoranH 2 Antworten Letzte Antwort
                                    • GlasfaserG Glasfaser
                                      Docker : v6.0.0
                                      Is a old Image ! 👻
                                      /usr/bin/npm 9.1.2
                                      /usr/bin/npx 9.1.2
                                      Federico Gallinari
                                      @glasfaser the problem is that I need to see all preferences in the container that doesn't permit login, and the second problem is that as I restore the backup in a new image container ...(the last one), iobroker lock in start and doesn't complete the startup process....
                                      The first problem to solve is unlock the login, is there a method to disable authentication? or reset to standard (admin/iobroker)???
                                      Second problem is to solve the restore of the backup.
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        add a Admin Instanz.1 !?
                                          Federico Gallinari
                                          @glasfaser I have another user in admin group, but doesn't work.
                                          Maybe I make some mistake? How I have to add the other instance.1?
                                          thanks
