  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
    1.9k
    1.5k
1.2k Beiträge 121 Kommentatoren 640.1k Aufrufe 64 Beobachtet
  • C CaesarII
    Hab das gleiche Problem mit dem Adapter
    2023-07-31 15:38:18.192 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker-community-adapters/ioBroker.worx: 1
    2023-07-31 15:38:19.231 - info: host.raspberrypi iobroker exit 25
    Die Anleitung mit "iob fix" habe ich schon gemacht. Lässt sich nicht installieren.
    Grüß
    Thomas
    Thomas BraunT
    Thomas BraunT
    #1032
    @caesarii
    Grundsätzlich ist der Adapter nämlich installierbar:
    echad@chet:~ $ iob add worx --debug
    NPM version: 9.8.0
    Installing iobroker.worx@2.3.2... (System call)
    added 113 packages in 19s
    107 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter worx
    upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
    upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
    host.chet object system.adapter.worx created/updated
    host.chet create instance worx
    host.chet object system.adapter.worx.0.alive created
    host.chet object system.adapter.worx.0.connected created
    host.chet object system.adapter.worx.0.compactMode created
    host.chet object system.adapter.worx.0.cpu created
    host.chet object system.adapter.worx.0.cputime created
    host.chet object system.adapter.worx.0.memHeapUsed created
    host.chet object system.adapter.worx.0.memHeapTotal created
    host.chet object system.adapter.worx.0.memRss created
    host.chet object system.adapter.worx.0.uptime created
    host.chet object system.adapter.worx.0.inputCount created
    host.chet object system.adapter.worx.0.outputCount created
    host.chet object system.adapter.worx.0.eventLoopLag created
    host.chet object system.adapter.worx.0.sigKill created
    host.chet object system.adapter.worx.0.logLevel created
    host.chet object worx.0.info created
    host.chet object worx.0.info.connection created
    host.chet Set default value of worx.0.info.connection: false
    host.chet object system.adapter.worx.0 created
    echad@chet:~ $
    C 1 Antwort Letzte Antwort
      @optus28 sagte in Adapter: Worx Landroid v2.x.x:
      Leider endet der Prozess nach etlichen Meldungen mit Code 25
      Und wie lauteten die etlichen geheimen Meldungen?
      Und ich würde an deiner Stelle überlegen das Betriebssystem zu wechseln...
      O
      O
      optus28
      #1033
      @thomas-braun Hast Du mir einen Tipp wie ich die Ergebnisliste kopieren kann. Sind mehrere Seiten.
      Es ist für mich geheim ;-) weil ich nicht verstehe was da passiert!!
      O 1 Antwort Letzte Antwort
        @caesarii
        Auch bei dir geheime Meldungen?
        sagt?
        C
        C
        CaesarII
        #1034
        @thomas-braun Dass der Adapter installierbar ist bezweifle ich auch nicht. Nur mir fehlt komplett das Knoff-Hoff was bei einer Installation im Hintergrund abläuft. Hier das gewünschte Ergebnis:
        host.raspberrypi create instance worx
        host.raspberrypi object system.adapter.worx.1.alive created
        host.raspberrypi object system.adapter.worx.1.connected created
        host.raspberrypi object system.adapter.worx.1.compactMode created
        host.raspberrypi object system.adapter.worx.1.cpu created
        host.raspberrypi object system.adapter.worx.1.cputime created
        host.raspberrypi object system.adapter.worx.1.memHeapUsed created
        host.raspberrypi object system.adapter.worx.1.memHeapTotal created
        host.raspberrypi object system.adapter.worx.1.memRss created
        host.raspberrypi object system.adapter.worx.1.uptime created
        host.raspberrypi object system.adapter.worx.1.inputCount created
        host.raspberrypi object system.adapter.worx.1.outputCount created
        host.raspberrypi object system.adapter.worx.1.eventLoopLag created
        host.raspberrypi object system.adapter.worx.1.sigKill created
        host.raspberrypi object system.adapter.worx.1.logLevel created
        host.raspberrypi object worx.1.info created
        host.raspberrypi object worx.1.info.connection created
        host.raspberrypi Set default value of worx.1.info.connection: false
        host.raspberrypi object system.adapter.worx.1 created
        • O optus28
          O
          O
          optus28
          schrieb am zuletzt editiert von optus28
          #1035
          Habe ich gelöscht
            @caesarii
            sagt?
            O
            O
            optus28
            #1036
            @thomas-braun $ iobroker add worx auto --host klaus-PC(SmartHomeKlaus230620) --debug
            npm WARN cleanup [ npm WARN cleanup 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx', npm WARN cleanup [Error: EPERM: operation not permitted, rmdir 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules'] { npm WARN cleanup errno: -4048, npm WARN cleanup code: 'EPERM', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules' npm WARN cleanup } npm WARN cleanup ] npm WARN cleanup ]
            npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node ./scripts/install.js
            npm ERR! _secureEstablished: true,
            npm ERR! error: [Function: socketErrorListener], npm ERR! data: [Function: socketOnData], npm ERR! drain: [Function: ondrain] npm ERR! }, npm ERR! _eventsCount: 11,
            npm ERR! errorEmitted: false, npm ERR! emitClose: false,
            npm ERR! destroyed: false,
            npm ERR! pendingcb: 0,
            npm ERR! _parent: TCP { npm ERR! reading: [Getter/Setter], npm ERR! onconnection: null, npm ERR! [Symbol(owner_symbol)]: [Circular *1]
            npm ERR! constructed: true,
            npm ERR! emitClose: true, npm ERR! autoDestroy: true, npm ERR! destroyed: false, npm ERR! errored: null, npm ERR! closed: false, npm ERR! closeEmitted: false, npm ERR! defaultEncoding: 'utf8', npm ERR! awaitDrainWriters: null, npm ERR! multiAwaitDrain: false, npm ERR! readingMore: true,
            npm ERR! 'Connection',
            npm ERR! 'FRA53-C1',
            npm ERR! [Symbol(kTrailersCount)]: 0
            npm ERR! [Symbol(async_id_symbol)]: 8, npm ERR! [Symbol(kHandle)]: TLSWrap {
            npm ERR! maxBodyLength: 10485760, npm ERR! protocol: 'https:', npm ERR! path: null, npm ERR! method: 'GET',
            npm ERR! OutgoingMessage: [Function: OutgoingMessage],
            npm ERR! free: [Function (anonymous)], npm ERR! newListener: [Function: maybeEnableKeylog] npm ERR! }, npm ERR! _eventsCount: 2,
            npm ERR! _maxListeners: undefined, npm ERR! defaultPort: 443,
            npm ERR! }
            npm ERR! _keepAliveTimeout: 0, npm ERR! _onPendingData: [Function: nop], npm ERR! agent: Agent {
            npm ERR! _securePending: false, npm ERR! _newSessionPending: false,
            npm ERR! [Symbol(kBufferGen)]: null, npm ERR! [Symbol(kCapture)]: false,
            npm ERR! },
            npm ERR! tail: { data: [Buffer [Uint8Array]], next: null }, npm ERR! length: 1 npm ERR! },
            npm ERR! sync: true, npm ERR! needReadable: false, npm ERR! emittedReadable: false, npm ERR! readableListening: false, npm ERR! resumeScheduled: false, npm ERR! errorEmitted: false,
            npm ERR! decoder: null, npm ERR! encoding: null, npm ERR! [Symbol(kPaused)]: null
            npm ERR! secureConnecting: false,
            npm ERR! servername: 'd332vdhbectycy.cloudfront.net',
            npm ERR! _hadError: false, npm ERR! _parent: null, npm ERR! _host: 'd332vdhbectycy.cloudfront.net', npm ERR! _closeAfterHandlingError: false, npm ERR! _readableState: ReadableState { npm ERR! objectMode: false, npm ERR! highWaterMark: 16384, npm ERR! buffer: BufferList { head: null, tail: null, length: 0 }, npm ERR! length: 0,
            npm ERR! sync: false,
            npm ERR! reading: true,
            npm ERR! }
            npm ERR! }, npm ERR! [Symbol(verified)]: true, npm ERR! [Symbol(pendingSession)]: null, npm ERR! [Symbol(async_id_symbol)]: 8, npm ERR! [Symbol(kHandle)]: TLSWrap { npm ERR! _parent: TCP {
            npm ERR! [Symbol(kBufferCb)]: null,
            npm ERR! Accept: 'application/json, text/plain, /', npm ERR! 'User-Agent': 'axios/0.24.0' npm ERR! }, npm ERR! agent: undefined,
            npm ERR! maxCachedSessions: 100, npm ERR! _sessionCache: [Object], npm ERR! [Symbol(kCapture)]: false npm ERR! }, npm ERR! host: 'd332vdhbectycy.cloudfront.net',
            npm ERR! 'Server', npm ERR! 'AmazonS3',
            npm ERR! method: null, npm ERR! statusCode: 403, npm ERR! statusMessage: 'Forbidden',
            npm ERR! session: undefined, npm ERR! ALPNProtocols: undefined, npm ERR! requestOCSP: undefined,
            npm ERR! },
            npm ERR! readingMore: false,
            npm ERR! errored: null, npm ERR! closed: false, npm ERR! closeEmitted: false, npm ERR! [Symbol(kOnFinished)]: [] npm ERR! },
            npm ERR! onhandshakestart: {},
            npm ERR! reading: true, npm ERR! onkeylog: [Function: onkeylog], npm ERR! onhandshakestart: {},
            npm ERR! }, npm ERR! _consuming: false, npm ERR! _dumped: false, npm ERR! req: [Circular *2],
            npm ERR! timeoutCb: null, npm ERR! upgradeOrConnect: false,
            npm ERR! pskCallback: undefined, npm ERR! highWaterMark: undefined, npm ERR! onread: undefined, npm ERR! signal: undefined
            npm ERR! needDrain: false,
            npm ERR! _parentWrap: undefined, npm ERR! _secureContext: SecureContext { context: SecureContext {} }, npm ERR! reading: true, npm ERR! onkeylog: [Function: onkeylog],
            npm ERR! onerror: [Function: onerror], npm ERR! [Symbol(owner_symbol)]: [Circular *1] npm ERR! },
            npm ERR! connecting: false,
            npm ERR! pendingcb: 0, npm ERR! constructed: true,
            npm ERR! [Symbol(res)]: TLSWrap {
            npm ERR! maxRedirects: 21, npm ERR! maxBodyLength: 10485760,
            npm ERR! noDelay: true, npm ERR! servername: 'd332vdhbectycy.cloudfront.net', npm ERR! _agentKey: 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::',
            npm ERR! complete: false,
            npm ERR! 'AmazonS3', npm ERR! 'X-Cache',
            npm ERR! pipe: false, npm ERR! secureContext: [SecureContext], npm ERR! isServer: false,
            npm ERR! onwrite: [Function: bound onwrite], npm ERR! writecb: null,
            npm ERR! afterWriteTickInfo: null, npm ERR! buffered: [], npm ERR! bufferedIndex: 0, npm ERR! allBuffers: true, npm ERR! allNoop: true, npm ERR! pendingcb: 0, npm ERR! constructed: true,
            npm ERR! _pendingEncoding: '', npm ERR! server: undefined, npm ERR! _server: null,
            npm ERR! [Symbol(connect-options)]: {
            npm ERR! headers: [Object],
            npm ERR! auth: undefined, npm ERR! hostname: 'd332vdhbectycy.cloudfront.net',
            npm ERR! [Symbol(kHeaders)]: { npm ERR! 'content-type': 'application/xml', npm ERR! 'transfer-encoding': 'chunked',
            npm ERR! 'x-amz-cf-pop': 'FRA53-C1',
            npm ERR! req: [Circular *2] npm ERR! } npm ERR! }, npm ERR! maxHeadersCount: null, npm ERR! reusedSocket: false,
            npm ERR! ending: false, npm ERR! ended: false, npm ERR! finished: false,
            npm ERR! STATUS_CODES: [Object], npm ERR! Agent: [Function], npm ERR! ClientRequest: [Function: ClientRequest],
            npm ERR! validateHeaderValue: [Function: _node_internal], npm ERR! get: [Function: get],
            npm ERR! },
            npm ERR! _redirectCount: 0, npm ERR! _redirects: [], npm ERR! _requestBodyLength: 0,
            npm ERR! }, npm ERR! response: {
            npm ERR! connection: 'close', npm ERR! date: 'Mon, 31 Jul 2023 15:12:52 GMT', npm ERR! server: 'AmazonS3', npm ERR! 'x-cache': 'Error from cloudfront',
            npm ERR! 'x-amz-cf-id': 'eyCnE7Hu2dATVaM4hD2J5DQQJBoMLKrqHyAG-u_X4uTlBQt9arqb7g==' npm ERR! }, npm ERR! config: {
            npm ERR! forcedJSONParsing: true,
            npm ERR! transformResponse: [ [Function: transformResponse] ], npm ERR! timeout: 0, npm ERR! xsrfCookieName: 'XSRF-TOKEN', npm ERR! xsrfHeaderName: 'X-XSRF-TOKEN',
            npm ERR! abort: [Function (anonymous)], npm ERR! aborted: [Function (anonymous)], npm ERR! connect: [Function (anonymous)],
            npm ERR! error: [Function (anonymous)], npm ERR! socket: [Function (anonymous)], npm ERR! timeout: [Function (anonymous)],
            npm ERR! _last: true, npm ERR! chunkedEncoding: false,
            npm ERR! _defaultKeepAlive: true,
            npm ERR! secureConnecting: false, npm ERR! _SNICallback: null, npm ERR! servername: 'd332vdhbectycy.cloudfront.net',
            npm ERR! [Function: onClose], npm ERR! [Function: socketCloseListener] npm ERR! ],
            npm ERR! reading: true, npm ERR! constructed: true,
            npm ERR! decoder: null, npm ERR! encoding: null, npm ERR! [Symbol(kPaused)]: false
            npm ERR! writecb: null, npm ERR! writelen: 0,
            npm ERR! socket: [Circular *1], npm ERR! incoming: <ref *3> IncomingMessage { npm ERR! _readableState: [ReadableState], npm ERR! _events: [Object: null prototype],
            npm ERR! upgrade: false, npm ERR! url: '', npm ERR! method: null,
            npm ERR! }, npm ERR! outgoing: [Circular *2], npm ERR! maxHeaderPairs: 2000, npm ERR! _consumed: false, npm ERR! onIncoming: [Function: parserOnIncomingClient],
            npm ERR! _defaultAgent: Agent {
            npm ERR! _eventsCount: 2, npm ERR! _maxListeners: undefined, npm ERR! defaultPort: 443, npm ERR! protocol: 'https:', npm ERR! options: [Object: null prototype],
            npm ERR! sockets: [Object: null prototype] { npm ERR! 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::': [ [TLSSocket] ]
            npm ERR! _eventsCount: 1, npm ERR! _maxListeners: undefined, npm ERR! socket: <ref *1> TLSSocket { npm ERR! _tlsOptions: { npm ERR! allowHalfOpen: undefined,
            npm ERR! onhandshakedone: [Function (anonymous)],
            npm ERR! onocspresponse: [Function: onocspresponse], npm ERR! onnewsession: [Function: onnewsessionclient], npm ERR! onerror: [Function: onerror], npm ERR! [Symbol(owner_symbol)]: [Circular *1] npm ERR! },
            npm ERR! decodeStrings: false,
            npm ERR! pathname: '/aws-crt-1.17.0-source.tgz', npm ERR! _defaultAgent: [Agent], npm ERR! host: 'd332vdhbectycy.cloudfront.net', npm ERR! noDelay: true, npm ERR! servername: 'd332vdhbectycy.cloudfront.net', npm ERR! _agentKey: 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::',
            npm ERR! encrypted: true, npm ERR! _events: [Object: null prototype] { npm ERR! close: [Array], npm ERR! end: [Array], npm ERR! newListener: [Function: keylogNewListener],
            npm ERR! allowHalfOpen: false,
            npm ERR! dataEmitted: false,
            npm ERR! 'Content-Type', npm ERR! 'application/xml',
            npm ERR! secureContext: SecureContext { context: SecureContext {} },
            npm ERR! emitClose: false, npm ERR! autoDestroy: true,
            npm ERR! _removedContLen: false, npm ERR! _removedTE: false, npm ERR! strictContentLength: false,
            npm ERR! '\r\n',
            npm ERR! joinDuplicateHeaders: undefined,
            npm ERR! [Symbol(kBytesWritten)]: 0, npm ERR! [Symbol(kNeedDrain)]: false, npm ERR! [Symbol(corked)]: 0,
            npm ERR! _closed: false, npm ERR! socket: [Circular *1],
            npm ERR! _removedTE: false, npm ERR! strictContentLength: false, npm ERR! _contentLength: 0,
            npm ERR! '2': [Function: parserOnHeadersComplete], npm ERR! '3': [Function: parserOnBody], npm ERR! '4': [Function: parserOnMessageComplete],
            npm ERR! _last: true, npm ERR! chunkedEncoding: false, npm ERR! shouldKeepAlive: false,
            npm ERR! _redirectCount: 0, npm ERR! _redirects: [], npm ERR! _requestBodyLength: 0, npm ERR! _requestBodyBuffers: [],
            npm ERR! }, npm ERR! [Symbol(kHeadersCount)]: 18,
            npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T15_11_23_568Z-debug-0.log
            host.klaus-PC(SmartHomeKlaus230620) Cannot install iobroker.worx@2.3.2: 1
            ERROR: Process exited with code 25
            Schließen wenn fertig
            • C CaesarII
              Thomas BraunT
              Thomas BraunT
              #1037
              @caesarii sagte in Adapter: Worx Landroid v2.x.x:
              Da wurde offenbar ohne Fehlermeldung eine Instanz worx.1 angelegt.
              • O optus28
                npm ERR! }
                npm ERR! },
                npm ERR! }
                npm ERR! },
                npm ERR! },
                npm ERR! '\r\n',
                Thomas BraunT
                Thomas BraunT
                #1038
                Hab ich aber keine Ahnung von. Vielleicht ein Windooze-User.
                  O
                  O
                  optus28
                  #1039
                  @thomas-braun Dennoch Danke!
                  • L
                    L
                    Lucky_ESA
                    #1040
                    Steht doch in der Fehlermeldung! EPERM - Du hast ein permission Problem.
                    Ich würde alle Worx Instanzen und den Adapter deinstallieren. Funktioniert das nicht per Adminoberfläche, dann halt manuell und Windows restart.
                    Gruß//Lucky
                    • L Lucky_ESA
                      Gruß//Lucky
                      O
                      O
                      optus28
                      #1041
                      @lucky_esa Danke für die Antwort. Habe ich gemacht. Es gibt keine Instanzen und keinen Adapter mehr.
                      PC wurde neu gestartet. Ergebnis bei versuchter Installation wie von mir beschrieben.
                      Wie gesagt, das erste mal dass ein Worx update nicht funktioniert.
                      L GarganoG 2 Antworten Letzte Antwort
                      • O optus28
                        L
                        L
                        Lucky_ESA
                        #1042
                        Wie bereits gesagt hast du ein permission Problem. Wenn du alles löscht dann mal schauen, ob alle Ordner (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules) wirklich gelöscht wurden.
                        Gruß//Lucky
                        Thomas BraunT O 2 Antworten Letzte Antwort
                        • L Lucky_ESA
                          Gruß//Lucky
                          Thomas BraunT
                          Thomas BraunT
                          #1043
                          @lucky_esa sagte in Adapter: Worx Landroid v2.x.x:
                          Wieso?
                          War vielleicht doch nicht das gleiche Problem... :-D
                          Also besser nicht an Threads hängen, die allenfalls ähnliche Fehlerbilder haben.
                          L 1 Antwort Letzte Antwort
                            Wieso?
                            L
                            L
                            Lucky_ESA
                            #1044
                            @thomas-braun sagte in Adapter: Worx Landroid v2.x.x:
                            Wieso?
                            Darum: EPERM: operation not permitted
                            Gruß//Lucky
                            • O optus28
                              GarganoG
                              GarganoG
                              Gargano
                              #1045
                              @optus28 'iob fix' gemacht ?
                              Falls dies unter Windows gibt.
                              • L Lucky_ESA
                                Gruß//Lucky
                                O
                                O
                                optus28
                                #1046
                                @lucky_esa Habe alles gemacht. von Worx war nichts mehr zu finden.
                                Immerhin wurde die Fehlermeldung deutlich kürzer.
                                npm ERR! code 1
                                npm ERR! path F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt npm ERR! command failed npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node ./scripts/install.js npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106 npm ERR! throw new Error("CMake is not installed. Install CMake."); npm ERR! ^ npm ERR! npm ERR! Error: CMake is not installed. Install CMake. npm ERR! at CMake.getGenerators (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106:15) npm ERR! at Toolset._getTopSupportedVisualStudioGenerator (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:217:28) npm ERR! at async Toolset.initializeWin (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:159:17) npm ERR! at async Toolset.initialize (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:32:13) npm ERR! at async BuildSystem._ensureInstalled (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:40:9) npm ERR! at async BuildSystem._invokeCMake (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:69:9) npm ERR! at async buildLocally (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:154:5) npm ERR! at async buildFromRemoteSource (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:176:5) npm ERR! npm ERR! Node.js v18.16.0 npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T21_43_20_887Z-debug-0.log
                                Schade, dass ich es nicht hinbekomme. Nutze seit den ersten Worx Adaptern in 2017 , 2018 bis zur letzten Version vor 2.3.xx den Adapter und hatte bisher keine Probleme.
                                Viele Grüße
                                Klaus
                                • O optus28
                                  npm ERR! code 1
                                  Viele Grüße
                                  Klaus
                                  Thomas BraunT
                                  Thomas BraunT
                                  #1047
                                  @optus28
                                  Installier das nach. Wenn es cmake für Windows gibt.
                                    @optus28
                                    O
                                    O
                                    optus28
                                    #1048
                                    @thomas-braun Nach Installation von CMAKE im System Path.
                                    Wieder ein Stück kürzer aber leider noch nicht erfolgreich.
                                    npm ERR! info RUN '--no-warn-unused-cli', npm ERR! info RUN '-G',
                                    npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T23_14_49_746Z-debug-0.log
                                    Wüsste gerne ob es jemand geschafft hat Worx 2.3.xx unter Win zum Laufen gebracht zu haben.
                                    Vielen Dank für die bisherige Geduld und Unterstützung.
                                    O L 2 Antworten Letzte Antwort
                                    • O optus28
                                      O
                                      O
                                      optus28
                                      #1049
                                      @optus28 Ich bekomme es nicht hin und gebe auf. Dann eben iobroker ohne worx.
                                      Vielleicht könnte sich der Entwickler / Programmiere ja mal anschauen was er programmiert hat.
                                      Vielen Dank für die Hilfen.
                                      • O optus28
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1050
                                        Das passt ja. Dein Betrübssystem spielt da nicht mit. Musst du richtig konfigurieren.
                                          O
                                          O
                                          optus28
                                          #1051
                                          @thomas-braun Hallo Thomas, das mag ja sein. Aber es gibt halt iobroker unter windows. Und ich wiederhole mich, bisher gab es auch zumindest mit worx keine Probleme. Ich würde ja gerne auf die vor 2.3.xx zurückgehen, weiss aber nicht wie.
                                          Klaus
                                          83.8k
