  4. Erledigt: Zigbee mit TCP
    5.3k
zigbee
20 Beiträge 3 Kommentatoren 765 Aufrufe 3 Beobachtet
    @michihorn
    Bitte in CodeTags eingebettet hier in den Thread.
    michihorn
    2023-07-26 21:21:45.054  - info: zigbee.1 (5664) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.0, js-controller: 5.0.8
    2023-07-26 21:21:45.193  - info: zigbee.1 (5664) delete old Backup files. keep only last 10
    2023-07-26 21:21:45.196  - info: zigbee.1 (5664) Starting Zigbee  npm ...
    2023-07-26 21:21:45.568  - info: zigbee.1 (5664) Installed Version: iobroker.zigbee@1.8.12
    2023-07-26 21:21:47.052  - error: zigbee.1 (5664) Configuration is not consistent with adapter state/backup!
    2023-07-26 21:21:47.054  - error: zigbee.1 (5664) - PAN ID: configured=6754, adapter=6755
    2023-07-26 21:21:47.055  - error: zigbee.1 (5664) - Extended PAN ID: configured=00124b0025792115, adapter=00124b0025792115
    2023-07-26 21:21:47.056  - error: zigbee.1 (5664) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2023-07-26 21:21:47.057  - error: zigbee.1 (5664) - Channel List: configured=11, adapter=11
    2023-07-26 21:21:47.059  - error: zigbee.1 (5664) Please update configuration to prevent further issues.
    2023-07-26 21:21:47.059  - error: zigbee.1 (5664) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json.
    2023-07-26 21:21:47.060  - error: zigbee.1 (5664) Re-commissioning your network will require re-pairing of all devices!
    2023-07-26 21:21:47.060  - error: zigbee.1 (5664) Running despite adapter configuration mismatch as configured. Please update the adapter to compatible firmware and recreate your network as soon as possible.
    2023-07-26 21:21:47.357  - info: zigbee.1 (5664) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220726}}
    2023-07-26 21:21:47.368  - info: zigbee.1 (5664) Disable LED
    2023-07-26 21:21:47.370  - info: zigbee.1 (5664) Unable to disable LED, unsupported function.
    2023-07-26 21:21:47.390  - info: zigbee.1 (5664)   --> transmitPower : high+
    2023-07-26 21:21:47.401  - info: zigbee.1 (5664) Currently no devices.
    2023-07-26 21:21:47.402  - info: zigbee.1 (5664) Zigbee started
    2023-07-26 21:21:47.405  - error: zigbee.1 (5664) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
    2023-07-26 21:21:47.407  - error: zigbee.1 (5664) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-26 21:21:47.408  - error: zigbee.1 (5664) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    2023-07-26 21:21:47.450  - error: zigbee.1 (5664) TypeError: Cannot read properties of undefined (reading 'Error')
        at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
        at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
        at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
        at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
        at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
    2023-07-26 21:21:47.450  - error: zigbee.1 (5664) Cannot read properties of undefined (reading 'Error')
    2023-07-26 21:21:47.464  - info: zigbee.1 (5664) cleaned everything up...
    2023-07-26 21:21:47.467  - info: zigbee.1 (5664) Zigbee: disabling joining new devices.
    2023-07-26 21:21:47.966  - info: zigbee.1 (5664) terminating
    2023-07-26 21:21:47.969  - warn: zigbee.1 (5664) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-07-26 21:21:48.673  - error: host.CAS-pi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-07-26 21:21:48.673  - error: host.CAS-pi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
    2023-07-26 21:21:48.674  - error: host.CAS-pi Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    2023-07-26 21:21:48.675  - error: host.CAS-pi Caught by controller[1]:     at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    2023-07-26 21:21:48.675  - error: host.CAS-pi Caught by controller[1]:     at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    2023-07-26 21:21:48.675  - error: host.CAS-pi Caught by controller[1]:     at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    2023-07-26 21:21:48.675  - error: host.CAS-pi Caught by controller[1]:     at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
    2023-07-26 21:21:48.676  - error: host.CAS-pi instance system.adapter.zigbee.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-07-26 21:21:48.676  - info: host.CAS-pi Restart adapter system.adapter.zigbee.1 because enabled
    • M michihorn
      @michihorn sagte in Zigbee mit TCP:
      Ich wiederhole mich glaube ich.
      Die Werte MÜSSEN übereinstimmen.
      • M michihorn
        @michihorn
        Und schalte Sentry für die Instanz aus.
          michihorn
          schrieb am zuletzt editiert von michihorn
          @thomas-braun Ich weiß hattest du geschrieben, habe ich auch mittels Screenshot gezeigt.
          Offenbar ist irgendwo noch die 6755 gespeichert.
          Ich habe aus dem aktuellen Protokoll eine neue Erweiterte Pan ID angezeigt bekommen, die konnte gespeichert werden, im Moment ist der Adapter grün. Das wars leider nicht nun ist der Adapter gelb. Sentry ist ausgeschaltet. Witzigerweise ist wärend ich hier schreibe der Adapter wieder auf grün gegangen
          Nun ist er wieder auf gelb, im Protokoll steht folgendes:
          zigbee.1
          6054	2023-07-26 21:46:28.878	error	Failed to start Zigbee
          zigbee.1
          6054	2023-07-26 21:46:28.876	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
          zigbee.1
          6054	2023-07-26 21:45:22.035	info	Installed Version: iobroker.zigbee@1.8.12
          zigbee.1
          6054	2023-07-26 21:45:21.572	info	Starting Zigbee npm ...
          zigbee.1
          6054	2023-07-26 21:45:21.388	info	starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.0, js-controller: 5.0.8
          zigbee.1
          5949	2023-07-26 21:45:07.905	info	terminating
          zigbee.1
          5949	2023-07-26 21:45:07.730	warn	setObject info.debugmessages (type=state) property common.role missing!
          zigbee.1
          5949	2023-07-26 21:45:07.637	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.1
          5949	2023-07-26 21:45:07.632	info	terminating
          zigbee.1
          5949	2023-07-26 21:45:07.630	warn	Failed to stop zigbee during startup
          zigbee.1
          5949	2023-07-26 21:45:07.615	warn	setObject info.undefinedDevices (type=state) property common.role missing!
          zigbee.1
          5949	2023-07-26 21:45:07.595	info	Zigbee: disabling joining new devices.
          zigbee.1
          5949	2023-07-26 21:45:07.403	info	cleaned everything up...
          zigbee.1
          5949	2023-07-26 21:45:07.400	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.1
          5949	2023-07-26 21:44:47.814	info	Installed Version: iobroker.zigbee@1.8.12
          zigbee.1
          5949	2023-07-26 21:44:47.430	info	Starting Zigbee npm ...
          zigbee.1
          5949	2023-07-26 21:44:47.239	info	starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.0, js-controller: 5.0.8
          zigbee.1
          5933	2023-07-26 21:44:38.970	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.1
          5933	2023-07-26 21:44:38.968	info	terminating
          zigbee.1
          5933	2023-07-26 21:44:38.782	warn	setObject info.debugmessages (type=state) property common.role missing!
          zigbee.1
          5933	2023-07-26 21:44:38.580	warn	setObject info.undefinedDevices (type=state) property common.role missing!
          zigbee.1
          5933	2023-07-26 21:44:38.563	info	Zigbee: disabling joining new devices.
          zigbee.1
          5933	2023-07-26 21:44:38.467	info	cleaned everything up...
          zigbee.1
          5933	2023-07-26 21:44:38.464	info	Got terminate signal TERMINATE_YOURSELF
          zigbee.1
          5933	2023-07-26 21:44:35.502	info	List of port: [{"path":"/dev/ttyAMA0"}]
          Thomas BraunT ? 2 Antworten Letzte Antwort
          • M michihorn
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            zigbee.1
            @michihorn
            Das ist wieder der chronologisch falsche Eintrag aus dem Admin.
            Ich hab keine Lust von unten nach oben zu lesen.
              @michihorn
              michihorn
              @thomas-braun Offenbar weiß ich nicht was du sehen willst, so habe ich das Protokoll kopiert
              • M michihorn
                @michihorn
                Du nimmst das natürlich aus dem Terminal. Dafür hast du das ja offen und das Log läuft da mit. Chronologisch richtig.
                  @michihorn
                  michihorn
                  @thomas-braun Aktuell ist der Adapter wieder grün
                  2023-07-26 21:57:02.102  - info: zigbee.1 (6127) Try to reconnect.
                  2023-07-26 21:57:02.103  - info: zigbee.1 (6127) Starting Zigbee  npm ...
                  2023-07-26 21:57:02.104  - info: zigbee.1 (6127) Try to reconnect.
                  2023-07-26 21:57:02.105  - info: zigbee.1 (6127) Starting Zigbee  npm ...
                  2023-07-26 21:57:03.868  - info: zigbee.1 (6127) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220726}}
                  2023-07-26 21:57:03.870  - info: zigbee.1 (6127) Disable LED
                  2023-07-26 21:57:03.871  - info: zigbee.1 (6127) Unable to disable LED, unsupported function.
                  2023-07-26 21:57:03.872  - info: zigbee.1 (6127)   --> transmitPower : high+
                  2023-07-26 21:57:03.883  - info: zigbee.1 (6127) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220726}}
                  2023-07-26 21:57:03.883  - info: zigbee.1 (6127) Disable LED
                  2023-07-26 21:57:03.884  - info: zigbee.1 (6127) Unable to disable LED, unsupported function.
                  2023-07-26 21:57:03.885  - info: zigbee.1 (6127)   --> transmitPower : high+
                  2023-07-26 21:57:03.892  - info: zigbee.1 (6127) Currently no devices.
                  2023-07-26 21:57:03.892  - info: zigbee.1 (6127) Zigbee started
                  2023-07-26 21:57:03.901  - info: zigbee.1 (6127) Currently no devices.
                  2023-07-26 21:57:03.901  - info: zigbee.1 (6127) Zigbee started
                  • M michihorn
                    Na dann.
                      Na dann.
                      michihorn
                      @thomas-braun Danke für deinen Einsatz, konnte auch gerade ein Gerät pairen
                      • M michihorn
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        zigbee.1
                        @michihorn sagte in Erledigt: Zigbee mit TCP:
                        zigbee.1
                        Moin,
                        irgendwo in Deinem Netzwerk gibt es da Überlappungen, Du musst mal schauen, ob noch andere auf dem Kanal 11 Funken, ansonsten kann es immer wieder mal zu Aussetzern im Zigbee Netzwerk kommen.
                        Das ist nur zur Information:
                        Hier mal etwas von Github, ist zwar zigbee2mqtt, ist aber egal, das der zigbee` Adapter darauf aufbaut.
                        https://github.com/Koenkk/zigbee2mqtt/issues/10858
                        Bernd
