  4. SQL-Adapter Error: connect ECONNREFUSED
    5.3k
17 Beiträge 4 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • G guitardoc
    @dp20eic
    Tja, was habe ich gemacht - diverse Updates per apt (die man immer mal machen sollte), ansonsten nichts woran ich mich erinnere...
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     14:26:23 up 12:26,  1 user,  load average: 3.21, 2.53, 2.22
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=67.6'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Fri 2023-07-14 14:26:23 CEST
               Universal time: Fri 2023-07-14 12:26:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.7G        2.4G         97M        0.0K        1.3G        1.3G
    Swap:            99M        1.0M         98M
    Total:          3.8G        2.4G        196M
             3743 M total memory
             2364 M used memory
             2879 M active memory
              471 M inactive memory
               96 M free memory
               45 M buffer memory
             1236 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      235G  8.0G  218G   4% /
    devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     749M  1.2M  748M   1% /run
    /dev/sda1      vfat      255M   32M  224M  13% /boot
    tmpfs          tmpfs     375M  4.0K  375M   1% /run/user/1000
    [Fri Jul 14 02:00:21 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:3E:50:C8 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4fcad63-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Jul 14 02:00:23 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jul 14 02:00:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Jul 14 02:00:25 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.6G	/var/
    1.7G	/var/log
    1.6G	/var/log/journal/694251d2e85b40cfbf382e56db08597d
    1.3G	/var/cache/apt
    Archived and active journals take up 1.5G in the file system.
    /opt/iobroker/backups:
    40K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    312M	/opt/iobroker/iobroker-data/
    175M	/opt/iobroker/iobroker-data/files
    94M	/opt/iobroker/iobroker-data/backup-objects
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/files/telegram.admin
    25M	/opt/iobroker/iobroker-data/objects.jsonl
    18M	/opt/iobroker/iobroker-data/states.jsonl
    15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    7.2M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    6.9M	/opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.1
    /usr/bin/node 		v18.16.1
    /usr/bin/npm 		9.5.1
    /usr/bin/npx 		9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            500 http://deb.debian.org/debian bullseye-proposed-updates/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	7.0.3
    Adapters from github: 	0
    Adapter State
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
    + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
    + system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://iobroker.live/repo/sources-dist.json
    Latest        : http://iobroker.live/repo/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "eusec"        : 1.0.0    , installed 1.0.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "followthesun" : 0.4.1    , installed 0.4.1
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "socketio"     : 4.2.0    , installed 6.1.9
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "web"          : 4.3.0    , installed 5.2.5
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 1.3.0    , installed 2.1.4
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects: 	9362
    States: 	7628
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:5 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:8 https://repo.homebridge.io stable InRelease
    Get:9 https://pkgs.tailscale.com/stable/debian bullseye InRelease
    Fetched 6525 B in 3s (1990 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:38085         0.0.0.0:*               LISTEN      110        20351      2147/chromium
    tcp        0      0 127.0.0.1:38225         0.0.0.0:*               LISTEN      110        17844      1676/homebridge
    tcp        0      0 127.0.0.1:38379         0.0.0.0:*               LISTEN      110        16304      1776/homebridge: ho
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1825       597/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:42565         0.0.0.0:*               LISTEN      110        19674      1768/homebridge: @m
    tcp        0      0 127.0.0.1:36461         0.0.0.0:*               LISTEN      1001       2751770    227283/io.yahka.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11861      401/deCONZ
    tcp        0      0 127.0.0.1:46707         0.0.0.0:*               LISTEN      110        20730      1769/homebridge: ho
    tcp        0      0 127.0.0.1:44793         0.0.0.0:*               LISTEN      110        2754906    1776/homebridge: ho
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15584      401/deCONZ
    tcp        0      0 127.0.0.1:36837         0.0.0.0:*               LISTEN      110        19694      1776/homebridge: ho
    tcp        0      0 127.0.0.1:41043         0.0.0.0:*               LISTEN      110        19747      1771/homebridge: ho
    tcp        0      0 0.0.0.0:8182            0.0.0.0:*               LISTEN      1001       2752872    226752/io.wiffi-wz.
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2742215    225641/iobroker.js-
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2740156    225641/iobroker.js-
    tcp        0      0 100.89.105.61:53458     0.0.0.0:*               LISTEN      0          15981      604/tailscaled
    tcp6       0      0 :::43877                :::*                    LISTEN      110        19657      1776/homebridge: ho
    tcp6       0      0 :::31670                :::*                    LISTEN      110        17873      1768/homebridge: @m
    tcp6       0      0 :::39846                :::*                    LISTEN      110        19652      1776/homebridge: ho
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1827       597/sshd: /usr/sbin
    tcp6       0      0 :::51391                :::*                    LISTEN      110        16271      1676/homebridge
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       2744209    226351/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       2744200    226351/go2rtc
    tcp6       0      0 :::8581                 :::*                    LISTEN      110        19524      1445/hb-service
    tcp6       0      0 :::52764                :::*                    LISTEN      110        17896      1769/homebridge: ho
    tcp6       0      0 :::40681                :::*                    LISTEN      1001       2751763    227283/io.yahka.0
    tcp6       0      0 fd7a:115c:a1e0:ab:53458 :::*                    LISTEN      0          15982      604/tailscaled
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2747637    226306/io.simple-ap
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2741031    225659/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2750138    226536/io.web.0
    tcp6       0      0 :::8181                 :::*                    LISTEN      110        16270      1676/homebridge
    tcp6       0      0 :::30690                :::*                    LISTEN      110        19661      1771/homebridge: ho
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       2744197    226351/go2rtc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        17927      1769/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        19712      1769/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        19662      1771/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        19658      1776/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        19654      1776/homebridge: ho
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        17874      1768/homebridge: @m
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        16273      1676/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        19521      1445/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1711       396/avahi-daemon: r
    udp        0      0 0.0.0.0:50480           0.0.0.0:*                           1001       2746269    226125/io.eusec.0
    udp        0      0 0.0.0.0:34309           0.0.0.0:*                           108        1713       396/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2741221    225829/io.shelly.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           110        16276      1676/homebridge
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2746495    226058/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2746492    226058/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2746489    226058/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17103      401/deCONZ
    udp        0      0 0.0.0.0:46987           0.0.0.0:*                           1001       2746264    226125/io.eusec.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12047      1040/dhcpcd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2745431    225866/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2745432    225866/io.tuya.0
    udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          2802033    604/tailscaled
    udp6       0      0 :::5353                 :::*                                108        1712       396/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       2746497    226058/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2746496    226058/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2746494    226058/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2746493    226058/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2746491    226058/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2746490    226058/io.deconz.0
    udp6       0      0 :::8443                 :::*                                1001       2744201    226351/go2rtc
    udp6       0      0 :::8555                 :::*                                1001       2744203    226351/go2rtc
    udp6       0      0 :::546                  :::*                                0          12114      1040/dhcpcd
    udp6       0      0 :::51801                :::*                                108        1714       396/avahi-daemon: r
    udp6       0      0 :::41641                :::*                                0          2802032    604/tailscaled
    2023-07-14 14:16:56.021  - info: shelly.0 (225829) [CoAP] Device 192.168.188.69 (shellydw2 / shellydw2-A9A87A / SHDW-2#A9A87A#1) connected! Polltime set to 3600 sec.
    2023-07-14 14:17:01.235  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:17:31.240  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:18:01.248  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:18:31.253  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:19:01.258  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:19:31.263  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:20:01.268  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:20:31.272  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:21:01.277  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:21:31.282  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:22:01.292  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:22:31.297  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:23:01.304  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:23:31.310  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:24:01.316  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:24:31.322  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:25:01.328  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:25:09.912  - info: shuttercontrol.0 (226230) Sunprotect #415 Set ID: Wohnzimmer Südostseite value: 100%
    2023-07-14 14:25:09.985  - info: javascript.0 (225719) script.js.common.Initialisiere_Service.Initialisiere_Shuttercontrol: Alle Jalousien stehen auf 100% (offen): false
    2023-07-14 14:25:31.336  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:26:01.353  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:26:31.361  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:27:01.379  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    2023-07-14 14:27:31.391  - error: sql.0 (229660) Error: connect ECONNREFUSED 127.0.0.1:3306
    		     v.2023-04-16
    Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
    Kernel: 		6.1.21-v8+
    Installation: 		Native
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.1
    			/usr/bin/npm 		9.5.1
    			/usr/bin/npx 		9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.7G        2.3G        171M        0.0K        1.3G        1.4G
    Swap:            99M        1.0M         98M
    Total:          3.8G        2.3G        270M
    Active iob-Instances: 	22
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		9362
    States: 		7628
    Size of iob-Database:
    HomoranH Offline
    HomoranH Offline
    @guitardoc sagte in SQL-Adapter Error: connect ECONNREFUSED:
    Ich sehe nichts was auf Port 3306 lauscht.
    • G guitardoc
      @dp20eic said in SQL-Adapter Error: connect ECONNREFUSED:
      Den Datenbankmanager geupdatet und dabei die Konfiguration überschrieben?
      Ahhh - da haben wir vermutlich schon das Problem:
      pi@raspberrypi:~ $ systemctl status mariadb.service
      ● mariadb.service
           Loaded: masked (Reason: Unit mariadb.service is masked.)
           Active: inactive (dead)
      pi@raspberrypi:~ $
      Aber wie bekommt man die nun wieder gestartet? Ich hab da doch keine Ahnung... Und wieso ist die aus? Fragen über Fragen... :-)
      mariadb.service
      sudo systemctl unmask mariadb.service
        @homoran sagte in SQL-Adapter Error: connect ECONNREFUSED:
        Moin,
        wie @guitardoc schon weiter oben geschrieben hat, läuft der Service ja auch nicht ;)
        @guitardoc
        Eins ist wichtig, Du bist Dir ganz sicher, das Du MariaDB installiert hast, nicht MySQL?
        Warum auch immer der Service auf masked steht, kann ich nicht sagen, ohne dass man anfängt in den Logs zu wühlen.
        Versuchen kannst Du es erst einmal so
        sudo systemctl unkask mariadb.service
        sudo systemctl start mariadb.service
        sudo systemctl status mariadb.service
        Wenn ich mir aber das Log File vom iob diag anschaue, wirst Du über kurz oder lang Probleme mit dem Speicher bekommen, das solltest Du im Auge behalten.
        Bernd
          Moin,
          @guitardoc
          Bernd
          @dp20eic sagte in SQL-Adapter Error: connect ECONNREFUSED:
          LOAD scheint mir auch recht hoch zu sein.
          G 1 Antwort Letzte Antwort
            guitardoc
            pi@raspberrypi:~ $ sudo systemctl unmask mariadb.service
            Removed /etc/systemd/system/mariadb.service.
            pi@raspberrypi:~ $ sudo systemctl start mariadb.service
            pi@raspberrypi:~ $ sudo systemctl status mariadb.service
            ● mariadb.service - LSB: Start and stop the mysql database server daemon
                 Loaded: loaded (/etc/init.d/mariadb; generated)
                 Active: active (exited) since Fri 2023-07-14 15:17:11 CEST; 8s ago
                   Docs: man:systemd-sysv-generator(8)
                Process: 260279 ExecStart=/etc/init.d/mariadb start (code=exited, status=0/SUCCESS)
                    CPU: 8ms
            Jul 14 15:17:11 raspberrypi systemd[1]: Starting LSB: Start and stop the mysql database server daemon...
            Jul 14 15:17:11 raspberrypi systemd[1]: Started LSB: Start and stop the mysql database server daemon.
            MariaDB scheint jetzt zu laufen, aber in ioB ist immer noch keine Verbindung da...
            Ich brauche die Datenbank nicht unbedingt. Vielleicht werde ich sie demnächst mal löschen. Das ist vielleicht auch einfacher wenn der Speicher sowieso schon zur Neige geht? Wie würde man das machen?
            HomoranH ? 2 Antworten Letzte Antwort
            • G guitardoc
                      CPU: 8ms
              HomoranH Offline
              HomoranH Offline
              immer zeigen!
              am besten mit debug
                immer zeigen!
                am besten mit debug
                guitardoc
                Ach ich werde sie einfach deinstallieren und den SQL-Adapter auch. Ich brauche das nicht wirklich und wenn die Auslastung schon recht hoch ist... Dann gleich weg damit.
                Danke an alle für die Hilfe!
                • G guitardoc
                  HomoranH Offline
                  HomoranH Offline
                  ist sie das?
                  oder lag/liegt es nur an den Verbindungsversuchen?
                  was sagt top im Header?
                  • G guitardoc
                            CPU: 8ms
                    Moin,
                    das ist doch erst die halbe Miete, Du musst auch schauen, ob Du den mariadb-client installiert hast, denn den braucht der ioBroker um sich mit der Datenbank zu verbinden.
                    apt list --installed | grep -i maria*
                    Wenn der Client nicht da ist, dann nachinstallieren.
                    sudo apt install mariadb-client
                    Bernd
                      Moin,
                      Bernd
                      guitardoc
                      @dp20eic
                      Ich hab mir noch mal angesehen wofür ich die Datenbank gebraucht hab - das sind alles alte Daten, die ich sowieso nicht mehr brauche. Hab die Datenbank schon komplett installiert und den Adapter auch. Kann ich ja bei Bedarf wieder installieren wenn ich mal wieder Daten sammeln möchte.
