  4. (erledigt) Javascript startet nicht mehr
14 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • DJMarc75D DJMarc75
    @hm_krause und jetzt die Langfassung bitte
    hm_krause
    @djmarc75
    i```
    code_text
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 12 (bookworm)
    Release:        12
    Codename:       bookworm
    PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
    NAME="Debian GNU/Linux"
    VERSION_ID="12"
    VERSION="12 (bookworm)"
    VERSION_CODENAME=bookworm
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:41:53 up  1:19,  2 users,  load average: 0.11, 0.23, 0.30
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Fri 2023-07-07 15:41:53 CEST
               Universal time: Fri 2023-07-07 13:41:53 UTC
                     RTC time: Fri 2023-07-07 13:41:53
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        2.7G        634M        593K        1.1G        1.4G
    Swap:           1.0G          0B        1.0G
    Total:          5.1G        2.7G        1.7G
             3915 M total memory
             2586 M used memory
              411 M active memory
             2439 M inactive memory
              605 M free memory
              121 M buffer memory
              919 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  580K  391M   1% /run
    /dev/sda1      ext4      125G   11G  108G   9% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
    [Fri Jul  7 14:22:52 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jul  7 14:22:53 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    464M    /var/
    249M    /var/cache
    242M    /var/cache/apt
    168M    /var/lib
    166M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    778M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    5.2G    /opt/iobroker/iobroker-data/
    4.7G    /opt/iobroker/iobroker-data/history
    362M    /opt/iobroker/iobroker-data/files
    268M    /opt/iobroker/iobroker-data/history/backup-objects
    140M    /opt/iobroker/iobroker-data/history/files
    334M    /opt/iobroker/iobroker-data/history/objects.jsonl
    129M    /opt/iobroker/iobroker-data/history/objects.json.migrated
    129M    /opt/iobroker/iobroker-data/history/objects.json.bak.migrated
    114M    /opt/iobroker/iobroker-data/history/states.jsonl
    48M     /opt/iobroker/iobroker-data/history/states.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
    + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-watcher": 2.9.1   , installed 2.9.1
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
    Adapter    "resol"        : 1.1.6    , installed 1.1.6
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "zigbee"       : 1.8.12   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        19863
    States:         17455
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          25794      2122/upsd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15403      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17037      534/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       46424      5557/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       44765      5557/iobroker.js-co
    tcp        0      0 192.168.178.4:8081      0.0.0.0:*               LISTEN      1001       46477      5575/io.admin.0
    tcp        0      0 192.168.178.4:42010     0.0.0.0:*               LISTEN      1001       46555      5636/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       44843      5666/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       45477      5756/io.sonoff.0
    tcp        0      0 192.168.178.4:3493      0.0.0.0:*               LISTEN      0          25793      2122/upsd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1276       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17039      534/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45894      6450/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53015      8055/io.simple-api.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55444      8116/io.upnp.0
    udp        0      0 0.0.0.0:41000           0.0.0.0:*                           1001       53111      8116/io.upnp.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14766      1/init
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       45536      5786/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       45537      5786/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          13851      1/init
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
    2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:23:47
    2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]: Node.js v18.16.1
    2023-07-07 15:14:43.708  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-07-07 15:14:43.708  - info: host.iobroker Do not restart adapter system.adapter.javascript.0 because disabled or deleted
    2023-07-07 15:23:00.054  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 9517
    2023-07-07 15:23:05.960  - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-07-07 15:30:00.074  - info: host.iobroker instance system.adapter.ical.0 started with pid 9552
    2023-07-07 15:30:04.092  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9567
    2023-07-07 15:30:07.927  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-07-07 15:30:19.772  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • H hm_krause
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Geekom MiniAir 11
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Debian 12
      Node-Version: 8.16.1
      NPM-Version: 9.5.1
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      bin von Raspi 4 auf Geekom umgezogen.
      Mit dem Backitup Adapter alles wieder hergestellt nur der Javascript- Adapter will nicht starten.
      Folgender Fehler:
      host.iobroker
      	2023-07-07 15:14:13.361	info	Restart adapter system.adapter.javascript.0 because enabled
      host.iobroker
      	2023-07-07 15:14:13.361	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2023-07-07 15:14:13.361	error	Caught by controller[0]: Node.js v18.16.1
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:23:11)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js:5:16)
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js:3:15)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/index.js:11:10)
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: at Object.Module._extensions..json (node:internal/modules/cjs/loader:1324:39)
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: at parse (<anonymous>:null:null)
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/entry.json: Unexpected end of JSON input
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: ^
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: throw err;
      host.iobroker
      	2023-07-07 15:14:13.356	error	Caught by controller[0]: node:internal/modules/cjs/loader:1327
      Was ist hier falsch
      bei
      @hm_krause sagte in Javascript startet nicht mehr:
      würde ich versuchen den
      nochmal drüberzuinstallieren
      wieso hast du denn diese Version?
      github:	7.1.0
      latest:	7.1.0 for 24 days
      stable:	6.1.4 for 7 months
      die ist nicht stable
      H 1 Antwort Letzte Antwort
        bei
        github:	7.1.0
        hm_krause
        github: 7.1.0
        ..wo ist denn das?
        Adapter schon neu installiert, ohne Erfolg
        • H hm_krause
          github: 7.1.0
          ..wo ist denn das?
          wie?
          mit welchen Meldungen?
          wo ist denn das?
          das ist gar nichts.
          7.0.3 ist eine sehr frühe Beta gewesen. Aber selbst die Tester sind inzwischen auf 7.1.0
            wie?
            wo ist denn das?
            das ist gar nichts.
            hm_krause
            Habe den Adapter jetzt nochmal neu installiert und er läuft.
            Was auch immer da vorher war.
            • H hm_krause
              @hm_krause sagte in (erledigt) Javascript startet nicht mehr:
              wo ist/war der Unterschied zu
              stand doch im log
              Datei defekt
              Deswegen die Frage was du jetzt anders gemacht hast.
              Welche Version läuft denn jetzt?
                stand doch im log
                Datei defekt
                hm_krause
                Bin mit der 7.0.3, wie zuvor auch, unterwegs.
                • H hm_krause
                  @hm_krause Danke!
                  die Antwort auf die wichtigere Frage
                  @homoran sagte in (erledigt) Javascript startet nicht mehr:
                  bitte auch noch.
                    @hm_krause Danke!
                    bitte auch noch.
                    hm_krause
                    Ich hatte, nachdem Backitup durchgelaufen war, gesehen das der Adapter nicht gestartet war (mit den oben gezeigetn Fehlern)
                    Daraufhin hatte ich diesen gelöscht und wieder neu Installiert.
                    Da diese Fehler dann aber immer noch da waren habe ich hier um Hilfe gebeten.
                    Es gab eigentlich keinen Unterschied zur letzten Installation.
                    Das Protokoll hatte ich zwischenzeitlich gelöscht.
                    • H hm_krause
                      Danke, wenn auch seltsam.
