  4. (erledigt) Javascript startet nicht mehr
14 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • H hm_krause
    @djmarc75
    Auf dem Geekom läuft Proxmox und der Iobroker in einer VM
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 12 (bookworm)
    Kernel:                 6.1.0-10-amd64
    Installation:           kvm
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/node           v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            4.1G        2.8G        594M        593K        1.1G        1.3G
    Swap:           1.0G          0B        1.0G
    Total:          5.1G        2.8G        1.6G
    Active iob-Instances:   36
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
      system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
    Objects:                19863
    States:                 17455
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    30M     /opt/iobroker/iobroker-data/states.jsonl
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @hm_krause und jetzt die Langfassung bitte
    Lehrling seit 1975 !!!
    H 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      hm_krause
      @djmarc75
      i```
      code_text
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
      NAME="Debian GNU/Linux"
      VERSION_ID="12"
      VERSION="12 (bookworm)"
      VERSION_CODENAME=bookworm
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       15:41:53 up  1:19,  2 users,  load average: 0.11, 0.23, 0.30
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Fri 2023-07-07 15:41:53 CEST
                 Universal time: Fri 2023-07-07 13:41:53 UTC
                       RTC time: Fri 2023-07-07 13:41:53
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        2.7G        634M        593K        1.1G        1.4G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        2.7G        1.7G
               3915 M total memory
               2586 M used memory
                411 M active memory
               2439 M inactive memory
                605 M free memory
                121 M buffer memory
                919 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  580K  391M   1% /run
      /dev/sda1      ext4      125G   11G  108G   9% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [Fri Jul  7 14:22:52 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jul  7 14:22:53 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      464M    /var/
      249M    /var/cache
      242M    /var/cache/apt
      168M    /var/lib
      166M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      778M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      5.2G    /opt/iobroker/iobroker-data/
      4.7G    /opt/iobroker/iobroker-data/history
      362M    /opt/iobroker/iobroker-data/files
      268M    /opt/iobroker/iobroker-data/history/backup-objects
      140M    /opt/iobroker/iobroker-data/history/files
      334M    /opt/iobroker/iobroker-data/history/objects.jsonl
      129M    /opt/iobroker/iobroker-data/history/objects.json.migrated
      129M    /opt/iobroker/iobroker-data/history/objects.json.bak.migrated
      114M    /opt/iobroker/iobroker-data/history/states.jsonl
      48M     /opt/iobroker/iobroker-data/history/states.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   5
      Adapter State
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
      + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "device-watcher": 2.9.1   , installed 2.9.1
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "linux-control": 1.1.3    , installed 1.1.3
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "operating-hours": 1.0.4  , installed 1.0.4
      Adapter    "resol"        : 1.1.6    , installed 1.1.6
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "zigbee"       : 1.8.12   , installed 1.8.10 [Updatable]
      Objects and States
      Objects:        19863
      States:         17455
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          25794      2122/upsd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15403      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17037      534/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       46424      5557/iobroker.js-co
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       44765      5557/iobroker.js-co
      tcp        0      0 192.168.178.4:8081      0.0.0.0:*               LISTEN      1001       46477      5575/io.admin.0
      tcp        0      0 192.168.178.4:42010     0.0.0.0:*               LISTEN      1001       46555      5636/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       44843      5666/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       45477      5756/io.sonoff.0
      tcp        0      0 192.168.178.4:3493      0.0.0.0:*               LISTEN      0          25793      2122/upsd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1276       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17039      534/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45894      6450/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53015      8055/io.simple-api.
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55444      8116/io.upnp.0
      udp        0      0 0.0.0.0:41000           0.0.0.0:*                           1001       53111      8116/io.upnp.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14766      1/init
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       45536      5786/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       45537      5786/io.tuya.0
      udp6       0      0 :::111                  :::*                                0          13851      1/init
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-07-07 15:14:43.707  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
      2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:23:47
      2023-07-07 15:14:43.708  - error: host.iobroker Caught by controller[0]: Node.js v18.16.1
      2023-07-07 15:14:43.708  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-07-07 15:14:43.708  - info: host.iobroker Do not restart adapter system.adapter.javascript.0 because disabled or deleted
      2023-07-07 15:23:00.054  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 9517
      2023-07-07 15:23:05.960  - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2023-07-07 15:30:00.074  - info: host.iobroker instance system.adapter.ical.0 started with pid 9552
      2023-07-07 15:30:04.092  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9567
      2023-07-07 15:30:07.927  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-07-07 15:30:19.772  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      • H hm_krause
        Systemdata Bitte Ausfüllen
        Hardwaresystem: Geekom MiniAir 11
        Arbeitsspeicher: 16GB
        Festplattenart: SSD
        Betriebssystem: Debian 12
        Node-Version: 8.16.1
        NPM-Version: 9.5.1
        Installationsart: Manuell
        Image genutzt: Nein
        Ort/Name der Imagedatei: Link
        bin von Raspi 4 auf Geekom umgezogen.
        Mit dem Backitup Adapter alles wieder hergestellt nur der Javascript- Adapter will nicht starten.
        Folgender Fehler:
        host.iobroker
        	2023-07-07 15:14:13.361	info	Restart adapter system.adapter.javascript.0 because enabled
        host.iobroker
        	2023-07-07 15:14:13.361	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2023-07-07 15:14:13.361	error	Caught by controller[0]: Node.js v18.16.1
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
        host.iobroker
        	2023-07-07 15:14:13.360	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        	2023-07-07 15:14:13.359	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:23:11)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js:5:16)
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js:3:15)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.357	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/index.js:11:10)
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: at Object.Module._extensions..json (node:internal/modules/cjs/loader:1324:39)
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: at parse (<anonymous>:null:null)
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema/lib/entry.json: Unexpected end of JSON input
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: ^
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: throw err;
        host.iobroker
        	2023-07-07 15:14:13.356	error	Caught by controller[0]: node:internal/modules/cjs/loader:1327
        Was ist hier falsch
        bei
        @hm_krause sagte in Javascript startet nicht mehr:
        würde ich versuchen den
        nochmal drüberzuinstallieren
        wieso hast du denn diese Version?
        github:	7.1.0
        latest:	7.1.0 for 24 days
        stable:	6.1.4 for 7 months
        die ist nicht stable
          bei
          github:	7.1.0
          hm_krause
          github: 7.1.0
          ..wo ist denn das?
          Adapter schon neu installiert, ohne Erfolg
          • H hm_krause
            github: 7.1.0
            ..wo ist denn das?
            wie?
            mit welchen Meldungen?
            wo ist denn das?
            das ist gar nichts.
            7.0.3 ist eine sehr frühe Beta gewesen. Aber selbst die Tester sind inzwischen auf 7.1.0
              wie?
              wo ist denn das?
              das ist gar nichts.
              hm_krause
              Habe den Adapter jetzt nochmal neu installiert und er läuft.
              Was auch immer da vorher war.
              • H hm_krause
                @hm_krause sagte in (erledigt) Javascript startet nicht mehr:
                wo ist/war der Unterschied zu
                stand doch im log
                Datei defekt
                Deswegen die Frage was du jetzt anders gemacht hast.
                Welche Version läuft denn jetzt?
                  stand doch im log
                  Datei defekt
                  hm_krause
                  Bin mit der 7.0.3, wie zuvor auch, unterwegs.
                  • H hm_krause
                    @hm_krause Danke!
                    die Antwort auf die wichtigere Frage
                    @homoran sagte in (erledigt) Javascript startet nicht mehr:
                    bitte auch noch.
                      @hm_krause Danke!
                      bitte auch noch.
                      hm_krause
                      Ich hatte, nachdem Backitup durchgelaufen war, gesehen das der Adapter nicht gestartet war (mit den oben gezeigetn Fehlern)
                      Daraufhin hatte ich diesen gelöscht und wieder neu Installiert.
                      Da diese Fehler dann aber immer noch da waren habe ich hier um Hilfe gebeten.
                      Es gab eigentlich keinen Unterschied zur letzten Installation.
                      Das Protokoll hatte ich zwischenzeitlich gelöscht.
                      • H hm_krause
                        Danke, wenn auch seltsam.
