  4. Openhab-Adapter Error
    5.8k
34 Beiträge 5 Kommentatoren 6.3k Aufrufe
  • N Offline
    N Offline
    nibblerrick
    Ich habe jetzt ueber die Oberflaeche aus Github die 1.6 installiert (wenn ich in die package.json schaue steht auch 1.6 drin, scheint also funktioniert zu haben) bekomme ich jetzt folgendes, sowohl mit meiner IP als auch mit dem.openhab.org:
    host.iobroker	2017-10-14 16:09:57.706	info	Restart adapter system.adapter.openhab.0 because enabled
    host.iobroker	2017-10-14 16:09:57.706	error	instance system.adapter.openhab.0 terminated with code 1 ()
    host.iobroker	2017-10-14 16:09:57.706	error	Caught by controller[0]: at node.js:1043:3
    host.iobroker	2017-10-14 16:09:57.706	error	Caught by controller[0]: at startup (node.js:140:18)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Function.Module.runMain (module.js:441:10)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Function.Module._load (module.js:300:12)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Module.load (module.js:343:32)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:416:10)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Module._compile (module.js:409:26)
    host.iobroker	2017-10-14 16:09:57.705	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openhab/main.js:15:25)
    host.iobroker	2017-10-14 16:09:57.704	error	Caught by controller[0]: TypeError: utils.adapter is not a function
    host.iobroker	2017-10-14 16:09:57.704	error	Caught by controller[0]: ^
    host.iobroker	2017-10-14 16:09:57.704	error	Caught by controller[0]: var adapter = utils.adapter('openhab');
    host.iobroker	2017-10-14 16:09:57.704	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.openhab/main.js:15
    host.iobroker	2017-10-14 16:09:56.908	info	instance system.adapter.openhab.0 started with pid 735
    host.iobroker	2017-10-14 16:09:56.906	info	object change system.adapter.openhab.0
    host.iobroker	2017-10-14 16:09:47.388	info	Restart adapter system.adapter.openhab.0 because enabled
    host.iobroker	2017-10-14 16:09:47.388	error	instance system.adapter.openhab.0 terminated with code 1 ()
    host.iobroker	2017-10-14 16:09:47.388	error	Caught by controller[0]: at node.js:1043:3
    host.iobroker	2017-10-14 16:09:47.388	error	Caught by controller[0]: at startup (node.js:140:18)
    host.iobroker	2017-10-14 16:09:47.388	error	Caught by controller[0]: at Function.Module.runMain (module.js:441:10)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: at Function.Module._load (module.js:300:12)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: at Module.load (module.js:343:32)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:416:10)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: at Module._compile (module.js:409:26)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openhab/main.js:15:25)
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: TypeError: utils.adapter is not a function
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: ^
    host.iobroker	2017-10-14 16:09:47.387	error	Caught by controller[0]: var adapter = utils.adapter('openhab');
    host.iobroker	2017-10-14 16:09:47.386	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.openhab/main.js:15
    host.iobroker	2017-10-14 16:09:46.589	info	instance system.adapter.openhab.0 started with pid 727
      Hast du 2 Installationen?
      @nibblerrick:
      instance system.adapter.openhab.0 `
      @nibblerrick:
      inMem message openhab.1 `
      • N Offline
        N Offline
        nibblerrick
        Ich hatte am Anfang einen zweiten Adapter erstellt und den ersten rausgeworfen. Ich habe jetzt den verbliebenen .1 entfernt und nochmal neu einen hinzugefuegt, der dann wieder .0 hat. Ich habe zum Test jetzt gerade nochmal wieder einen Zweiten installiert, der wieder die .1 bekommen hat, Ergebnis scheint aber nicht zu differieren:
        host.iobroker	2017-10-14 17:06:54.427	info	Restart adapter system.adapter.openhab.1 because enabled
        host.iobroker	2017-10-14 17:06:54.427	error	instance system.adapter.openhab.1 terminated with code 1 ()
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at node.js:1043:3
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at startup (node.js:140:18)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Function.Module.runMain (module.js:441:10)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Function.Module._load (module.js:300:12)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Module.load (module.js:343:32)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:416:10)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Module._compile (module.js:409:26)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openhab/main.js:15:25)
        host.iobroker	2017-10-14 17:06:54.426	error	Caught by controller[0]: TypeError: utils.adapter is not a function
        host.iobroker	2017-10-14 17:06:54.425	error	Caught by controller[0]: ^
        host.iobroker	2017-10-14 17:06:54.425	error	Caught by controller[0]: var adapter = utils.adapter('openhab');
        host.iobroker	2017-10-14 17:06:54.425	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.openhab/main.js:15
        host.iobroker	2017-10-14 17:06:53.645	info	instance system.adapter.openhab.1 started with pid 2429
        host.iobroker	2017-10-14 15:06:27.196	info	Do not restart adapter system.adapter.openhab.0 because disabled or deleted
        host.iobroker	2017-10-14 15:06:27.196	error	instance system.adapter.openhab.0 terminated with code 1 ()
        Caught	2017-10-14 15:06:27.196	error	by controller[0]: at node.js:1043:3
        Caught	2017-10-14 15:06:27.196	error	by controller[0]: at startup (node.js:140:18)
        Caught	2017-10-14 15:06:27.196	error	by controller[0]: at Function.Module.runMain (module.js:441:10)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: at Function.Module._load (module.js:300:12)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: at Module.load (module.js:343:32)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: at Object.Module._extensions..js (module.js:416:10)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: at Module._compile (module.js:409:26)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openhab/main.js:15:25)
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: TypeError: utils.adapter is not a function
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: ^
        Caught	2017-10-14 15:06:27.195	error	by controller[0]: var adapter = utils.adapter('openhab');
        Caught	2017-10-14 15:06:27.194	error	by controller[0]: /opt/iobroker/node_modules/iobroker.openhab/main.js:15
        host.iobroker	2017-10-14 15:06:23.592	info	Restart adapter system.adapter.openhab.1 because enabled
        host.iobroker	2017-10-14 15:06:23.592	error	instance system.adapter.openhab.1 terminated with code 1 ()
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at node.js:1043:3
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at startup (node.js:140:18)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Function.Module.runMain (module.js:441:10)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Function.Module._load (module.js:300:12)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Module.load (module.js:343:32)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Object.Module._extensions..js (module.js:416:10)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Module._compile (module.js:409:26)
        Caught	2017-10-14 15:06:23.592	error	by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openhab/main.js:15:25)
        Caught	2017-10-14 15:06:23.591	error	by controller[0]: TypeError: utils.adapter is not a function
        Caught	2017-10-14 15:06:23.591	error	by controller[0]: ^
        Caught	2017-10-14 15:06:23.591	error	by controller[0]: var adapter = utils.adapter('openhab');
        Caught	2017-10-14 15:06:23.591	error	by controller[0]: /opt/iobroker/node_modules/iobroker.openhab/main.js:15
        host.iobroker	2017-10-14 15:06:22.794	info	instance system.adapter.openhab.1 started with pid 2417
        host.iobroker	2017-10-14 15:06:22.780	info	object change system.adapter.openhab.1
        host.iobroker	2017-10-14 15:06:21.553	info	object change system.adapter.openhab.0
        iobroker	2017-10-14 15:06:07.873	info	exit 0
        iobroker	2017-10-14 15:06:07.857	info	host.iobroker object system.adapter.openhab.1 created
        host.iobroker	2017-10-14 15:06:07.853	info	object change system.adapter.openhab.1
        iobroker	2017-10-14 15:06:07.813	info	host.iobroker object system.adapter.openhab.1.alive
        • BluefoxB Offline
          BluefoxB Offline
          1.0.7 ? :)
          • N Offline
            N Offline
            nibblerrick
            Macht schonmal wieder mehr, demo.openhab geht, bei mir kommt nun:
            openhab.0	2017-10-14 17:31:11.778	error	Invalid answer on 'http://oh2:8080/rest/items?recursive=false': cannot parse response
            • N Offline
              N Offline
              nibblerrick
              Ich bin kein Programmierer, aber trotzdessen moechte ich noch einen Gedanken loswerden: Es scheint mir so, als wenn der mit den items die kommen ein Problem hat. Da in den items auch die Beschreibungen drin sind die Zahlanzeigen/Umwandlungen fuer die Openhabanzeige, kann es sein, dass der sich an den Sachen wie "%.1f °C" verschluckt? Nur so als Idee.
              • BluefoxB Offline
                BluefoxB Offline
                @nibblerrick:
                Ich bin kein Programmierer, aber trotzdessen moechte ich noch einen Gedanken loswerden: Es scheint mir so, als wenn der mit den items die kommen ein Problem hat. Da in den items auch die Beschreibungen drin sind die Zahlanzeigen/Umwandlungen fuer die Openhabanzeige, kann es sein, dass der sich an den Sachen wie "%.1f °C" verschluckt? Nur so als Idee. `
                Ich konnte das Problem finden. Bitte 0.2.0 ausprobieren.
                • N Offline
                  N Offline
                  nibblerrick
                  Funktioniert! Sehr cool!
                  Ich bin ja nicht neugierig oder so, was war denn grob das Problem?
                  • BluefoxB Offline
                    BluefoxB Offline
                    @nibblerrick:
                    Ich bin ja nicht neugierig oder so, was war denn grob das Problem? `
                    Einige Objekte hatten kein pattern in stateDescription
                    • N Offline
                      N Offline
                      nibblerrick
                      Danke.
                      Dann will ich mal weiter in IOBroker einsteigen, das meiste funktioniert bisher gut.
                        Don_Hasso
                        hänge mich mal als totaler Anfänger dran mit meinem Problem.
                        ioBroker läuft unter http://IP1:8081 auf nen Raspberry Zero W
                        OpenHab läuft (auf Raspberry3) und ist erreichbar unter http://IP2:8080/openhab.app?sitemap=demo
                        Öffne ich nun über die Openhab-Instanz die hinterlegte Seite, wird nur
                        geöffnet. Alles hinter dem Fragezeichen und das Fragezeichen selbst auch, wird nicht übernommen.
                        Ich verwende noch OpenHab1.
                        Wo ist mein Fehler?
                          Hallo und Willkommen im Forum!
                          @Don_Hasso:
                          ioBroker läuft … auf nen Raspberry Zero W `
                          Der mit:
                          ` > 1GHz, single-core CPU
                          512MB RAM `
                          Ich denke, dass das nicht reicht.
                          • N Offline
                            N Offline
                            nibblerrick
                            Soweit ich weiss funktioniert der Adapter nur mit Openhab 2.
                              Don_Hasso
                              Wau, Ihr seid wirklich schnell. Vielen Dank für Eure Antworten. Auch wenn sie mich nicht glücklich machen :D
                              • N Offline
                                N Offline
                                nibblerrick
                                upgrade doch auch OH2 :-D
                                Oder einfach versuchen alles was du hast direkt in IOBroker nachzubauen. Ging bei mir zumindest viel schneller als gedacht…
                                  Don_Hasso
                                  Never change a running system ;)
                                  Über ioBroker bin ich eigentlich nur wegen der Ansteuerung meiner Stomtankstelle über modbus gestolpert. Wobei ich sagen muss, dass ioBroker schon sehr viel übersichtlicher als OpenHab wirkt. Allerdings hab ich trotzdem ziemliche Sorgen was den Aufwand und die Zeit betrifft. Auch fehlt mir beim ioBroker noch ein wichtiger Adapter (Nissan Leaf). Aber wer weiß, wenn ich mal viel Zeit habe…
                                  • N Offline
                                    N Offline
                                    nibblerrick
                                    Kann ich verstehen. Auf OH2 upgraden ist auch nicht immer ganz ohne.
                                    Ich hatte schonmal von IOBroker gehoert und auf Grund des Adapters (ich hatte schon OH2 laufen) wollte ich es einfach mal probieren und dann habe ich festgestellt, dass ich viele Sachen wesentlich schneller umgesetzt bekommen habe. OpenHab ist aber auch gut und hat bei mir lange gute Dienste geleistet.
