  4. [Erledigt] Landroid-S Adapter funktioniert nicht mehr
    5.8k
9 Beiträge 3 Kommentatoren 1.5k Aufrufe
    mandragora
    Hallo Leute,
    Seit heute funktioniert mein Landroid-S Adapter nicht mehr richtig.
    Hab am Landroid die 0.82 Version installiert die bisher ohne Probleme funktioniert hat.
    Der Adapter lief auch immer ohne Probleme.
    Plötzlich bekomme ich im Log diese Fehlermeldungen:
    host.ioBroker-RasPi	2017-10-05 21:07:35.052	info	Restart adapter system.adapter.landroid-s.0 because enabled
    host.ioBroker-RasPi	2017-10-05 21:07:35.051	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
    host.ioBroker-RasPi	2017-10-05 21:07:35.051	error	Caught by controller[0]: at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: 'CERT_HAS_EXPIRED' }
    host.ioBroker-RasPi	2017-10-05 21:07:35.050	error	Caught by controller[0]: at TLSSocket._finishInit (_tls_wrap.js:603:8)
    host.ioBroker-RasPi	2017-10-05 21:07:35.049	error	Caught by controller[0]: at TLSSocket.emit (events.js:185:7)
    host.ioBroker-RasPi	2017-10-05 21:07:35.049	error	Caught by controller[0]: at emitNone (events.js:86:13)
    host.ioBroker-RasPi	2017-10-05 21:07:35.048	error	Caught by controller[0]: at TLSSocket. (_tls_wrap.js:1085:38)
    host.ioBroker-RasPi	2017-10-05 21:07:35.048	error	Caught by controller[0]: at Error (native)
    host.ioBroker-RasPi	2017-10-05 21:07:35.047	error	Caught by controller[0]: { Error: certificate has expired
    landroid-s.0	2017-10-05 21:07:34.992	info	cleaned everything up...
    landroid-s.0	2017-10-05 21:07:34.989	error	Error: certificate has expired at Error (native) at TLSSocket. (_tls_wrap.js:1085:38) at emitNone (events.js:86:13) at TLSSocket.emit (events.js:185:7) at TLSSocket._fin
    landroid-s.0	2017-10-05 21:07:34.986	error	uncaught exception: certificate has expired
    landroid-s.0	2017-10-05 21:07:34.643	info	Connecting to MQTT broker
    landroid-s.0	2017-10-05 21:07:34.040	info	Fetching root CA
    landroid-s.0	2017-10-05 21:07:33.945	info	Certificate retrieved
    landroid-s.0	2017-10-05 21:07:33.528	info	API token set to RCqWV7jjxpcFEBmqENLYQB2JHjtjvbTS
    landroid-s.0	2017-10-05 21:07:33.528	info	Logged in as c.xxxxxxxxx@gmx.at - user token retrieved from API
    landroid-s.0	2017-10-05 21:07:33.059	info	API token set to qiJNz3waS4I99FPvTaPt2C2R46WXYdhw
    landroid-s.0	2017-10-05 21:07:33.058	info	Downloaded guest token
    landroid-s.0	2017-10-05 21:07:32.731	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.10.0
    host.ioBroker-RasPi	2017-10-05 21:07:30.452	info	instance system.adapter.landroid-s.0 started with pid 27085
    host.ioBroker-RasPi	2017-10-05 21:07:00.428	info	Restart adapter system.adapter.landroid-s.0 because enabled
    host.ioBroker-RasPi	2017-10-05 21:07:00.427	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
    Caught	2017-10-05 21:07:00.427	error	by controller[0]: at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38) code: 'CERT_HAS_EXPIRED' }
    Caught	2017-10-05 21:07:00.427	error	by controller[0]: at TLSSocket._finishInit (_tls_wrap.js:603:8)
    Caught	2017-10-05 21:07:00.427	error	by controller[0]: at TLSSocket.emit (events.js:185:7)
    Caught	2017-10-05 21:07:00.427	error	by controller[0]: at emitNone (events.js:86:13)
    Caught	2017-10-05 21:07:00.426	error	by controller[0]: at TLSSocket. (_tls_wrap.js:1085:38)
    Caught	2017-10-05 21:07:00.426	error	by controller[0]: at Error (native)
    Caught	2017-10-05 21:07:00.426	error	by controller[0]: { Error: certificate has expired
    landroid-s.0	2017-10-05 21:07:00.393	info	terminating
    landroid-s.0	2017-10-05 21:07:00.384	info	cleaned everything up...
    landroid-s.0	2017-10-05 21:07:00.382	error	at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:433:38)
    landroid-s.0	2017-10-05 21:07:00.382	error	at TLSSocket._finishInit (_tls_wrap.js:603:8)
    landroid-s.0	2017-10-05 21:07:00.382	error	at TLSSocket.emit (events.js:185:7)
    landroid-s.0	2017-10-05 21:07:00.382	error	at emitNone (events.js:86:13)
    landroid-s.0	2017-10-05 21:07:00.382	error	at TLSSocket. (_tls_wrap.js:1085:38)
    landroid-s.0	2017-10-05 21:07:00.382	error	at Error (native)
    landroid-s.0	2017-10-05 21:07:00.382	error	Error: certificate has expired
    landroid-s.0	2017-10-05 21:07:00.381	error	uncaught exception: certificate has expired
    landroid-s.0	2017-10-05 21:06:59.709	info	Connecting to MQTT broker
    landroid-s.0	2017-10-05 21:06:59.295	info	Fetching root CA
    landroid-s.0	2017-10-05 21:06:59.190	info	Certificate retrieved
    landroid-s.0	2017-10-05 21:06:58.634	info	API token set to RCqWV7jjxpcFEBmqENLYQB2JHjtjvbTS
    landroid-s.0	2017-10-05 21:06:58.634	info	Logged in as c.markowitz@gmx.at - user token retrieved from API
    landroid-s.0	2017-10-05 21:06:57.137	info	API token set to qiJNz3waS4I99FPvTaPt2C2R46WXYdhw
    landroid-s.0	2017-10-05 21:06:57.136	info	Downloaded guest token
    landroid-s.0	2017-10-05 21:06:56.704	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.10.0
    landroid-s.0	2017-10-05 21:06:56.632	info	States connected to redis: 127.0.0.1:6379
    Hat jemand eventuell das selbe Problem oder kann mir sagen was hier los ist ?
    Vielen Dank schon mal für Eure Hilfe.
    lg
    mandragora
    ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
      mandragora
      Hmmm
      Ok… hab jetzt mal den Adapter und Instanz deinstalliert und nochmals installiert.
      Jetzt zumindest scheint mal die Verbindung wieder zu klappen.
      Muss ich morgen mal weiter beobachten.
      Aber komisch das es plötzlich nicht mehr ging.
      lg
      mandragora
        tesso
        Ich kenne den Adapter und die Kommunikation nicht, aber ein Zertifikat ist abgelaufen.
        PS: Deine Adresse solltest du an allen Stellen bearbeiten.
        • MeistertrM Offline
          MeistertrM Offline
          Meistertr
          @mandragora:
          Hmmm
          lg
          mandragora ` Worx hat heute Nacht den Server gewechselt. Ich habe den haben Tag nach den Änderungen gesucht und gegen 17 Uhr die Änderungen in den Adapter einfließen lassen. Zur Zeit nur auf git
          Gesendet von meinem Handy
            MeistertrM Offline
            Meistertr
            Bitte einmal die 1.1.4 uber url istallieren:
            https://github.com/MeisterTR/ioBroker.l … withoutssl
            befindet sich gerade im test
              mandragora
              Jaaaa… es geht wieder
              Vielen Dank Meistertr fürs schnelle fixen.
              Danke danke danke
              lg
              mandragora
                mandragora
                Hallo nochmals
                Seit heute bekomm ich diese Fehlermeldung im Log.
                Hab nichts geändert odgl.
                Kann es sein das die bei Worx wieder mal was geändert haben ?
                host.ioBroker-RasPi 2017-10-15 08:31:51.055 error Caught by controller[0]: at Object.exports.request (http.js:31:10)
                host.ioBroker-RasPi 2017-10-15 08:31:51.054 error Caught by controller[0]: at new ClientRequest (_http_client.js:86:14)
                host.ioBroker-RasPi 2017-10-15 08:31:51.054 error Caught by controller[0]: at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11)
                host.ioBroker-RasPi 2017-10-15 08:31:51.053 error Caught by controller[0]: Error: "value" required in setHeader("X-Auth-Token", value)
                landroid-s.0 2017-10-15 08:31:51.016 info cleaned everything up...
                landroid-s.0 2017-10-15 08:31:51.015 error Error: "value" required in setHeader("X-Auth-Token", value) at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11) at new ClientRequest (_http_client.js:86:14) at Object.exp
                landroid-s.0 2017-10-15 08:31:51.015 error uncaught exception: "value" required in setHeader("X-Auth-Token", value)
                landroid-s.0 2017-10-15 08:31:51.015 info undefined
                landroid-s.0 2017-10-15 08:31:51.014 info CA certificate done
                landroid-s.0 2017-10-15 08:31:50.768 info Mqtt Server: undefined
                landroid-s.0 2017-10-15 08:31:50.767 info Logged in as xxx@xxx.com API Token Set to : undefined
                landroid-s.0 2017-10-15 08:31:50.262 info
                landroid-s.0 2017-10-15 08:31:50.262 info post:{"email":"xxx@xxx.com","password":"xxxxxx","uuid":"xxxxxx","type":"app","platform":"android"}
                landroid-s.0 2017-10-15 08:31:50.262 info API token set to
                landroid-s.0 2017-10-15 08:31:50.261 info Downloaded guest token
                landroid-s.0 2017-10-15 08:31:50.042 info UUID: xxxxxx
                landroid-s.0 2017-10-15 08:31:50.042 info starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.10.0
                host.ioBroker-RasPi 2017-10-15 08:31:48.052 info instance system.adapter.landroid-s.0 started with pid 21303
                host.ioBroker-RasPi 2017-10-15 08:31:17.997 info Restart adapter system.adapter.landroid-s.0 because enabled
                host.ioBroker-RasPi 2017-10-15 08:31:17.997 error instance system.adapter.landroid-s.0 terminated with code 0 (OK)
                Caught 2017-10-15 08:31:17.997 error by controller[0]: at IncomingMessage.emit (events.js:185:7)
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at emitNone (events.js:91:20)
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:170:37)
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at /opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:71:14
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at LandroidCloud.retrieveAwsCert (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:84:10)
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at LandroidCloud.worx (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:191:21)
                Caught 2017-10-15 08:31:17.996 error by controller[0]: at Object.exports.request (https.js:199:15)
                Caught 2017-10-15 08:31:17.995 error by controller[0]: at Object.exports.request (http.js:31:10)
                Caught 2017-10-15 08:31:17.995 error by controller[0]: at new ClientRequest (_http_client.js:86:14)
                Caught 2017-10-15 08:31:17.995 error by controller[0]: at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11)
                Caught 2017-10-15 08:31:17.994 error by controller[0]: Error: "value" required in setHeader("X-Auth-Token", value)
                landroid-s.0 2017-10-15 08:31:17.966 info terminating
                landroid-s.0 2017-10-15 08:31:17.952 info cleaned everything up...
                landroid-s.0 2017-10-15 08:31:17.951 error at IncomingMessage.emit (events.js:185:7)
                landroid-s.0 2017-10-15 08:31:17.951 error at emitNone (events.js:91:20)
                landroid-s.0 2017-10-15 08:31:17.951 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:170:37)
                landroid-s.0 2017-10-15 08:31:17.951 error at /opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:71:14
                landroid-s.0 2017-10-15 08:31:17.951 error at LandroidCloud.retrieveAwsCert (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:84:10)
                landroid-s.0 2017-10-15 08:31:17.951 error at LandroidCloud.worx (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:191:21)
                landroid-s.0 2017-10-15 08:31:17.951 error at Object.exports.request (https.js:199:15)
                landroid-s.0 2017-10-15 08:31:17.951 error at Object.exports.request (http.js:31:10)
                landroid-s.0 2017-10-15 08:31:17.951 error at new ClientRequest (_http_client.js:86:14)
                landroid-s.0 2017-10-15 08:31:17.951 error at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11)
                landroid-s.0 2017-10-15 08:31:17.951 error Error: "value" required in setHeader("X-Auth-Token", value)
                landroid-s.0 2017-10-15 08:31:17.950 error uncaught exception: "value" required in setHeader("X-Auth-Token", value)
                landroid-s.0 2017-10-15 08:31:17.935 info undefined
                landroid-s.0 2017-10-15 08:31:17.934 info CA certificate done
                landroid-s.0 2017-10-15 08:31:17.676 info Mqtt Server: undefined
                landroid-s.0 2017-10-15 08:31:17.676 info Logged in as xxx@xxx.com API Token Set to : undefined
                landroid-s.0 2017-10-15 08:31:17.265 info
                landroid-s.0 2017-10-15 08:31:17.264 info post:{"email":"xxx@xxx.com","password":"xxxxxx","uuid":"xxxxxx","type":"app","platform":"android"}
                landroid-s.0 2017-10-15 08:31:17.263 info API token set to
                landroid-s.0 2017-10-15 08:31:17.261 info Downloaded guest token
                landroid-s.0 2017-10-15 08:31:16.850 info UUID: xxxxx
                landroid-s.0 2017-10-15 08:31:16.838 info starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.10.0
                landroid-s.0 2017-10-15 08:31:16.767 info States connected to redis: 127.0.0.1:6379
                host.ioBroker-RasPi 2017-10-15 08:31:15.015 info instance system.adapter.landroid-s.0 started with pid 21247
                host.ioBroker-RasPi 2017-10-15 08:31:14.976 info object change system.adapter.landroid-s.0
                host.ioBroker-RasPi 2017-10-15 08:31:04.569 info object change system.adapter.landroid-s.0
                host.ioBroker-RasPi 2017-10-15 08:30:53.658 info Restart adapter system.adapter.landroid-s.0 because enabled
                host.ioBroker-RasPi 2017-10-15 08:30:53.658 error instance system.adapter.landroid-s.0 terminated with code 0 (OK)
                Caught 2017-10-15 08:30:53.658 error by controller[0]: at IncomingMessage.emit (events.js:185:7)
                Caught 2017-10-15 08:30:53.658 error by controller[0]: at emitNone (events.js:91:20)
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:170:37)
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at /opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:71:14
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at LandroidCloud.retrieveAwsCert (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:84:10)
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at LandroidCloud.worx (/opt/iobroker/node_modules/iobroker.landroid-s/lib/newlc.js:191:21)
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at Object.exports.request (https.js:199:15)
                Caught 2017-10-15 08:30:53.657 error by controller[0]: at Object.exports.request (http.js:31:10)
                Caught 2017-10-15 08:30:53.656 error by controller[0]: at new ClientRequest (_http_client.js:86:14)
                Caught 2017-10-15 08:30:53.656 error by controller[0]: at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11)
                Caught 2017-10-15 08:30:53.656 error by controller[0]: Error: "value" required in setHeader("X-Auth-Token", value)
                VIelen Dank schon mal fürs drüberschauen.
                lg
                mandragora
                  MeistertrM Offline
                  Meistertr
                  Jep einfach die aktuelle version von git installieren. Du hast ja noch die Testversion laufen :)
                    mandragora
                    Hi Meistertr
                    Danke für den Hinweis.
                    Hab verabsäumt vorher die aktuelle Version zu checken.
                    Danke nochmals
                    Funktioniert wieder wunderbar.
                    lg
                    mandragora
