  4. OpenKNX funktioniert nach Updates nicht mehr
21 Beiträge 3 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • R rsw2004
    bin weiterhin noch am rumprobieren. Hab es gleich soweit, dass gar nichts mehr geht.. ```
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    sudo: node: command not found
    Pending iob updates:    0
    /home/iobroker/.diag.sh: line 340: nodejs: command not found
    Nodejs-Installation:
    /home/iobroker/.diag.sh: line 341: node: command not found
    /usr/bin/env: 'node': No such file or directory
                            /usr/local/bin/npm
                            /usr/local/bin/npx
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    *** nodejs is NOT correctly installed ***
    MEMORY:
    Mem:           3.8G         50M        3.5G         16M        283M        3.6G
    Swap:           99M          0B         99M
    Total:         3.9G         50M        3.6G
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    4.8M    /opt/iobroker/iobroker-data/objects.jsonl
    3.8M    /opt/iobroker/iobroker-data/objects.json.migrated
    3.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    3.9M    /opt/iobroker/iobroker-data/states.jsonl
    384K    /opt/iobroker/iobroker-data/states.json.migrated
    384K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    rsw2004
    @rsw2004
    es scheint kein nodejs installiert zu sein. Wenn ich es installieren möchte, sagt die Konsole, dass bereits 20.3.1 installiert ist.
    pi@raspberrypi4:~ $ node -v
    -bash: /usr/local/bin/node: No such file or directory
    pi@raspberrypi4:~ $ nodejs -v
    -bash: /usr/bin/nodejs: No such file or directory
    pi@raspberrypi4:~ $ npm -v
    /usr/bin/env: ‘node’: No such file or directory
    pi@raspberrypi4:~ $ sudo apt-get install -y nodejs
    Reading package lists... Done
    Building dependency tree
    nodejs is already the newest version (20.3.1-deb-1nodesource1).
    The following package was automatically installed and is no longer required:
      python-colorzero
    Use 'sudo apt autoremove' to remove it.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    • R rsw2004
      @rsw2004
        python-colorzero
      @rsw2004
      Auf welchem wirren Weg haste denn
      nach einem Update von ioBroker, allen Adapter, NPM, NodeJS
      durchgeführt?
      R 1 Antwort Letzte Antwort
        @rsw2004
        durchgeführt?
        rsw2004
        Die Adapter einfach über die ioBroker Web-Oberfläche.
        JS-Controller per Konsole, aber den Code auch von der ioBroker Web-Oberfläche kopiert.
        ioBroker:
        iob stop
        iob update
        iob fix
        iob upgrade self
        iob start
        Node & NPM per
        sudo apt update
        sudo apt full-upgrade
        Fand ich jetzt gar nicht so wirr. Ist auch alles sauber durchgelaufen, zumindest hat es den Anschein gehabt.
        • R rsw2004
          ioBroker:
          iob stop
          iob update
          iob fix
          iob upgrade self
          iob start
          Node & NPM per
          sudo apt update
          @rsw2004
          Da ist aber schon vorher was krumm gewesen.
          sudo apt update
          sagt?
          • R rsw2004
            ioBroker:
            iob stop
            iob update
            iob fix
            iob upgrade self
            iob start
            Node & NPM per
            sudo apt update
            @rsw2004 sagte in OpenKNX funktioniert nach Updates nicht mehr:
            usr/local/bin/npm
            da hat kein node was verloren.
              usr/local/bin/npm
              rsw2004
              das kann gut sein, dafür habe ich zu wenig Ahnung um mir darauf einen Reim zu machen.
              Also am besten den Raspberry komplett neu aufsetzen und nie wieder ein Update machen!?
              • R rsw2004
                Mit einem aktuellen Release in 64bit.
                Updates machst du natürlich weiter!
                • R rsw2004
                  wie kommst du auf das schmale Brett?
                  das ist größter Mumpitz.
                  Richtig installieren und immer auf dem aktuellen Stand halten.
                  Dann müssen auch keine großen Sprünge gemacht werden, bei denen man stolpert.
                    @rsw2004
                    sudo apt update
                    sagt?
                    @rsw2004
                    sudo apt update
                    sagt?
                    Machen wir jetzt hier weiter oder willst du das System ohnehin neuaufsetzen?
                      rsw2004
                      @homoran said in OpenKNX funktioniert nach Updates nicht mehr:
                      naja im Endeffekt zerschieße ich mir das ganze System, nur weil ich ein Update machen wollte.. Keine Ahnung was an der Vorgehensweise falsch war.. wie gesagt, habe eigentlich nicht so viel Ahnung von dem Ganzen und will nur, dass das mit minimalem Aufwand funktioniert.
                      • R rsw2004
                        never!
                        wie Thomas schon schrieb
                        @thomas-braun sagte in OpenKNX funktioniert nach Updates nicht mehr:
                        • R rsw2004
                          Nein, das System hast du dir schon vorher zerschossen, weil du nodejs NICHT wie vorgesehen über den Paketmanager installiert hast sondern irgendwie anders. Bei ordentlicher Installation landet da nichts in /usr/local/bin.
                            rsw2004
                            ok, dann werde ich zukünftig versuchen, dass im Hinterkopf zu behalten.
                            Bin jetzt dabei das System neuaufzusetzen.
                            Vielen Dank Euch!
                            • R rsw2004
                              Vielen Dank Euch!
                              wenn du dann das Backup wieder einspielst und vis benutzst, musst du vor dem Restore vis manuell installieren
                              • R rsw2004
                                Vielen Dank Euch!
                                @rsw2004
                                Dann lass die Finger von irgendwelchen 'tools' oder von n oder von nvm was Installationen von Software angeht. Insbesondere bei nodejs und Konsorten.
                                  @rsw2004
                                  @rsw2004
                                  das kommt bei einer ordnungsgemäßen Installation von iobroker automatisch mit!
                                  BTW Nach welcher Anleitung gehst (gingst) du vor?
