  4. web0 startet nicht - versehentlich Beta Updates gemacht
    5.4k
53 Beiträge 4 Kommentatoren 5.3k Aufrufe 2 Beobachtet
  • F fraso
    mach ich.
    was gebe ich ein um die relevanten Informationen zu erhalten ?
    @fraso
    Jag
    iob diag
    nochmals drüber.
    F 1 Antwort Letzte Antwort
      @fraso
      Jag
      iob diag
      nochmals drüber.
      fraso
      @thomas-braun sagte in web0 startet nicht - versehentlich Beta Updates gemacht:
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       15:37:51 up 5 min,  1 user,  load average: 1.88, 1.60, 0.72
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2023-06-25 15:37:51 CEST
                 Universal time: Sun 2023-06-25 13:37:51 UTC
                       RTC time: Sun 2023-06-25 13:37:51
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      e6iob
      /home/e6iob
      e6iob adm cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:             15G        5.4G        9.3G        1.0M        1.1G         10G
      Swap:           976M          0B        976M
      Total:           16G        5.4G         10G
              15710 M total memory
               5383 M used memory
                346 M active memory
               5740 M inactive memory
               9273 M free memory
                 71 M buffer memory
                982 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  7.7G     0  7.7G   0% /dev
      tmpfs          tmpfs     1.6G  884K  1.6G   1% /run
      /dev/nvme0n1p2 ext4      233G   43G  178G  20% /
      tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/nvme0n1p1 vfat      511M  5.8M  506M   2% /boot/efi
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Sun Jun 25 15:32:41 2023] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Jun 25 15:32:41 2023] EXT4-fs (nvme0n1p2): re-mounted. Opts: errors=remount-ro
      TARGET      SOURCE         FSTYPE OPTIONS
      /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      19G	/var/
      12G	/var/lib
      9.8G	/var/lib/motioneye
      7.1G	/var/log
      5.1G	/var/lib/motioneye/Camera11
      Archived and active journals take up 4.0G in the file system.
      /opt/iobroker/backups:
      11G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G	/opt/iobroker/iobroker-data/
      566M	/opt/iobroker/iobroker-data/files
      461M	/opt/iobroker/iobroker-data/backup-objects
      88M	/opt/iobroker/iobroker-data/files/echarts.admin
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      136M	/opt/iobroker/iobroker-data/states.jsonl
      85M	/opt/iobroker/iobroker-data/objects.jsonl
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.20.1
      /usr/bin/node 		v16.20.1
      /usr/bin/npm 		8.19.4
      /usr/bin/npx 		8.19.4
      nodejs:
        Installed: 16.20.1-deb-1nodesource1
        Candidate: 16.20.1-deb-1nodesource1
        Version table:
       *** 16.20.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.5.9
      javascript: 	7.0.3
      Adapters from github: 	1
      Adapter State
      + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : NUCioBroker                              -  enabled
      + system.adapter.backitup.0               : backitup              : NUCioBroker                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : NUCioBroker                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : NUCioBroker                              -  enabled
        system.adapter.devices.0                : devices               : NUCioBroker                              - disabled
        system.adapter.discovery.0              : discovery             : NUCioBroker                              - disabled
      + system.adapter.echarts.0                : echarts               : NUCioBroker                              -  enabled
      + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
        system.adapter.flot.0                   : flot                  : NUCioBroker                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
      + system.adapter.fronius.0                : fronius               : NUCioBroker                              -  enabled
        system.adapter.habpanel.0               : habpanel              : NUCioBroker                              - disabled
        system.adapter.ham.0                    : ham                   : NUCioBroker                              - disabled
      + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.1                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.2                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.3                : hm-rega               : NUCioBroker                              -  enabled
      + system.adapter.hm-rega.4                : hm-rega               : NUCioBroker                              -  enabled
        system.adapter.hm-rega.5                : hm-rega               : NUCioBroker                              - disabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
        system.adapter.hm-rpc.5                 : hm-rpc                : NUCioBroker                              - disabled, port: 0
      + system.adapter.hs100.0                  : hs100                 : NUCioBroker                              -  enabled
        system.adapter.ical.0                   : ical                  : NUCioBroker                              - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              - disabled
      + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
      + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
      + system.adapter.libre.0                  : libre                 : NUCioBroker                              -  enabled
      + system.adapter.modbus.0                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.modbus.1                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.modbus.2                 : modbus                : NUCioBroker                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : NUCioBroker                              -  enabled, port: 1887, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : NUCioBroker                              - disabled, port: 1885, bind: 0.0.0.0
      + system.adapter.niu.0                    : niu                   : NUCioBroker                              -  enabled
        system.adapter.node-red.0               : node-red              : NUCioBroker                              - disabled, port: 1880, bind: 192.168.178.35
        system.adapter.openhab.0                : openhab               : NUCioBroker                              - disabled, port: 8080
        system.adapter.openweathermap.0         : openweathermap        : NUCioBroker                              -  enabled
      + system.adapter.parser.0                 : parser                : NUCioBroker                              -  enabled
      + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
      + system.adapter.puppeteer.0              : puppeteer             : NUCioBroker                              -  enabled
      + system.adapter.ring.0                   : ring                  : NUCioBroker                              -  enabled
      + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
      + system.adapter.shelly.0                 : shelly                : NUCioBroker                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : NUCioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.systeminfo.0             : systeminfo            : NUCioBroker                              - disabled
      + system.adapter.telegram.0               : telegram              : NUCioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tesla-motors.0           : tesla-motors          : NUCioBroker                              -  enabled
      + system.adapter.text2command.0           : text2command          : NUCioBroker                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : NUCioBroker                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              - disabled
        system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
      + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : NUCioBroker                              -  enabled
      + system.adapter.withings.0               : withings              : NUCioBroker                              -  enabled
      + system.adapter.wled.0                   : wled                  : NUCioBroker                              -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : NUCioBroker                              -  enabled
        system.adapter.zigbee.0                 : zigbee                : NUCioBroker                              -  enabled, port: tcp://192.168.178.63:6638
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
      Adapter    "admin"        : 6.3.5    , installed 6.5.9
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 3.1.0    , installed 3.2.0
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "fritzdect"    : 2.2.6    , installed 2.3.1
      Adapter    "fronius"      : 1.1.3    , installed 2.0.1
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "libre"        : 0.0.4    , installed 0.0.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "niu"          : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "puppeteer"    : 0.2.7    , installed 0.2.6  [Updatable]
      Adapter    "ring"         : 3.2.2    , installed 3.4.0
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
      Adapter    "telegram"     : 1.15.6   , installed 1.16.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "ws"           : 1.3.0    , installed 2.3.6
      Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.1
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects: 	71655
      States: 	56221
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 https://packages.grafana.com/oss/deb stable InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 http://deb.debian.org/debian bullseye InRelease
      Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1001       21022      1059/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       21931      1169/io.shelly.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       20038      1137/io.mqtt.0
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       20039      1137/io.mqtt.0
      tcp        0      0 127.0.0.1:38881         0.0.0.0:*               LISTEN      1001       18699      726/chrome
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15752      540/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16876      540/iobroker.js-con
      tcp        0      0 127.0.0.1:45325         0.0.0.0:*               LISTEN      1001       25022      1484/chrome
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12137      1/init
      tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1001       19031      1040/io.hm-rpc.1
      tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1001       19024      1017/io.hm-rpc.0
      tcp        0      0 192.168.178.35:2002     0.0.0.0:*               LISTEN      1001       21083      1092/io.hm-rpc.4
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15661      467/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        10724      463/influxd
      tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1001       19941      1077/io.hm-rpc.3
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21977      1184/io.sonoff.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12141      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15345      569/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26084      1614/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        10730      463/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15663      467/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25832      1539/io.simple-api.
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        10809      539/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25415      1644/io.wled.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19277      1199/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19278      1199/io.tuya.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16801      400/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12138      1/init
      udp6       0      0 :::111                  :::*                                0          12144      1/init
      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      2023-06-25 15:39:00.204  - warn: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at processTimers (node:internal/timers:502:7)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629) getState "javascript.0.System.System.akt_Datum_Tag" not found (3)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Sicherung_Data (script.js.IOS.SchichtPlanFtpUpload:15:143)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Object.<anonymous> (script.js.IOS.SchichtPlanFtpUpload:10:41)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      2023-06-25 15:39:00.205  - warn: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
      2023-06-25 15:39:00.206  - error: javascript.0 (629) script.js.IOS.SchichtPlanFtpUpload: TypeError: Cannot read properties of undefined (reading 'Client')
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at kopieren (script.js.IOS.SchichtPlanFtpUpload:23:28)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Sicherung_Data (script.js.IOS.SchichtPlanFtpUpload:17:15)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Object.<anonymous> (script.js.IOS.SchichtPlanFtpUpload:10:41)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at listOnTimeout (node:internal/timers:559:17)
      2023-06-25 15:39:00.206  - error: javascript.0 (629)     at processTimers (node:internal/timers:502:7)
      2023-06-25 15:39:02.881  - warn: shelly.0 (1169) [Mqtt.rpcNotifications] 192.168.178.17 (shellyplus1pm / shellyplus1pm-7c87ce64a74c / shellyplus1pm#7c87ce64a74c#1): "RPC Status Notifications" are disabled (see adapter documentation for details)
      paul53P Thomas BraunT 2 Antworten Letzte Antwort
      • F fraso
        iob diag
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:	11
        Codename:	bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        e6iob
        /home/e6iob
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           976M          0B        976M
        Total:           16G        5.4G         10G
                 5383 M used memory
                  346 M active memory
                 9273 M free memory
                   71 M buffer memory
                  982 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        *** FILESYSTEM ***
        /var:
        19G	/var/
        12G	/var/lib
        7.1G	/var/log
        /usr/bin/npm 		8.19.4
        /usr/bin/npx 		8.19.4
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.5.9
        javascript: 	7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	71655
        States: 	56221
        Pending Updates: 0
        @fraso sagte: IOS.SchichtPlanFtpUpload
        Dieses Skript enthält Fehler: Erst mal deaktivieren und Fehler beheben.
        • F fraso
          iob diag
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          e6iob
          /home/e6iob
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:           976M          0B        976M
          Total:           16G        5.4G         10G
                   5383 M used memory
                    346 M active memory
                   9273 M free memory
                     71 M buffer memory
                    982 M swap cache
                    976 M total swap
                      0 M used swap
                    976 M free swap
          *** FILESYSTEM ***
          /var:
          19G	/var/
          12G	/var/lib
          7.1G	/var/log
          /usr/bin/npm 		8.19.4
          /usr/bin/npx 		8.19.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.5.9
          javascript: 	7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	71655
          States: 	56221
          Pending Updates: 0
          @fraso
          Dann bring nodes jetzt noch auf die derzeitige Empfehlung nodejs@18.
            @fraso
            fraso
            darf ich auch hier fragen wo im forum das aktuellste dazu ist. wenn man das sucht gibt es so viele Ergebnisse....
            • F fraso
              @fraso
              Steht in meiner Signatur drin.
                @fraso
                fraso
                äh. ja sorry. in dem moment gerade gesehen.
                • F fraso
                  @fraso
                  Oder da. Ergebnis sollte das gleiche sein.
                    @fraso
                    fraso
                    schrieb am zuletzt editiert von fraso
                    hab Deins genutzt
                    Auszug aus der Diagnose:
                    alles gut so?
                    e6iob@NUCioBroker:~$ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    x86_64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v18.16.1
                    v18.16.1
                    9.5.1
                    9.5.1
                    4.0.24
                    e6iob
                    tty
                    /home/e6iob
                    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:2 https://packages.grafana.com/oss/deb stable InRelease
                    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                    OK:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                    OK:5 http://deb.debian.org/debian bullseye InRelease
                    OK:6 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:7 https://repos.influxdata.com/debian stable InRelease
                    Alle Pakete sind aktuell.
                    nodejs:
                      Installiert:           18.16.1-deb-1nodesource1
                      Installationskandidat: 18.16.1-deb-1nodesource1
                      Versionstabelle:
                     *** 18.16.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                    • F fraso
                      hab Deins genutzt
                      alles gut so?
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v18.16.1
                      v18.16.1
                      9.5.1
                      9.5.1
                      4.0.24
                      e6iob
                      tty
                      /home/e6iob
                      nodejs:
                        Versionstabelle:
                      @fraso
                      Ja, jetzt schaut das Grundsystem gut aus.
                      Dann kannste ja jetzt das Skript in Angriff nehmen.
                      Und vielleicht mal schauen, warum dein puppeteer noch nicht aktuell ist.
                      Und für den Herbst kannst du dir ein Upgrade auf 'Bookworm / Debian 12' vormerken.
                        @fraso
                        fraso
                        GROSSES DANKESCHÖN.
