  4. Parser Wert auslesen aber wie?
    5.4k
147 Beiträge 5 Kommentatoren 24.7k Aufrufe 3 Beobachtet
  • G G.Hawk
    @mickym
    Ich habe auf aktualisiere geändert.
    Was macht das denn genau?
    Log sieht jetzt so aus:
    javascript.0
    2023-06-25 12:45:02.023	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 12:45:02.022	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 12:45:02.020	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 12:45:01.984	info	script.js_.Strom.Gesamtstrom.Elmo_auslesen: {}
    javascript.0
    2023-06-25 12:45:01.983	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 12:45:01.983	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
    javascript.0
    2023-06-25 12:45:01.982	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 12:45:01.981	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    javascript.0
    2023-06-25 12:45:01.979	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 12:45:01.979	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
    javascript.0
    2023-06-25 12:45:01.979	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 12:45:01.977	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    javascript.0
    2023-06-25 12:45:01.976	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 12:45:01.975	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
    javascript.0
    2023-06-25 12:45:01.975	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 12:45:01.973	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    mickymM Offline
    mickymM Offline
    mickym
    #109
    @g-hawk Aktualisiere schickt die Werte bestätigt. Steuere brauchst Du nur bei Geräten, die was schalten sollen - diese Werte schickst Du unbestätigt. Unter 0_userdata.0 ist aber kein Adapter, der Deine Werte bestätigen kann.
      @mickym sagte in Parser Wert auslesen aber wie?:
      dann kommen doch überall Zahlen raus.
      wo siehst du das?
      die Ziffern können doch string sein
      edit:
      auf dein edit hab ich gewartet :-)
      mickymM Offline
      mickymM Offline
      mickym
      #110
      @homoran sagte in Parser Wert auslesen aber wie?:
      wo siehst du das?
      edit:
      Ja ist nur komisch, dass das vorher richtig als Zahl erkannt wurde und man nun konvertieren muss.
      @G-Hawk
      Also hier noch eine Konvertierung dazwischen schalten:
      G 1 Antwort Letzte Antwort
      • mickymM mickym
        wo siehst du das?
        edit:
        @G-Hawk
        G.Hawk
        #111
        @mickym
        Habe ich geändert.
        Log:
        javascript.0
        2023-06-25 12:52:30.104	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 1170
        javascript.0
        2023-06-25 12:52:30.103	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 68.31400299072266
        javascript.0
        2023-06-25 12:52:30.102	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 11108.470703125
        javascript.0
        2023-06-25 12:52:20.064	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 1348
        javascript.0
        2023-06-25 12:52:20.060	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 68.31400299072266
        javascript.0
        2023-06-25 12:52:20.052	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 11108.4677734375
        javascript.0
        2023-06-25 12:52:10.055	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 1243
        javascript.0
        2023-06-25 12:52:10.053	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 68.31400299072266
        javascript.0
        2023-06-25 12:52:10.050	info	script.js.Gerätesteuerung.Strom.Gesamtstrom.Elmo_auslesen: 11108.46484375
        javascript.0
        2023-06-25 12:52:09.421	info	script.js_.Überwachung.Verbraucherüberwachung_Fernseher_Strom: Es sind folgende Fernseher an:switch_1,
        javascript.0
        2023-06-25 12:52:09.421	info	script.js.Gerätesteuerung.Überwachung.Verbraucherüberwachung_Fernseher_Strom: Es sind folgende Fernseher an:switch_1,
        javascript.0
        2023-06-25 12:52:09.420	info	script.js_.Überwachung.Verbraucherüberwachung_Fernseher_Strom: Es sind folgende Fernseher an:
        javascript.0
        javascript.0
        javascript.0
        2023-06-25 12:52:09.328	info	script.js.Gerätesteuerung.Überwachung.Verbraucherüberwachung_Fernseher_Strom: Es sind folgende Fernseher an:
        javascript.0
        javascript.0
        javascript.0
        2023-06-25 12:52:02.100	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" has to be type "number" but received type "string"
        javascript.0
        2023-06-25 12:52:02.099	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" has to be type "number" but received type "string"
        javascript.0
        2023-06-25 12:52:02.055	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" has to be type "number" but received type "string"
        javascript.0
        2023-06-25 12:52:02.044	info	script.js_.Strom.Gesamtstrom.Elmo_auslesen: {}
        javascript.0
        2023-06-25 12:52:02.043	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
        javascript.0
        2023-06-25 12:52:02.042	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
        javascript.0
        2023-06-25 12:52:02.042	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
        javascript.0
        2023-06-25 12:52:02.041	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
        javascript.0
        2023-06-25 12:52:02.038	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
        javascript.0
        2023-06-25 12:52:02.037	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
        javascript.0
        2023-06-25 12:52:02.037	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
        javascript.0
        2023-06-25 12:52:02.036	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
        javascript.0
        2023-06-25 12:52:02.034	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
        javascript.0
        2023-06-25 12:52:02.034	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
        javascript.0
        2023-06-25 12:52:02.034	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
        javascript.0
        2023-06-25 12:52:02.032	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
        • G G.Hawk
          @mickym
          Habe ich geändert.
          Log:
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          mickymM Offline
          mickymM Offline
          mickym
          #112
          @g-hawk Ja und kommen die Fehlermeldungen noch? Im Log die Zahlen sind ja später und danach nichts mehr. Du kannst ja jetzt die Debug Bausteine einfach deaktivieren - aber drin lassen - falls Du sie nochmal brauchst.
          HomoranH G 2 Antworten Letzte Antwort
          • mickymM mickym
            HomoranH Offline
            HomoranH Offline
            #113
            @G-Hawk
            und die würde ich noch mit runde oder runde auf...Nachkommastellen behandeln
            • mickymM mickym
              G.Hawk
              #114
              @mickym
              Er führt das ja alle 10 Sekunden aus.
              Das funktioniert auch, nur jede Minute einmal kommt das:
              	2023-06-25 12:59:02.022	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:59:02.022	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:59:02.022	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:59:02.020	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:59:02.019	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:59:02.018	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              javascript.0
              2023-06-25 12:59:02.018	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:59:02.014	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:59:02.013	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:59:02.013	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
              javascript.0
              2023-06-25 12:59:02.012	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:59:02.010	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:58:02.061	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:58:02.061	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:58:02.060	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:58:02.059	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:58:02.054	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:58:02.054	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              javascript.0
              2023-06-25 12:58:02.053	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:58:02.051	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:58:02.047	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:58:02.047	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
              javascript.0
              2023-06-25 12:58:02.047	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:58:02.045	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:57:01.928	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:57:01.928	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:57:01.928	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:57:01.926	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:57:01.925	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:57:01.925	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              javascript.0
              2023-06-25 12:57:01.925	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:57:01.922	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:57:01.918	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:57:01.909	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
              javascript.0
              2023-06-25 12:57:01.909	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:57:01.907	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:56:01.962	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:56:01.962	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:56:01.962	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:56:01.961	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:56:01.960	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:56:01.960	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              javascript.0
              2023-06-25 12:56:01.959	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:56:01.958	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:56:01.957	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:56:01.957	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
              javascript.0
              2023-06-25 12:56:01.956	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:56:01.955	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:55:02.042	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:55:02.042	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:55:02.041	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:55:02.039	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:55:02.037	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:55:02.037	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              javascript.0
              2023-06-25 12:55:02.036	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:55:02.035	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:55:02.032	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:55:02.031	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
              javascript.0
              2023-06-25 12:55:02.030	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:55:02.015	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:54:02.125	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
              javascript.0
              2023-06-25 12:54:02.125	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
              javascript.0
              2023-06-25 12:54:02.125	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:54:02.123	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
              javascript.0
              2023-06-25 12:54:02.122	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2023-06-25 12:54:02.122	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
              • G G.Hawk
                @mickym
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                mickymM Offline
                mickymM Offline
                mickym
                #115
                @g-hawk Ehrlich gesagt ich habe sogar ohne Zahlenkonvertierung das bei mir in einen Datenpunkt geschrieben und ich bekomme diese Fehlermeldungen nicht.
                Wenn @Homoran oder ein anderer Blockly Freund nicht helfen kann, dann bin ich hier auch mit meiner Weisheit am Ende. Ich nutze ja sonst kein Blockly.
                Ich fürchte, ich bin nun mit meiner Weisheit am Ende - glaube aber nun nicht mehr dass es an dem Script liegt, sondern dass ein anderes Problem vorliegt.
                Klick mal auf den Bleistift rechts neben dem Datenpunkt und schau ob wirklich überall Zahl drin steht:
                Ich bekomme mit Deinen Daten und mit dem JSONATA keine Fehlermeldung im Log.
                Gibts vielleicht noch ein anderes Script oder Instanz die in den Datenpunkt was rein schreibt?
                • mickymM mickym
                  G.Hawk
                  schrieb am zuletzt editiert von G.Hawk
                  #116
                  @mickym
                    "common": {
                      "name": "Stromverbrauch_aktuell",
                      "desc": "Manuell erzeugt",
                      "role": "state",
                      "type": "number",
                      "read": true,
                      "write": true,
                      "def": 0,
                      "unit": "W"
                    "type": "state",
                    "native": {},
                    "_id": "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                    "user": "system.user.admin",
                    "ts": 1680442197289
                  Ich habe jetzt eine Minute die Werte beobachtet und er aktualisiert korrekt.
                  Aber dann kommt auf einemal bei allen drei Datenpunkten: {}
                  und dann wieder Zahlen.
                  Es wird noch interessanter:
                  Ich habe das Script gestoppt die Fehlermeldung kommt aber trotzdem jede Minute
                  T mickymM 3 Antworten Letzte Antwort
                  • G G.Hawk
                    @mickym
                      "common": {
                        "role": "state",
                        "type": "number",
                        "read": true,
                        "write": true,
                        "def": 0,
                        "unit": "W"
                      "type": "state",
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                      "ts": 1680442197289
                    TT-Tom
                    #117
                    @g-hawk
                    Starte man die JavaScript Instanz neu. Es sieht aus als ob noch ein Phantom Script mit läuft.
                    Gruß Tom
                    Public Transport
                    NSPanel Adapter Wiki
                    • G G.Hawk
                      @mickym
                        "common": {
                          "role": "state",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "def": 0,
                          "unit": "W"
                        "type": "state",
                        "native": {},
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "ts": 1680442197289
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #118
                      @g-hawk Na OK - dann haben wir doch des Rätsels Lösung. Du musst also die leeren Objekte ausfiltern. Wahrscheinlich fragst Du zu oft ab und das mag das Ding nicht.
                      • T TT-Tom
                        @g-hawk
                        G.Hawk
                        #119
                        @tt-tom
                        Hab ich gemacht, keine Änderung.
                        Ich habe das Script gelöscht, auch keine Änderung.
                        Reboot?
                        • G G.Hawk
                          @mickym
                            "common": {
                              "role": "state",
                              "type": "number",
                              "read": true,
                              "write": true,
                              "def": 0,
                              "unit": "W"
                            "type": "state",
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                            "ts": 1680442197289
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #120
                          @g-hawk sagte in Parser Wert auslesen aber wie?:
                          Ja dann läuft noch was anderes. ;) - Dann musst Du suchen was da noch rein schreibt. Vielleicht hast Du beim Speichern das ganze dopppelt.
                          • G G.Hawk
                            @tt-tom
                            Reboot?
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #121
                            @tt-tom
                            Reboot?
                            Na es langt wenn Du den iobroker neu startest.
                            Auf der Kommandozeile:
                            iob restart
                            • mickymM mickym
                              G.Hawk
                              #122
                              @mickym
                              Aber das Log sagt ja, das es um das Script geht, das es garnicht mehr gibt.
                              javascript.0
                              2023-06-25 13:31:01.291	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" has to be type "number" but received type "string"
                              javascript.0
                              2023-06-25 13:31:01.290	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" has to be type "number" but received type "string"
                              javascript.0
                              2023-06-25 13:31:01.289	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" has to be type "number" but received type "string"
                              javascript.0
                              2023-06-25 13:31:01.099	info	script.js_.Strom.Gesamtstrom.Elmo_auslesen: {}
                              javascript.0
                              2023-06-25 13:31:01.097	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                              javascript.0
                              2023-06-25 13:31:01.097	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
                              javascript.0
                              2023-06-25 13:31:01.096	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                              javascript.0
                              2023-06-25 13:31:01.094	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                              javascript.0
                              2023-06-25 13:31:01.092	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                              javascript.0
                              2023-06-25 13:31:01.092	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
                              javascript.0
                              2023-06-25 13:31:01.091	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                              javascript.0
                              2023-06-25 13:31:01.087	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                              javascript.0
                              2023-06-25 13:31:01.086	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                              javascript.0
                              2023-06-25 13:31:01.086	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
                              javascript.0
                              2023-06-25 13:31:01.085	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                              javascript.0
                              2023-06-25 13:31:01.083	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                              • G G.Hawk
                                @mickym
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                javascript.0
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #123
                                @g-hawk Wie gesagt, wenn Du das Script angehalten hast und es kommen die Meldungen immer noch dann gibts noch was.
                                Insofern würde @TT-Tom Rat folgen und entweder die JS Instanz oder den ganzen IOB neu starten. Nochmal wenn Du das Script stoppst und die Meldungen kommen noch, dann ist entweder das Script nicht gestoppt oder ein anderes arbeitet noch.
                                Im Blockly kann man leider nur noch Scriptnamen suchen, sonst könntest Du ja nach allen Strings suchen, die Du zum Parsen verwendest.
                                • mickymM mickym
                                  G.Hawk
                                  #124
                                  @mickym
                                  Das ist schon klar, aber ich habe das Script "Elmo_auslesen" gelöscht und es steht aber trotzdem jede Minute im Log.
                                  Ich mache einen Neustart und guck mal was passiert
                                  • G G.Hawk
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #125
                                    @g-hawk Ja geh mal unter die Ghostbusters. ;) 👻 👻 👻 👻 - Von der Ferne geht das schlecht.
                                    • mickymM mickym
                                      G.Hawk
                                      #126
                                      @mickym
                                      javascript.0
                                      2023-06-25 13:37:01.121	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      javascript.0
                                      2023-06-25 13:37:01.121	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
                                      javascript.0
                                      2023-06-25 13:37:01.121	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                                      javascript.0
                                      2023-06-25 13:37:01.119	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                                      javascript.0
                                      2023-06-25 13:37:01.118	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      javascript.0
                                      2023-06-25 13:37:01.118	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
                                      javascript.0
                                      2023-06-25 13:37:01.117	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                                      javascript.0
                                      2023-06-25 13:37:01.116	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                                      javascript.0
                                      2023-06-25 13:37:01.115	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      javascript.0
                                      2023-06-25 13:37:01.115	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
                                      javascript.0
                                      2023-06-25 13:37:01.114	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                                      javascript.0
                                      2023-06-25 13:37:01.112	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
                                      Diesen Eintrag:
                                      javascript.0
                                      kann es doch garnicht mehr geben
                                      HomoranH mickymM 2 Antworten Letzte Antwort
                                      • G G.Hawk
                                        @mickym
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        Diesen Eintrag:
                                        javascript.0
                                        HomoranH Offline
                                        HomoranH Offline
                                        #127
                                        warum nicht?
                                        zeig mal die script enabled Datepunkte unter system (experte)
                                        • G G.Hawk
                                          @mickym
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          javascript.0
                                          Diesen Eintrag:
                                          javascript.0
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #128
                                          Hast Du schon mal gesucht?
                                          Ich bin da aber eigentlich raus, da ich kein Blockly oder Javascript nutze - da sind andere VIEL schlauer 🤓 🤓 🤓 als ich.
