  4. Huawei Sun2000 & ioBroker via JS script funktioniert
481 Beiträge 62 Kommentatoren 193.5k Aufrufe 63 Beobachtet
  • G g.polat
    @xanon sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
    @chris_b
    Würdest du dein Skript hier zur Verfügung stellen?
    Funktioniert bei mir mir 10kw Akku perfekt.
    // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
    // If you like this code, feel free to buy me a beer ...
    // Have fun with it! der Kachel
    var ModbusRTU = require("modbus-serial");
    var client = new ModbusRTU();
    var modbusErrorMessages = [
        "Unknown error",
        "Illegal function (device does not support this read/write function)",
        "Illegal data address (register not supported by device)",
        "Illegal data value (value cannot be written to this register)",
        "Slave device failure (device reports internal error)",
        "Acknowledge (requested data will be available later)",
        "Slave device busy (retry request again later)"
    // open connection to a tcp line
    client.setTimeout(10000);
    // Enter your inverter modbus IP and port here:
    client.connectTCP("192.168.0.45", { port: 502 });
    // Enter the Modbus-IDs of your Sun2000 inverters here:
    const ModBusIDs = [1];
    // On which Modbus-ID can we reach the power meter? (via Sun2000!)
    const PowerMeterID = 0;
    // Enter your battery stack setup. 2 dimensional array.
    // e.g. [[3, 2], [3, 0]] means:
    // First inverter has two battery stacks with 3 + 2 battery modules
    // while second inverter has only one battery stack with 3 battery modules
    const BatteryUnits = [[3, 0], [3, 0]];
    // These register spaces need to be read:
    const RegisterSpacesToReadContinuously = [[30000, 81], [37100, 114], [32000, 116], [37000, 68],  [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100], [35300, 40]];
    var RegisterSpacesToReadContinuouslyPtr = 0;
    var GlobalDataBuffer = new Array(2);
    for(var i=0; i<ModBusIDs.length; i++) {
        GlobalDataBuffer[i] = new Array(50000); // not optimized....
    // Some helper functions:
    function readUnsignedInt16(array) {
        var value = array[0];
        return value;
    function readUnsignedInt32(array) {
        var value = array[0] * 256 * 256 + array[1];
        return value;
    function readSignedInt16(array) {
        var value = 0;
        if (array[0] > 32767)
            value = array[0] - 65535;
        else
            value = array[0];
        return value;
    function readSignedInt32(array) {
        var value = 0;
        for (var i = 0; i < 2; i++) {
            value = (value << 16) | array[i];
        return value;
    function getU16(dataarray, index) {
        var value = readUnsignedInt16(dataarray.slice(index, index+1));
        return value;
    function getU32(dataarray, index) {
        var value = readUnsignedInt32(dataarray.slice(index, index+2));
        return value;
    function getI16(dataarray, index) {
        var value = readSignedInt16(dataarray.slice(index, index+1));
        return value;
    function getI32(dataarray, index) {
        var value = readSignedInt32(dataarray.slice(index, index+2));
        return value;
    function getString(dataarray, index, length) {
        var shortarray = dataarray.slice(index, index+length);
        var bytearray = [];
        for(var i = 0; i < length; i++) {
            bytearray.push(dataarray[index+i] >> 8);
            bytearray.push(dataarray[index+i] & 0xff);
        var value =  String.fromCharCode.apply(null, bytearray);
        return value;
    function getZeroTerminatedString(dataarray, index, length) {
        var bytearray = [];
        var value2 = new String(value).trim();
        return value2;
    function forcesetState(objectname, value, options) {
        if(!existsState("javascript.0." + objectname)) {
            createState(objectname, value, options);
            console.log("createstate " +  objectname + " to value " + value);
            setState(objectname, value);
    // Functions to map registers into ioBreaker objects:
    function processOptimizers(id) {
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
    function processInverterPowerAdjustments(id) {
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
    function processBattery(id) {
        // Battery registers 1-15 (Stack 1 related)
        if(BatteryUnits[id-1][0] > 0) {
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",            getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",       getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",    getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",            getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",             getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
        // Battery registers 16+17 (Storage-related)
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",             getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
        // Battery register 18-20 (Stack 1 related)
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
        // Battery register 21-31 (Stack 2 related)
        if(BatteryUnits[id-1][1] > 0) {
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getU16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
        // Battery register 32-41 (Storage related)
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
        // Battery registers 42+43 (Battery stack related)
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
            forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
        // Registers 44 to 98: (Battery pack related)
        for(var i = 1; i <= 2; i++){
            if(BatteryUnits[id-1][i-1] >= 0) {
                for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++) {
                    //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                    forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                    // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                    createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                    createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
        // Battery registers 110-141 are not supported by this script yet!
    function ProcessPowerMeterStatus() {
        forcesetState("Solarpower2.Huawei.Meter.Status",          getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL1",        getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL2",        getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL3",        getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.CurrentL1",        getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Meter.CurrentL2",        getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Meter.CurrentL3",        getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Meter.ActivePower",     getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Meter.ReactivePower",   getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
        forcesetState("Solarpower2.Huawei.Meter.PowerFactor",     getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Meter.GridFrequency",   getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
        forcesetState("Solarpower2.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
        forcesetState("Solarpower2.Huawei.Meter.MeterType",       getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL1-L2",       getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL2-L3",       getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.VoltageL3-L1",       getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Meter.ActivePowerL1",    getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Meter.ActivePowerL2",    getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Meter.ActivePowerL3",    getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
        forcesetState("Solarpower2.Huawei.Meter.MeterModel",      getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
    function processInverterStatus(id) {
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".DailyEnergyYield",         getU32(GlobalDataBuffer[id-1], 32114) / 100, {name: "", unit: "kWh"});
        //forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
        //forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",          getU32(GlobalDataBuffer[id-1], 32114) / 100, {name: "", unit: "kWh"});
    function ProcessDeviceInfo(id) {
        // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
        forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
    function readRegisterSpace(id, address, length) {
        client.setID(ModBusIDs[id-1]);
        client.readHoldingRegisters(address, length, function(err, data) {
            if (err) {
                console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
            else
                console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                    GlobalDataBuffer[id-1][address+i] = data.data[i];
    function processData() {
        console.log("Processing new data...");
        for(var i = 1; i <= ModBusIDs.length; i++) {
            ProcessDeviceInfo(i);
            processInverterStatus(i);
            processBattery(i);
            processInverterPowerAdjustments(i);
            processOptimizers(i);
        ProcessPowerMeterStatus();
        console.log("Processing done!");
    // This is the main function triggering a  read via modbus-tcp every two seconds.
    // Processing of data is triggered as soon as one complete set of registers is copied.
    var triggerprocessing = 0;
    var currentinverter = 1;
    setInterval(function() {
        if(triggerprocessing == 1) {
            processData();
        console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
        readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
        RegisterSpacesToReadContinuouslyPtr++;
        if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
            currentinverter++
            if(currentinverter > ModBusIDs.length){
                triggerprocessing = 1;
    }, 4000);
    X
    X
    Xanon
    #112
    @g-polat Super Vielen Dank
    Werde ich mal testen 👍
    • C Chris_B
      @xanon Mach' ich in den nächsten 1-2 Tagen. Ich möchte noch ein paar weitere Verbesserungen vornehmen, dann stelle ich das Skript zur Verfügung.
      X
      X
      Xanon
      #113
      @chris_b
      Ok, bin gespannt, was du noch aus dem Skript heraus zauberst.😊
      Danke für deine Mühe.👍
      C 1 Antwort Letzte Antwort
      • X Xanon
        @chris_b
        C
        C
        Chris_B
        #114
        @xanon
        Hier schon einmal vorab mein aktueller Stand des Skripts. Dazu folgende Bemerkungen:
        • Das Skript ist noch nicht wirklich fertig. Ich komme aber erst am Wochenende dazu noch mehr Funktionalität einzubauen. Ich werde dann ein Update posten.
        • Die Sache mit createState() ist jetzt optimiert.
        • Neuer State: javascript.0.Solarpower.Dervied.PeakPower --> Zeigt den Max Wert der Panels an einem Tag an.
        • Neuer State: javascript.0.Solarpower.Dervied.BatteryOverview --> hier werden die % Werte jedes Battery Packs angezeigt, momentan fix für 3, sollte ich allgemeiner schreiben.
        Ich werde am Wochenende weiter am Skript arbeiten und weitere Funktionen einfügen. Habe aber bis dann keine Zeit.
        // From iobroker Forum: Huawei Sun2000 & ioBroker via JS script funktioniert
        // https://forum.iobroker.net/topic/53005/huawei-sun2000-iobroker-via-js-script-funktioniert
        createState("javascript.0.Solarpower.Dervied.PeakPower", 0,  {read: true, write: true, name: "Peak Solar Panel Power today"});
        createState("javascript.0.Solarpower.Dervied.BatteryOverview", "",  {read: true, write: true, name: "Battery Overview SOC"});
        var testCreateState = 0;
        [   "Unknown error",
        client.connectTCP("192.168.1.127", { port: 502 });
        // Enter the Modbus-IDs of your Sun2000 inverters here (example for two inverters): const ModBusIDs = [16, 1];
        // Enter your battery stack setup. 2 dimensional array, e.g. [[3, 2], [3, 0]] means:
        const BatteryUnits = [[3, 0]];
        for ( var i=0; i < ModBusIDs.length; i++)
        {   return array[0];
        {   return array[0] * 256 * 256 + array[1];
        {   var value = 0;
            if (array[0] > 32767)   value = array[0] - 65535;
                else                value = array[0];
            return value;
        {   var value = 0;
            for (var i = 0; i < 2; i++) { value = (value << 16) | array[i]; }
            return value;
        {   return readUnsignedInt16(dataarray.slice(index, index+1));
        {   return readUnsignedInt32(dataarray.slice(index, index+2));
        {   return readSignedInt16(dataarray.slice(index, index+1));
        {   return readSignedInt32(dataarray.slice(index, index+2));
        {   var shortarray = dataarray.slice(index, index+length);
            var bytearray = [];
            for (var i = 0; i < length; i++)
            {   bytearray.push(dataarray[index+i] >> 8);
            return value;
            var bytearray = [];
            return value2;
        // perform createState() only if variable does not yet exist, and perform the check via existsState() only once for each processing round
        {   if (testCreateState == 0)
            {   if (!existsState("javascript.0." + objectname)) { createState(objectname, value, options); }
                else                                            { setState(objectname, value); testCreateState = 1; }
            } else
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
            if ( BatteryUnits[id-1][0] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",                 getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",            getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",         getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                     getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime",getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",                 getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",                  getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                     getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",                  getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
            if (BatteryUnits[id-1][0] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",                          getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
            if ( BatteryUnits[id-1][1] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",                          getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                        createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                        createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
            forcesetState("Solarpower.Huawei.Meter.Status",                   getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.VoltageL1",                getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL2",                getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL3",                getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL1",                getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL2",                getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL3",                getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.ActivePower",              getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ReactivePower",            getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
            forcesetState("Solarpower.Huawei.Meter.PowerFactor",              getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.GridFrequency",            getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
            forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
            forcesetState("Solarpower.Huawei.Meter.MeterType",                getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2",             getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3",             getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1",             getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL1",            getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL2",            getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL3",            getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.MeterModel",               getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
                if (err)
                {   console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                else
                {   console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                    for (var i = 0; i < length; i++) GlobalDataBuffer[id-1][address+i] = data.data[i];
            console.debug("Processing new data...");   // this was originally .log
            for ( var i = 1; i <= ModBusIDs.length; i++)
                processBattery(i);
            // get SOC of all batteries and combine to one string
            var BatOverview = getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC").val + "%, " +
                getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery2.BatterySOC").val + "%, " +
                getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery3.BatterySOC").val + "%";
            setState("javascript.0.Solarpower.Dervied.BatteryOverview", BatOverview);
            // determine maximum power delivery of today (this is reset at midnight)
            var PeakPV = parseFloat(getState("javascript.0.Solarpower.Huawei.Inverter.1.InputPower").val);
            PeakPV = max(PeakPV, getState("javascript.0.Solarpower.Dervied.PeakPower").val);
            setState("javascript.0.Solarpower.Dervied.PeakPower", PeakPV);
            console.debug("Processing done!");  // this was originally .log
        // one minute before midnight: reset min/max variables
        schedule("59 23 * * *", function ()
            setState("javascript.0.Solarpower.Dervied.PeakPower", 0);
        // This is the main function triggering a  read via modbus-tcp every 2 seconds - changed to 5 seconds
        // with 5 seconds, new values are displyed every 50 seconds
            if (triggerprocessing == 1)
                processData();
            // this was originally also a .log
            console.debug("Triggering read of inverter " + currentinverter + " at address " +
            if (RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length)
                currentinverter++
                if (currentinverter > ModBusIDs.length)
        }, 5000);
        Hier noch ein Screenshot meiner Vis. Auch diese ist erst im Aufbau, möchte ich noch stark verbessern...
        S C 2 Antworten Letzte Antwort
        • C Chris_B
          @xanon
          [   "Unknown error",
          {   return array[0];
          {   var value = 0;
              return value;
          {   var value = 0;
              return value;
              var bytearray = [];
              return value;
              var bytearray = [];
              return value2;
              } else
                  if (err)
                  else
                  processBattery(i);
                  processData();
                  currentinverter++
          }, 5000);
          S
          S
          spooky82
          #115
          @chris_b
          ich habe wohl ein Verständnisproblem.
          Ich habe das Skript und den easee Adapter eingerichtet und alle Datenpunkte mMn korrekt gesetzt.
          Das Laden geht jedoch nicht los.
          Habt ihr Ideen?
          3c553291-ba34-461a-8ab6-484a46857849-image.png 050572b2-4e9d-48b9-aa2c-9f57c6a49de9-image.png
          Dankeschön
          • S spooky82
            @chris_b
            Habt ihr Ideen?
            Dankeschön
            C
            C
            Chris_B
            #116
            @spooky82 Sorry, aber da muss eine Verwechslung voliegen. Das von mir abgeänderte Skript oben ist für Huawei Sun2000 / Luna2000 Anlagen. Für das Auslesen der Anlagen via TCP / Modbus braucht man ausschliesslich das Skript, wie oben in diversen Beiträgen beschrieben.
            Die Datenpunkte dafür befinden sich dann unter javascript.0.Solarpower....
            Gruss
            • C Chris_B
              @xanon
              [   "Unknown error",
              {   return array[0];
              {   var value = 0;
                  return value;
              {   var value = 0;
                  return value;
                  var bytearray = [];
                  return value;
                  var bytearray = [];
                  return value2;
                  } else
                      if (err)
                      else
                      processBattery(i);
                      processData();
                      currentinverter++
              }, 5000);
              C
              C
              Chris_B
              #117
              @chris_b Ich bin immer noch an der Anänderung des Skripts. Habe noch ein paar Fehler darin gefunden (falsche Skalierung der Werte). Ich brauche noch etwas mehr Zeit. Hier mein aktueller Stand für das UI (im Wesentlichen eine Nachbildung der Huawei App, aber, wenn ich dann fertig bin, so, wie es mir passt, und mit zusätzlicher Information.
              (Dies ist ein noch fehlerhafter Zwischenstand)
              • C Chris_B
                Gruss
                S
                S
                spooky82
                #118
                @chris_b
                Sorry, hast absolut Recht. Falsches Forum.
                Danke dir!
                • C Chris_B
                  S
                  S
                  Sweatchuck
                  #119
                  @chris_b
                  Hallo Chris,
                  ich hätte starkes Interesse an deinem Script. Node-red ist leider nichts für mich ;-)
                  Meine PV-Konfiguration ist sehr ähnlich.
                  2 Strings (Ost/West), Powermeter, Optimierer und 1x Akkuturm mit 3x 5kwh Packs.
                  Würde mich freuen wenn du deine Arbeit mit uns/mir teilen würdest.
                  • S Sweatchuck
                    @chris_b
                    Hallo Chris,
                    C
                    C
                    Chris_B
                    #120
                    @sweatchuck
                    Hallo
                    Hier mein aktueller Stand des Skripts. Bitte beachten:
                    • Das Skript ist noch NICHT fertig. Ich werde in den nächsten Tagen noch weitere Verbesserungen vornehmen.
                    • Unter client.connectTCP("192.168.0.0", { port: 502 }); die eigene TCP-IP Adresse des INverters angeben
                    • Verwendung des Skripts auf eigene Verantwortung.
                      Das Skript erzeugt neu noch zusätzliche Variable unter Solarpower.Derived.XXX. Die Beschreibung der Variable ist meist selbsterklärend.
                      Ich werde in den nächsten Tagen und Wochen noch folgendes erweitern:
                    1. Am Ende jedes Tages die aktuellen Werte in ein File schreiben, zur Analyse in bspw. Excel.
                    2. Den Tagesverbrauch ausgeben (wie im Huawei Portal)
                    3. Den Modbus-Trafic verringern (bspw. Nachts)
                    4. Mein UI verbessern
                      Hier mein aktuelles UI und das Skript.
                    // From iobroker Forum: "Huawei Sun2000 & ioBroker via JS script funktioniert"
                    createState("javascript.0.Solarpower.Derived.BatteryOverview", "",  {read: true, write: true, name: "Battery Overview SOC"});
                    createState("javascript.0.Solarpower.Derived.HouseConsumption", "",  {read: true, write: true, name: "Consumption of House", unit: "W"});
                    createState("javascript.0.Solarpower.Derived.YieldToday", "",  {read: true, write: true, name: "Yield Today", unit: "kW"});
                    createState("javascript.0.Solarpower.Derived.IsBatteryLoading", 0,  {read: true, write: true, name: "Luna 2000 Battery is loading", type: "number"});
                    createState("javascript.0.Solarpower.Derived.IsGridExporting", 0,  {read: true, write: true, name: "Exporting Power to Grid", type: "number"});
                    createState("javascript.0.Solarpower.Derived.PeakPanelPower", 0,  {read: true, write: true, name: "Peak panel power today"});
                    createState("javascript.0.Solarpower.Derived.GridExportSum", 0,  {read: true, write: true, name: "Total export to grid", unit: "kWh"});
                    createState("javascript.0.Solarpower.Derived.GridImportSum", 0,  {read: true, write: true, name: "Total import from grid", unit: "kWh"});
                    createState("javascript.0.Solarpower.Derived.GridExportToday", 0,  {read: true, write: true, name: "Export to grid today", unit: "kWh"});
                    createState("javascript.0.Solarpower.Derived.GridImportToday", 0,  {read: true, write: true, name: "Import from grid today", unit: "kWh"});
                    [   "Unknown error",
                    {   return array[0];
                    {   var value = 0;
                        return value;
                    {   var value = 0;
                        return value;
                        var bytearray = [];
                        return value;
                        var bytearray = [];
                        return value2;
                        } else
                    function ProcessOptimizers(id)
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 37200), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 37201), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 37202), {name: "", unit: ""});
                    function ProcessInverterPowerAdjustments(id)
                    function ProcessBattery(id)
                            //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",                 getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                            //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",                  getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                        //forcesetState("Solarpower.Huawei.Meter.MeterType",                getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                        //forcesetState("Solarpower.Huawei.Meter.MeterModel",               getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                    function ProcessInverterStatus(id)
                        //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                        //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".AccumulatedEnergyYield",    getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
                            if (err)
                            else
                    function ProcessData()
                            ProcessInverterStatus(i);
                            ProcessBattery(i);
                            //ProcessInverterPowerAdjustments(i);
                            ProcessOptimizers(i);
                        setState("javascript.0.Solarpower.Derived.BatteryOverview", BatOverview);
                        // determine peak panel power
                        var PanelPower = getState("javascript.0.Solarpower.Huawei.Inverter.1.InputPower").val;
                        var PanelMax = getState("javascript.0.Solarpower.Derived.PeakPanelPower").val;
                        if (PanelPower > PanelMax) setState("javascript.0.Solarpower.Derived.PeakPanelPower", PanelPower);
                        // determine power used by house
                        setState("javascript.0.Solarpower.Derived.HouseConsumption", getState("javascript.0.Solarpower.Huawei.Inverter.1.ActivePower").val * 1000 -
                            getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val);
                        // determine yield today
                        setState("javascript.0.Solarpower.Derived.YieldToday", getState("javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield").val +
                            getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity").val -
                            getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity").val)
                        // determine if battery is loading
                        setState("javascript.0.Solarpower.Derived.IsBatteryLoading", getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.ChargeAndDischargePower").val > 0 ? 0 : 1);
                        // determine if power is imported or exported
                        setState("javascript.0.Solarpower.Derived.IsGridExporting", getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val > 0 ? 1 : 0);
                        // compute export and import today
                        setState("javascript.0.Solarpower.Derived.GridExportToday", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridExportSum").val);
                        setState("javascript.0.Solarpower.Derived.GridImportToday", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridImportSum").val);
                            ProcessData();
                            currentinverter++
                    }, 5000);
                    // one minute before midnight - perform housekeeping actions
                        // reset peak power for next day
                        setState("javascript.0.Solarpower.Derived.PeakPanelPower", 0);
                        // copy current export/import kWh - used to compute daily import/export in kWh
                        setState("javascript.0.Solarpower.Derived.GridExportSum", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val);
                        setState("javascript.0.Solarpower.Derived.GridImportSum", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val);
                    S S 2 Antworten Letzte Antwort
                    • C Chris_B
                      @sweatchuck
                      Hallo
                      [   "Unknown error",
                      {   return array[0];
                      {   var value = 0;
                          return value;
                      {   var value = 0;
                          return value;
                          var bytearray = [];
                          return value;
                          var bytearray = [];
                          return value2;
                          } else
                              if (err)
                              else
                              ProcessBattery(i);
                              ProcessData();
                              currentinverter++
                      }, 5000);
                      S
                      S
                      Sweatchuck
                      #121
                      @chris_b
                      Vielen herzlichen Dank.
                      Deine Updates/Verbesserungen würde ich natürlich gerne auch bei mir integrieren.
                      Wenn ich bei der Entwicklung/Weiterentwicklung unterstützen kann (Tester etc.), lass es mich wissen!
                      • A
                        A
                        anno171986
                        schrieb am zuletzt editiert von anno171986
                        #122
                        @Chris_B Vielen Dank für dein Skript. Ich habe die vorletzte Vdersion und mit der Ausnahme der Datenpunkterzeugung läuft es auch gut.
                        Was mich ein bisschen ärgert ist, das Huawei anscheinend nicht alle Werte hier per API bereitstellt die man über die App sieht. Mich interessiert z.B. der Gesamtstromverbrauch am Tag. Kann man den aus den vorliegenden Werten berechnen, bin da noch nicht fündig geworden.
                        • S Sweatchuck
                          @chris_b
                          C
                          C
                          Chris_B
                          #123
                          @sweatchuck
                          Mach ich gerne. Und Feedback, Testen sind sehr willkommen. Gerne würde ich mich auch in Sachen Sun2000 / Luna 2000 austauschen. Ich habe da noch einige Fragen. Ich melde mich am Wochenende. Bin gerade ziemlich mit Arbeit zu...
                          Danke und Gruss
                          • A anno171986
                            C
                            C
                            Chris_B
                            #124
                            @anno171986 Was meinst Du genau mit dem Problem der Datenpunkterzeugung?
                            Am besten Skript stoppen, Alle Datenpunkte löschen und Skript wieder neu starten.
                            Noch eine Bemerkung: Gewisse Datenpunkte werden erst 'sinnvoll' wenn einmal Mitternacht durch ist, da Differenzen zum Vortag benötigt werden...
                            Gruss
                            • C Chris_B
                              Gruss
                              A
                              A
                              anno171986
                              #125
                              @chris_b
                              Vorweg: ich habe mein Skript noch nicht mit deinem neuen Stand vom 05.06.2023 aktualisiert.
                              Bei mir waren die Werte immer nur einmal aktualisiert worden, n achdem ich die Dtaenpunkte gelöscht hatte. Dann wurden sie per Skript einmaöl neu angelegt aber danach nicht mehr aktualisiert. Habe jetzt Teile ausgeklammert, damit funktioniert es:
                                  /* if (testCreateState == 0)
                                  {   if (!existsState(Folder + objectname)) { createState(objectname, value, options); }
                                  } else
                              Wieviel kwh du verbraucht hast, das kannst du auch nicht auslesen oder berechnen, richtig?
                              • A anno171986
                                @chris_b
                                    } else
                                C
                                C
                                Chris_B
                                #126
                                @anno171986 Ganz kurz: Bitte das neuste Skript nehmen. Das mit den Datenpunkten ist ein Problem des ursprünglichen Skripts (nicht von mir). Nochmals alle Datenpunkte löschen und das neuste Skript nehmen.
                                Den Verbrauch an einem Tag kann man rechnen. Das habe ich noch nicht gemacht, ist nicht sehr kompliziert, kommt vermutlich am Wochenende. Bitte etwas Geduld…
                                Ich möchte auch noch eine bessere Doku machen, damit es verständlich ist, was das Skript macht und kann. Ich möchte alle sinnvollen Werte der Huawei App in iobroker darstellen können…
                                Gruss
                                R 1 Antwort Letzte Antwort
                                • C Chris_B
                                  Gruss
                                  R
                                  R
                                  road_runner31
                                  schrieb am zuletzt editiert von road_runner31
                                  #127
                                  @chris_b Hi, ich habe diesen Thread gerade gefunden und das Script bei mir installiert. Wenn ich es starte, erscheinen nach einigen Sekunden Warnungen, die dann zyklisch wiederholt werden
                                  In den Objekten erscheinen Werte, die zunächst grün sind, dann rot werden. Auch scheinen die Werte falsch formatiert zu sein?
                                  Hab ich irgendwo einen Fehler in der Konfiguration gemacht?
                                  Der Battery Overview scheint ja auch nicht zu klappen.
                                  Habe eine SUN2000 mit 10kWh Speicher in 2 Modulen.. Ein Tipp wäre super!
                                  Und: VIELEN DANK für die Arbeit, die da drin steckt! :)
                                  C exelE 2 Antworten Letzte Antwort
                                  • R road_runner31
                                    C
                                    C
                                    Chris_B
                                    #128
                                    @road_runner31 Hallo. Kurz ein paar Hinweise. Das ursprüngliche Skript ist nicht von mir, siehe ganz oben in diesem thread. Ich habe das Skript abgeändert, Fehler korrigiert und bin am erweitern. Was mir einfällt:
                                    1. Im Javascript Adapter muss (!!) Modbus-Serial eingetragen sein:
                                    2. Prüfe Deine IP Adresse.
                                    3. Die PowerMeterID musst Du ausprobieren, scheint aber meist 0 zu sein.
                                    4. Du schreibst, dass Deine Luna2000 2 Module hat, dann solltest Du auch entsprechen BatteryUnits = [[2, 0]]; schreiben.
                                    5. Einige Werte unter 'Derived' sind erst nach dem erstamligen Überschreiten von Mitternacht sinnvoll gefüllt.
                                    Mehr fällt mir gerade nicht ein. Gruss
                                    • C Chris_B
                                      R
                                      R
                                      road_runner31
                                      #129
                                      @chris_b Hallo, danke für die Antworten. Die Anzahl der Module hab ich schon korrigiert. Die IP-Adresse stimmt, es sind ja auch ein paar Werte korrekt (bspw. das Modell). "modbus-serial" ist auch eingebunden.
                                      Ich lasse das Script jetzt mal laufen, trotz Fehlern, mal schauen was morgen drinsteht..
                                      Viele Grüße!
                                      • R road_runner31
                                        Viele Grüße!
                                        C
                                        C
                                        Chris_B
                                        #130
                                        @road_runner31 Ich glaube aber, dass Du noch ein anderes Problem hast bei Deiner Anlage. Die Sache mit den Werten nach Mitternacht kann das nicht sein, das ergibt nur am ersten Tag für ein paar Werte sinnlose Zahlen, aber keine Fehlermeldungen.
                                        Ich glaube Deine Sun2000 ist nicht ansprechbar. Anwortet sie auf ein PING? Das würde ich einmal als nächstes checken. Gruss
                                        • R road_runner31
                                          exelE
                                          exelE
                                          exel
                                          schrieb am zuletzt editiert von exel
                                          #131
                                          @road_runner31 Ich kann das Verhalten bestätigen, sieht bei mir genauso aus.
                                          84.1k
