Updates 10.07.2016
Ich scheine da auch Probleme mit dem Update zu haben …
root@penguin:/opt/iobroker# npm cache clean root@penguin:/opt/iobroker# npm install iobroker.js-controller \ > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller > node lib/setup.js setup first fs.js:549 return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode); ^ Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh' at Error (native) at Object.fs.openSync (fs.js:549:18) at Object.fs.writeFileSync (fs.js:1156:15) at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:513:23 at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:534:11) at Module._compile (module.js:410:26) at Object.Module._extensions..js (module.js:417:10) at Module.load (module.js:344:32) at Function.Module._load (module.js:301:12) npm ERR! Linux 4.4.0-28-generic npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller" npm ERR! node v4.2.6 npm ERR! npm v2.15.8 npm ERR! code ELIFECYCLE npm ERR! iobroker.js-controller@0.10.1 install: `node lib/setup.js setup first` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.js-controller@0.10.1 install script 'node lib/setup.js setup first'. npm ERR! This is most likely a problem with the iobroker.js-controller package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/setup.js setup first npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.js-controller npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls iobroker.js-controller npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /opt/iobroker/npm-debug.log root@penguin:/opt/iobroker#</anonymous>
Läuft auf Ubuntu 16.04 LTS …
"Er ist tot, Jim"
Habt Ihr evt. eine Idee, wieso der controller nicht installiert?
1000x
Werner
@dwm:Habt Ihr evt. eine Idee, wieso der controller nicht installiert? `
@dwm:EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh' `
hast du vorher
iobroker stop
gemacht?
Sonst weiss ich ausser dem dummen reboot auch nichts
@dwm:Ich scheine da auch Probleme mit dem Update zu haben …
"Er ist tot, Jim"
1000x
Werner `
Kannst ducd /opt/iobroker sudo iobroker stop sudo chmod 777 * -R sudo npm install iobroker.js-controller --production sudo iobroker start
ausführen?
das hats getan …
Jetzt klappts auch mit dem 1.2.6er admin!
Erst mal herzlichen Dank!
Jetzt nur mal um das auch zu verstehen ...
Zugriffsrechte vermurkst? Wie kann das sein? Sollte "root" nicht alles überbügeln können? Ich hab beobachtet dass manche module auf 755 standen, aber nicht als Problem gesehen.
was macht --production?
Ich hatte das auch probiert mit
iobroker stop iobroker update iobroker upgrade iobroker start
… was aber auch nicht geklappt hatte. Na ja, läuft ja wieder!
Nochmals merci
Werner
ioBroker lief aber nicht als root und konnte auf die Dateien nicht zugreifen."–production" installiert keine "Test"-Pakete und nur das was fürs Laufen gebraucht wird.
Kannst du
ausführen? `
habe ich jetzt auch probiert, bekomme jetzt aber folgende Fehlermeldung
root@raspberrypi:/opt/iobroker# sudo iobroker start Starting iobroker controller daemon... /home/pi/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136 throw new Error(msg.error); ^ Error: /home/pi/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/json3/lib/json3.js:379 }); ^ SyntaxError: Unexpected token ) at exports.runInThisContext (vm.js:73:16) at Module._compile (module.js:443:25) at Object.Module._extensions..js (module.js:478:10) at Module.load (module.js:355:32) at Function.Module._load (module.js:310:12) at Module.require (module.js:365:17) at require (module.js:384:17) at Object. <anonymous>(/home/pi/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/index.js:7:12) at Module._compile (module.js:460:26) at Object.Module._extensions..js (module.js:478:10) at ChildProcess. <anonymous>(/home/pi/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19) at ChildProcess.emit (events.js:110:17) at handleMessage (child_process.js:324:10) at Pipe.channel.onread (child_process.js:352:11)</anonymous></anonymous>
Was ist jetzt noch falsch? Vor dem Update lief alles ohne Probleme.. zumindest nicht das ich welche germerkt hätte
Error: /home/pi/node_modules/iobroker.js-controller/node_modules/… `
Es existiert noch eine alte Installation im falschen Verzeichnis. Ich würde das gesamte Verzeichnis "node_modules" im Verzeichnis "/home/pi" löschen und es als user "root" im Verzeichnis "/opt/iobroker" nochmal versuchen. -
Hallo!
Ich brauche doch noch mal Hilfe. Nach dem Update bekomme ich keinen Zugriff mehr über den Browser (Site can't be reached).
Ich habe schon die einzelnen Befehle ausgeführt (stop,start,cache clean etc) es hilft aber leider nicht.
Auf dem Cubietruck sehe ich mit "ps ax" nur den iobroker.js-controller laufen. nichts weiter.
Mit "iobroker list instances" kommt keine Ausgabe. Versuche ich "iobroker update" kommt "system.config not found".
Eigentlich hat das Update erst funktioniert, alles war Ok. Nach Neustart war ging nichts mehr.
Jemand eine Idee?
Hallo!
Jemand eine Idee?
Schon probiert?
Hallo!
Habe ich soweit mal durchprobiert.
js-controller
6109 ? 00:00:3 iobroker.js-con
netstat -n -a -p TCP
tcp6 0 0 :::9000 :::* LISTEN 6109/iobroker.js-co tcp6 0 0 :::9001 :::* LISTEN 6109/iobroker.js-co
node -v
v4.4.7
npm -v
npm -v
Hab probiert:
npm install iobroker.admin iobroker upload admin iobroker start admin
dann kommt
Cannot find any instance of "admin"
Habe mir mal das IOBroker Log von heute angesehen. Dieser Eintrag sscheitn auf jeden Fall ein Problem zu sein:
2016-07-17 20:34:23.107 - error: admin.0 no connection to objects DB 2016-07-17 20:49:16.885 - error: host.cubietruck _design/system missing - call node iobroker.js setup
Kann ich noch etwas tun oder hilft nur eine Neuinstallation?
Hallo!
js-controller
node -v
v4.4.7
npm -v
npm -v
Hab probiert:
dann kommt
Gruß `
IM welchem Verzeichnis hast du alle Befehle ausgeführt?Es sieht so aus als ob im "home".
Hallo!
Das war unter /opt/iobroker.. ganz sicher. Ich bin immer erst in den Ordner gewechselt direkt nach dem Login über SSH.
Aber lass mal gut sein.. ich mache das neu drauf, keine Ahnung was ich da anscheinend vorher zerschossen habe.
Hi Paul,
habe ich gemacht. Beim installieren bekomme ich unter anderem die Meldung. Hat die was zu sagen?
` > > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controllernode lib/setup.js setup first `
Komplett:! root@raspberrypi:/opt/iobroker# sudo npm install iobroker.js-controller –production
! > iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
! > node lib/setup.js setup first
! iobroker.js-controller@0.10.1 node_modules/iobroker.js-controller
! ├── winston-daily-rotate-file@1.1.5
! ├── daemonize2@0.4.2
! ├── mime@1.3.4
! ├── ncp@2.0.0
! ├── node.extend@1.1.5 (is@3.1.0)
! ├── semver@4.3.6
! ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
! ├── redis@2.6.2 (double-ended-queue@2.1.0-0, redis-parser@2.0.3, redis-commands@1.2.0)
! ├── yargs@3.32.0 (camelcase@2.1.1, decamelize@1.2.0, y18n@3.2.1, window-size@0.1.4, os-locale@1.4.0, string-width@1.0.1, cliui@3.2.0)
! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.1, async@1.0.0, colors@1.0.3)
! ├── socket.io-client@1.4.8 (to-array@0.1.4, indexof@0.0.1, component-emitter@1.2.0, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.2.0, parseuri@0.0.4, socket.io-parser@2.2.6, engine.io-client@1.6.11)
! ├── request@2.73.0 (is-typedarray@1.0.0, aws-sign2@0.6.0, oauth-sign@0.8.2, forever-agent@0.6.1, tunnel-agent@0.4.3, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, aws4@1.4.1, node-uuid@1.4.7, qs@6.2.0, tough-cookie@2.2.2, combined-stream@1.0.5, mime-types@2.1.11, form-data@1.0.0-rc4, bl@1.1.2, har-validator@2.0.6, http-signature@1.1.1, hawk@3.1.3)
! ├── socket.io@1.4.8 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.11)
! ├── jszip@3.0.0 (asap@2.0.4, es6-promise@3.0.2, readable-stream@2.0.6, pako@1.0.1)
! ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.10.2, fstream@1.0.10, mout@0.11.1)
! ├── prompt@1.0.0 (revalidator@0.1.8, colors@1.1.2, pkginfo@0.4.0, read@1.0.7, winston@2.1.1, utile@0.3.0)
! ├── npm@2.15.9
! └── iobroker.admin@1.2.6 (connect-flash@0.1.1, xtend@4.0.1, cookie-parser@1.4.3, passport-local@1.0.0, passport@0.3.2, express-session@1.14.0, body-parser@1.15.2, express@4.14.0)beim starten von iobroker bekomme ich dann:
` > root@raspberrypi:/opt/iobroker# sudo iobroker start
module.js:338
throw err;
Error: Cannot find module '/home/pi/node_modules/iobroker.js-controller/iobroker.js'
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Function.Module.runMain (module.js:501:10)
at startup (node.js:129:16)
at node.js:814:3
root@raspberrypi:/opt/iobroker# `
irgendwas habe ich wohl einmal im falschen Ordner ausgeführt :(.
wie kann ich das wieder bereinigen?
Hi Paul,
! ├── mime@1.3.4
! ├── ncp@2.0.0
! ├── semver@4.3.6
! ├── npm@2.15.9
module.js:338
throw err;
at node.js:814:3
wie kann ich das wieder bereinigen? `
Vermutlich "iobroker" Skript liegt in "/home/pi". Was passiert wenn du:cd /opt/iobroker node node_modules/iobroker.js-controller/controller.js
Aufrufst?
Aufrufst? `
habe ich versucht, aber er steht dann über eine Stunde in dem Bild und nichts passiert. Ist das normal? Ist ein Rasbberry3
root@raspberrypi:~# cd /opt/iobroker root@raspberrypi:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js
Aufrufst? `
root@raspberrypi:~# cd /opt/iobroker root@raspberrypi:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js ```` `
Dafür sollte aber dann admin und alles laufen. Ist das so?
Es wird übrigens ewig stehen
hehe, da hätte ich ja noch ewig warten können
admin läuft, aber alle meine Instanzen sind weg und alles was ich eingerichtet hatte. Gib es da noch eine Chance?
Läuft es dann jetzt auch nach einen reboot wieder automatisch?
Läuft es dann jetzt auch nach einen reboot wieder automatisch? `
Das heißt, dass entwider deine Konfig in "home" geblieben ist oder dein hostname hat sich geändert. -
Heute hat es wieder einige Updates gegeben.
Achtung es ist auch eine neue Controller Version dabei.(0.10.1)
Anscheinend läuft die neue Version Admin (1.2.6) nicht mehr mit dem alten Controller . Iobroker ist dann nicht mehr erreichbar.
Dann bitte auf der Konsole ausführen
cd /opt/iobroker iobroker stop npm install iobroker.js-controller iobroker start
Evtl. Ist auch noch ein Reboot notwendigen.
Wenn man sicherheitshalber alles über die Konsole machen will macht man am besten
cd /opt/iobroker iobroker stop iobroker update iobroker upgrade reboot
Dann läuft alles weitestgehend automatisch.
Rainer `
ich habe heute nach längerer Abwesenheit mal mein System updaten wollen.
Zuerst das besagte Problem nach Update des Admin gehabt. Dann über Konsole den controler upgedated.
Danach kann ich kein anderes installiertes Pluging updaten.
Habe auch 2x die Version über die Konsole versucht, ohne Erfolg.
Hier mal der Printout:
So sieht es nach dem restart aus:
Wenn ich jetzt, egal bei welchem Adapter auf die Upgrade funktion klicke, passiert nur das:
Jemand ne Idee was da noch falsch läuft?
Danke und Gruß
Hallo wendy,
es gibt leider einen bug in der aktuellen Version des Controller, weswegen zurzeit die Updates nicht funktionieren.
Der Fix hierfür wird aber wohl noch etwas dauern.
Die einfachste Lösung ist, vorerst auf die letzte funktionierende Version des Controller zurück zu gehen. Dafür muss der Controller manuell mittels npm installiert werden.
cd /opt/iobroker iobroker stop npm install iobroker.js-controller@0.11.0 iobroker start
Danach sollten auch die Updates wieder wie gewohnt laufen.
