Update Node.js
Hier noch eine weitere Info
sudo npm cache clean -f
ERROR: npm is known not to run on Node.js v4.3.2
Node.js 4 is supported but the specific version you're running has
a bug known to break npm. Please update to at least ${rel.min} to use this
version of npm. You can find the latest release of Node.js at https://nodejs.org/
Das Update in dem Fall sollte per „sudo apt-get upgrade“ automatisch gehen … `
So kenne ich das auch, aber hast du wirklich
@wake2010:Sudo App-get … bereits ausgeführt ` ?
Natürlich musst du vorher noch ein
sudo apt-get update machen
Poste mal bitte den output, den du bekommst, nachdem du durchgeführt hast
sudo apt-get update sudo apt-get upgrade
Bevor du das anschließende yes bestätigst
pi@raspberrypi:~ $ sudo apt-get update Hit http://mirrordirector.raspbian.org jessie InRelease Hit http://archive.raspberrypi.org jessie InRelease Hit https://deb.nodesource.com jessie InRelease Hit http://mirrordirector.raspbian.org jessie/main armhf Packages Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages Hit http://archive.raspberrypi.org jessie/main armhf Packages Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages Hit https://deb.nodesource.com jessie/main Sources Hit https://deb.nodesource.com jessie/main armhf Packages Hit http://archive.raspberrypi.org jessie/ui armhf Packages Get:1 https://deb.nodesource.com jessie/main Translation-en_GB [162 B] Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB Ign http://mirrordirector.raspbian.org jessie/main Translation-en Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB Ign http://archive.raspberrypi.org jessie/main Translation-en_GB Ign http://archive.raspberrypi.org jessie/main Translation-en Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB Ign http://archive.raspberrypi.org jessie/ui Translation-en Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:3 https://deb.nodesource.com jessie/main Translation-en_GB [162 B] Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:5 https://deb.nodesource.com jessie/main Translation-en_GB [162 B] Get:6 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:7 https://deb.nodesource.com jessie/main Translation-en_GB [162 B] Get:8 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:9 https://deb.nodesource.com jessie/main Translation-en_GB [162 B] Ign https://deb.nodesource.com jessie/main Translation-en_GB Get:10 https://deb.nodesource.com jessie/main Translation-en [162 B] Ign https://deb.nodesource.com jessie/main Translation-en Reading package lists... Done pi@raspberrypi:~ $ sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. pi@raspberrypi:~ $ node -v v4.3.2 pi@raspberrypi:~ $ nodejs -v v6.11.4
MOD-Edit by eric2905; Code-Tags gesetzt
Bitte Logs & Co. immewr in Code-Tags setzen (ggf. aucgh Spoiler-Tags verwenden).
Gruß,
Eric
Dann hast du es irgendwie geschafft zwei Installationen von nodejs auf den Rechner zu bekommen
Um zu sehen, welche Version wo installiert wurde, gib bitte auf der Console ein
ls -l /usr/local/bin/node* ls -l /usr/bin/node*
und poste das Ergebnis.
pi@raspberrypi:~ $ ls -l /usr/local/bin/node*
-rwxr-xr-x 1 root staff 22144561 Feb 16 2017 /usr/local/bin/node
lrwxrwxrwx 1 root staff 44 May 26 03:34 /usr/local/bin/node-gyp -> ../lib/node_modules/node-gyp/bin/node-gyp.js
pi@raspberrypi:~ $ ls -l /usr/bin/node*
-rwxr-xr-x 1 root root 21515844 Oct 3 22:36 /usr/bin/node
lrwxrwxrwx 1 root root 24 Oct 22 14:33 /usr/bin/nodejs -> /etc/alternatives/nodejs
Du hast 3 Versionen installiert:
-rwxr-xr-x 1 root staff 22144561 Feb 16 2017 /usr/local/bin/node -rwxr-xr-x 1 root root 21515844 Oct 3 22:36 /usr/bin/node lrwxrwxrwx 1 root root 24 Oct 22 14:33 /usr/bin/nodejs -> /etc/alternatives/nodejs
Um zu sehen, ob die Datei /usr/bin/node vom 3. Oktober aktuell ist, teste mal:
/usr/bin/node -v
pi@raspberrypi:~ $ /usr/bin/node -v
v6.11.4
/usr/bin/node -v
v6.11.4 `
Das sieht gut aus. Die alte Version /usr/local/bin/node schiebt sich im Suchpfad nach vorn und sollte gelöscht werden.sudo rm /usr/local/bin/node node -v npm -v
node -v sollte v6.11.4 und npm -v sollte 3.10.10 liefern.
Leider ist dies die Rückmeldung
pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
v6.11.4
pi@raspberrypi:~ $ npm -v
/usr/local/bin/npm: 2: exec: /usr/local/bin/node: not found
/usr/local/bin/npm: 2: exec: /usr/local/bin/node: not found `
Dann drängelt sich die alte NPM-Version im Suchpfad vor und muss auch gelöscht werden.sudo rm /usr/local/bin/npm npm -v
pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
-bash: /usr/local/bin/npm: No such file or directorypi@raspberrypi:~ $
Ich verzweifle!
Ich verzweifle! `
iobroker stop apt-get --purge remove node apt-get --purge remove nodejs apt-get autoremove reboot curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash - sudo apt-get install -y build-essential python nodejs npm
So?
pi@raspberrypi:~ $ sudo apt-get install -y build-essential python nodejs npm
Reading package lists… Done
build-essential is already the newest version.
python is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Conflicts: npm
E: Unable to correct problems, you have held broken packages.
-bash: node: command not found
-bash: npm: command not found
nodejs wurde nicht installiert, weil
@wake2010:The following packages have unmet dependencies:
E: Unable to correct problems, you have held broken packages. `
Es scheint noch ein falsches NPM-Packet zu existieren ? Versuche nochmal:sudo apt-get purge node sudo apt-get purge nodejs sudo apt-get purge npm sudo apt-get autoremove sudo reboot
Nach dem Einloggen
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash - sudo apt-get install -y nodejs node -v npm -v /usr/bin/node -v
v6.11.5
3.10.10
v6.11.5
Ich würde sagen es läuft!
Wie starte ich ioBroker wieder? Der läuft nämlich nicht mehr.
Wie starte ich ioBroker wieder? Der läuft nämlich nicht mehr. `
iobroker start
Um gleich zu testen, ob ioBroker automatisch startet:
sudo reboot
Eventuell noch einen reinstall.sh hinterher `
Dazu sollte erst getestet werden, ob die Datei reinstall.sh in Linux-Format vorliegt.ls -l /opt/iobroker/reinstall.sh -rwxrwxrwx 1 root root 654 Aug 23 16:39 /opt/iobroker/reinstall.sh
Wenn die Datei ca. 654 Byte groß ist, ist sie im Linux-Format; ist sie mehr als 680 Byte groß, muss sie erst in das Linux-Format gebracht werden, z.B. mit Notepad++. Dann ausführen
cd /opt/iobroker sudo ./reinstall.sh iobroker start
EDIT: Das würde ich aber nur veranstalten, wenn bei Start von ioBroker irgendein Error-Log erzeugt wird. Ansonsten gilt: Never touch a running system.
…muss sie erst in das Linux-Format gebracht werden, z.B. mit Notepad++. `
Das geht auch auf der Linux Kommandozeile:mv /opt/iobroker/reinstall.sh /opt/iobroker/reinstall.dos tr -d '\r' < /opt/iobroker/reinstall.dos > /opt/iobroker/reinstall.sh
