@marc-berg super, danke.
L
Latest posts made by Leahcim
Installation Docker Image auf Synology 920+posted in Installation
ich habe mir das "latest-v9" Image runter geladen und den Container gestartet. Danach habe ich im Web-Portal Port 8081 auf Port 8081 von diesem Container gemapped. Wenn ich Port 8081 auf dem NAS aufrufe bekomme ich allerdings nur das ioBroker Logo in dem ein Virtel blau rotiert.
In der Browser Konsole sehe ich jede Menge Websocket Verbindungsfehler.socket.io.js:67 [2024-01-09T07:00:18.133Z] No READY flag received in 3 seconds. Re-init (anonym) @ instrument.ts:144 warn @ socket.io.js:67 (anonym) @ socket.io.js:148 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 socket.onerror @ socket.io.js:189 error (async) SocketClient.connect @ socket.io.js:182 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 12 weitere Frames anzeigen Weniger anzeigen socket.io.js:396 WebSocket connection to 'ws://192.168.101.6:8081/?sid=1704783615128&name=admin' failed: WebSocket is closed before the connection is established. SocketClient.close @ socket.io.js:396 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 socket.onerror @ socket.io.js:189 error (async) SocketClient.connect @ socket.io.js:182 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 11 weitere Frames anzeigen Weniger anzeigen socket.io.js:66 [2024-01-09T07:00:18.142Z] Start reconnect 5 socket.io.js:66 [2024-01-09T07:00:18.142Z] Reconnect is already running 5 socket.io.js:68 [2024-01-09T07:00:18.142Z] ws connection error: CLOSE_ABNORMAL (anonym) @ instrument.ts:144 error @ socket.io.js:68 socket.onclose @ socket.io.js:177 1 weiteren Frame anzeigen Weniger anzeigen socket.io.js:66 [2024-01-09T07:00:18.142Z] Reconnect is already running 5 socket.io.js:66 [2024-01-09T07:00:23.145Z] Try to connectHat jemand einen Tip für mich?
Viele Grüße
Michael
Hier gehts zur Hilfe.
