Skript v.2023-06-20
*** BASE SYSTEM ***
Static hostname: iobroker-pi
Icon name: computer
Machine ID: 8c7521687f1c426fafe88f497be66f04
Boot ID: d3b295b8436d44e2beb25306385497a1
Kernel: Linux 5.10.103-v7l+
Architecture: arm
Model : Raspberry Pi 4 Model B Rev 1.5
Docker : false
Virtualization : none
Kernel : armv7l
Userland : armhf
Systemuptime and Load:
22:36:03 up 22:32, 1 user, load average: 0.28, 0.56, 0.86
CPU threads: 4
Raspberry only:
throttled=0x0
Other values than 0x0 hint to temperature/voltage problems
temp=51.6'C
volt=0.8600V
*** Time and Time Zones ***
Local time: Tue 2023-09-26 22:36:03 CEST
Universal time: Tue 2023-09-26 20:36:03 UTC
RTC time: n/a
NTP service: active
RTC in local TZ: no
*** User and Groups ***
pi
/home/pi
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
*** X-Server-Setup ***
X-Server: false
Desktop:
Terminal: tty
Boot Target: multi-user.target
*** MEMORY ***
Mem: 1.9G 1.1G 398M 4.0M 450M 744M
Swap: 99M 12M 87M
Total: 2.0G 1.1G 485M
1921 M total memory
1072 M used memory
215 M active memory
1195 M inactive memory
398 M free memory
132 M buffer memory
318 M swap cache
99 M total swap
12 M used swap
87 M free swap
Raspberry only:
oom events: 0
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 58G 6.5G 49G 12% /
devtmpfs devtmpfs 800M 0 800M 0% /dev
tmpfs tmpfs 961M 0 961M 0% /dev/shm
tmpfs tmpfs 961M 17M 945M 2% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 961M 0 961M 0% /sys/fs/cgroup
/dev/mmcblk0p1 vfat 247M 49M 198M 20% /boot
tmpfs tmpfs 193M 0 193M 0% /run/user/1000
[Tue Sep 26 00:04:00 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:2560x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=E4:5F:01:93:C5:D4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=c03af850-02 rootfstype=ext4 fsck.repair=yes rootwait
[Tue Sep 26 00:04:01 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[Tue Sep 26 00:04:01 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[Tue Sep 26 00:04:04 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
TARGET SOURCE FSTYPE OPTIONS
/ /dev/mmcblk0p2 ext4 rw,noatime
|-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700
`-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
661M /var/
465M /var/cache
460M /var/cache/apt
401M /var/cache/apt/archives
93M /var/lib
Archived and active journals take up 16.0M in the file system.
/opt/iobroker/backups:
92M /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
2.7G /opt/iobroker/iobroker-data/
2.2G /opt/iobroker/iobroker-data/history
293M /opt/iobroker/iobroker-data/files
108M /opt/iobroker/iobroker-data/backup-objects
88M /opt/iobroker/iobroker-data/files/echarts.admin
42M /opt/iobroker/iobroker-data/objects.jsonl
23M /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
23M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
*** NodeJS-Installation ***
/usr/bin/nodejs v18.18.0
/usr/bin/node v18.18.0
/usr/bin/npm 9.8.1
/usr/bin/npx 9.8.1
nodejs:
Installed: 18.18.0-1nodesource1
Candidate: 18.18.0-1nodesource1
Version table:
*** 18.18.0-1nodesource1 1001
500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
100 /var/lib/dpkg/status
18.17.1-1nodesource1 1001
18.17.0-1nodesource1 1001
18.16.1-1nodesource1 1001
18.16.0-1nodesource1 1001
18.15.0-1nodesource1 1001
18.14.2-1nodesource1 1001
18.14.1-1nodesource1 1001
18.14.0-1nodesource1 1001
18.13.0-1nodesource1 1001
18.12.0-1nodesource1 1001
18.11.0-1nodesource1 1001
18.10.0-1nodesource1 1001
18.9.1-1nodesource1 1001
18.9.0-1nodesource1 1001
18.8.0-1nodesource1 1001
18.7.0-1nodesource1 1001
18.6.0-1nodesource1 1001
18.5.0-1nodesource1 1001
18.4.0-1nodesource1 1001
18.3.0-1nodesource1 1001
18.2.0-1nodesource1 1001
18.1.0-1nodesource1 1001
18.0.0-1nodesource1 1001
10.24.0~dfsg-1~deb10u3 500
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States type: jsonl
No configuration change needed.
Multihost discovery server: disabled
Discovery authentication: enabled
Persistent activation: disabled
Objects: jsonl on 127.0.0.1
States: jsonl on 127.0.0.1
Core adapters versions
js-controller: 4.0.23
admin: 6.10.1
javascript: 7.1.4
Adapters from github: 1
Adapter State
+ system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0 : backitup : iobroker-pi - enabled
system.adapter.ble.0 : ble : iobroker-pi - disabled
system.adapter.discovery.0 : discovery : iobroker-pi - disabled
+ system.adapter.echarts.0 : echarts : iobroker-pi - enabled
system.adapter.flot.0 : flot : iobroker-pi - disabled
system.adapter.fritzdect.0 : fritzdect : iobroker-pi - disabled
system.adapter.habpanel.0 : habpanel : iobroker-pi - disabled
+ system.adapter.history.0 : history : iobroker-pi - enabled
system.adapter.jarvis.0 : jarvis : iobroker-pi - disabled
+ system.adapter.javascript.0 : javascript : iobroker-pi - enabled
+ system.adapter.javascript.1 : javascript : iobroker-pi - enabled
+ system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.mqtt.1 : mqtt : iobroker-pi - enabled, port: 1885, bind: 0.0.0.0
system.adapter.netatmo-crawler.1 : netatmo-crawler : iobroker-pi - disabled
system.adapter.netatmo-crawler.2 : netatmo-crawler : iobroker-pi - enabled
system.adapter.parser.0 : parser : iobroker-pi - disabled
+ system.adapter.shelly.0 : shelly : iobroker-pi - enabled, port: 1882, bind: 0.0.0.0
system.adapter.smartmeter.0 : smartmeter : iobroker-pi - disabled
+ system.adapter.sonoff.0 : sonoff : iobroker-pi - enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-pi - enabled
+ system.adapter.statistics.0 : statistics : iobroker-pi - enabled
system.adapter.vis-bars.0 : vis-bars : iobroker-pi - disabled
system.adapter.vis-history.0 : vis-history : iobroker-pi - disabled
system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker-pi - disabled
system.adapter.vis-rgraph.0 : vis-rgraph : iobroker-pi - disabled
system.adapter.vis.0 : vis : iobroker-pi - enabled
+ system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
2stable : http://iobroker.live/repo/sources-dist.json
stable : http://download.iobroker.net/sources-dist.json
beta : http://download.iobroker.net/sources-dist-latest.json
Active repo(s): stable
Installed ioBroker-Instances
Used repository: stable
Adapter "admin" : 6.10.1 , installed 6.10.1
Adapter "backitup" : 2.8.1 , installed 2.8.1
Adapter "ble" : 0.13.4 , installed 0.13.4
Adapter "discovery" : 3.1.0 , installed 3.1.0
Adapter "echarts" : 1.5.1 , installed 1.5.1
Adapter "flot" : 1.12.0 , installed 1.12.0
Adapter "fritzdect" : 2.3.1 , installed 2.3.1
Adapter "habpanel" : 0.5.0 , installed 0.5.0
Adapter "history" : 2.2.6 , installed 2.2.6
Adapter "jarvis" : 3.1.2 , installed 3.1.2
Adapter "javascript" : 7.1.4 , installed 7.1.4
Controller "js-controller": 5.0.12 , installed 4.0.23 [Updatable]
Adapter "mqtt" : 4.1.1 , installed 4.1.1
Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
Adapter "parser" : 1.3.2 , installed 1.3.2
Adapter "shelly" : 6.4.1 , installed 6.4.1
Adapter "simple-api" : 2.7.2 , installed 2.7.2
Adapter "smartmeter" : 3.3.4 , installed 3.3.4
Adapter "socketio" : 6.5.5 , installed 6.5.5
Adapter "sonoff" : 2.5.3 , installed 2.5.3
Adapter "statistics" : 2.3.0 , installed 2.3.0
Adapter "vis" : 1.4.16 , installed 1.4.16
Adapter "vis-bars" : 0.1.4 , installed 0.1.4
Adapter "vis-history" : 1.0.0 , installed 1.0.0
Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
Adapter "web" : 6.1.2 , installed 6.1.2
Adapter "ws" : 2.5.5 , installed 2.5.5
Objects and States
Objects: 25686
States: 2979
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14184 610/sshd
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 75185 18839/io.sonoff.0
tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 76016 18795/io.mqtt.1
tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 76017 18795/io.mqtt.1
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 60237 13076/iobroker.js-c
tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 60232 13076/iobroker.js-c
tcp6 0 0 :::8081 :::* LISTEN 1001 75797 18206/io.admin.0
tcp6 0 0 :::8082 :::* LISTEN 1001 76290 19061/io.web.0
tcp6 0 0 :::22 :::* LISTEN 0 14186 610/sshd
udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 74666 18852/io.shelly.0
udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13924 602/dhcpcd
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 13873 353/avahi-daemon: r
udp 0 0 0.0.0.0:44418 0.0.0.0:* 108 13875 353/avahi-daemon: r
udp6 0 0 :::45057 :::* 108 13876 353/avahi-daemon: r
udp6 0 0 :::546 :::* 0 13969 602/dhcpcd
udp6 0 0 :::5353 :::* 108 13874 353/avahi-daemon: r
2023-09-26 22:37:10.729 - error: mqtt.0 (18772) Client error:Error: connect ECONNREFUSED ::1:1883
2023-09-26 22:37:10.730 - info: mqtt.0 (18772) Disconnected from localhost
2023-09-26 22:37:11.602 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:14.112 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:14.158 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:15.100 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:16.838 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:19.294 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:19.335 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:19.746 - info: sonoff.0 (18839) Client [DVES_5
2023-09-26 22:37:20.396 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:20.736 - info: mqtt.0 (18772) Reconnected to localhost
2023-09-26 22:37:20.742 - error: mqtt.0 (18772) Client error:Error: connect ECONNREFUSED ::1:1883
2023-09-26 22:37:20.743 - info: mqtt.0 (18772) Disconnected from localhost
2023-09-26 22:37:22.097 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:24.423 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:24.475 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:25.729 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:27.346 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:29.543 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:29.616 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:30.747 - info: mqtt.0 (18772) Reconnected to localhost
2023-09-26 22:37:31.064 - warn: shelly.0 (18852) [authEnabled]
2023-09-26 22:37:30.752 - error: mqtt.0 (18772) Client error:Error: connect ECONNREFUSED ::1:1883
2023-09-26 22:37:30.752 - info: mqtt.0 (18772) Disconnected from localhost
