    2. oscool90
    O
    • Posts 7
    oscool90
    @oscool90
    oscool90 Follow
    Latest posts made by oscool90
    • RE: hm-rega down nach Umzug
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       10:45:18 up 6 min,  1 user,  load average: 0.70, 0.73, 0.39
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=47.7'C
      volt=0.9360V
      *** Time and Time Zones ***
                     Local time: Mon 2023-07-10 10:45:18 CEST
                 Universal time: Mon 2023-07-10 08:45:18 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        877M        2.0G        1.0M        891M        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        877M        2.1G
               3794 M total memory
                877 M used memory
                986 M active memory
                585 M inactive memory
               2025 M free memory
                 86 M buffer memory
                804 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       59G  5.9G   50G  11% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      [Mon Jul 10 10:39:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74        072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-ser        ial-consoles
      [Mon Jul 10 10:39:09 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
      [Mon Jul 10 10:39:09 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
      [Mon Jul 10 10:39:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      1.4G    /var/
      783M    /var/lib
      599M    /var/lib/piVCCU3
      545M    /var/lib/piVCCU3/rootfs
      332M    /var/cache
      Archived and active journals take up 168.0M in the file system.
      /opt/iobroker/backups:
      11M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      119M    /opt/iobroker/iobroker-data/
      103M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a        8.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42        .chunk.js.map
      5.4M    /opt/iobroker/iobroker-data/files/jarvis/js/index-566ba00e.js
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.1
      /usr/bin/node           v18.16.1
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi        - disabled
        system.adapter.history.0                : history               : raspberrypi        - disabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi        -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi        -  enabled, port: 0
        system.adapter.influxdb.0               : influxdb              : raspberrypi        - disabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi        -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi        - disabled
      + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi        -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi        -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.web.0                    : web                   : raspberrypi        - disabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.9-beta.2
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Objects and States
      Objects:        1324
      States:         1040
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN        1001       21460      4380/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          14745      859/sshd: /usr/sbin
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          15475      888/dnsmasq
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN        1001       25807      4262/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       21433      4348/io.sonoff.0
      tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN        1001       25827      4290/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       25740      4200/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       23884      4200/iobroker.js-co
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN        0          1635       817/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN        0          15456      859/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN        1001       23929      4219/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN        0          1634       817/cupsd
      udp        0      0 10.0.3.1:53             0.0.0.0:*        0          15474      888/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*        0          15471      888/dnsmasq
      udp        0      0 0.0.0.0:631             0.0.0.0:*        0          15501      891/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        14595      365/avahi-daemon: r
      udp        0      0 0.0.0.0:44409           0.0.0.0:*        108        14597      365/avahi-daemon: r
      udp6       0      0 :::42084                :::*        108        14598      365/avahi-daemon: r
      udp6       0      0 :::5353                 :::*        108        14596      365/avahi-daemon: r
      2023-07-10 10:44:44.373  - info: host.raspberrypi iobroker upload [19] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swi        pe/img/noSwipe.jpg image/jpeg
      2023-07-10 10:44:44.387  - info: host.raspberrypi iobroker upload [18] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes        .js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
      2023-07-10 10:44:44.406  - info: host.raspberrypi iobroker upload [17] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js        widgets/swipe/js/jquery.roundabout.min.js application/javascript
      2023-07-10 10:44:44.425  - info: host.raspberrypi iobroker upload [16] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js        widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
      2023-07-10 10:44:44.445  - info: host.raspberrypi iobroker upload [15] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html tex        t/html
      2023-07-10 10:44:44.473  - info: host.raspberrypi iobroker upload [14] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets        /tabs/jquery.sliderTabs.js application/javascript
      2023-07-10 10:44:44.489  - info: host.raspberrypi iobroker upload [13] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png        widgets/tabs/styles/images/indicator.png image/png
      2023-07-10 10:44:44.508  - info: host.raspberrypi iobroker upload [12] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActiv        e.png widgets/tabs/styles/images/indicatorActive.png image/png
      2023-07-10 10:44:44.528  - info: host.raspberrypi iobroker upload [11] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png        widgets/tabs/styles/images/leftArrow.png image/png
      2023-07-10 10:44:44.550  - info: host.raspberrypi iobroker upload [10] vis /opt/        iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow        .png widgets/tabs/styles/images/leftPanelArrow.png image/png
      2023-07-10 10:44:44.573  - info: host.raspberrypi iobroker upload [9] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png        widgets/tabs/styles/images/rightArrow.png image/png
      2023-07-10 10:44:44.589  - info: host.raspberrypi iobroker upload [8] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow        .png widgets/tabs/styles/images/rightPanelArrow.png image/png
      2023-07-10 10:44:44.611  - info: host.raspberrypi iobroker upload [7] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css        widgets/tabs/styles/jquery.sliderTabs.css text/css
      2023-07-10 10:44:44.629  - info: host.raspberrypi iobroker upload [6] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.        orig widgets/tabs/styles/jquery.sliderTabs.css.orig null
      2023-07-10 10:44:44.652  - info: host.raspberrypi iobroker upload [5] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.        css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
      2023-07-10 10:44:44.678  - info: host.raspberrypi iobroker upload [4] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/h        tml
      2023-07-10 10:44:44.694  - info: host.raspberrypi iobroker upload [3] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.htm        l text/html
      2023-07-10 10:44:44.711  - info: host.raspberrypi iobroker upload [2] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/h        omematic.html text/html
      2023-07-10 10:44:44.738  - info: host.raspberrypi iobroker upload [1] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/spe        cial.html text/html
      2023-07-10 10:44:44.757  - info: host.raspberrypi iobroker upload [0] vis /opt/i        obroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/wea        ther.html text/html
      2023-07-10 10:44:44.848  - info: host.raspberrypi iobroker upload [3] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
      2023-07-10 10:44:44.858  - info: host.raspberrypi iobroker upload [2] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/htm        l
      2023-07-10 10:44:44.872  - info: host.raspberrypi iobroker upload [1] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      2023-07-10 10:44:44.880  - info: host.raspberrypi iobroker upload [0] vis.admin        /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/java        script
      2023-07-10 10:44:45.976  - info: host.raspberrypi iobroker exit 0
      O
      oscool90
      Hallo Thomas,
      danke für deine ausführliche Antwort.
      Localization steht jetzt auf Berlin.
      Grafische Oberfläche ausschalten:
      1b1886c4-610d-46d7-b66d-58fdc11e285b-grafik.png Dürfte bereits aus sein, wenn ich es richtig verstehe.
      Den Befehl ls -lah /var/lib/lxcfs/cgroup verstehe ich nicht, sorry. Bei LXC handelt es sich wohl um ein eigenes System(?), in dem ich mit meinen bescheidenen Kenntnissen nicht allein herumwühlen möchte.
      Das mit NVM habe ich vorher geahnt... Konnte es nun deinstallieren und node v18 aufsetzen.
      Vis und JavaScript sind auch aktualisiert. Ich nutze Jarvis/Grafana. Ist ein aktuelles Vis notwendig, damit die anderen Adapter korrekt arbeiten?
      Und siehe da: Der ReGa-Adapter läuft jetzt. 😊 Werde später ans Testen gehen. Falls ich mich nicht mehr melde, läuft alles und ich darf mich vielmals bedanken!
      Grüße
      O
      oscool90
      Hallo Thomas,
      dann auf ein Neues:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
       08:31:29 up  9:57,  3 users,  load average: 0.07, 0.38, 0.34
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=45.2'C
      volt=0.9360V
                     Local time: Mon 2023-07-10 08:31:30 BST
                 Universal time: Mon 2023-07-10 07:31:30 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        952M        1.6G         35M        1.3G        2.7G
      Swap:            99M          0B         99M
      Total:          3.9G        952M        1.7G
               3794 M total memory
                952 M used memory
               1162 M active memory
                804 M inactive memory
               1552 M free memory
                143 M buffer memory
               1145 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       59G  6.0G   50G  11% /
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Sun Jul  9 22:33:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Jul  9 22:33:49 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Jul  9 22:33:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Jul  9 22:33:51 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      783M    /var/lib
      332M    /var/cache
      Archived and active journals take up 136.0M in the file system.
      135M    /opt/iobroker/iobroker-data/
      100M    /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
      /usr/bin/nodejs         v20.4.0
      /home/pi/.nvm/versions/node/v18.16.1/bin/node           v18.16.1
      /home/pi/.nvm/versions/node/v18.16.1/bin/npm            9.5.1
      /home/pi/.nvm/versions/node/v18.16.1/bin/npx            9.5.1
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 20.4.0-deb-1nodesource1
        Candidate: 20.4.0-deb-1nodesource1
        Version table:
       *** 20.4.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_20.x bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
      Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
      Objects and States
      Objects:        1319
      States:         1034
      Hit:5 https://deb.nodesource.com/node_20.x bullseye InRelease
      Pending Updates: 0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       204254     41977/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       204259     41977/iobroker.js-c
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13268      910/dnsmasq
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       204550     42183/io.jarvis.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          49552      8937/cupsd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15502      888/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       204531     42143/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       205283     42059/node-red
      tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN      1001       204397     42094/io.hm-rpc.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15504      888/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       205227     42004/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          49551      8937/cupsd
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13267      910/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13264      910/dnsmasq
      udp        0      0 0.0.0.0:53578           0.0.0.0:*                           108        13904      379/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          51286      8940/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13902      379/avahi-daemon: r
      udp6       0      0 :::35405                :::*                                108        13905      379/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13903      379/avahi-daemon: r
      2023-07-10 08:27:15.924  - info: host.raspberrypi iobroker upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2023-07-10 08:27:15.934  - info: host.raspberrypi iobroker upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2023-07-10 08:27:15.944  - info: host.raspberrypi iobroker upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2023-07-10 08:27:15.956  - info: host.raspberrypi iobroker upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2023-07-10 08:27:15.976  - info: host.raspberrypi iobroker upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2023-07-10 08:27:15.986  - info: host.raspberrypi iobroker upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
      2023-07-10 08:27:15.996  - info: host.raspberrypi iobroker upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
      2023-07-10 08:27:16.006  - info: host.raspberrypi iobroker upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
      2023-07-10 08:27:16.362  - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-10 08:27:17.078  - info: host.raspberrypi iobroker exit 0
      2023-07-10 08:27:18.858  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 42423
      2023-07-10 08:27:21.170  - info: hm-rega.0 (42423) starting. Version 3.0.46 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v20.4.0, js-controller: 4.0.24
      2023-07-10 08:27:21.306  - info: hm-rega.0 (42423) [REGASCRIPTS] Successfully updated datapoints.fn
      2023-07-10 08:27:21.345  - info: hm-rega.0 (42423) subscribe .BidCoS-RF.50.PRESS_SHORT
      2023-07-10 08:27:21.387  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:27:51.409  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:28:21.429  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:28:51.446  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:29:21.464  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:29:51.481  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:30:21.505  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:30:51.523  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:31:21.535  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:31:51.545  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      2023-07-10 08:32:21.554  - error: hm-rega.0 (42423) ReGaHSS 192.168.100.6 down
      Ich sehe zwar
      mir fehlen aber die Kenntnisse zur Reparatur. Welche Schritte sind hier notwendig?
      Ich nutze die Desktop-Oberfläche des Pi ohnehin nicht. Wie kann ich sie ausschalten?
      Wie prüfe ich die Zeit? Zumindest augenscheinlich passt die Systemzeit.
      Was meinst du mit "Adapter auf Stand bringen"?
      O
      oscool90
      Danke für eure Hilfe! Habe versucht, node mit nvm zurückzudrehen. Laut Konsole hat das wohl auch geklappt. Habe vorher den iobroker gestoppt.
      pi@raspberrypi:~ $ node -v
      v18.16.1
      pi@raspberrypi:~ $ npm -v
      9.5.1
      Nach Start des iobroker wird in der Weboberfläche aber immer noch node 20.4.0 angezeigt; hm-rega funktioniert noch nicht (gleich Meldung wie oben). Kann ich prüfen, ob zwei Versionen von node gleichzeitig laufen?! Wie kann ich das korrigieren?
      O
      oscool90
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
       06:54:26 up  8:20,  3 users,  load average: 0.19, 0.23, 0.21
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=44.8'C
      volt=0.9360V
                     Local time: Mon 2023-07-10 06:54:26 BST
                 Universal time: Mon 2023-07-10 05:54:26 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        1.1G        1.7G         35M        1.1G        2.6G
      Swap:            99M          0B         99M
      Total:          3.9G        1.1G        1.8G
               3794 M total memory
               1064 M used memory
               1272 M active memory
                610 M inactive memory
               1651 M free memory
                133 M buffer memory
                944 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       59G  5.8G   51G  11% /
      [Sun Jul  9 22:33:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:1C:C9 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=99a74        072-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-ser        ial-consoles
      [Sun Jul  9 22:33:49 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
      /var:
      1.4G    /var/
      783M    /var/lib
      332M    /var/cache
      132M    /opt/iobroker/iobroker-data/
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c        9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922        d.chunk.js.map
      /usr/bin/node           v20.4.0
      /usr/bin/npm            9.7.2
      /usr/bin/npx            9.7.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.44 [Updatable]
      Objects and States
      Objects:        1319
      States:         1034
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Pending Updates: 0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15776      832/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16735      832/iobroker.js-con
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21288      3769/io.jarvis.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19124      2644/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18234      2376/node-red
      tcp        0      0 192.168.100.7:2010      0.0.0.0:*               LISTEN      1001       49163      8644/io.hm-rpc.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18119      1798/io.admin.0
      2023-07-10 06:42:55.281  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:43:25.286  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:43:55.292  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:44:25.297  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:44:55.302  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:45:25.307  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:45:55.312  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:46:25.317  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:46:55.323  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:47:25.327  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:47:55.335  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:48:25.362  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:48:55.375  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:49:25.383  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:49:55.388  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:50:25.394  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:50:55.408  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:51:25.414  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:51:55.420  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:52:25.428  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:52:55.433  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:53:25.439  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:53:55.443  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:54:25.449  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      2023-07-10 06:54:55.456  - error: hm-rega.0 (8605) ReGaHSS 192.168.100.6 down
      O
      oscool90
      @sigi234 Node 20.4.0, NPM 9.7.2
      O
      oscool90
    • hm-rega down nach Umzug
      erstmal ein großes Dankeschön an die diversen gut dokumentierten Fragestellungen anderer Threads, die mir sehr weitergeholfen haben! Nun komme ich leider an meine Grenzen...
      Mein Setup: IObroker auf Pi4 mit Homematic-Funkmodul HM-MOD-RPI-PCB, pivCCU3, Adapter hm-rega und hm-rpc, Steuerung (geplant) via NodeRed und IObroker-Objekte der Homematic-IP-Geräte
      Das System habe ich gerade neu aufgesetzt. Vorher lief es auf einem Pi3, muste aber wegen zu wenig RAM auf den Pi4 umziehen. Nach Einspielen des Backups über Backitup geht zwar hm-rpc, aber hm-rega meldet "error -- ReGaHSS 192.168.100.6 down" (Instanz ist gelb). Wie bekomme ich das gelöst?
      Die Weboberfläche der CCU ist über die obige IP erreichbar und die verbundenen Geräte lassen sich darüber manuell ansprechen. Der Pi/IObroker hat die IP 192.168.100.7. Den ReGa-Adapter habe ich versuchsweise gelöscht und neu installiert. Die Adapter-Einstellungen habe ich geprüft, ebenso die Firewall der CCU (da bin mir aber nicht 100% sicher). Kann mir jemand bei der weiteren Fehlersuche helfen?
      Grüße
      O
      oscool90
