    2. Gallemann
    G
    • Posts 6
    Gallemann
    @Gallemann
    Gallemann Follow
    Latest posts made by Gallemann
    • RE: Gelöst: Update Tradfri auf Version 1.2.1
      ja..
      G
      Gallemann
      npm i iobroker.tradfri –production --unsafe-perm
      hat leider wieder nicht geklappt
      ` > PS C:\iobroker> npm i iobroker.tradfri –production --unsafe-perm
      npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
      npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
      npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp-github
      npm ERR! path C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
      npm ERR! code ENOENT
      npm ERR! errno -4058
      npm ERR! syscall access
      npm ERR! enoent ENOENT: no such file or directory, access 'C:\iobroker\node_modules\node-aead-crypto\node_modules\nan'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! C:\Users\Gallemann\AppData\Roaming\npm-cache_logs\2018-05-10T16_01_14_205Z-debug.log `
      G
      Gallemann
      heute komplett neu installiert leider immer noch nicht… soll wohl nicht bei mir sein
      $ ./iobroker add tradfri
      npm install iobroker.tradfri --production --prefix "c:/ioBroker" (System call)
      npm WARN invalid config loglevel="notice"
      npm
       WARN deprecated
      node-pre-gyp WARN Pre-built binaries not installable for node-aead-crypto@1.1.3 and node@8.11.1 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error ENOTDIR: Cannot cd into 'c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64'
      gyp
      ERR! configure error
      gyp
      ERR!
      stack
       Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp
      ERR!
       stack
           at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)
      gyp
      ERR!
      stack
           at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
      gyp
      ERR!
      stack
           at FSReqWrap.oncomplete (fs.js:152:21)
      gyp
      ERR!
      System
       Windows_NT 10.0.16299
      gyp
      ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp
      ERR!
      cwd c:\ioBroker\node_modules\node-aead-crypto
      gyp ERR! node -v
       v8.11.1
      gyp
      ERR!
       node-gyp -v
       v3.6.2gyp ERR!
      not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp
      ERR!
      stack
       Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)
      node-pre-gyp
      ERR!
       stack
           at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
      node-pre-gyp ERR! stack
           at emitTwo (events.js:126:13)
      node-pre-gyp
      ERR!
      stack     at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR!
      stack
           at maybeClose (internal/child_process.js:925:16)
      node-pre-gyp
      ERR!
      stack
           at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      node-pre-gyp
      ERR!
      System
      node-pre-gyp
      ERR!
      command
       "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR!
      cwd
      node-pre-gyp
      ERR!
      node -v
       v8.11.1
      node-pre-gyp
      ERR!
      node-pre-gyp -v
       v0.9.1
      node-pre-gyp
      ERR!
       not ok
      npm
      ERR!
      npm
       ERR! argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "run" "install:default"
      npm
      ERR!
      node v8.11.1npm ERR!
      npm
       v2.15.12
      npm
       ERR!
       code ELIFECYCLE
      npm
      ERR!
       node-aead-crypto@1.1.3 install:default: `node-pre-gyp install --fallback-to-build`
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm
      ERR! Failed at the node-aead-crypto@1.1.3 install:default script 'node-pre-gyp install --fallback-to-build'.npm
      ERR! This is most likely a problem with the node-aead-crypto package,npm
      ERR!
       not with npm itself.
      npm
      ERR!
       Tell the author that this fails on your system:
      npm ERR!     node-pre-gyp install --fallback-to-build
      npm
      ERR!
       You can get information on how to open an issue for this project with:
      npm
      ERR!
           npm bugs node-aead-crypto
      npm
      ERR! Or if that isn't available, you can get their info via:
      npm
      ERR!
      npm
      ERR!
           npm owner ls node-aead-crypto
      npm
       ERR!
       There is likely additional logging output above.
      npm
      ERR!
       Please include the following file with any support request:
      npm
      ERR!
           c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
      child_process.js:644
          throw err;
      Error: Command failed: npm run install:default
          at checkExecSyncError (child_process.js:601:13)
          at execSync (child_process.js:641:13)
          at Object. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\lib\install.js:22:1)
          at Module._compile (module.js:652:30)
          at Object.Module._extensions..js (module.js:663:10)
          at Module.load (module.js:565:32)
          at tryModuleLoad (module.js:505:12)
          at Function.Module._load (module.js:497:3)
          at Function.Module.runMain (module.js:693:10)
          at startup (bootstrap_node.js:188:16)
      npm
       ERR! Windows_NT 10.0.16299
      npm
      ERR!
      argv
       "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
      npm
      ERR!
      node
       v8.11.1
      npm
      ERR!
       npm
       v2.15.12
      npm
      ERR!
      code ELIFECYCLE
      npm
      ERR!
       node-aead-crypto@1.1.3 install: `node lib/install.js`
      npm
      ERR!
       Exit status 1
      npm ERR!
      npm
      ERR!
       Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
      npm
      ERR!
      npm
      ERR!
       Tell the author that this fails on your system:npm ERR!
           node lib/install.js
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm ERR!
      npm
       ERR!
      npm
      ERR!
      npm ERR!
      npm
      ERR!
           c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
      npm
      ERR!
      code
       ELIFECYCLE
      npm
      ERR!
      errno
      npm
      ERR!
       node-dtls-client@0.5.4 install: `node install/postinstall.js`
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm ERR! Failed at the node-dtls-client@0.5.4 install script.npm ERR!
       This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm
      ERR!
           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_22_42_185Z-debug.log
      host.Gallemann-PC install adapter tradfri
      npm
      gyp
      ERR!
      configure error
      gyp
      ERR!
      stack
      gyp
      ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp
      ERR!
      stack
      gyp
      ERR!
      stack
      gyp
      ERR!
      stack
      gyp
      ERR!
      System
      gyp
      ERR!
      command
       "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp ERR!
      cwd
       c:\ioBroker\node_modules\node-aead-cryptogyp ERR!
      node -v
       v8.11.1
      gyp ERR! node-gyp -v v3.6.2gyp ERR!
      not ok
      node-pre-gyp
      ERR!
      build error
      node-pre-gyp
      ERR!
       stack
       Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
      stack
           at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp
       ERR!
      stack
      node-pre-gyp
       ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
       ERR! System Windows_NT 10.0.16299
      node-pre-gyp
       ERR!
       command
       "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
      ERR!
      cwd
      node-pre-gyp
      ERR!
      node -v
       v8.11.1
      node-pre-gyp
      ERR!
      node-pre-gyp -v
       v0.9.1
      node-pre-gyp ERR! not ok
      npm
      ERR!
      npm
      ERR!
      argv
      npm
      ERR!
      node
       v8.11.1
      npm
       ERR! npm  v2.15.12
      npm
      ERR!
      code
       ELIFECYCLE
      npm
      ERR!
      npm
       ERR! Exit status 1
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR! not with npm itself.
      npm
      ERR!
      npm
      ERR!
      npm
      ERR! You can get information on how to open an issue for this project with:
      npm
      ERR!
      npm ERR! Or if that isn't available, you can get their info via:
      npm
      ERR!
      npm
       ERR!
           npm owner ls node-aead-cryptonpm
      ERR!
      npm
      ERR!
      npm ERR!     c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
          throw err;
      npm
      ERR!
      npm
       ERR! argv
      npm
      ERR! node v8.11.1
      npm
      ERR!
       npm  v2.15.12
      npm
       ERR!
      code
       ELIFECYCLE
      npm
      ERR!
      npm
      ERR!
       Exit status 1
      npm
      ERR!
       npm ERR! Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
      npm
      ERR!
      npm
      ERR!
      npm
      ERR! Tell the author that this fails on your system:
      npm ERR!
           node lib/install.js
      npm
       ERR!
       You can get information on how to open an issue for this project with:npm
      ERR!
      npm
      ERR!
      npm
      ERR! npm
      ERR!
      npm
      ERR! There is likely additional logging output above.
      npm
      ERR!
      npm ERR!     c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
      npm
       ERR! code ELIFECYCLE
      npm
      ERR!
      errno
      npm
       ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
      npm
      ERR!
      npm
      ERR!
      ERR!
      ERR!
           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_18_890Z-debug.log
      npm
      npm
       WARN deprecated
      gyp
      ERR!
      configure error
      gyp
      ERR!
      stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
      gyp
      ERR!
       stack
      gyp
       ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp
      ERR!
      stack
      gyp
      ERR! System Windows_NT 10.0.16299gyp
      ERR!
      command
      gyp
      ERR!
      gyp ERR! node -v
       v8.11.1
      gyp
      ERR!
      node-gyp -v
       v3.6.2
      gyp
      ERR!
      not ok
      node-pre-gyp
      ERR!
      build error
      node-pre-gyp
      ERR!
      stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
       ERR! stack     at maybeClose (internal/child_process.js:925:16)node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      System
      node-pre-gyp
      ERR!
      command "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp
      ERR! cwd
      node-pre-gyp
      ERR!
      node -v
       v8.11.1
      node-pre-gyp
      ERR!
      node-pre-gyp -v
       v0.9.1
      node-pre-gyp
      ERR!
      not ok
      npm
      ERR!
      npm
      npm
      ERR! node
       v8.11.1
      npm
      ERR!
      npm
       v2.15.12
      npm
       ERR!
       code ELIFECYCLE
      npm
      ERR!
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm
      ERR!
      npm
       ERR!
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
          throw err;
      npm
      npm
      ERR!
      argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
      npm ERR! node v8.11.1
      npm
      ERR!
      npm
       v2.15.12
      npm
      npm
      ERR!
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm
       ERR!
      npm
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
           node lib/install.js
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
       ERR!
       code ELIFECYCLE
      npm
      ERR!
       errno 1
      npm
      ERR!
      npm
       ERR!
       Exit status 1
      npm
      ERR!
       npm
      ERR!
           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_53_017Z-debug.log
      ERROR: host.Gallemann-PC Cannot install tradfri
      ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      G
      Gallemann
      @AlCalzone:
      Jetzt hast du doch 6.0.0, das ist >= 5.7.1. Müsste also gehen?! `
      Leider nein.. bekomme es nicht drauf
      Fertig mit Fehler: host.Gallemann-PC Cannot install tradfri
      G
      Gallemann
      jetzt bekomme ich diesen fehler
      NPM version: 5.6.0
      ERROR: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!NPM 5 is only supported starting with version 5.7.1!
      Please use "npm install -g npm@4" to downgrade npm to 4.x or
      use "npm install -g npm@>=5.7.1" to install a supported version of npm 5!
      You need to make sure to repeat this step after installing an update to NodeJS and/or npm
      ERROR: process exited with code 25
      aber wenn ich npm -v eingebe bekomme ich version 6.0.0
      c:\ioBroker>npm install -g npm@>=5.7.1
      c:\ioBroker>npm -v
      6.0.0
      c:\ioBroker>
      welche eingabe müsste ich eingeben das ich ihn installiert bekomme
      G
      Gallemann
      ich bekomme diese Fehler meldung .. könnte mir jemand sagen was ich machen müsste
      Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
      npm
      npm
       WARN deprecated
      gyp
      ERR!
      configure error
      gyp
       ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp
      ERR!
      stack
      gyp
      ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)gyp
      ERR!
      stack
      gyp
      ERR!
      stack
      gyp
      ERR!
      System
      gyp
      ERR!
      command
      gyp
      ERR!
      cwd
      gyp
      ERR!
      node -v
       v8.11.1
      gyp
      ERR!
      node-gyp -v
       v3.6.2
      gyp
      ERR!
       not ok
      node-pre-gyp
      ERR! build error
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
       stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      stack
      node-pre-gyp
      ERR!
      System
      node-pre-gyp
      ERR!
      command
      node-pre-gyp
      ERR!
      cwd
      node-pre-gyp
      ERR!
      node -v
       v8.11.1
      node-pre-gyp
      ERR!
      node-pre-gyp -v
       v0.9.1
      node-pre-gyp
      ERR!
      not ok
      npm
      ERR!
      npm
      ERR!
      argv
      npm
      ERR!
      node
       v8.11.1
      npm
      ERR!
      npm
       v2.15.12
      npm
      ERR!
      code
       ELIFECYCLE
      npm
      ERR!
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
          throw err;
      npm
      npm
      ERR!
      argv
      npm
      ERR!
      node
       v8.11.1
      npm
      ERR!
      npm
       v2.15.12
      npm
      ERR!
      code
       ELIFECYCLE
      npm
      ERR!
      npm
      ERR!
       Exit status 1
      npm
      ERR!
      npm
       ERR!
      npm
      ERR! This is most likely a problem with the node-aead-crypto package,npm ERR!
      npm
      ERR!
      npm
      ERR!
           node lib/install.js
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm ERR!
      npm
      ERR!
      npm ERR!
      npm
      ERR!
      npm
      ERR!
      code ELIFECYCLE
      npm
      ERR!
      errno
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-05T09_26_14_900Z-debug.log
      host.Gallemann-PC create instance tradfri
      ERROR: host.Gallemann-PC error: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
      ERROR: process exited with code 20</anonymous></anonymous></anonymous>
      G
      Gallemann
