    2. michi_rosenbuehl
    • Posts 6
    michi_rosenbuehl
    @michi_rosenbuehl
    michi_rosenbuehl Follow
    Latest posts made by michi_rosenbuehl
    • RE: [Adapter] ValloxMV Steuerung Lüftungsanlagen der Fa. Vallox
      @feuersturm
      Dann geht es 🤗
      Danke für den Hinweis!
      @hacki11
      ursprünglicher Wert
      geänderter Wert
      aktualisierter Wert
      michi_rosenbuehl
      @hacki11
      Das lässt sich leider auch nicht setzen bzw. wird wieder zurück gesetzt.
      @Feuersturm
      valloxmv.0
      	2023-01-07 05:48:17.143	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.141	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIME changed: 15 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.139	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.135	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_EXTR_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.132	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_SUPP_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.127	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.113	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIME changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.112	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.110	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.107	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_SPEED_SETTING changed: 100 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.105	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.104	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.104	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.101	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_SPEED_SETTING changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.098	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.097	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.094	debug	state valloxmv.0.profiles.home.A_CYC_HOME_AIR_TEMP_TARGET changed: 22 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.094	debug	state valloxmv.0.profiles.home.A_CYC_HOME_SPEED_SETTING changed: 73 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.088	debug	state valloxmv.0.profiles.home.A_CYC_HOME_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.087	debug	state valloxmv.0.profiles.home.A_CYC_HOME_RH_CTRL_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.083	debug	state valloxmv.0.A_CYC_BYPASS_LOCKED changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.082	debug	state valloxmv.0.A_CYC_SUPP_FAN_BALANCE_BASE changed: 61 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.078	debug	state valloxmv.0.A_CYC_EXTR_FAN_BALANCE_BASE changed: 69 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.077	debug	state valloxmv.0.A_CYC_OPT_TEMP_SENSOR_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.076	debug	state valloxmv.0.A_CYC_SUPPLY_HEATING_ADJUST_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.073	debug	state valloxmv.0.A_CYC_RH_LEVEL_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.072	debug	state valloxmv.0.A_CYC_TOTAL_FAULT_COUNT changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.068	debug	state valloxmv.0.A_CYC_REMAINING_TIME_FOR_FILTER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.068	debug	state valloxmv.0.A_CYC_TOTAL_UP_TIME_HOURS changed: 8194 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.067	debug	state valloxmv.0.A_CYC_CELL_STATE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.066	debug	state valloxmv.0.A_CYC_DEFROSTING changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.057	debug	state valloxmv.0.A_CYC_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.057	debug	state valloxmv.0.A_CYC_ANALOG_SENSOR_INPUT changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.055	debug	state valloxmv.0.A_CYC_CO2_VALUE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.049	debug	state valloxmv.0.A_CYC_RH_VALUE changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.044	debug	state valloxmv.0.A_CYC_SUPP_FAN_SPEED changed: 1000 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.043	debug	state valloxmv.0.A_CYC_EXTR_FAN_SPEED changed: 1069 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.042	debug	state valloxmv.0.A_CYC_CO2_THRESHOLD changed: 1900 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.041	debug	state valloxmv.0.A_CYC_CO2_LEVEL changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.033	debug	state valloxmv.0.A_CYC_RH_LEVEL changed: 1 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.033	debug	state valloxmv.0.A_CYC_RH_BASIC_LEVEL changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.031	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_AIR changed: 21.15 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.030	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_CELL_AIR changed: 21.07 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.025	debug	state valloxmv.0.A_CYC_TEMP_OUTDOOR_AIR changed: 8.73 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.021	debug	state valloxmv.0.A_CYC_TEMP_EXHAUST_AIR changed: 11.99 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.019	debug	state valloxmv.0.A_CYC_TEMP_EXTRACT_AIR changed: 21.63 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.010	debug	state valloxmv.0.A_CYC_FAN_SPEED changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.009	debug	state valloxmv.0.A_CYC_MACHINE_MODEL changed: 7 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.008	debug	state valloxmv.0.A_CYC_MACHINE_TYPE changed: 3 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.007	debug	state valloxmv.0.A_CYC_SERIAL_NUMBER changed: 1725058885 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.006	debug	state valloxmv.0.A_CYC_IP_ADDRESS changed: 192.168.2.31 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:17.003	debug	state valloxmv.0.A_CYC_APPL_SW_VERSION changed: 2.0.14 (ack = true)
      valloxmv.0
      	2023-01-07 05:48:16.877	debug	state valloxmv.0.ACTIVE_PROFILE changed: 2 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.674	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.671	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIME changed: 15 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.668	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.665	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_EXTR_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.663	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_SUPP_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.661	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.655	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIME changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.652	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.649	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.646	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_SPEED_SETTING changed: 100 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.643	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.641	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.637	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.634	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_SPEED_SETTING changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.630	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.627	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.623	debug	state valloxmv.0.profiles.home.A_CYC_HOME_AIR_TEMP_TARGET changed: 22 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.620	debug	state valloxmv.0.profiles.home.A_CYC_HOME_SPEED_SETTING changed: 73 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.617	debug	state valloxmv.0.profiles.home.A_CYC_HOME_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.614	debug	state valloxmv.0.profiles.home.A_CYC_HOME_RH_CTRL_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.611	debug	state valloxmv.0.A_CYC_BYPASS_LOCKED changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.608	debug	state valloxmv.0.A_CYC_SUPP_FAN_BALANCE_BASE changed: 61 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.606	debug	state valloxmv.0.A_CYC_EXTR_FAN_BALANCE_BASE changed: 69 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.602	debug	state valloxmv.0.A_CYC_OPT_TEMP_SENSOR_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.600	debug	state valloxmv.0.A_CYC_SUPPLY_HEATING_ADJUST_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.596	debug	state valloxmv.0.A_CYC_RH_LEVEL_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.593	debug	state valloxmv.0.A_CYC_TOTAL_FAULT_COUNT changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.585	debug	state valloxmv.0.A_CYC_REMAINING_TIME_FOR_FILTER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.582	debug	state valloxmv.0.A_CYC_TOTAL_UP_TIME_HOURS changed: 8194 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.578	debug	state valloxmv.0.A_CYC_CELL_STATE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.575	debug	state valloxmv.0.A_CYC_DEFROSTING changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.570	debug	state valloxmv.0.A_CYC_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.567	debug	state valloxmv.0.A_CYC_ANALOG_SENSOR_INPUT changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.561	debug	state valloxmv.0.A_CYC_CO2_VALUE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.557	debug	state valloxmv.0.A_CYC_RH_VALUE changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.554	debug	state valloxmv.0.A_CYC_SUPP_FAN_SPEED changed: 1001 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.550	debug	state valloxmv.0.A_CYC_EXTR_FAN_SPEED changed: 1068 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.546	debug	state valloxmv.0.A_CYC_CO2_THRESHOLD changed: 1900 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.543	debug	state valloxmv.0.A_CYC_CO2_LEVEL changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.541	debug	state valloxmv.0.A_CYC_RH_LEVEL changed: 1 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.538	debug	state valloxmv.0.A_CYC_RH_BASIC_LEVEL changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.532	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_AIR changed: 21 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.529	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_CELL_AIR changed: 21.24 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.525	debug	state valloxmv.0.A_CYC_TEMP_OUTDOOR_AIR changed: 8.73 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.522	debug	state valloxmv.0.A_CYC_TEMP_EXHAUST_AIR changed: 12.05 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.518	debug	state valloxmv.0.A_CYC_TEMP_EXTRACT_AIR changed: 21.58 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.515	debug	state valloxmv.0.A_CYC_FAN_SPEED changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.511	debug	state valloxmv.0.A_CYC_MACHINE_MODEL changed: 7 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.508	debug	state valloxmv.0.A_CYC_MACHINE_TYPE changed: 3 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.503	debug	state valloxmv.0.A_CYC_SERIAL_NUMBER changed: 1725058885 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.499	debug	state valloxmv.0.A_CYC_IP_ADDRESS changed: 192.168.2.31 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.496	debug	state valloxmv.0.A_CYC_APPL_SW_VERSION changed: 2.0.14 (ack = true)
      valloxmv.0
      	2023-01-07 05:47:25.492	debug	state valloxmv.0.ACTIVE_PROFILE changed: 2 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.943	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.943	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIME changed: 15 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.934	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.933	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_EXTR_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.932	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_SUPP_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.928	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.921	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIME changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.921	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.921	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.920	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_SPEED_SETTING changed: 100 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.920	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.919	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.919	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.919	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_SPEED_SETTING changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.918	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.918	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.917	debug	state valloxmv.0.profiles.home.A_CYC_HOME_AIR_TEMP_TARGET changed: 22 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.917	debug	state valloxmv.0.profiles.home.A_CYC_HOME_SPEED_SETTING changed: 73 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.916	debug	state valloxmv.0.profiles.home.A_CYC_HOME_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.916	debug	state valloxmv.0.profiles.home.A_CYC_HOME_RH_CTRL_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.915	debug	state valloxmv.0.A_CYC_BYPASS_LOCKED changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.914	debug	state valloxmv.0.A_CYC_SUPP_FAN_BALANCE_BASE changed: 61 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.913	debug	state valloxmv.0.A_CYC_EXTR_FAN_BALANCE_BASE changed: 69 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.865	debug	state valloxmv.0.A_CYC_OPT_TEMP_SENSOR_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.864	debug	state valloxmv.0.A_CYC_SUPPLY_HEATING_ADJUST_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.864	debug	state valloxmv.0.A_CYC_RH_LEVEL_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.863	debug	state valloxmv.0.A_CYC_TOTAL_FAULT_COUNT changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.862	debug	state valloxmv.0.A_CYC_REMAINING_TIME_FOR_FILTER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.862	debug	state valloxmv.0.A_CYC_TOTAL_UP_TIME_HOURS changed: 8193 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.861	debug	state valloxmv.0.A_CYC_CELL_STATE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.860	debug	state valloxmv.0.A_CYC_DEFROSTING changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.839	debug	state valloxmv.0.A_CYC_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.838	debug	state valloxmv.0.A_CYC_ANALOG_SENSOR_INPUT changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.838	debug	state valloxmv.0.A_CYC_CO2_VALUE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.837	debug	state valloxmv.0.A_CYC_RH_VALUE changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.836	debug	state valloxmv.0.A_CYC_SUPP_FAN_SPEED changed: 1010 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.830	debug	state valloxmv.0.A_CYC_EXTR_FAN_SPEED changed: 1067 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.830	debug	state valloxmv.0.A_CYC_CO2_THRESHOLD changed: 1900 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.829	debug	state valloxmv.0.A_CYC_CO2_LEVEL changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.829	debug	state valloxmv.0.A_CYC_RH_LEVEL changed: 1 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.828	debug	state valloxmv.0.A_CYC_RH_BASIC_LEVEL changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.828	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_AIR changed: 21.13 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.827	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_CELL_AIR changed: 21.09 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.826	debug	state valloxmv.0.A_CYC_TEMP_OUTDOOR_AIR changed: 8.67 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.826	debug	state valloxmv.0.A_CYC_TEMP_EXHAUST_AIR changed: 12.03 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.825	debug	state valloxmv.0.A_CYC_TEMP_EXTRACT_AIR changed: 21.6 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.817	debug	state valloxmv.0.A_CYC_FAN_SPEED changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.816	debug	state valloxmv.0.A_CYC_MACHINE_MODEL changed: 7 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.781	debug	state valloxmv.0.A_CYC_MACHINE_TYPE changed: 3 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.780	debug	state valloxmv.0.A_CYC_SERIAL_NUMBER changed: 1725058885 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.777	debug	state valloxmv.0.A_CYC_IP_ADDRESS changed: 192.168.2.31 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.776	debug	state valloxmv.0.A_CYC_APPL_SW_VERSION changed: 2.0.14 (ack = true)
      valloxmv.0
      	2023-01-07 05:46:16.745	debug	state valloxmv.0.ACTIVE_PROFILE changed: 2 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:30.875	debug	state valloxmv.0.A_CYC_EXTR_FAN_BALANCE_BASE changed: 70 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.951	debug	state valloxmv.0.info.connection changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.949	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.946	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIME changed: 15 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.943	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.940	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_EXTR_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.935	debug	state valloxmv.0.profiles.fireplace.A_CYC_FIREPLACE_SUPP_FAN changed: 50 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.932	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.871	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIME changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.869	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_TIMER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.867	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.866	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_SPEED_SETTING changed: 100 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.863	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.861	debug	state valloxmv.0.profiles.boost.A_CYC_BOOST_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.860	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_AIR_TEMP_TARGET changed: 20 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.856	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_SPEED_SETTING changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.855	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.851	debug	state valloxmv.0.profiles.away.A_CYC_AWAY_RH_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.847	debug	state valloxmv.0.profiles.home.A_CYC_HOME_AIR_TEMP_TARGET changed: 22 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.846	debug	state valloxmv.0.profiles.home.A_CYC_HOME_SPEED_SETTING changed: 73 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.842	debug	state valloxmv.0.profiles.home.A_CYC_HOME_CO2_CTRL_ENABLED changed: false (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.838	debug	state valloxmv.0.profiles.home.A_CYC_HOME_RH_CTRL_ENABLED changed: true (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.838	debug	state valloxmv.0.A_CYC_BYPASS_LOCKED changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.833	debug	state valloxmv.0.A_CYC_SUPP_FAN_BALANCE_BASE changed: 61 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.830	debug	state valloxmv.0.A_CYC_EXTR_FAN_BALANCE_BASE changed: 69 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.827	debug	state valloxmv.0.A_CYC_OPT_TEMP_SENSOR_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.822	debug	state valloxmv.0.A_CYC_SUPPLY_HEATING_ADJUST_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.819	debug	state valloxmv.0.A_CYC_RH_LEVEL_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.816	debug	state valloxmv.0.A_CYC_TOTAL_FAULT_COUNT changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.811	debug	state valloxmv.0.A_CYC_REMAINING_TIME_FOR_FILTER changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.808	debug	state valloxmv.0.A_CYC_TOTAL_UP_TIME_HOURS changed: 8193 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.805	debug	state valloxmv.0.A_CYC_CELL_STATE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.801	debug	state valloxmv.0.A_CYC_DEFROSTING changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.798	debug	state valloxmv.0.A_CYC_MODE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.795	debug	state valloxmv.0.A_CYC_ANALOG_SENSOR_INPUT changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.792	debug	state valloxmv.0.A_CYC_CO2_VALUE changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.789	debug	state valloxmv.0.A_CYC_RH_VALUE changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.788	debug	state valloxmv.0.A_CYC_SUPP_FAN_SPEED changed: 1000 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.783	debug	state valloxmv.0.A_CYC_EXTR_FAN_SPEED changed: 1068 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.780	debug	state valloxmv.0.A_CYC_CO2_THRESHOLD changed: 1900 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.776	debug	state valloxmv.0.A_CYC_CO2_LEVEL changed: 0 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.775	debug	state valloxmv.0.A_CYC_RH_LEVEL changed: 1 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.769	debug	state valloxmv.0.A_CYC_RH_BASIC_LEVEL changed: 47 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.768	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_AIR changed: 21.13 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.763	debug	state valloxmv.0.A_CYC_TEMP_SUPPLY_CELL_AIR changed: 20.98 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.762	debug	state valloxmv.0.A_CYC_TEMP_OUTDOOR_AIR changed: 8.59 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.760	debug	state valloxmv.0.A_CYC_TEMP_EXHAUST_AIR changed: 12.11 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.751	debug	state valloxmv.0.A_CYC_TEMP_EXTRACT_AIR changed: 21.48 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.750	debug	state valloxmv.0.A_CYC_FAN_SPEED changed: 32 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.744	debug	state valloxmv.0.A_CYC_MACHINE_MODEL changed: 7 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.743	debug	state valloxmv.0.A_CYC_MACHINE_TYPE changed: 3 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.738	debug	state valloxmv.0.A_CYC_SERIAL_NUMBER changed: 1725058885 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.737	debug	state valloxmv.0.A_CYC_IP_ADDRESS changed: 192.168.2.31 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.735	debug	state valloxmv.0.A_CYC_APPL_SW_VERSION changed: 2.0.14 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.691	debug	state valloxmv.0.ACTIVE_PROFILE changed: 2 (ack = true)
      valloxmv.0
      	2023-01-07 05:45:16.689	info	Connection established successfully
      valloxmv.0
      	2023-01-07 05:45:16.517	info	Establish connection to ValloxMV (192.168.2.31:80)
      valloxmv.0
      	2023-01-07 05:45:16.481	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.valloxmv, node: v14.21.1, js-controller: 4.0.23
      valloxmv.0
      	2023-01-07 05:45:16.281	debug	States connected to redis: 127.0.0.1:9000
      valloxmv.0
      	2023-01-07 05:45:16.267	debug	States create User PubSub Client
      valloxmv.0
      	2023-01-07 05:45:16.266	debug	States create System PubSub Client
      valloxmv.0
      	2023-01-07 05:45:16.255	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      valloxmv.0
      	2023-01-07 05:45:16.231	debug	Objects connected to redis: 127.0.0.1:9001
      valloxmv.0
      	2023-01-07 05:45:16.224	debug	Objects client initialize lua scripts
      valloxmv.0
      	2023-01-07 05:45:16.199	debug	Objects create User PubSub Client
      valloxmv.0
      	2023-01-07 05:45:16.197	debug	Objects create System PubSub Client
      valloxmv.0
      	2023-01-07 05:45:16.188	debug	Objects client ready ... initialize now
      valloxmv.0
      	2023-01-07 05:45:16.060	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      valloxmv.0
      	2023-01-07 05:45:11.679	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      valloxmv.0
      	2023-01-07 05:45:11.677	info	terminating
      valloxmv.0
      	2023-01-07 05:45:11.676	info	cleaned everything up...
      valloxmv.0
      	2023-01-07 05:45:11.673	info	Got terminate signal TERMINATE_YOURSELF
      michi_rosenbuehl
      @feuersturm
      auch bei numerischer Eingabe bleibt das Verhalten identisch.
      michi_rosenbuehl
      @feuersturm
      ACTIVE_PROFILE zum Umschalten der Parameter
      der Wert leuchtet auch kurz grün auf in der Objektübersicht.
      Mit der nächsten Aktualisierung steht aber wieder der alte Wert im Objekt.
      michi_rosenbuehl
      ich habe auch ein Gerät von Vallox (ValloPlus 510 MV).
      Ich habe den Adapter installiert und es konnte eine Verbindung aufgebaut werden.
      Es werden auch die Aktualdaten ausgelesen.
      Jedoch ist ein setzen der Betriebsmodi oder anderer schreibbarer Werte nicht möglich.
      Das Thema mit dem "Bestätigten Werten" ist mir bekannt.
      Gibt es eine Einstellung am Gerät, welche die Fernsteuerung womöglich unterbindet?
      Michael
      michi_rosenbuehl
    • RE: Modbus adapter
      ich habe aktuell auch einen ähnlichen Anwendungsfall wie du.
      Ich möchte der Wärmepumpe die IST-Leistung am Einspeisepunkt vorgeben ohne einen extra Zähler mit Modbus-Interface nur für die WP zu setzen.
      Kannst du bei Gelegenheit bitte noch die Einstellungen vom Waveshare Gateway hier bekannt machen?
      Ich bin leider noch nicht so weit, dass eine Kommunikation zwischen IObroker und Gateway besteht.
      Michael
      michi_rosenbuehl
