Alles neuinstallieren hat funktioniert. DANKE für die Unterstützung!
Latest posts made by schoetju
RE: Neuinstallation auf RPI3 mit CURL-Installer geht schief
@thomas-braun sagte in Neuinstallation auf RPI3 mit CURL-Installer geht schief:
Mach es trotzdem neu.
Was meinst Du genau?
Wie schon erwähnt - ein erneutes
pi@smartpi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installer! Installer version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye-updates InRelease Hit:3 http://security.debian.org/debian-security bullseye-security InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease Reading package lists... Done Changing npm registry to https://registry.npmjs.org Installed gcc-c++ ========================================================================== Creating ioBroker user and directory (2/4) ========================================================================== Created /etc/sudoers.d/iobroker Directory /opt/iobroker created ========================================================================== Installing ioBroker (3/4) ========================================================================== npm ERR! code 6 npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller npm ERR! command failed npm ERR! command sh -c node iobroker.js setup first npm ERR! Cannot check config file: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input npm ERR! Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input npm ERR! at JSON.parse (<anonymous>) npm ERR! at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17) npm ERR! at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23) npm ERR! at setupObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:252:9) npm ERR! at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1140:13) npm ERR! at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23) npm ERR! at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5) npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1105:14) npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-07-23T14_37_36_347Z-debug-0.log ========================================================================== Finalizing installation (4/4) ========================================================================== Enabling autostart... Autostart enabled! Fixing directory permissions... ========================================================================== ioBroker was installed successfully Open http://192.168.134.32:8081 in a browser and start configuring! ========================================================================== You need to re-login before doing anything else on the console!
sieht so aus.
Oder meinst Du, ich soll auch das Betriebssystem neuinstallieren?
Installation war als user pi - bzw. wenn ich das als user pi zum x.-ten Male wiederhole ändert sich nichts...War nur als root unterwegs, um nachzuschauen, wie die
aussieht... -
Ja, Internetzugriff funktioniert.Der Installationsfixer
curl -fsL https://iobroker.net/fix.sh | bash -
meint auch, dass alles in Ordnung sei.Aber
pi@smartpi:/opt/iobroker $ iobroker start pi@smartpi:/opt/iobroker $ iobroker status Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input at JSON.parse (<anonymous>) at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17) at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23) at CLIProcess.status (/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliProcess.js:203:9) at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:510:25) at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24) at Module._compile (node:internal/modules/cjs/loader:1105:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) at Module.load (node:internal/modules/cjs/loader:981:32)
ich hab vor rund einem Monat auf einem RPI3 mit SD-Karte iobroker erfolgreich installiert und genutzt (PV-Anlage plus Smartmeter gemonitort).
Das ganze macht einen guten Eindruck - und nun wird es Zeit die Installation auf eine Festplatte zu verschieben. Ansatz:
- Backup der Daten, Einstellungen, etc. (Backup-Iobroker-Instanz), um später rückzusichern...
- SD-Karte raus,
- neue Festplatte mit RaspberryPi OS 64Bit Lite bespielt
- an den RPI3 angestöpselt --> Nacktes Betriebssystem läuft
- sudo apt-get update && sudo apt-get upgrade
- Nun das IOBroker-Setup per
Das endet leider - trotz mehrfacher reboots, lesen von
https://www.iobroker.net/#de/documentation/install/linux.md
etc. immer noch mit folgender Fehlermeldung:========================================================================== Installing ioBroker (3/4) ========================================================================== npm ERR! code 6 npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller npm ERR! command failed npm ERR! command sh -c node iobroker.js setup first npm ERR! Cannot check config file: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input npm ERR! Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input npm ERR! at JSON.parse (<anonymous>) npm ERR! at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17) npm ERR! at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23) npm ERR! at setupObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:252:9) npm ERR! at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1140:13) npm ERR! at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23) npm ERR! at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5) npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1105:14) npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10) npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-07-23T13_50_41_078Z-debug-0.log ========================================================================== Finalizing installation (4/4) ========================================================================== Enabling autostart... Autostart enabled! Fixing directory permissions... ========================================================================== ioBroker was installed successfully Open http://192.168.xxx.xxx:8081 in a browser and start configuring! ========================================================================== You need to re-login before doing anything else on the console!
z.Info: Die erwähnte Datei iobroker.json - scheint ja irgendwie wichtig zu sein
- ist leer:
root@smartpi:/opt/iobroker/iobroker-data# ls iobroker.json -al -rw-rwxr--+ 1 iobroker iobroker 0 23. Jul 13:43 iobroker.json root@smartpi:/opt/iobroker/iobroker-data#
Die Installation vor rund 6 Wochen (auf SD-Karte) hab ich im Großen und Ganzen genauso gemacht - das lief wie geschmiert...
Wer kann sich darauf einen Reim machen und mir weiterhelfen?
Viele Grüße
schoetju
