    2. udo-2112
    U
    • Posts 11
    udo-2112
    @udo-2112
    udo-2112 Follow
    Latest posts made by udo-2112
    • RE: iobroker add ecovacs-deebot
      Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
      Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
      Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
      Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.182 kB]
      Get:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [175 kB]
      Get:7 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.592 B]
      Get:8 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [774 B]
      Fetched 8.573 kB in 5s (1.698 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      /usr/bin/nodejs
      /usr/bin/nodejs
      /usr/bin/which
      /usr/bin/node
      /usr/bin/node
      /usr/bin/which
      /usr/bin/npm
      /usr/bin/npm
      /usr/bin/apt
      /usr/bin/nodejs
      This upgrade of "discovery" will introduce the following changes:
      -> 3.0.5:
      Fix potential crash cases reported by Sentry
      -> 3.0.4:
      Disable configuration settings for this adapter
      Would you like to upgrade discovery from @3.0.3 to @3.0.5 now? [(y)es, (n)o]: y
      Update discovery from @3.0.3 to @3.0.5
      NPM version: 8.11.0
      Installing iobroker.discovery@3.0.5... (System call)
      host.Poxdorf Cannot install iobroker.discovery@3.0.5: 217
      Danke und Gruß Martin
      U
      udo-2112
      Hi, ```
      Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [175 kB]
      Get:6 http://deb.debian.org/debian bullseye/main amd64 Packages [8.182 kB]
      Get:7 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [774 B]
      Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.592 B]
      Fetched 8.573 kB in 6s (1.544 kB/s)
      Ich hab:
      v16.16.0
      leider immer noch code 25.
      Was kann ich denn noch tun?
      Danke und Gruß
      Martin
      U
      udo-2112
      @mrbungle64
      Hi, ja habe ich. Hab aber immer diverse Fehlermeldung:
      -> 3.0.5:
      -> 3.0.4:
      NPM version: 8.11.0
      Ich weiß nicht was hier bei mir falsch ist:
      PLATTFORM: DOCKER
      RAM: 15.5 GB
      NODE.JS: V16.15.1
      NPM: 8.11.0
      nodejs is already the newest version (16.15.1-deb-1nodesource1).
      Objects type: jsonl
      States  type: jsonl
      This upgrade of "telegram" will at least introduce the following changes:
      -> 1.13.0:
      Added Admin 5 UI config
      Added rule block for javascript as plugin
      -> 1.12.6:
      Fix crash cases reported by Sentry
      -> 1.12.5:
      -> 1.12.4:
      -> 1.12.3:
      Make sure also not set states can be queried - will return "State not set" in this case!
      -> 1.12.2:
      -> 1.12.0:
      Add new JSON states communication.responseJson and communication.responseSilentJson to also accept json structures (stringified!) to send messages
      Try to prevent adapter crashes when internet is not available
      Add Sentry for crash reporting
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade telegram from @0.0.0 to @1.13.0 now? [(y)es, (n)o]: y
      Update telegram from @0.0.0 to @1.13.0
      NPM version: 8.11.0
      Installing iobroker.telegram@1.13.0... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/concat-stream
      npm ERR! dest /opt/iobroker/node_modules/.concat-stream-0YCrXysM
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/concat-stream' -> '/opt/iobroker/node_modules/.concat-stream-0YCrXysM'
      npm ERR!     /opt/iobroker/.npm/_logs/2022-07-24T07_48_04_751Z-debug-0.log
      host.Poxdorf Cannot install iobroker.telegram@1.13.0: 217
      U
      udo-2112
      @mrbungle64
      Hi, ich kann einen Terminal öffnen. Da gibt es aber keinen Button für CodeTags. Wie könnte ich meinen 25er Fehler denn beheben?
      Danke und Gruß Martin.
      U
      udo-2112
      Hi, ich habe ein solches Feld nicht. Ich gebe die Befehle im Docker in die Container Station ein. Gibt es noch eine andere Möglichkeit?
      Gruß Martin
      U
      udo-2112
      Ich dachte es muss so aussehen:
      echad@chet:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.1
      echad
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://repos.influxdata.com/debian bullseye InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Hit:7 https://deb.nodesource.com/node_12.x bullseye InRelease
      Hit:8 https://deb.nodesource.com/node_14.x bullseye InRelease
      Hit:9 https://deb.nodesource.com/node_16.x bullseye InRelease
      Was heißt in CodeTags einbetten? Wie geht das?
      Gruß Martin
      U
      udo-2112
      Danke dir. Hab ich gerade gemacht.
      Schaut bei mir aber anders aus.
      Nach: sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      Noch paar Infos zum Setup, kenne mich leider nicht so gut aus:
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "hue"          : 3.7.0    , installed 3.7.0
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "onvif"        : 0.4.4    , installed 0.4.4
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Gruß Martin
      U
      udo-2112
      @mrbungle64 said in iobroker add ecovacs-deebot:
      Node.js
      hab ich erledigt, geht leider immer noch nicht:
      PLATTFORM: DOCKER
      RAM: 15.5 GB
      NODE.JS: V16.15.1
      NPM: 8.11.0
      Gruß Martin
      U
      udo-2112
      Hallo, bei der Installation habe ich das folgende Problem:
      ERROR: Process exited with code 25
      weniger
      mehr
      $ iobroker add ecovacs-deebot --host XXXXXXXX
      NPM version: 8.11.0
      Installing iobroker.ecovacs-deebot@1.4.4... (System call)
      host.Poxdorf Cannot install iobroker.ecovacs-deebot@1.4.4: 217
      Wie kann ich dies lösen?
      Danke und Gruß
      Martin
      U
      udo-2112
    • iobroker add ecovacs-deebot
      Systemdata Bitte Ausfüllen
      Hardwaresystem: QNAP TS-253A
      Arbeitsspeicher: 16GB
      Festplattenart: HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      U
      udo-2112
