Vielen Dank für die rasche Antwort.
Ich hoffe nicht, dass es mal einen richtigen Alarm gibt - falls doch lasse ich dir die Daten zukommen.
Ich habe heute geschaut jedoch noch keine neue Version gefunden. Werde es am Wochenende nochmals versuchen.
Anbei auch die Ereignisse:
"events": [
"id": "035e569c4502721828a47594c9b28db2e7498aef",
"state": "ok",
"ts": "1656661763179",
"type": "end_sd01_test",
"o": {
"reason": "acknowledged_by_user"
"source_id": "app-mids-user-management@dkrh4.reef",
"source_type": "iml01",
"state_pre": "ok"
"id": "29f97a3d45855e6593001dffe2c2ed00374958c5",
"state": "ok",
"ts": "1656661749349",
"type": "test",
"o": {
"frontendTags": {
"room": {
"roomName": "Technikraum"
"friendly_name": "Brandmelder",
"id": "033e3d32b7",
"type": "sd01",
"room": {
"id": 79283,
"friendlyName": "Technikraum"
"source_id": "AFF135FD706A21DB007B94E87A4BCA09",
"source_name": "Basisstation",
"source_type": "basestation",
"state_pre": "ok"
Anbei die Daten. Zur Info, ich habe heute einen Testalarm durchgeführt.
"bs": [
"id": "baseId000-c3PZt",
"friendly_name": "baseName000-H9lRZ",
"status": "online",
"firmware_status": "up_to_date",
"updates_available": false,
"version": "bas-002.009.001",
"latest_version": "bas-002.009.001",
"fw_outdated": false,
"intrusion_settings": {
"active_mode": "home",
"requestedMode": "home",
"modeTransitionInProgress": false,
"modes": [
"away": {
"sirens_on": true,
"trigger_delay": 0,
"privacy_mode": false
"home": {
"sirens_on": false,
"trigger_delay": 0,
"night": {
"sirens_on": false,
"trigger_delay": 0,
"custom": {
"sirens_on": false,
"trigger_delay": 0,
"endnodes": [
"id": "elementId000-1Dhhr",
"type": "sd01",
"friendly_name": "elementName000-GetDw",
"status": "online",
"fw_version": "0013000010250000",
"latest_version": "0013000010250000",
"battery": {
"state": "ok"
"ts_button": 1656661747223
"id": "elementId001-xyK4u",
"type": "wd01",
"friendly_name": "elementName001-uG6Wo",
"status": "online",
"fw_version": "0006000010250000",
"latest_version": "0006000010250000",
"battery": {
"state": "ok"
"ts_button": 1613757851275
"sensors": [
"type": "sd01",
"status": "online",
"battery": {
"state": "ok"
"type": "wd01",
"status": "online",
"battery": {
"state": "ok"
"elements": {
"gp01": [],
"gp02": [],
"yc01": [],
"bs01": [
"type": "bs01",
"friendlyName": "baseName000-H9lRZ",
"firmwareStatus": "up_to_date",
"firmwareVersion": "bas-002.009.001",
"latestFirmwareVersion": "bas-002.009.001",
"connectionStatus": "online",
"timezone": "Europe/Vienna",
"mac": "589EC6135618",
"disabled": false,
"pairingMode": false,
"subelements": [
"id": "baseId000-c3PZt.elementId001-xyK4u",
"type": "bs01.wd01",
"friendlyName": "elementName001-uG6Wo",
"firmwareVersion": "0006000010250000",
"latestFirmwareVersion": "0006000010250000",
"batteryStatus": "ok",
"states": {
"temperature": 27.7,
"humidity": 55.2,
"waterAlarm": "water_no_longer_detected",
"testRequired": true,
"lastAlarmTestTimestamp": 1613256919306
"frontendTags": {
"room": {
"roomName": "Room 000-pBh0M"
"room": {
"id": 79283,
"friendlyName": "Room 000-pBh0M"
"buttonPressedTs": 1613757851275,
"capabilities": [],
"debug": {
"simple": "batteryLifetimePrediction: green",
"extended": {
"batteryLifetimePredictionColor": "green"
"id": "baseId000-c3PZt.elementId000-1Dhhr",
"type": "bs01.sd01",
"friendlyName": "elementName000-GetDw",
"firmwareVersion": "0013000010250000",
"latestFirmwareVersion": "0013000010250000",
"frontendTags": {
"room": {
"room": {
"id": 79283,
"buttonPressedTs": 1656661747223,
"capabilities": [],
"debug": {
"extended": {
"testRequired": false,
"unmounted": false,
"smokeDetected": false,
"permanentBatteryLow": false,
"permanentBatteryChangeRequest": false,
"smokeChamberFail": false,
"smokeDetectorOff": false,
"lastAlarmTestTimestamp": 1656661749339,
"lastPairingTimestamp": 1613251172762
"frontendTags": {
"room": {
"capabilities": [
"firmware.update.procedure.managed",
"presentation.deviceType.elementsBasestation",
"hardware.radio.dect.ule"
"states": {
"dect.remaining_devices_to_be_paired": 62,
"dect.remaining_devices_to_be_paired._meta": {
"modificationTimestamp": 1656661749345
"room": {
"id": 79283,
"bs02": []
"events": {
"events": [
"state": "ok",
"o": {
"state_pre": "ok"
"state": "ok",
"type": "test",
"o": {
"frontendTags": {
"room": {
"roomName": "Room 001-AXVvW"
"type": "sd01",
"room": {
"id": 79283,
"friendlyName": "Room 001-AXVvW"
"source_id": "baseId000-c3PZt",
"source_name": "baseName000-H9lRZ",
"state_pre": "ok"
"id": "ad44eed33f11325b38b3133b81c246489101e989",
"state": "ok",
"ts": "1655477524169",
"type": "isl01.bs01.intrusion_mode_loaded",
"o": {
"configurationLoadedId": "0123",
"modeBefore": "away",
"modeAfter": "home",
"userId": "https://im.gigaset-elements.de/identity/api/v1/openid/identifier/id/xxx"
"source_id": "app-services-intrusion-detector@dkrd4.reef",
"source_type": "isl01",
"state_pre": "ok"
"id": "f05ae7289a0df9039c807c8ac70090fc0ac7b6fa",
"state": "ok",
"ts": "1655477524159",
"type": "isl01.configuration_changed.user.intrusion_mode",
"o": {
"modeAfter": "home"
"state_pre": "ok"
"home_state": "ok"
Hätte doch noch eine Frage.
Ich bekomme zu den standardmäßig angelegten Datenpunkten eine Aktualisierung, doch nicht zu jenen, welche ich nachträglich anlege. Ich nehme an, dass diese nicht abgefragt werden.
Allerdings bekomme ich so keine Alarmzustände von meinem Wassersensor und meines Brandmelders.
Gemäß Debug-Infos wäre beim Wassermelder nicht "alarm" sondern "waterAlarm" als String und beim Brandmelder "smokeDetected" als Boolean notwendig.
Anbei der Debug-Auszug:
"gp01": [],
"gp02": [],
"yc01": [],
"bs01": [
"type": "bs01",
"friendlyName": "Basisstation",
"disabled": false,
"subelements": [
"friendlyName": "Wassermelder",
"states": {
"temperature": 25.3,
"humidity": 50.7,
"frontendTags": {
"room": {
"room": {
"id": 79283,
"capabilities": [],
"debug": {
"extended": {
"friendlyName": "Brandmelder",
"frontendTags": {
"room": {
"room": {
"buttonPressedTs": 1655474417620,
"capabilities": [],
"debug": {
"extended": {
"unmounted": false,
"lastAlarmTestTimestamp": 1655474419605,
"frontendTags": {
"room": {
"capabilities": [
"states": {
"modificationTimestamp": 1655474901079
"room": {
"bs02": []
Sorry ... alles geklärt. Bin gerade drauf gekommen, dass ich in den allgemeinen Einstellungen nur das "Stable" Repository ausgewählt hatte.
Habe nun installieren können und auf den ersten Blick schaut alles super aus.
Vielen Dank.
@thomas-braun @matthsc
Vielen Dank für eure raschen Rückmeldungen. Bin erst jetzt dazu gekommen mir diese durchzusehen.
Leider finde ich weder in den NPM noch Github Adaptern einen mit einer Bezeichnung "Gigaset Elements". Suche ich falsch?
@matthsc Danke für die rasche Rückmeldung.
Anbei die Versionen:
GigaSet Adapter: v0.2.0
NODE.JS: V14.17.5
NPM: 6.14.14
IOBroker: v5.3.8
Weiters kommt bei mir nach der Installation nur eine "leere Seite" anstatt der Konfiguration. Wenn ich in der Protokollierung von IOBroker nachsehe, finde ich die Fehlermeldung "host.homeserver
2022-06-10 21:31:43.222 error startInstance gigaset-elements.0: cannot find start file!".
Habe vom Github-Url installiert.
Hallo. Ich habe das Problem, dass immer wenn ich den Adapter installiere, die Fehlermeldung kommt, dass kein Start File vorhanden ist. Kann ich das selbst erstellen, oder wäre es möglich eines hochzuladen?
Vielen Dank.
