Den Eintrag habe ich gemacht -> https://github.com/instalator/ioBroker.synology/issues/66
Hier die Logdatei, ich persönlich kann dies nicht lesen
2021-07-20 15:25:31.339 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) * Packet SS non installed, skipped
2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * Packet DL non installed, skipped
2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {}
2021-07-20 15:25:31.489 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0}
2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data.
2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) setStates
2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.time"
2021-07-20 15:25:31.491 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.uptime"
2021-07-20 15:25:31.491 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.cpu_load"
2021-07-20 15:25:31.591 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:31.592 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
2021-07-20 15:25:31.592 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
2021-07-20 15:25:32.670 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:32.671 - [34mdebug[39m: synology.0 (7079) SystemUtilization - Response: {"cpu":{"15min_load":56,"1min_load":60,"5min_load":53,"device":"System","other_load":3,"system_load":8,"user_load":15},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974},{"device":"sdb","display_name":"Drive 2","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":2,"write_access":4,"write_byte":31948}},"lun":[],"memory":{"avail_real":131836,"avail_swap":2892524,"buffer":76368,"cached":859704,"device":"Memory","memory_size":2097152,"real_usage":42,"si_disk":0,"so_disk":0,"swap_usage":10,"total_real":1871684,"total_swap":3221428},"network":[{"device":"total","rx":1693923,"tx":46163},{"device":"eth0","rx":1693923,"tx":46163}],"nfs":[{"device":"nfs","read_OPS":0,"read_max_latency":0,"total_OPS":0,"total_max_latency":0,"write_OPS":0,"write_max_latency":0}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011},"volume":[{"device":"dm-1","display_name":"volume1","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011}]},"time":1626787529}
2021-07-20 15:25:32.671 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:32.672 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
2021-07-20 15:25:32.672 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
2021-07-20 15:25:32.924 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getInfo params: {}
2021-07-20 15:25:32.956 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) TempInfo - Response: {"codepage":"ger","model":"DS218+","ram":2048,"serial":"1870PCN814705","temperature":40,"temperature_warn":false,"time":"Tue Jul 20 15:25:32 2021","uptime":12580,"version":"41890","version_string":"DSM 7.0-41890"}
2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) InfoSystem - Response: {"hdd_info":[{"capacity":"6001175126016","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":1,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":32,"testing_progress":"","testing_type":"idle","volume":"reuse_1"},{"capacity":"6001175126016","diskPath":"/dev/sdb","diskType":"SATA","diskno":"Drive 2","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":2,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":33,"testing_progress":"","testing_type":"idle","volume":"reuse_1"}],"vol_info":[{"desc":"","inode_free":"363593799","inode_total":"365953024","name":"volume_1","status":"normal","total_size":"5901558661120","used_size":"3241873846272","vol_desc":"","volume":"volume_1"}]}
2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * Packet SS non installed, skipped
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * Packet DL non installed, skipped
2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {}
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) * The response is received, parse:
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0}
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data.
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) setStates
2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.time"
2021-07-20 15:25:33.279 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.uptime"
2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) -----------------------------------------------------------------------------------------------------
2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
