    2. Fanny 0
    F
    • Following 1
    • Posts 27
    Fanny 0
    @Fanny 0
    27
    Fanny 0 Follow
    Latest posts made by Fanny 0
    • RE: Backup einspielen
      Aktuell habe ich Ihn erst einmal wieder zu laufen bekommen.😁
      Vielen Dank für Eure Hilfe!👍 👊
      F
      Fanny 0
      Das ist jetzt ein Auszug aus dem Log. Habe den Admin neu angelegt, dann kam ich wieder rauf.
      2022-03-02 15:49:00.072  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:00.133  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:00.141  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:00.167  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:00.168  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:00.172  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:00.173  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:00.174  - info: host.fanny no instances found
      2022-03-02 15:49:00.178  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:00.179  - error: host.fanny TypeError: doc.rows is not iterable
          at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
          at async getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
      2022-03-02 15:49:00.188  - info: host.fanny iobroker _restart
      2022-03-02 15:49:00.214  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:00.248  - info: host.fanny terminated
      2022-03-02 15:49:00.823  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:01.237  - info: host.fanny received SIGTERM
      2022-03-02 15:49:01.241  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:01.242  - info: host.fanny terminated
      2022-03-02 15:49:01.244  - info: host.fanny iobroker exit null
      2022-03-02 15:49:02.362  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:02.369  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:02.370  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:02.370  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:02.487  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:02.567  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:02.592  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:02.630  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:02.631  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:02.695  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:02.702  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:02.730  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:02.731  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:02.734  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:02.735  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:02.736  - info: host.fanny no instances found
      2022-03-02 15:49:02.741  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:02.741  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:02.750  - info: host.fanny iobroker _restart
      2022-03-02 15:49:02.778  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:02.802  - info: host.fanny terminated
      2022-03-02 15:49:03.380  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:03.569  - info: host.fanny received SIGTERM
      2022-03-02 15:49:03.573  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:03.574  - info: host.fanny terminated
      2022-03-02 15:49:03.579  - info: host.fanny iobroker exit null
      2022-03-02 15:49:04.902  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:04.909  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:04.910  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:04.910  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:05.028  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:05.107  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:05.132  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:05.169  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:05.170  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:05.190  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:05.243  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:05.270  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:05.271  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:05.274  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:05.275  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:05.276  - info: host.fanny no instances found
      2022-03-02 15:49:05.281  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:05.282  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:05.291  - info: host.fanny iobroker _restart
      2022-03-02 15:49:05.318  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:05.342  - info: host.fanny terminated
      2022-03-02 15:49:05.926  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:06.133  - info: host.fanny received SIGTERM
      2022-03-02 15:49:06.138  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:06.139  - info: host.fanny terminated
      2022-03-02 15:49:06.144  - info: host.fanny iobroker exit null
      2022-03-02 15:49:07.496  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:07.503  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:07.504  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:07.505  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:07.626  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:07.706  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:07.731  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:07.770  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:07.771  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:07.835  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:07.842  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:07.870  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:07.871  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:07.874  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:07.875  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:07.876  - info: host.fanny no instances found
      2022-03-02 15:49:07.881  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:07.882  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:07.891  - info: host.fanny iobroker _restart
      2022-03-02 15:49:07.918  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:07.941  - info: host.fanny terminated
      2022-03-02 15:49:08.517  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:08.821  - info: host.fanny received SIGTERM
      2022-03-02 15:49:08.826  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:08.827  - info: host.fanny terminated
      2022-03-02 15:49:08.832  - info: host.fanny iobroker exit null
      2022-03-02 15:49:10.055  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:10.062  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:10.063  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:10.063  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:10.178  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:10.259  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:10.284  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:10.323  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:10.324  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:10.387  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:10.394  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:10.422  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:10.423  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:10.426  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:10.427  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:10.428  - info: host.fanny no instances found
      2022-03-02 15:49:10.433  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:10.434  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:10.443  - info: host.fanny iobroker _restart
      2022-03-02 15:49:10.470  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:10.493  - info: host.fanny terminated
      2022-03-02 15:49:11.071  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:11.278  - info: host.fanny received SIGTERM
      2022-03-02 15:49:11.283  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:11.284  - info: host.fanny terminated
      2022-03-02 15:49:11.288  - info: host.fanny iobroker exit null
      2022-03-02 15:49:12.633  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:12.641  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:12.641  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:12.642  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:12.760  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:12.840  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:12.865  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:12.902  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:12.903  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:12.924  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:12.975  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:13.002  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:13.003  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:13.006  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:13.007  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:13.008  - info: host.fanny no instances found
      2022-03-02 15:49:13.013  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:13.013  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:13.022  - info: host.fanny iobroker _restart
      2022-03-02 15:49:13.050  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:13.074  - info: host.fanny terminated
      2022-03-02 15:49:13.647  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:13.821  - info: host.fanny received SIGTERM
      2022-03-02 15:49:13.825  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:13.826  - info: host.fanny terminated
      2022-03-02 15:49:13.828  - info: host.fanny iobroker exit null
      2022-03-02 15:49:15.195  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:15.202  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:15.203  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:15.203  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:15.319  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:15.399  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:15.424  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:15.462  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:15.463  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:15.527  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:15.534  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:15.562  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:15.563  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:15.566  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:15.567  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:15.568  - info: host.fanny no instances found
      2022-03-02 15:49:15.573  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:15.574  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:15.583  - info: host.fanny iobroker _restart
      2022-03-02 15:49:15.608  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:15.632  - info: host.fanny terminated
      2022-03-02 15:49:16.208  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:16.401  - info: host.fanny received SIGTERM
      2022-03-02 15:49:16.407  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:16.408  - info: host.fanny terminated
      2022-03-02 15:49:16.410  - info: host.fanny iobroker exit null
      2022-03-02 15:49:17.752  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:17.760  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:17.760  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:17.761  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:17.875  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:17.955  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:17.980  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:18.018  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:18.019  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:18.081  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:18.089  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:18.114  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:18.115  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:18.118  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:18.120  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:18.120  - info: host.fanny no instances found
      2022-03-02 15:49:18.125  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:18.126  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:18.134  - info: host.fanny iobroker _restart
      2022-03-02 15:49:18.162  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:18.186  - info: host.fanny terminated
      2022-03-02 15:49:18.762  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:18.933  - info: host.fanny received SIGTERM
      2022-03-02 15:49:18.939  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:18.940  - info: host.fanny terminated
      2022-03-02 15:49:18.943  - info: host.fanny iobroker exit null
      2022-03-02 15:49:20.303  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:20.310  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:20.311  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:20.311  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:20.434  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:20.514  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:20.540  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:20.578  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:20.579  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:20.641  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:20.649  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:20.674  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:20.675  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:20.679  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:20.680  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:20.680  - info: host.fanny no instances found
      2022-03-02 15:49:20.685  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:20.686  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:20.695  - info: host.fanny iobroker _restart
      2022-03-02 15:49:20.722  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:20.746  - info: host.fanny terminated
      2022-03-02 15:49:21.327  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:21.506  - info: host.fanny received SIGTERM
      2022-03-02 15:49:21.509  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:21.510  - info: host.fanny terminated
      2022-03-02 15:49:21.516  - info: host.fanny iobroker exit null
      2022-03-02 15:49:22.851  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:22.859  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:22.859  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:22.860  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:22.970  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:23.050  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:23.075  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:23.114  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:23.115  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:23.179  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:23.186  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:23.214  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:23.215  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:23.218  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:23.219  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:23.220  - info: host.fanny no instances found
      2022-03-02 15:49:23.225  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:23.225  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:23.234  - info: host.fanny iobroker _restart
      2022-03-02 15:49:23.262  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:23.286  - info: host.fanny terminated
      2022-03-02 15:49:23.867  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:24.057  - info: host.fanny received SIGTERM
      2022-03-02 15:49:24.061  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:24.062  - info: host.fanny terminated
      2022-03-02 15:49:24.065  - info: host.fanny iobroker exit null
      2022-03-02 15:49:25.406  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:25.413  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:25.414  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:25.414  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:25.531  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:25.610  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:25.635  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:25.674  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:25.675  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:25.739  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:25.746  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:25.774  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:25.775  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:25.778  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:25.779  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:25.780  - info: host.fanny no instances found
      2022-03-02 15:49:25.785  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:25.785  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:25.794  - info: host.fanny iobroker _restart
      2022-03-02 15:49:25.822  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:25.846  - info: host.fanny terminated
      2022-03-02 15:49:26.426  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:26.596  - info: host.fanny received SIGTERM
      2022-03-02 15:49:26.599  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:26.600  - info: host.fanny terminated
      2022-03-02 15:49:26.606  - info: host.fanny iobroker exit null
      2022-03-02 15:49:27.969  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:27.977  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:27.977  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:27.978  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:28.100  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:28.179  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:28.205  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:28.242  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:28.244  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:28.264  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:28.313  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:28.342  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:28.343  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:28.346  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:28.347  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:28.348  - info: host.fanny no instances found
      2022-03-02 15:49:28.353  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:28.353  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:28.362  - info: host.fanny iobroker _restart
      2022-03-02 15:49:28.390  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:28.414  - info: host.fanny terminated
      2022-03-02 15:49:28.987  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:29.196  - info: host.fanny received SIGTERM
      2022-03-02 15:49:29.201  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:29.202  - info: host.fanny terminated
      2022-03-02 15:49:29.205  - info: host.fanny iobroker exit null
      2022-03-02 15:49:30.527  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:30.534  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:30.535  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:30.535  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:30.650  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:30.730  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:30.756  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:30.794  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:30.795  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:30.861  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:30.869  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:30.898  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:30.899  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:30.903  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:30.904  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:30.904  - info: host.fanny no instances found
      2022-03-02 15:49:30.909  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:30.910  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:30.919  - info: host.fanny iobroker _restart
      2022-03-02 15:49:30.945  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:30.970  - info: host.fanny terminated
      2022-03-02 15:49:31.542  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:31.724  - info: host.fanny received SIGTERM
      2022-03-02 15:49:31.728  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:31.729  - info: host.fanny terminated
      2022-03-02 15:49:31.735  - info: host.fanny iobroker exit null
      2022-03-02 15:49:33.111  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:33.118  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:33.119  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:33.120  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:33.243  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:33.323  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:33.348  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:33.387  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:33.388  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:33.450  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:33.458  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:33.486  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:33.487  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:33.490  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:33.491  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:33.492  - info: host.fanny no instances found
      2022-03-02 15:49:33.497  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:33.497  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:33.506  - info: host.fanny iobroker _restart
      2022-03-02 15:49:33.533  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:33.557  - info: host.fanny terminated
      2022-03-02 15:49:34.136  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:34.310  - info: host.fanny received SIGTERM
      2022-03-02 15:49:34.315  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:34.316  - info: host.fanny terminated
      2022-03-02 15:49:34.319  - info: host.fanny iobroker exit null
      2022-03-02 15:49:35.690  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:35.697  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:35.698  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:35.699  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:35.813  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:35.891  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:35.916  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:35.953  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:35.955  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:35.975  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:36.027  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:36.054  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:36.055  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:36.058  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:36.059  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:36.060  - info: host.fanny no instances found
      2022-03-02 15:49:36.065  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:36.066  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:36.075  - info: host.fanny iobroker _restart
      2022-03-02 15:49:36.102  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:36.125  - info: host.fanny terminated
      2022-03-02 15:49:36.711  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:36.929  - info: host.fanny received SIGTERM
      2022-03-02 15:49:36.935  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:36.936  - info: host.fanny terminated
      2022-03-02 15:49:36.939  - info: host.fanny iobroker exit null
      2022-03-02 15:49:38.240  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:38.247  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:38.248  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:38.248  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:38.362  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:38.442  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:38.467  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:38.505  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:38.507  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:38.571  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:38.578  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:38.606  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:38.607  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:38.610  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:38.611  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:38.612  - info: host.fanny no instances found
      2022-03-02 15:49:38.617  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:38.617  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:38.626  - info: host.fanny iobroker _restart
      2022-03-02 15:49:38.654  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:38.677  - info: host.fanny terminated
      2022-03-02 15:49:39.258  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:39.446  - info: host.fanny received SIGTERM
      2022-03-02 15:49:39.453  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:39.454  - info: host.fanny terminated
      2022-03-02 15:49:39.456  - info: host.fanny iobroker exit null
      2022-03-02 15:49:40.793  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:40.800  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:40.801  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:40.801  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:40.918  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:40.999  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:41.024  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:41.062  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:41.064  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:41.126  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:41.134  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:41.162  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:41.163  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:41.166  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:41.167  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:41.168  - info: host.fanny no instances found
      2022-03-02 15:49:41.173  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:41.173  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:41.182  - info: host.fanny iobroker _restart
      2022-03-02 15:49:41.210  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:41.234  - info: host.fanny terminated
      2022-03-02 15:49:41.810  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:41.985  - info: host.fanny received SIGTERM
      2022-03-02 15:49:41.990  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:41.991  - info: host.fanny terminated
      2022-03-02 15:49:41.994  - info: host.fanny iobroker exit null
      2022-03-02 15:49:43.347  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:43.354  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:43.355  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:43.356  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:43.478  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:43.555  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:43.581  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:43.621  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:43.622  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:43.687  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:43.694  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:43.722  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:43.723  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:43.726  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:43.727  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:43.728  - info: host.fanny no instances found
      2022-03-02 15:49:43.733  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:43.734  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:43.743  - info: host.fanny iobroker _restart
      2022-03-02 15:49:43.770  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:43.797  - info: host.fanny terminated
      2022-03-02 15:49:44.371  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:44.539  - info: host.fanny received SIGTERM
      2022-03-02 15:49:44.543  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:44.544  - info: host.fanny terminated
      2022-03-02 15:49:44.548  - info: host.fanny iobroker exit null
      2022-03-02 15:49:45.929  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:45.936  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:45.937  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:45.937  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:46.056  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:46.135  - info: host.fanny connected to Objects and States
      2022-03-02 15:49:46.160  - info: host.fanny added notifications configuration of host
      2022-03-02 15:49:46.197  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:46.199  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:49:46.218  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:49:46.269  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:49:46.298  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:49:46.299  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:49:46.302  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:49:46.303  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:49:46.304  - info: host.fanny no instances found
      2022-03-02 15:49:46.309  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:49:46.309  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:49:46.318  - info: host.fanny iobroker _restart
      2022-03-02 15:49:46.345  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:49:46.369  - info: host.fanny terminated
      2022-03-02 15:49:46.955  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:49:47.197  - info: host.fanny received SIGTERM
      2022-03-02 15:49:47.202  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:49:47.203  - info: host.fanny terminated
      2022-03-02 15:49:47.207  - info: host.fanny iobroker exit null
      2022-03-02 15:49:48.498  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:49:48.505  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:49:48.506  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:49:48.506  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:49:48.627  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:49:48.638  - info: host.fanny-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
      2022-03-02 15:50:18.537  - error: host.fanny No connection to databases possible, restart
      2022-03-02 15:50:18.557  - info: host.fanny iobroker _restart
      2022-03-02 15:50:19.211  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:50:19.423  - info: host.fanny received SIGTERM
      2022-03-02 15:50:19.433  - info: host.fanny iobroker exit null
      2022-03-02 15:50:19.444  - info: host.fanny terminated
      2022-03-02 15:50:20.701  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:50:20.708  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:50:20.709  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:50:20.710  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:50:20.830  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:50:20.910  - info: host.fanny connected to Objects and States
      2022-03-02 15:50:20.936  - info: host.fanny added notifications configuration of host
      2022-03-02 15:50:20.974  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:20.975  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:50:21.037  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:50:21.045  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:50:21.070  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:50:21.071  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:21.075  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:50:21.076  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:50:21.076  - info: host.fanny no instances found
      2022-03-02 15:50:21.081  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:50:21.082  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:50:21.091  - info: host.fanny iobroker _restart
      2022-03-02 15:50:21.118  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:50:21.152  - info: host.fanny terminated
      2022-03-02 15:50:21.719  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:50:21.901  - info: host.fanny received SIGTERM
      2022-03-02 15:50:21.905  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:50:21.906  - info: host.fanny terminated
      2022-03-02 15:50:21.911  - info: host.fanny iobroker exit null
      2022-03-02 15:50:23.273  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:50:23.281  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:50:23.281  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:50:23.282  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:50:23.410  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:50:23.491  - info: host.fanny connected to Objects and States
      2022-03-02 15:50:23.516  - info: host.fanny added notifications configuration of host
      2022-03-02 15:50:23.555  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:23.556  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:50:23.619  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:50:23.626  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:50:23.654  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:50:23.655  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:23.658  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:50:23.659  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:50:23.660  - info: host.fanny no instances found
      2022-03-02 15:50:23.665  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:50:23.665  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:50:23.674  - info: host.fanny iobroker _restart
      2022-03-02 15:50:23.699  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:50:23.723  - info: host.fanny terminated
      2022-03-02 15:50:24.295  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:50:24.481  - info: host.fanny received SIGTERM
      2022-03-02 15:50:24.487  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:50:24.490  - info: host.fanny terminated
      2022-03-02 15:50:24.494  - info: host.fanny iobroker exit null
      2022-03-02 15:50:25.847  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:50:25.854  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:50:25.855  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:50:25.856  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:50:25.977  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:50:26.057  - info: host.fanny connected to Objects and States
      2022-03-02 15:50:26.082  - info: host.fanny added notifications configuration of host
      2022-03-02 15:50:26.120  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:26.121  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:50:26.141  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:50:26.191  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:50:26.218  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:50:26.219  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:26.222  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:50:26.224  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:50:26.224  - info: host.fanny no instances found
      2022-03-02 15:50:26.229  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:50:26.230  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:50:26.238  - info: host.fanny iobroker _restart
      2022-03-02 15:50:26.266  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:50:26.290  - info: host.fanny terminated
      2022-03-02 15:50:26.867  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:50:27.043  - info: host.fanny received SIGTERM
      2022-03-02 15:50:27.047  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:50:27.048  - info: host.fanny terminated
      2022-03-02 15:50:27.050  - info: host.fanny iobroker exit null
      2022-03-02 15:50:28.430  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:50:28.437  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:50:28.438  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:50:28.438  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:50:28.557  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:50:28.636  - info: host.fanny connected to Objects and States
      2022-03-02 15:50:28.661  - info: host.fanny added notifications configuration of host
      2022-03-02 15:50:28.698  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:28.700  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:50:28.720  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:50:28.769  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:50:28.798  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:50:28.799  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:28.802  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:50:28.803  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:50:28.804  - info: host.fanny no instances found
      2022-03-02 15:50:28.809  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:50:28.809  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:50:28.818  - info: host.fanny iobroker _restart
      2022-03-02 15:50:28.846  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:50:28.870  - info: host.fanny terminated
      2022-03-02 15:50:29.446  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:50:29.626  - info: host.fanny received SIGTERM
      2022-03-02 15:50:29.631  - warn: host.fanny get state error: Connection is closed.
      2022-03-02 15:50:29.632  - info: host.fanny terminated
      2022-03-02 15:50:29.635  - info: host.fanny iobroker exit null
      2022-03-02 15:50:31.003  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:50:31.010  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:50:31.011  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:50:31.011  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:50:31.126  - error: host.fanny Cannot read system.config: null (OK when migrating or restoring)
      2022-03-02 15:50:31.207  - info: host.fanny connected to Objects and States
      2022-03-02 15:50:31.232  - info: host.fanny added notifications configuration of host
      2022-03-02 15:50:31.271  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:31.272  - error: host.fanny Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-02 15:50:31.335  - info: host.fanny Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-02 15:50:31.342  - error: host.fanny Cannot find view "system" for search "host"
      2022-03-02 15:50:31.370  - error: host.fanny Cannot find view "system" for search "state"
      2022-03-02 15:50:31.371  - error: host.fanny Cannot find view "system" for search "instance"
      2022-03-02 15:50:31.374  - error: host.fanny Could not collect system.host.fanny states to check for obsolete states: Error: Cannot find view "system"
      2022-03-02 15:50:31.376  - error: host.fanny _design/system missing - call node iobroker.js setup
      2022-03-02 15:50:31.376  - info: host.fanny no instances found
      2022-03-02 15:50:31.381  - error: host.fanny uncaught exception: doc.rows is not iterable
      2022-03-02 15:50:31.382  - error: host.fanny TypeError: doc.rows is not iterable
      2022-03-02 15:50:31.391  - info: host.fanny iobroker _restart
      2022-03-02 15:50:31.418  - error: host.fanny Cannot write host object:Error: DB closed
      2022-03-02 15:50:31.442  - info: host.fanny terminated
      2022-03-02 15:50:32.024  - info: host.fanny iobroker Starting node restart.js
      2022-03-02 15:53:53.703  - info: host.fanny iobroker.js-controller version 3.3.22 js-controller starting
      2022-03-02 15:53:53.710  - info: host.fanny Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2022-03-02 15:53:53.711  - info: host.fanny hostname: fanny, node: v14.19.0
      2022-03-02 15:53:53.712  - info: host.fanny ip addresses: 192.168.178.137 2001:9e8:e5fe:d900:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-02 15:53:53.903  - info: host.fanny connected to Objects and States
      2022-03-02 15:53:53.929  - info: host.fanny added notifications configuration of host
      2022-03-02 15:53:54.276  - info: host.fanny no instances found
      2022-03-02 15:53:54.277  - info: host.fanny no instances found
      2022-03-02 15:59:04.202  - info: host.fanny instance system.adapter.admin.0 started with pid 20437
      2022-03-02 15:59:06.110  - info: admin.0 (20437) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 3.3.22
      2022-03-02 15:59:06.169  - info: admin.0 (20437) requesting all states
      2022-03-02 15:59:06.170  - info: admin.0 (20437) requesting all objects
      2022-03-02 15:59:06.259  - info: admin.0 (20437) received all objects
      2022-03-02 15:59:06.354  - info: admin.0 (20437) http server listening on port 8081
      2022-03-02 15:59:06.355  - info: admin.0 (20437) Use link "http://localhost:8081" to configure.
      2022-03-02 15:59:06.482  - warn: admin.0 (20437) Repository cannot be read. Active repo: stable
      2022-03-02 15:59:31.824  - info: host.fanny Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-03-02 16:10:56.522  - info: host.fanny iobroker add backitup --host fanny
      2022-03-02 16:10:58.396  - info: host.fanny iobroker host.fanny install adapter backitup
      2022-03-02 16:10:58.634  - info: host.fanny iobroker These apt-get packages were already installed: cifs-utils, nfs-common
      2022-03-02 16:10:58.663  - info: host.fanny iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      2022-03-02 16:10:58.782  - info: host.fanny iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      2022-03-02 16:10:58.857  - info: host.fanny iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      2022-03-02 16:10:58.929  - info: host.fanny iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      2022-03-02 16:10:59.002  - info: host.fanny iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      2022-03-02 16:10:59.072  - info: host.fanny iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      2022-03-02 16:10:59.143  - info: host.fanny iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      2022-03-02 16:10:59.218  - info: host.fanny iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      2022-03-02 16:10:59.288  - info: host.fanny iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      2022-03-02 16:10:59.362  - info: host.fanny iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      2022-03-02 16:10:59.433  - info: host.fanny iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      Wie gesagt ist nur ein Teil, so ziemlich nachdem ich das Backup über dei Konsole eingespielt habe
      F
      Fanny 0
    • RE: Backup einspielen
      @fredf
      Jepp...hat aber nicht geklappt
      F
      Fanny 0
      @fredf
      ja genau das ist ja das Problem....es öffnet sich kein neues Fenster
      F
      Fanny 0
      @fredf
      Das bezieht sich eine Sicherung
      Ich möchte aber eine Backup-Wiederherstellung
      F
      Fanny 0
      @fredf
      ja, aber wie ist es beim Wiederherstellen
      F
      Fanny 0
      @fredf
      das war mein erster Weg. Über Backitup sehe ich das LogFenster nicht.Im Browser öffnet sich kein zweites Fenster. POP up Blocker sind aus.
      Aber auch das Backup über Putty geht nicht
      F
      Fanny 0
      @fredf
      Habe den Iobroker bereits mehrfach installiert. Aber sofern ich ein Backup einspiele geht nichts mehr
      F
      Fanny 0
      den Hostnamen habe ich geändert
      F
      Fanny 0
      @thomas-braun ok...wie kann ich das ändern??
      F
      Fanny 0
