    2. McDagobert99
    McDagobert99
    @McDagobert99
    McDagobert99 Follow
    Latest posts made by McDagobert99
    • RE: Zigbee/Conbee2 / Netzwerkkarte Funktioniert nicht.
      @Asgothian
      Keine Fehlermeldungen im Log.
      Wenn ich die anderen Optionen anklicke(Geschwister/Mesh) ändert sich nichts.
      Anbei noch ein Log wenn ich den Adapter wider starte.
      2020-10-27 08:05:34.673 - info: host.iobroker "system.adapter.zigbee.0" enabled
      2020-10-27 08:05:34.712 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 13979
      2020-10-27 08:05:35.879 - debug: zigbee.0 (13979) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-10-27 08:05:35.911 - debug: zigbee.0 (13979) Objects client ready ... initialize now
      2020-10-27 08:05:35.914 - debug: zigbee.0 (13979) Objects create System PubSub Client
      2020-10-27 08:05:35.916 - debug: zigbee.0 (13979) Objects create User PubSub Client
      2020-10-27 08:05:35.917 - debug: zigbee.0 (13979) Objects client initialize lua scripts
      2020-10-27 08:05:35.933 - debug: zigbee.0 (13979) Objects connected to redis: 127.0.0.1:9001
      2020-10-27 08:05:35.939 - debug: zigbee.0 (13979) objectDB connected
      2020-10-27 08:05:35.941 - debug: zigbee.0 (13979) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-10-27 08:05:35.950 - debug: zigbee.0 (13979) States create User PubSub Client
      2020-10-27 08:05:35.953 - debug: zigbee.0 (13979) States create System PubSub Client
      2020-10-27 08:05:35.965 - debug: zigbee.0 (13979) States connected to redis: 127.0.0.1:9000
      2020-10-27 08:05:35.967 - debug: zigbee.0 (13979) statesDB connected
      2020-10-27 08:05:36.736 - info: zigbee.0 (13979) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.13.0, js-controller: 3.1.6
      2020-10-27 08:05:36.774 - debug: zigbee.0 (13979) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"}}
      2020-10-27 08:05:36.839 - info: zigbee.0 (13979) Starting Zigbee...
      2020-10-27 08:05:36.840 - debug: zigbee.0 (13979) Starting zigbee-herdsman...
      2020-10-27 08:05:37.009 - debug: zigbee.0 (13979) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_27-08_05_36.tar.gz success
      2020-10-27 08:05:37.143 - debug: zigbee.0 (13979) zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'DeconzAdapter'
      2020-10-27 08:05:37.147 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":null,"acceptJoiningDeviceHandler":null}'
      2020-10-27 08:05:37.151 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver Opening with /dev/ttyACM0
      2020-10-27 08:05:37.162 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver Serialport opened
      2020-10-27 08:05:37.164 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Started with result 'resumed'
      2020-10-27 08:05:37.164 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Injected database: true, adapter: true
      2020-10-27 08:05:37.170 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
      2020-10-27 08:05:37.171 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.173 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101010
      2020-10-27 08:05:37.173 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.196 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
      2020-10-27 08:05:37.199 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 2
      2020-10-27 08:05:37.204 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser MAC: 0x00212effff054fdd
      2020-10-27 08:05:37.206 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 2 srcAddr: 0x2ae destAddr: 0x0 profile id: 0x104 cluster id: 0x6
      2020-10-27 08:05:37.207 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser response payload: 0,151,10,0,0,32,1
      2020-10-27 08:05:37.213 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":151,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":32,"attrData":1}]},"address":686,"endpoint":8,"linkquality":178,"groupID":null}'
      2020-10-27 08:05:37.219 - debug: zigbee.0 (13979) zigbee-herdsman:controller:endpoint DefaultResponse 0x00124b0018ed227d/8 6(10, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null})
      2020-10-27 08:05:37.221 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter zclFrame.payload:
      2020-10-27 08:05:37.226 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter { cmdId: 10, statusCode: 0 }
      2020-10-27 08:05:37.227 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter no response expected
      2020-10-27 08:05:37.228 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.246 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 4 paramId: 7
      2020-10-27 08:05:37.248 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 3
      2020-10-27 08:05:37.253 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser NWKADDR: 0
      2020-10-27 08:05:37.257 - debug: zigbee.0 (13979) zigbee-herdsman started
      2020-10-27 08:05:37.263 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 3 srcAddr: 0x2ae destAddr: 0x0 profile id: 0x104 cluster id: 0x11
      2020-10-27 08:05:37.264 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser response payload: 0,152,10,28,0,66,23,56,54,52,50,47,48,120,48,48,49,50,52,66,48,48,49,56,69,68,50,52,53,54,46,0,66,6,80,65,82,69,78,84,85,0,57,0,0,0,0,104,0,57,0,0,0,64,66,0,35,0,0,0,0
      2020-10-27 08:05:37.266 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":152,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":28,"dataType":66,"attrData":"8642/0x00124B0018ED2456"},{"attrId":46,"dataType":66,"attrData":"PARENT"},{"attrId":85,"dataType":57,"attrData":0},{"attrId":104,"dataType":57,"attrData":2},{"attrId":66,"dataType":35,"attrData":0}]},"address":686,"endpoint":8,"linkquality":178,"groupID":null}'
      2020-10-27 08:05:37.269 - debug: zigbee.0 (13979) handleMessage. {"type":"attributeReport","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337267},"endpoint":"[Circular]","data":{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0},"linkquality":178,"groupID":null,"cluster":"genBinaryValue","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      2020-10-27 08:05:37.271 - debug: zigbee.0 (13979) zigbee-herdsman:controller:endpoint DefaultResponse 0x00124b0018ed227d/8 17(10, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null})
      2020-10-27 08:05:37.271 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter zclFrame.payload:
      2020-10-27 08:05:37.272 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter { cmdId: 10, statusCode: 0 }
      2020-10-27 08:05:37.273 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter no response expected
      2020-10-27 08:05:37.273 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.274 - debug: zigbee.0 (13979) Received Zigbee message from '0x00124b0018ed227d', type 'attributeReport', cluster 'genBinaryValue', data '{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0}' from endpoint 8 with groupID null
      2020-10-27 08:05:37.275 - debug: zigbee.0 (13979) Type attributeReport device {"type":"device","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337267},"mapped":{"zigbeeModel":["lumi.router"],"model":"CC2530.ROUTER","vendor":"Custom devices (DiY)","description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","supports":"state, description, type, rssi","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBinaryValue","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["trigger","interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}]},"name":"0x00124b0018ed227d"} incoming event: {"type":"attributeReport","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337267},"endpoint":"[Circular]","data":{"description":"8642/0x00124B0018ED2456","inactiveText":"PARENT","presentValue":0,"relinquishDefault":2,"minimumOffTime":0},"linkquality":178,"groupID":null,"cluster":"genBinaryValue","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      2020-10-27 08:05:37.280 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed227d = true
      2020-10-27 08:05:37.293 - debug: zigbee.0 (13979) Publish {"description":"8642/0x00124B0018ED2456","type":"PARENT","rssi":0}
      2020-10-27 08:05:37.296 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read firmware version request from queue. seqNr: 7
      2020-10-27 08:05:37.300 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x2ae EP:8 SeqNr. 5 request id: 1
      2020-10-27 08:05:37.303 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser read firmware version response - version: 0,7,88,38
      2020-10-27 08:05:37.304 - info: zigbee.0 (13979) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
      2020-10-27 08:05:37.307 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 1 status: 0
      2020-10-27 08:05:37.308 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.312 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101110
      2020-10-27 08:05:37.313 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.347 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 10 paramId: 5
      2020-10-27 08:05:37.349 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 6
      2020-10-27 08:05:37.355 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser PANID: 1a62
      2020-10-27 08:05:37.361 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 6 srcAddr: 0x2ae destAddr: 0x0 profile id: 0x104 cluster id: 0x11
      2020-10-27 08:05:37.361 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser response payload: 0,153,10,28,0,66,20,48,47,48,120,48,48,50,49,50,69,70,70,70,70,48,53,52,70,68,68,46,0,66,5,67,79,79,82,68,85,0,57,0,0,220,66
      2020-10-27 08:05:37.363 - debug: zigbee.0 (13979) zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":153,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":28,"dataType":66,"attrData":"0/0x00212EFFFF054FDD"},{"attrId":46,"dataType":66,"attrData":"COORD"},{"attrId":85,"dataType":57,"attrData":110}]},"address":686,"endpoint":8,"linkquality":178,"groupID":null}'
      2020-10-27 08:05:37.364 - debug: zigbee.0 (13979) handleMessage. {"type":"attributeReport","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337364},"endpoint":"[Circular]","data":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110},"linkquality":178,"groupID":null,"cluster":"genBinaryValue","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      2020-10-27 08:05:37.366 - debug: zigbee.0 (13979) zigbee-herdsman:controller:endpoint DefaultResponse 0x00124b0018ed227d/8 17(10, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null})
      2020-10-27 08:05:37.366 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter zclFrame.payload:
      2020-10-27 08:05:37.367 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter { cmdId: 10, statusCode: 0 }
      2020-10-27 08:05:37.368 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter no response expected
      2020-10-27 08:05:37.369 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.370 - debug: zigbee.0 (13979) Received Zigbee message from '0x00124b0018ed227d', type 'attributeReport', cluster 'genBinaryValue', data '{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110}' from endpoint 8 with groupID null
      2020-10-27 08:05:37.371 - debug: zigbee.0 (13979) Type attributeReport device {"type":"device","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337364},"mapped":{"zigbeeModel":["lumi.router"],"model":"CC2530.ROUTER","vendor":"Custom devices (DiY)","description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","supports":"state, description, type, rssi","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBinaryValue","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["trigger","interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}]},"name":"0x00124b0018ed227d"} incoming event: {"type":"attributeReport","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337364},"endpoint":"[Circular]","data":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110},"linkquality":178,"groupID":null,"cluster":"genBinaryValue","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      2020-10-27 08:05:37.397 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 13 paramId: 11
      2020-10-27 08:05:37.400 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x2ae EP:8 SeqNr. 8 request id: 2
      2020-10-27 08:05:37.402 - debug: zigbee.0 (13979) Publish {"description":"0/0x00212EFFFF054FDD","type":"COORD","rssi":110}
      2020-10-27 08:05:37.405 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser APS_EXT_PANID: 0xdddddddddddddddd
      2020-10-27 08:05:37.407 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 2 status: 0
      2020-10-27 08:05:37.408 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.413 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10100110
      2020-10-27 08:05:37.413 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.447 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 16 paramId: 28
      2020-10-27 08:05:37.450 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser CHANNEL: 11
      2020-10-27 08:05:37.452 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 9
      2020-10-27 08:05:37.456 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr.: 9 status: 5
      2020-10-27 08:05:37.497 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 19 paramId: 24
      2020-10-27 08:05:37.500 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser NETWORK_KEY: hidden
      2020-10-27 08:05:37.501 - debug: zigbee.0 (13979) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
      2020-10-27 08:05:37.502 - info: zigbee.0 (13979) Disable LED
      2020-10-27 08:05:37.503 - info: zigbee.0 (13979) Unable to disable LED, unsupported function.
      2020-10-27 08:05:37.504 - info: zigbee.0 (13979) --> transmitPower : normal
      2020-10-27 08:05:37.505 - info: zigbee.0 (13979) Unable to set transmit power, unsupported function.
      2020-10-27 08:05:37.508 - info: zigbee.0 (13979) Currently 19 devices are joined:
      2020-10-27 08:05:37.508 - debug: zigbee.0 (13979) Publish available for 0x00158d00029a5b0f = true
      2020-10-27 08:05:37.509 - debug: zigbee.0 (13979) Publish available for 0x00158d0002739b1c = true
      2020-10-27 08:05:37.509 - debug: zigbee.0 (13979) Publish available for 0x00158d000252c8fd = true
      2020-10-27 08:05:37.510 - debug: zigbee.0 (13979) Publish available for 0x00158d000251ea06 = true
      2020-10-27 08:05:37.510 - debug: zigbee.0 (13979) Publish available for 0x680ae2fffe8f6ab5 = true
      2020-10-27 08:05:37.511 - debug: zigbee.0 (13979) Publish available for 0x680ae2fffe924068 = true
      2020-10-27 08:05:37.512 - debug: zigbee.0 (13979) Publish available for 0x00158d000247ea61 = true
      2020-10-27 08:05:37.512 - debug: zigbee.0 (13979) Publish available for 0x00158d00023a7f6d = true
      2020-10-27 08:05:37.512 - debug: zigbee.0 (13979) Publish available for 0x00158d0002c9d072 = true
      2020-10-27 08:05:37.513 - debug: zigbee.0 (13979) Publish available for 0x00158d00024de635 = true
      2020-10-27 08:05:37.513 - debug: zigbee.0 (13979) Publish available for 0x00158d000275b69f = true
      2020-10-27 08:05:37.513 - debug: zigbee.0 (13979) Publish available for 0x00158d00027cef69 = true
      2020-10-27 08:05:37.514 - debug: zigbee.0 (13979) Publish available for 0x00158d0001c9a37f = true
      2020-10-27 08:05:37.514 - debug: zigbee.0 (13979) Publish available for 0x00158d0002372735 = true
      2020-10-27 08:05:37.515 - debug: zigbee.0 (13979) Publish available for 0x00158d0002375ca9 = true
      2020-10-27 08:05:37.515 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed2456 = true
      2020-10-27 08:05:37.516 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed1840 = true
      2020-10-27 08:05:37.516 - debug: zigbee.0 (13979) Publish available for 0x00158d000252be87 = true
      2020-10-27 08:05:37.516 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d00029a5b0f lumi.sensor_motion.aq2 not needed
      2020-10-27 08:05:37.517 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d0002739b1c lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.517 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d000252c8fd lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.518 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d000251ea06 lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.518 - debug: zigbee.0 (13979) DeviceConfigure 0x680ae2fffe8f6ab5 TRADFRI Signal Repeater not needed
      2020-10-27 08:05:37.518 - debug: zigbee.0 (13979) DeviceConfigure 0x680ae2fffe924068 TRADFRI Signal Repeater not needed
      2020-10-27 08:05:37.519 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d000247ea61 lumi.weather not needed
      2020-10-27 08:05:37.519 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d00023a7f6d lumi.weather not needed
      2020-10-27 08:05:37.519 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d0002c9d072 lumi.weather not needed
      2020-10-27 08:05:37.520 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d00024de635 lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.520 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d000275b69f lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.520 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d00027cef69 lumi.sensor_cube.aqgl01 not needed
      2020-10-27 08:05:37.521 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d0001c9a37f RS 125 not needed
      2020-10-27 08:05:37.521 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d0002372735 lumi.sensor_wleak.aq1 not needed
      2020-10-27 08:05:37.521 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d0002375ca9 lumi.sensor_wleak.aq1 not needed
      2020-10-27 08:05:37.522 - debug: zigbee.0 (13979) DeviceConfigure 0x00124b0018ed2456 lumi.router not needed
      2020-10-27 08:05:37.522 - debug: zigbee.0 (13979) DeviceConfigure 0x00124b0018ed1840 lumi.router not needed
      2020-10-27 08:05:37.522 - debug: zigbee.0 (13979) DeviceConfigure 0x00158d000252be87 lumi.sensor_magnet.aq2 not needed
      2020-10-27 08:05:37.523 - debug: zigbee.0 (13979) DeviceConfigure 0x00124b0018ed227d lumi.router not needed
      2020-10-27 08:05:37.524 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d00029a5b0f","_networkAddress":12059,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":12059,"deviceIeeeAddress":"0x00158d00029a5b0f","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":133}},"genBasic":{"attributes":{"65281":{"1":3055,"3":21,"4":5032,"5":292,"6":[0,6],"10":0,"11":8,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001","modelId":"lumi.sensor_motion.aq2"}},"msOccupancySensing":{"attributes":{"occupancy":1}},"ssIasZone":{"attributes":{}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780512788},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","supports":"occupancy and illuminance","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00029a5b0f"}
      2020-10-27 08:05:37.525 - info: zigbee.0 (13979) 0x00158d00029a5b0f (addr 12059): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2020-10-27 08:05:37.530 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d0002739b1c","_networkAddress":41541,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":41541,"deviceIeeeAddress":"0x00158d0002739b1c","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":16,"4":17320,"5":96,"6":[1,50331677],"10":46527,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001","modelId":"lumi.sensor_magnet.aq2","appVersion":3}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603544605349},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d0002739b1c"}
      2020-10-27 08:05:37.531 - info: zigbee.0 (13979) 0x00158d0002739b1c (addr 41541): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.532 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d000252c8fd","_networkAddress":5914,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":5914,"deviceIeeeAddress":"0x00158d000252c8fd","clusters":{"genBasic":{"attributes":{"65281":{"1":2995,"3":21,"4":5032,"5":97,"6":[0,5],"10":0,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780664365},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000252c8fd"}
      2020-10-27 08:05:37.533 - info: zigbee.0 (13979) 0x00158d000252c8fd (addr 5914): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.534 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00158d000251ea06","_networkAddress":54102,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":54102,"deviceIeeeAddress":"0x00158d000251ea06","clusters":{"genBasic":{"attributes":{"65281":{"1":3005,"3":21,"4":5032,"5":11,"6":[0,1],"10":0,"100":1},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001","modelId":"lumi.sensor_magnet.aq2","appVersion":3}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780554777},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000251ea06"}
      2020-10-27 08:05:37.535 - info: zigbee.0 (13979) 0x00158d000251ea06 (addr 54102): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.536 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":7,"_type":"Router","_ieeeAddr":"0x680ae2fffe8f6ab5","_networkAddress":13473,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":8,"inputClusters":[0,3,9,2821,4096],"outputClusters":[25,32,4096],"deviceNetworkAddress":13473,"deviceIeeeAddress":"0x680ae2fffe8f6ab5","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI Signal Repeater","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":3,"appVersion":33,"stackVersion":98,"hwVersion":1,"dateCode":"20190311","swBuildId":"2.2.005"}}},"_binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00212effff054fdd","endpointID":1}],"meta":{}},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":13473,"deviceIeeeAddress":"0x680ae2fffe8f6ab5","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI Signal Repeater","_applicationVersion":33,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190311","_softwareBuildID":"2.2.005","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":2},"_lastSeen":1603782302622},"mapped":{"zigbeeModel":["TRADFRI signal repeater"],"model":"E1746","description":"TRADFRI signal repeater","supports":"linkquality","vendor":"IKEA","fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"ota":{},"meta":{"configureKey":2},"exposes":[]},"name":"0x680ae2fffe8f6ab5"}
      2020-10-27 08:05:37.537 - info: zigbee.0 (13979) 0x680ae2fffe8f6ab5 (addr 13473): E1746 - IKEA TRADFRI signal repeater (Router)
      2020-10-27 08:05:37.537 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":10,"_type":"Router","_ieeeAddr":"0x680ae2fffe924068","_networkAddress":24473,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":8,"inputClusters":[0,3,9,2821,4096],"outputClusters":[25,32,4096],"deviceNetworkAddress":24473,"deviceIeeeAddress":"0x680ae2fffe924068","clusters":{"genBasic":{"attributes":{"zclVersion":3}}},"_binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00212effff054fdd","endpointID":1}],"meta":{}},{"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":24473,"deviceIeeeAddress":"0x680ae2fffe924068","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI Signal Repeater","_applicationVersion":33,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20190311","_softwareBuildID":"2.2.005","_interviewCompleted":true,"_interviewing":false,"meta":{"configured":2},"_lastSeen":1603782302671},"mapped":{"zigbeeModel":["TRADFRI signal repeater"],"model":"E1746","description":"TRADFRI signal repeater","supports":"linkquality","vendor":"IKEA","fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"ota":{},"meta":{"configureKey":2},"exposes":[]},"name":"0x680ae2fffe924068"}
      2020-10-27 08:05:37.538 - info: zigbee.0 (13979) 0x680ae2fffe924068 (addr 24473): E1746 - IKEA TRADFRI signal repeater (Router)
      2020-10-27 08:05:37.539 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":11,"_type":"EndDevice","_ieeeAddr":"0x00158d000247ea61","_networkAddress":13940,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":13940,"deviceIeeeAddress":"0x00158d000247ea61","clusters":{"msRelativeHumidity":{"attributes":{"measuredValue":5562}},"msPressureMeasurement":{"attributes":{"16":10048,"20":-1,"measuredValue":996,"scale":-1,"scaledValue":9963}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2028}},"genBasic":{"attributes":{"65281":{"1":2995,"4":17320,"5":5377,"6":[0,1],"10":46527,"100":2027,"101":5517,"102":99624},"modelId":"lumi.weather","appVersion":3}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":3,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780351400},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","supports":"temperature, humidity and pressure","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000247ea61"}
      2020-10-27 08:05:37.540 - info: zigbee.0 (13979) 0x00158d000247ea61 (addr 13940): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2020-10-27 08:05:37.541 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d00023a7f6d","_networkAddress":62882,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":62882,"deviceIeeeAddress":"0x00158d00023a7f6d","clusters":{"genBasic":{"attributes":{"65281":{"1":2945,"4":17320,"5":1,"6":[0,65537],"10":8642,"100":1067,"101":8130,"102":99653},"modelId":"lumi.weather","appVersion":3}},"msTemperatureMeasurement":{"attributes":{"measuredValue":1074}},"msRelativeHumidity":{"attributes":{"measuredValue":8112}},"msPressureMeasurement":{"attributes":{"16":10052,"20":-1,"measuredValue":996,"scale":-1,"scaledValue":9966}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":3,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782254534},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","supports":"temperature, humidity and pressure","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00023a7f6d"}
      2020-10-27 08:05:37.542 - info: zigbee.0 (13979) 0x00158d00023a7f6d (addr 62882): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2020-10-27 08:05:37.543 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":13,"_type":"EndDevice","_ieeeAddr":"0x00158d0002c9d072","_networkAddress":43423,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":43423,"deviceIeeeAddress":"0x00158d0002c9d072","clusters":{"msTemperatureMeasurement":{"attributes":{"measuredValue":574}},"msRelativeHumidity":{"attributes":{"measuredValue":6961}},"msPressureMeasurement":{"attributes":{"16":10053,"20":-1,"measuredValue":996,"scale":-1,"scaledValue":9968}},"genBasic":{"attributes":{"65281":{"1":2955,"4":17320,"5":8280,"6":[0,1],"10":46527,"100":616,"101":7085,"102":99681},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20161129","swBuildId":"3000-0001"}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20161129","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782168904},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","supports":"temperature, humidity and pressure","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d0002c9d072"}
      2020-10-27 08:05:37.544 - info: zigbee.0 (13979) 0x00158d0002c9d072 (addr 43423): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2020-10-27 08:05:37.545 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d00024de635","_networkAddress":7401,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":7401,"deviceIeeeAddress":"0x00158d00024de635","clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":16,"4":5032,"5":51,"6":[0,1],"10":0,"100":1},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001","modelId":"lumi.sensor_magnet.aq2"}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780541069},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00024de635"}
      2020-10-27 08:05:37.546 - info: zigbee.0 (13979) 0x00158d00024de635 (addr 7401): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.547 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d000275b69f","_networkAddress":23785,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":23785,"deviceIeeeAddress":"0x00158d000275b69f","clusters":{"genBasic":{"attributes":{"65281":{"1":2995,"3":24,"4":17320,"5":52,"6":[0,1],"10":8642,"100":1},"modelId":"lumi.sensor_magnet.aq2"}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780251735},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000275b69f"}
      2020-10-27 08:05:37.548 - info: zigbee.0 (13979) 0x00158d000275b69f (addr 23785): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.549 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":16,"_type":"EndDevice","_ieeeAddr":"0x00158d00027cef69","_networkAddress":44993,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,25,18],"outputClusters":[0,4,3,5,25,18],"deviceNetworkAddress":44993,"deviceIeeeAddress":"0x00158d00027cef69","clusters":{"genBasic":{"attributes":{"65281":{"1":2995,"3":19,"4":5032,"5":111,"6":[0,1],"10":0,"151":0,"152":413,"153":323,"154":4},"manufacturerName":"LUMI","powerSource":3,"modelId":"lumi.sensor_cube.aqgl01","appVersion":5}}},"_binds":[],"meta":{}},{"ID":2,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":44993,"deviceIeeeAddress":"0x00158d00027cef69","clusters":{"genMultistateInput":{"attributes":{"presentValue":2}}},"_binds":[],"meta":{}},{"ID":3,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":44993,"deviceIeeeAddress":"0x00158d00027cef69","clusters":{"genAnalogInput":{"attributes":{"65285":500,"presentValue":-15.15999984741211}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_cube.aqgl01","_applicationVersion":5,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603780769819},"mapped":{"zigbeeModel":["lumi.sensor_cube","lumi.sensor_cube.aqgl01"],"model":"MFKZQ01LM","vendor":"Xiaomi","description":"Mi/Aqara smart home cube","supports":"shake, wakeup, fall, tap, slide, flip180, flip90, rotate_left and rotate_right","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genMultistateInput","type":["attributeReport","readResponse"]},{"cluster":"genAnalogInput","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d00027cef69"}
      2020-10-27 08:05:37.550 - info: zigbee.0 (13979) 0x00158d00027cef69 (addr 44993): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      2020-10-27 08:05:37.551 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":17,"_type":"Router","_ieeeAddr":"0x00158d0001c9a37f","_networkAddress":54656,"_manufacturerID":4454,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":256,"inputClusters":[0,4,3,6,8,5],"outputClusters":[25],"deviceNetworkAddress":54656,"deviceIeeeAddress":"0x00158d0001c9a37f","clusters":{"genBasic":{"attributes":{"modelId":"RS 125","manufacturerName":"innr","powerSource":1,"zclVersion":3,"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20161202-140","swBuildId":"2.1"}},"genOnOff":{"attributes":{"onOff":1}},"genLevelCtrl":{"attributes":{"currentLevel":254}}},"_binds":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":4096,"inputClusters":[4096],"outputClusters":[],"deviceNetworkAddress":54656,"deviceIeeeAddress":"0x00158d0001c9a37f","clusters":{},"_binds":[],"meta":{}}],"_manufacturerName":"innr","_powerSource":"Mains (single phase)","_modelID":"RS 125","_applicationVersion":1,"_stackVersion":2,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20161202-140","_softwareBuildID":"2.1","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603778264705},"mapped":{"exposes":[{"type":"light","features":["state","brightness"]}],"supports":"on/off, brightness","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["alert","flash"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},"[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]"],"zigbeeModel":["RS 125"],"model":"RS 125","vendor":"Innr","description":"GU10 spot","meta":{"applyRedFix":true,"turnsOffAtBrightness1":true}},"name":"0x00158d0001c9a37f"}
      2020-10-27 08:05:37.552 - info: zigbee.0 (13979) 0x00158d0001c9a37f (addr 54656): RS 125 - Innr GU10 spot (Router)
      2020-10-27 08:05:37.553 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0002372735","_networkAddress":663,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":663,"deviceIeeeAddress":"0x00158d0002372735","clusters":{"genBasic":{"attributes":{"65281":{"1":3175,"3":25,"4":5032,"5":79,"6":[0,1],"8":516,"10":46527,"100":0},"modelId":"lumi.sensor_wleak.aq1","appVersion":4}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_wleak.aq1","_applicationVersion":4,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603779051147},"mapped":{"zigbeeModel":["lumi.sensor_wleak.aq1"],"model":"SJCGQ11LM","vendor":"Xiaomi","description":"Aqara water leak sensor","supports":"water leak true/false","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"ssIasZone","type":"commandStatusChangeNotification"}],"toZigbee":[]},"name":"0x00158d0002372735"}
      2020-10-27 08:05:37.554 - info: zigbee.0 (13979) 0x00158d0002372735 (addr 663): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      2020-10-27 08:05:37.555 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":19,"_type":"EndDevice","_ieeeAddr":"0x00158d0002375ca9","_networkAddress":53996,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":53996,"deviceIeeeAddress":"0x00158d0002375ca9","clusters":{"genBasic":{"attributes":{"65281":{"1":3015,"3":25,"4":5032,"5":29,"6":[0,1],"8":516,"10":8642,"100":1},"modelId":"lumi.sensor_wleak.aq1","appVersion":4}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_wleak.aq1","_applicationVersion":4,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603779824950},"mapped":{"zigbeeModel":["lumi.sensor_wleak.aq1"],"model":"SJCGQ11LM","vendor":"Xiaomi","description":"Aqara water leak sensor","supports":"water leak true/false","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"ssIasZone","type":"commandStatusChangeNotification"}],"toZigbee":[]},"name":"0x00158d0002375ca9"}
      2020-10-27 08:05:37.556 - info: zigbee.0 (13979) 0x00158d0002375ca9 (addr 53996): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      2020-10-27 08:05:37.557 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":20,"_type":"Router","_ieeeAddr":"0x00124b0018ed2456","_networkAddress":8642,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":8642,"deviceIeeeAddress":"0x00124b0018ed2456","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"686/0x00124B0018ED227D","inactiveText":"CHILD_FFD_RXI","presentValue":0,"relinquishDefault":3,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782298706},"mapped":{"zigbeeModel":["lumi.router"],"model":"CC2530.ROUTER","vendor":"Custom devices (DiY)","description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","supports":"state, description, type, rssi","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBinaryValue","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["trigger","interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}]},"name":"0x00124b0018ed2456"}
      2020-10-27 08:05:37.557 - info: zigbee.0 (13979) 0x00124b0018ed2456 (addr 8642): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
      2020-10-27 08:05:37.558 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":21,"_type":"Router","_ieeeAddr":"0x00124b0018ed1840","_networkAddress":46527,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":46527,"deviceIeeeAddress":"0x00124b0018ed1840","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genBinaryValue":{"attributes":{"description":"13940/0x00158D000247EA61","inactiveText":"CHILD_RFD","presentValue":106,"relinquishDefault":3,"minimumOffTime":2}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782300315},"mapped":{"zigbeeModel":["lumi.router"],"model":"CC2530.ROUTER","vendor":"Custom devices (DiY)","description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","supports":"state, description, type, rssi","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBinaryValue","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["trigger","interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}]},"name":"0x00124b0018ed1840"}
      2020-10-27 08:05:37.559 - info: zigbee.0 (13979) 0x00124b0018ed1840 (addr 46527): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
      2020-10-27 08:05:37.560 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":22,"_type":"EndDevice","_ieeeAddr":"0x00158d000252be87","_networkAddress":30425,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":30425,"deviceIeeeAddress":"0x00158d000252be87","clusters":{"genBasic":{"attributes":{"65281":{"1":2995,"3":25,"4":5032,"5":53,"6":[0,1],"10":46527,"100":0},"modelId":"lumi.sensor_magnet.aq2","appVersion":3}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603779834400},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","supports":"contact","meta":{"battery":{"voltageToPercentage":"CR2032"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[]},"name":"0x00158d000252be87"}
      2020-10-27 08:05:37.561 - info: zigbee.0 (13979) 0x00158d000252be87 (addr 30425): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2020-10-27 08:05:37.562 - debug: zigbee.0 (13979) New device event: {"type":"device","device":{"ID":23,"_type":"Router","_ieeeAddr":"0x00124b0018ed227d","_networkAddress":686,"_manufacturerID":4447,"_endpoints":[{"ID":8,"profileID":260,"deviceID":256,"inputClusters":[0,6],"outputClusters":[0,6],"deviceNetworkAddress":686,"deviceIeeeAddress":"0x00124b0018ed227d","clusters":{"genBasic":{"attributes":{"modelId":"lumi.router","manufacturerName":"LUMI","powerSource":1,"zclVersion":1,"hwVersion":1,"dateCode":"2018-09-26"}},"genOnOff":{"attributes":{"onOff":1}},"genBinaryValue":{"attributes":{"description":"0/0x00212EFFFF054FDD","inactiveText":"COORD","presentValue":110,"relinquishDefault":2,"minimumOffTime":0}}},"_binds":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Mains (single phase)","_modelID":"lumi.router","_zclVersion":1,"_hardwareVersion":1,"_dateCode":"2018-09-26","_interviewCompleted":true,"_interviewing":false,"meta":{},"_lastSeen":1603782337364},"mapped":{"zigbeeModel":["lumi.router"],"model":"CC2530.ROUTER","vendor":"Custom devices (DiY)","description":"[CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/)","supports":"state, description, type, rssi","fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBinaryValue","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["trigger","interval"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]}]},"name":"0x00124b0018ed227d"}
      2020-10-27 08:05:37.563 - info: zigbee.0 (13979) 0x00124b0018ed227d (addr 686): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
      2020-10-27 08:05:37.564 - info: zigbee.0 (13979) Zigbee started
      2020-10-27 08:05:37.589 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 11
      2020-10-27 08:05:37.608 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr.: 11 status: 5
      2020-10-27 08:05:37.640 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 12
      2020-10-27 08:05:37.645 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0x2ae request id: 1 confirm status: 0
      2020-10-27 08:05:37.646 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.647 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter sendZclFrameToEndpoint - message send with transSeq Nr.: 151
      2020-10-27 08:05:37.690 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x2ae EP:8 SeqNr. 14 request id: 3
      2020-10-27 08:05:37.697 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 3 status: 0
      2020-10-27 08:05:37.698 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.702 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10100110
      2020-10-27 08:05:37.703 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.749 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 15
      2020-10-27 08:05:37.780 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0x2ae request id: 2 confirm status: 0
      2020-10-27 08:05:37.781 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.781 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter sendZclFrameToEndpoint - message send with transSeq Nr.: 152
      2020-10-27 08:05:37.800 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 17
      2020-10-27 08:05:37.804 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0x2ae request id: 3 confirm status: 0
      2020-10-27 08:05:37.805 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:37.806 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:adapter sendZclFrameToEndpoint - message send with transSeq Nr.: 153
      2020-10-27 08:05:37.850 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 18
      2020-10-27 08:05:37.854 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - seqNr.: 18 status: 5
      2020-10-27 08:05:37.900 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 20
      2020-10-27 08:05:37.904 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - seqNr.: 20 status: 5
      2020-10-27 08:05:37.949 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 21
      2020-10-27 08:05:37.953 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - seqNr.: 21 status: 5
      2020-10-27 08:05:38.000 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 22
      2020-10-27 08:05:38.004 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - seqNr.: 22 status: 5
      2020-10-27 08:05:38.050 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 23
      2020-10-27 08:05:38.053 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - seqNr.: 23 status: 5
      2020-10-27 08:05:38.524 - debug: zigbee.0 (13979) Publish available for 0x00158d00029a5b0f = true
      2020-10-27 08:05:38.530 - debug: zigbee.0 (13979) Publish available for 0x00158d0002739b1c = true
      2020-10-27 08:05:38.532 - debug: zigbee.0 (13979) Publish available for 0x00158d000252c8fd = true
      2020-10-27 08:05:38.534 - debug: zigbee.0 (13979) Publish available for 0x00158d000251ea06 = true
      2020-10-27 08:05:38.537 - debug: zigbee.0 (13979) Publish available for 0x680ae2fffe8f6ab5 = true
      2020-10-27 08:05:38.539 - debug: zigbee.0 (13979) Publish available for 0x680ae2fffe924068 = true
      2020-10-27 08:05:38.540 - debug: zigbee.0 (13979) Publish available for 0x00158d000247ea61 = true
      2020-10-27 08:05:38.544 - debug: zigbee.0 (13979) Publish available for 0x00158d00023a7f6d = true
      2020-10-27 08:05:38.545 - debug: zigbee.0 (13979) Publish available for 0x00158d0002c9d072 = true
      2020-10-27 08:05:38.546 - debug: zigbee.0 (13979) Publish available for 0x00158d00024de635 = true
      2020-10-27 08:05:38.550 - debug: zigbee.0 (13979) Publish available for 0x00158d000275b69f = true
      2020-10-27 08:05:38.551 - debug: zigbee.0 (13979) Publish available for 0x00158d00027cef69 = true
      2020-10-27 08:05:38.556 - debug: zigbee.0 (13979) Publish available for 0x00158d0001c9a37f = true
      2020-10-27 08:05:38.557 - debug: zigbee.0 (13979) Publish available for 0x00158d0002372735 = true
      2020-10-27 08:05:38.558 - debug: zigbee.0 (13979) Publish available for 0x00158d0002375ca9 = true
      2020-10-27 08:05:38.559 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed2456 = true
      2020-10-27 08:05:38.568 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed1840 = true
      2020-10-27 08:05:38.569 - debug: zigbee.0 (13979) Publish available for 0x00158d000252be87 = true
      2020-10-27 08:05:38.569 - debug: zigbee.0 (13979) Publish available for 0x00124b0018ed227d = true
      2020-10-27 08:05:40.771 - debug: zigbee.0 (13979) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-27 08:05:40.777 - debug: zigbee.0 (13979) getGroups result: {}
      2020-10-27 08:05:40.777 - debug: zigbee.0 (13979) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-27 08:05:40.813 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 24 request id: 4
      2020-10-27 08:05:40.818 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_REQUEST RESPONSE - request id: 4 status: 0
      2020-10-27 08:05:40.820 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 0 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:40.821 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DEVICE_STATE changed: 10101110
      2020-10-27 08:05:40.822 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 1 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:40.863 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_CONFIRM - sending data state request - SeqNr. 25
      2020-10-27 08:05:40.867 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_CONFIRM RESPONSE - destAddr: 0x0 request id: 4 confirm status: 0
      2020-10-27 08:05:40.868 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver networkstate: 2 apsDataConfirm: 0 apsDataIndication: 1 configChanged: 0 apsRequestFreeSlots: 1
      2020-10-27 08:05:40.952 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:driver DATA_INDICATION - sending read data request - SeqNr. 26
      2020-10-27 08:05:40.954 - debug: zigbee.0 (13979) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
      2020-10-27 08:05:40.955 - debug: zigbee.0 (13979) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
      2020-10-27 08:05:40.959 - debug: zigbee.0 (13979) zigbee-herdsman:deconz:frameParser DATA_INDICATION RESPONSE - seqNr. 26 srcAddr: 0x0 destAddr: 0x0 profile id: 0x0 cluster id: 0x8031
      McDagobert99
    • RE: Zigbee/Conbee2 / Netzwerkkarte Funktioniert nicht.
      @Asgothian
      habe die Osram Steckdose gelöscht und vom Strom genommen.
      Auch nach nach einer Wartezeit von mehreren Stunden hat sich an der Ansicht nicht geändert. Geräte all in Rot und keine Anzeige einer Verbindung (Auf der Map kann ich das senden der einzelnen Geräte aber sehne(blaues aufleuchten))
      Mfg
      Frank
      McDagobert99
    • Zigbee/Conbee2 / Netzwerkkarte Funktioniert nicht.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC / Proxmox / 8GB
      Arbeitsspeicher: 5GB
      Festplattenart: SSD
      Betriebssystem: VM / Debian
      Node-Version: 10.x.x
      Nodejs-Version: 14.13.0
      NPM-Version: 6.14.8
      Installationsart: Manuell
      Image genutzt: Nein
      habe ein Problem mit der Netzwerkkarte im Zigbee-Adapter (Vers. 1.3.0).
      Diese Zeigt keine Verbindungen an und alle Geräte sind rot.
      Nur die Verbindungstärke schein nicht plausibel zu sein und springen stark.
      Im Log habe ich folgende Meldung gefunden.
      2020-10-26 00:14:29.140  - debug: zigbee.0 (3041) zigbee-herdsman:deconz:adapter ROUTING_TABLE REQUEST FAILED - addr: 0xb6e5 Error: Routingtables for '46821' failed
      2020-10-26 00:14:29.142  - debug: zigbee.0 (3041) Failed to get map: "TypeError: Cannot read property 'stack' of undefined\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:532:115)"
      Netzwerkkarte:
      Geräte:
      Adapter neu installiert, auch die 1.3.1 ausprobiert. Einzelne Geräte neu angelernt.
      Komme leider erst mal nicht weiter. ☹
      Mfg
      Frank
      PS.
      Da ich meine Zigbee Netzwerk gerade erst aufbaue, würde mir die Netzwerkkarte erleichtern wo ich die Repeater am besten platzieren kann, bzw. wo eventuell noch welche fehlen.
      McDagobert99
