    2. siggi25
    • Posts 11
    siggi25
    @siggi25
    14
    siggi25 Follow
    Latest posts made by siggi25
    • RE: Cloud Adapter nicht erreichbar
      Vielen Dank trotzdem für deine Hilfe, kannst du mir jemanden sagen,
      der sich mit lxc netzwerk auskennt ?
      Gruß Gisela
      posted in Cloud Dienste
      siggi25
      @thomas-braun said in Cloud Adapter nicht erreichbar:
      systemctl status networking.service
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat Sep 14 21:27:39 CEST 2024 on tty1
      goppel@iobroker:~$ systemctl status networking.service
      x networking.service - Raise network interfaces
           Loaded: loaded (/lib/systemd/system/networking.service; enabled; preset: enabled)
           Active: failed (Result: timeout) since Sat 2024-09-14 21:27:10 CEST; 25min ago
             Docs: man:interfaces(5)
          Process: 68 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
          Process: 164 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited, status=0/SUCCESS)
         Main PID: 68 (code=exited, status=1/FAILURE)
              CPU: 66ms
      Sep 14 21:26:44 iobroker ifup[157]: XMT:  | X-- Request renew in  +3600
      Sep 14 21:26:44 iobroker ifup[157]: XMT:  | X-- Request rebind in +5400
      Sep 14 21:26:44 iobroker ifup[157]: XMT: Solicit on eth0, interval 128150ms.
      Sep 14 21:26:44 iobroker dhclient[157]: XMT: Solicit on eth0, interval 128150ms.
      Sep 14 21:27:10 iobroker systemd[1]: networking.service: start operation timed out. Terminating.
      Sep 14 21:27:10 iobroker systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
      Sep 14 21:27:10 iobroker ifup[68]: Got signal Terminated, terminating...
      Sep 14 21:27:10 iobroker ifup[68]: ifup: failed to bring up eth0
      Sep 14 21:27:10 iobroker systemd[1]: networking.service: Failed with result 'timeout'.
      Sep 14 21:27:10 iobroker systemd[1]: Failed to start networking.service - Raise network interfaces.
      siggi25
      sudo usermod -aG adm goppel
      habe ich gemacht
      siggi25
      === Mark text until here for copying ===
           Active: failed (Result: timeout) since Sat 2024-09-14 21:27:10 CEST; 6min ago
          Process: 68 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILU>
          Process: 164 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited,>
              CPU: 66ms
      Warning: some journal files were not opened due to insufficient permissions.
      siggi25
      hier der neue post
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-1-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       21:28:12 up 6 min,  2 users,  load average: 0.70, 0.47, 0.38
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sat 2024-09-14 21:28:12 CEST
                 Universal time: Sat 2024-09-14 19:28:12 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      goppel
      HOME=/home/goppel
      GROUPS=goppel sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             10G        1.5G        8.9G        114K        350M        9.3G
      Swap:           536M          0B        536M
      Total:           11G        1.5G        9.5G
      Active iob-Instances:   15
              10240 M total memory
               1396 M used memory
               1492 M active memory
                164 M inactive memory
               8509 M free memory
                  0 M buffer memory
                334 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 21:28:13 up 6 min,  2 users,  load average: 0.70, 0.47, 0.38
      Tasks:  41 total,   2 running,  39 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  10240.0 total,   8504.0 free,   1401.6 used,    334.5 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   8838.4 avail Mem
      *** FAILED SERVICES ***
        UNIT               LOAD   ACTIVE SUB    DESCRIPTION
      * networking.service loaded failed failed Raise network interfaces
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--1 ext4    63G   11G   49G  19% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.7G     0  7.7G   0% /dev/shm
      tmpfs                            tmpfs  3.1G  108K  3.1G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      [Sat Sep 14 10:25:57 2024] EXT4-fs (dm-1): mounted filesystem d9fd98c6-824d-40e5-a7d6-446096448298 ro with ordered data mode. Quota mode: none.
      [Sat Sep 14 10:25:57 2024] EXT4-fs (dm-1): re-mounted d9fd98c6-824d-40e5-a7d6-446096448298 r/w. Quota mode: none.
      [Sat Sep 14 10:26:05 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 10:42:52 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
      [Sat Sep 14 10:42:58 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 11:01:25 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
      [Sat Sep 14 11:01:36 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 19:23:45 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
      [Sat Sep 14 19:23:49 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 19:24:16 2024] EXT4-fs (dm-11): mounted filesystem c49b7add-f631-4847-a7d4-926e242cf401 r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 19:26:38 2024] EXT4-fs (dm-11): unmounting filesystem c49b7add-f631-4847-a7d4-926e242cf401.
      [Sat Sep 14 19:27:28 2024] EXT4-fs (dm-11): mounted filesystem c49b7add-f631-4847-a7d4-926e242cf401 r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 19:27:58 2024] EXT4-fs (dm-11): unmounting filesystem c49b7add-f631-4847-a7d4-926e242cf401.
      [Sat Sep 14 19:55:25 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
      [Sat Sep 14 19:57:40 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      [Sat Sep 14 21:22:07 2024] EXT4-fs (dm-9): unmounting filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f.
      [Sat Sep 14 21:22:07 2024] EXT4-fs (dm-9): mounted filesystem a9d197f4-76a5-4a16-9686-bd5f9d7a890f r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--100--disk--1 ext4       rw,relatime,stripe=32
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3217104k,nr_inodes=819200,mode=755,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc                           rpc_pipefs rw,relatime
      | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/hugepages                                      hugetlbfs                        hugetlbfs  rw,relatime,pagesize=2M
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64
      | | `-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      845M    /var/
      365M    /var/log
      364M    /var/log/journal/8c4501404c6148fea043b969672b388d
      334M    /var/cache
      Archived and active journals take up 28.6M in the file system.
      /opt/iobroker/backups:
      339M    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      1.7G    /opt/iobroker/iobroker-data/
      1.5G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      35M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.be60e800.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.0
      javascript:     8.8.3
      nodejs modules from github:     2
      +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#53944cad71449ceaa41c275f432df5423f218054)
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      Adapter State
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 42010
        system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
        system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
        system.adapter.material.0               : material              : iobroker                                 - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
        system.adapter.myvbus.0                 : myvbus                : iobroker                                 -  enabled
        system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        system.adapter.resol.0                  : resol                 : iobroker                                 - disabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
        system.adapter.senec.0                  : senec                 : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.0.139
        system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
        system.adapter.tedee.0                  : tedee                 : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
        system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
        system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.0.117:6638
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.1.0    , installed 7.1.0
      Adapter    "alarm"        : 3.6.2    , installed 3.6.2
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.1.0 , installed 0.1.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-icons8" : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "iot"          : 3.4.0    , installed 3.4.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "myvbus"       : 0.4.0    , installed 0.4.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "ping"         : 1.7.3    , installed 1.7.3
      Adapter    "resol"        : 1.3.0    , installed 1.3.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "senec"        : 1.6.14   , installed 1.6.14
      Adapter    "shelly"       : 8.1.1    , installed 8.1.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
      Adapter    "tedee"        : 0.3.2    , installed 0.3.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-2-widgets-weather-and-heating": 0.7.0, installed 0.7.0
      Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.3.0    , installed 6.3.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        24304
      States:         18441
      Hit:1 http://deb.debian.org/debian bookworm InRelease
      Hit:2 http://security.debian.org bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 192.168.0.139:1886      0.0.0.0:*               LISTEN      1000       1897625    655/io.sonoff.0
      tcp        0      0 192.168.0.139:42010     0.0.0.0:*               LISTEN      1000       1891943    510/io.hm-rpc.1
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1876529    1/init
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1895031    612/io.shelly.1
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1887923    328/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1888055    165/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1889254    165/iobroker.js-con
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1876530    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1877864    1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1891141    339/io.admin.0
      tcp6       0      0 :::29170                :::*                    LISTEN      1000       1897869    909/io.tedee.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1887924    328/master
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1896713    558/io.shelly.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1877773    1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1891262    440/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          1876531    1/init
      udp6       0      0 :::1900                 :::*                                1000       1891264    440/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       1891263    440/io.deconz.0
      2024-09-14 21:28:21.605  - info: cloud.0 (975) Connection changed: disconnect
      2024-09-14 21:28:24.476  - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 1004
      2024-09-14 21:28:24.664  - info: shelly.1 (612) [MQTT] Device with client id "shellypro1-30c6f7814ca8" connected!
      2024-09-14 21:28:25.198  - info: discovery.0 (1004) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
      2024-09-14 21:28:28.572  - info: host.iobroker instance system.adapter.energiefluss.0 in version "3.6.0" (non-npm: SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054) started with pid 1051
      2024-09-14 21:28:29.267  - info: energiefluss.0 (1051) starting. Version 3.6.0 (non-npm: SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054) in /opt/iobroker/node_modules/iobroker.energiefluss, node: v20.17.0, js-controller: 6.0.11
      2024-09-14 21:28:29.273  - info: energiefluss.0 (1051) Starting Energiefluss Adapter
      2024-09-14 21:28:29.324  - warn: energiefluss.0 (1051) The adapter could not find the state shelly.1.SHSW-25#8CAAB55517CD#1.Relay1.Power! Please review your configuration of the adapter!
      2024-09-14 21:28:29.325  - warn: energiefluss.0 (1051) The adapter could not find the state sonoff.0.Kuehlschrank .ENERGY_Power! Please review your configuration of the adapter!
      2024-09-14 21:28:29.326  - warn: energiefluss.0 (1051) The adapter could not find the state hm-rpc.1.0001D3C99C7EDA.6! Please review your configuration of the adapter!
      2024-09-14 21:28:29.327  - info: energiefluss.0 (1051) Method "deleteState" is deprecated and will be removed in js-controller 7, use "delObject" instead
      2024-09-14 21:28:29.328  - info: energiefluss.0 (1051) Adapter started and listening to 13 States
      2024-09-14 21:28:32.468  - info: host.iobroker instance system.adapter.homekit-controller.0 in version "0.5.10" started with pid 1625
      MOD-EDIT :Code in code-tags gesetzt!
      siggi25
      habe mich schon mit meinem Benutzer eingeloggt
      siggi25
      Wie kann ich herausfinden, was nicht stimmt
      vielen DAnk
      siggi25
      Skript v.2024-05-22
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
       20:33:36 up 35 min,  2 users,  load average: 0.12, 0.23, 0.24
      CPU threads: 4
                     Local time: Sat 2024-09-14 20:33:36 CEST
                 Universal time: Sat 2024-09-14 18:33:36 UTC
                       RTC time: n/a
                RTC in local TZ: no
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             10G        2.4G        7.6G        110K        773M        8.4G
      Swap:           536M          0B        536M
      Total:           11G        2.4G        8.1G
      Active iob-Instances:   31
               2271 M used memory
               2237 M active memory
                594 M inactive memory
               7230 M free memory
                  0 M buffer memory
                738 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 20:33:36 up 35 min,  2 users,  load average: 0.12, 0.23, 0.24
      Tasks:  56 total,   1 running,  55 sleeping,   0 stopped,   0 zombie
      MiB Mem :  10240.0 total,   7229.2 free,   2272.9 used,    738.1 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7967.1 avail Mem
      *** FILESYSTEM ***
      /dev/mapper/pve-vm--100--disk--1 ext4    63G   11G   49G  18% /
      tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
      /var:
      821M    /var/
      341M    /var/log
      340M    /var/log/journal/8c4501404c6148fea043b969672b388d
      334M    /var/cache
      Archived and active journals take up 339.5M in the file system.
      37M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      HINT:
      tcp
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.1.0
      javascript:     8.8.3
      Adapter State
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.myvbus.0                 : myvbus                : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.0.139
      + system.adapter.tedee.0                  : tedee                 : iobroker                                 -  enabled
      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Objects and States
      Objects:        24302
      States:         18494
      Pending Updates: 2
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1612848    161/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1607658    161/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1597892    1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1609629    324/master
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1615477    797/io.shelly.1
      tcp        0      0 192.168.0.139:1886      0.0.0.0:*               LISTEN      1000       1616517    835/io.sonoff.0
      tcp        0      0 192.168.0.139:42010     0.0.0.0:*               LISTEN      1000       1618012    690/io.hm-rpc.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1601033    1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1600937    1/init
      tcp6       0      0 :::29170                :::*                    LISTEN      1000       1616620    899/io.tedee.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1609630    324/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1608546    430/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1626372    1847/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       1623978    1862/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1620727    1494/io.simple-api.
      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       1624240    1509/io.terminal.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1618484    1074/io.homekit-con
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1618119    771/io.shelly.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1597893    1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1616164    586/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          1597894    1/init
      udp6       0      0 :::1900                 :::*                                1000       1616166    586/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1000       1616165    586/io.deconz.0
      2024-09-14 20:17:25.805  - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
      2024-09-14 20:17:41.503  - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
      2024-09-14 20:17:41.503  - info: iot.0 (1468) Connection changed: disconnect
      2024-09-14 20:18:25.550  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
      2024-09-14 20:18:25.805  - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
      2024-09-14 20:19:25.550  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
      2024-09-14 20:19:25.763  - info: cloud.0 (956) Connection changed: connect
      2024-09-14 20:19:49.730  - info: iot.0 (1468) Connection changed: connect "g_oppel_web_de"
      2024-09-14 20:25:05.767  - error: cloud.0 (956) Ping timeout
      2024-09-14 20:25:11.814  - info: homekit-controller.0 (1074) IP-0B:C9:1D:29:14:8F (LG webOS TV 70CD) found without known pairing data and already paired: ignoring
      2024-09-14 20:25:12.908  - info: homekit-controller.0 (1074) IP-0B:C9:1D:29:14:8F (LG webOS TV 70CD) found without known pairing data and already paired: ignoring
      2024-09-14 20:26:05.772  - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
      2024-09-14 20:26:05.904  - info: cloud.0 (956) Connection changed: connect
      siggi25
      wie bekomme ich das komplette script herein in den post
      siggi25
      @mcm1957
        v.2024-05-22
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                0
      Pending OS-Updates:     2
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json": timeout of 10000ms exceeded
      Cannot download repository file from "http://download.iobroker.net/sources-dist-latest.json": timeout of 10000ms exceeded
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.17.0 and npm 10.8.2
      MEMORY:
      Mem:             10G        2.3G        7.7G        102K        767M        8.5G
      Swap:           536M          0B        536M
      Total:           11G        2.3G        8.2G
      Active iob-Instances:   23
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.1.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                24302
      States:                 18542
      Size of iob-Database:
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      4.4M    /opt/iobroker/iobroker-data/states.jsonl
      iobroker diag funktioniert nicht kann die Diagnose nicht senden Fehler im iobroker
      2024-09-14 20:07:26.112 - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
      2024-09-14 20:07:39.354 - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
      2024-09-14 20:07:39.355 - info: iot.0 (1468) Connection changed: disconnect
      2024-09-14 20:08:25.546 - info: cloud.0 (956) Trying to connect as system.user.admin to cloud
      2024-09-14 20:08:25.815 - error: cloud.0 (956) Error while connecting to cloud: Error: websocket error
      2024-09-14 20:09:01.382 - error: iot.0 (1468) Error by device connection: {"code":"ETIMEDOUT"}
      Der cloud Adapter ist manchmal für kurze Zeit online die Verbindung bricht aber immer wieder ab., was kann ich da tun
      siggi25
