    2. Thomas Brodmann
    • Posts 52
    Thomas Brodmann
    @Thomas Brodmann
    97
    52
    Thomas Brodmann Follow
    Latest posts made by Thomas Brodmann
    • RE: Error 25
      Da seit ihr besser in dem Thema als ich.
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      thommy@DietPi:~$ iobroker stop
      Stopping iobroker controller daemon...
      iobroker controller daemon stopped.
      No "killall.sh" script found. Just stop.
      thommy@DietPi:~$ iobroker fix
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installation fixer!
          Script version: 2022-06-03
          Installing prerequisites (1/3)
      [sudo] Passwort für thommy:
      OK:1 https://deb.debian.org/debian bullseye InRelease
      OK:2 https://deb.debian.org/debian bullseye-updates InRelease
      OK:3 https://deb.debian.org/debian-security bullseye-security InRelease
      OK:4 https://deb.debian.org/debian bullseye-backports InRelease
      OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
      OK:5 https://armbian.site-meganet.com/apt bullseye InRelease
      Paketlisten werden gelesen… Fertig
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      thommy@DietPi:~$ iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 2094
      thommy@DietPi:~$
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      Steht aber so in der Beschreibung:
      Node.js neu installieren für Linux und Raspberry 2/3
      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      sudo apt install -y nodejs
      sudo reboot]
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      Node und nodejs muss doch als sudo installiert werden.
      Oder nicht?
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      @homoran sagte in Error 25:
      sudo ls -la /home/thommy/
      thommy@DietPi:/opt/iobroker$ sudo ls -la /home/thommy/
      insgesamt 64
      drwxr-xr-x 9 thommy thommy 4096 15. Jun 19:58 .
      drwxr-xr-x 5 root   root   4096 15. Jun 20:09 ..
      -rw------- 1 thommy thommy 5313 15. Jun 16:44 .bash_history
      -rw-r--r-- 1 thommy thommy  220  4. Nov 2021  .bash_logout
      -rw-r--r-- 1 thommy thommy 3716 15. Jun 19:58 .bashrc
      drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .cache
      drwx------ 4 thommy thommy 4096  4. Nov 2021  .config
      drwxr-xr-x 3 thommy thommy 4096 15. Jun 12:49 i0broker
      drwxr-xr-x 2 thommy thommy 4096  4. Nov 2021  .iobroker
      drwx------ 3 thommy thommy 4096  4. Nov 2021  .local
      lrwxrwxrwx 1 root   root     13 15. Jun 18:31 node -> /usr/bin/node
      lrwxrwxrwx 1 root   root     15 15. Jun 18:31 nodejs -> /usr/bin/nodejs
      -rw------- 1 thommy thommy    0 15. Jun 18:37 .node_repl_history
      drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .npm
      -rw------- 1 thommy thommy   36 15. Jun 14:09 .npmrc
      -rw-r--r-- 1 thommy thommy  807  4. Nov 2021  .profile
      drwxr-xr-x 3 thommy thommy 4096  4. Nov 2021  .terminfo
      -rw-r--r-- 1 thommy thommy 2945  1. Mai 07:27 terminfo.txt
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      thommy@DietPi:/opt/iobroker$ ls -la /home/
      insgesamt 20
      drwxr-xr-x 18 root     root     4096 29. Mai 14:11 ..
      drwxr-xr-x  2 dietpi   dietpi   4096 19. Okt 2021  dietpi
      drwxr-xr-x  3 iobroker iobroker 4096 15. Jun 20:11 iobroker
      drwxr-xr-x  9 thommy   thommy   4096 15. Jun 19:58 thommy
      Vielen lieben Dank für eure Großartige hilfe!!!
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      Das Anlegen des Ordners hat geholfen.
      thommy@DietPi:/opt/iobroker$ sudo mkdir /home/iobroker
      thommy@DietPi:/opt/iobroker$ sudo chown iobroker:iobroker /home/iobroker
      thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
      NPM version: 6.14.17
      Installing iobroker.sonoff@2.5.1... (System call)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      + iobroker.sonoff@2.5.1
      added 15 packages from 19 contributors in 37.07s
      38 packages are looking for funding
        run `npm fund` for details
      host.DietPi install adapter sonoff
      upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
      upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
      upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
      upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
      host.DietPi object system.adapter.sonoff created/updated
      host.DietPi create instance sonoff
      host.DietPi object system.adapter.sonoff.0.alive created
      host.DietPi object system.adapter.sonoff.0.connected created
      host.DietPi object system.adapter.sonoff.0.compactMode created
      host.DietPi object system.adapter.sonoff.0.cpu created
      host.DietPi object system.adapter.sonoff.0.cputime created
      host.DietPi object system.adapter.sonoff.0.memHeapUsed created
      host.DietPi object system.adapter.sonoff.0.memHeapTotal created
      host.DietPi object system.adapter.sonoff.0.memRss created
      host.DietPi object system.adapter.sonoff.0.uptime created
      host.DietPi object system.adapter.sonoff.0.inputCount created
      host.DietPi object system.adapter.sonoff.0.outputCount created
      host.DietPi object system.adapter.sonoff.0.eventLoopLag created
      host.DietPi object system.adapter.sonoff.0.sigKill created
      host.DietPi object system.adapter.sonoff.0.logLevel created
      host.DietPi object sonoff.0.info created
      host.DietPi object sonoff.0.info.connection created
      host.DietPi object system.adapter.sonoff.0 created
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      insgesamt 16
      drwxr-xr-x  4 root   root   4096 15. Jun 13:36 .
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      thommy@DietPi:/opt/iobroker$ sudo -H -u iobroker iobroker add sonoff --host DietPi
      host.DietPi Cannot install iobroker.sonoff@2.5.1: 243
      Thomas Brodmann
      Thomas Brodmann
    • RE: Error 25
      @thomas-braun sagte in Error 25:
      sudo -u iobroker ls -la /home/iobroker
      thommy@DietPi:/opt/iobroker$ sudo -u iobroker whoami
      iobroker
      thommy@DietPi:/opt/iobroker$ sudo -u iobroker ls -la /home/iobroker
      ls: Zugriff auf '/home/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
      Thomas Brodmann
      Thomas Brodmann
