    2. MarvinH
    • Posts 11
    MarvinH
    @MarvinH
    MarvinH Follow
    Latest posts made by MarvinH
    • RE: [gelöst] Adapter-Update funktioniert nicht - ohne Fehler
      @crunchip
      @Thomas-Braun
      Danke euch. Tolle, schnelle Hilfe. Alle Adapter laufen jetzt wieder auf dem neuesten Stand!
      MarvinH
      @thomas-braun said in Adapter-Update funktioniert nicht - ohne Fehlermeldung:
      iobroker del nightscout
      iobroker add simple-api
      pi@raspberrypi4-iob:/opt/iobroker $
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker del nightscout
      Delete adapter "nightscout"
      host.raspberrypi4-iob Counted 1 meta of nightscout
      host.raspberrypi4-iob Counted 1 adapter for nightscout
      host.raspberrypi4-iob Counted 2 states (system.adapter.nightscout.*) from states
      host.raspberrypi4-iob file nightscout.admin deleted
      host.raspberrypi4-iob object nightscout deleted
      host.raspberrypi4-iob object nightscout.admin deleted
      host.raspberrypi4-iob Deleting 2 object(s).
      host.raspberrypi4-iob Deleting 2 state(s).
      added 3 packages, and removed 1454 packages in 2m
      75 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker add simple-api
      host.raspberrypi4-iob create instance simple-api
      host.raspberrypi4-iob object system.adapter.simple-api.0.alive created
      host.raspberrypi4-iob object system.adapter.simple-api.0.connected created
      host.raspberrypi4-iob object system.adapter.simple-api.0.compactMode created
      host.raspberrypi4-iob object system.adapter.simple-api.0.cpu created
      host.raspberrypi4-iob object system.adapter.simple-api.0.cputime created
      host.raspberrypi4-iob object system.adapter.simple-api.0.memHeapUsed created
      host.raspberrypi4-iob object system.adapter.simple-api.0.memHeapTotal created
      host.raspberrypi4-iob object system.adapter.simple-api.0.memRss created
      host.raspberrypi4-iob object system.adapter.simple-api.0.uptime created
      host.raspberrypi4-iob object system.adapter.simple-api.0.inputCount created
      host.raspberrypi4-iob object system.adapter.simple-api.0.outputCount created
      host.raspberrypi4-iob object system.adapter.simple-api.0.eventLoopLag created
      host.raspberrypi4-iob object system.adapter.simple-api.0.sigKill created
      host.raspberrypi4-iob object system.adapter.simple-api.0.logLevel created
      host.raspberrypi4-iob object system.adapter.simple-api.0 created
      pi@raspberrypi4-iob:/opt/iobroker $ npm ls
      iobroker.inst@2.0.3 /opt/iobroker
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.admin@6.2.23
      ├── iobroker.backitup@2.4.6
      ├── iobroker.chromecast@2.3.1
      ├── iobroker.daikin@1.4.2
      ├── iobroker.daswetter@3.1.4
      ├── iobroker.discovery@3.1.0
      ├── iobroker.echarts@1.0.12
      ├── iobroker.feiertage@1.1.0
      ├── iobroker.flot@1.11.0
      ├── iobroker.fritzbox@0.2.1
      ├── iobroker.habpanel@0.5.0
      ├── iobroker.history@1.11.1
      ├── iobroker.hm-rega@3.0.40
      ├── iobroker.hm-rpc@1.15.12
      ├── iobroker.ical@1.13.1
      ├── iobroker.icons-open-icon-library-png@0.1.2
      ├── iobroker.icons-ultimate-png@1.0.1
      ├── iobroker.info@1.9.19
      ├── iobroker.iqontrol@2.0.0
      ├── iobroker.javascript@5.7.0
      ├── iobroker.js-controller@4.0.21
      ├── iobroker.klf200@1.0.1
      ├── iobroker.material@1.1.2
      ├── iobroker.ping@1.5.3
      ├── iobroker.shelly@5.3.2
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.smartgarden@2.0.0
      ├── iobroker.socketio@4.2.0
      ├── iobroker.telegram@1.14.1
      ├── iobroker.tr-064@4.2.16
      ├── iobroker.unifi@0.5.10
      ├── iobroker.vis-materialdesign@0.2.66
      ├── iobroker.vis-timeandweather@1.2.2
      ├── iobroker.vis@1.4.15
      ├── iobroker.web@4.3.0
      ├── iobroker.worx@1.5.5
      ├── iobroker.yr@5.3.0
      ├── iobroker@2.0.3
      ├── semver@5.7.1
      └── yargs@7.1.0
      pi@raspberrypi4-iob:/opt/iobroker $ iob upgrade admin --debug
      This upgrade of "admin" will introduce the following changes:
      -> 6.3.5:
      Corrected reading of node.js version
      -> 6.3.4:
      Corrected crashes in object browser
      -> 6.3.3:
      Corrected icons in object browser
      -> 6.3.2:
      Added `useNative` option to `sendTo` JSON Config component
      Added `checkLicense` and `uuid` components to JSON Config
      Corrected the news handler
      Would you like to upgrade admin from @6.2.23 to @6.3.5 now? [(y)es, (n)o]: y
      Update admin from @6.2.23 to @6.3.5
      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.19.3
      Installing iobroker.admin@6.3.5... (System call)
      changed 1 package in 47s
      Update "system.adapter.admin.0"
      upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.raspberrypi4-iob Adapter "system.adapter.admin.0" is started
      pi@raspberrypi4-iob:/opt/iobroker $ iob list adapters
      system.adapter.admin                   : admin          - v6.3.5
      Sieht erst mal sehr gut aus, herzlichen Dank! Ich update gerade noch einmal die anderen Adapter.
      MarvinH
      npm ls
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.nightscout@0.11.2
      ├── UNMET DEPENDENCY iobroker.simple-api@^2.4.6
      ├── iobroker@2.0.3
      ├── semver@5.7.1
      └── yargs@7.1.0
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.simple-api@^2.4.6, required by iobroker.inst@2.0.3
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-23T18_40_57_427Z-debug-0.log
      MarvinH
      @crunchip
      welche?
      Die der simpleapi.
      mach mal jetzt ein
      Gemacht:
      -> 6.3.5:
      -> 6.3.4:
      -> 6.3.3:
      -> 6.3.2:
      NPM version: 8.19.3
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: iobroker.nightscout@0.11.2
      npm ERR! notsup Not compatible with your version of node/npm: iobroker.nightscout@0.11.2
      npm ERR! notsup Required: {"node":"^12.16.1 || ^10.15.2 || ^8.15.1"}
      npm ERR! notsup Actual:   {"npm":"8.19.3","node":"v16.19.0"}
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-23T18_35_32_877Z-debug-0.log
      Ergebnis:
      system.adapter.admin                   : admin          - v6.2.23
      MarvinH
      @crunchip
      Hier die Diagnose:
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Model : Raspberry Pi 4 Model B Rev 1.1
      Architecture: armv7l
      Docker: false
      Virtualization: none
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 10 (buster)
      Release: 10
      Codename: buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
      19:32:16 up 141 days, 23:03, 1 user, load average: 0.98, 1.06, 1.22
      CPU threads: 4
      *** Time and Time Zones ***
      Fri Dec 23 18:32:16 UTC 2022
      Fri Dec 23 19:32:16 CET 2022
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      *** MEMORY ***
      Mem: 3.8G 1.2G 494M 105M 2.1G 2.6G
      Swap: 99M 9.0M 90M
      Total: 3.9G 1.2G 585M
           3827 M total memory
           1240 M used memory
            715 M active memory
           2355 M inactive memory
            494 M free memory
            227 M buffer memory
           1863 M swap cache
             99 M total swap
              9 M used swap
             90 M free swap
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 29G 14G 15G 50% /
      devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev
      tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
      tmpfs tmpfs 1.9G 114M 1.8G 6% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot
      tmpfs tmpfs 383M 0 383M 0% /run/user/1000
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.3G /var/
      1.3G /var/cache/apt
      1.3G /var/cache
      1.2G /var/cache/apt/archives
      901M /var/lib
      /opt/iobroker/backups:
      12M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      5.5G /opt/iobroker/iobroker-data/
      5.1G /opt/iobroker/iobroker-data/iobroker-data
      334M /opt/iobroker/iobroker-data/files
      87M /opt/iobroker/iobroker-data/backup-objects
      78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      27M /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      12M /opt/iobroker/iobroker-data/objects.jsonl
      12M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
      9.2M /opt/iobroker/iobroker-data/objects.json.migrated
      9.2M /opt/iobroker/iobroker-data/objects.json.bak.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs v16.19.0
      /usr/bin/node v16.19.0
      /usr/bin/npm 8.19.3
      nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
      *** 16.19.0-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
      100 /var/lib/dpkg/status
      10.24.0~dfsg-1~deb10u2 500
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 4.0.21
      admin: 6.2.23
      npm ERR! /home/pi/.npm/_logs/2022-12-23T18_32_29_208Z-debug-0.log
      Adapters from github: 0
      • system.adapter.admin.0 : admin : raspberrypi4-iob - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.hm-rpc.0 : hm-rpc : raspberrypi4-iob - enabled, port: 18701
      • system.adapter.hm-rpc.1 : hm-rpc : raspberrypi4-iob - enabled, port: 12001
      • system.adapter.hm-rpc.2 : hm-rpc : raspberrypi4-iob - enabled, port: 12010
      • system.adapter.shelly.0 : shelly : raspberrypi4-iob - enabled, port: 1882, bind: 0.0.0.0
      • system.adapter.telegram.0 : telegram : raspberrypi4-iob - enabled, port: 8443, bind: 0.0.0.0
      • system.adapter.web.0 : web : raspberrypi4-iob - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.3.5 , installed 6.2.23 [Updatable]
      Adapter "backitup" : 2.5.9 , installed 2.4.6 [Updatable]
      Adapter "chromecast" : 2.3.1 , installed 2.3.1
      Adapter "daikin" : 1.4.2 , installed 1.4.2
      Adapter "daswetter" : 3.1.4 , installed 3.1.4
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "echarts" : 1.0.12 , installed 1.0.12
      Adapter "feiertage" : 1.1.0 , installed 1.1.0
      Adapter "flot" : 1.11.0 , installed 1.11.0
      Adapter "fritzbox" : 0.2.1 , installed 0.2.1
      Adapter "habpanel" : 0.5.0 , installed 0.5.0
      Adapter "history" : 2.2.4 , installed 1.11.1 [Updatable]
      Adapter "hm-rega" : 3.0.40 , installed 3.0.40
      Adapter "hm-rpc" : 1.15.12 , installed 1.15.12
      Adapter "ical" : 1.13.2 , installed 1.13.1 [Updatable]
      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter "info" : 1.9.19 , installed 1.9.19
      Adapter "iqontrol" : 2.0.0 , installed 2.0.0
      Adapter "javascript" : 6.1.4 , installed 5.7.0 [Updatable]
      Controller "js-controller": 4.0.23 , installed 4.0.21 [Updatable]
      Adapter "klf200" : 1.0.1 , installed 1.0.1
      Adapter "material" : 1.1.2 , installed 1.1.2
      Adapter "ping" : 1.5.3 , installed 1.5.3
      Adapter "shelly" : 6.0.0 , installed 5.3.2 [Updatable]
      Adapter "smartgarden" : 2.0.0 , installed 2.0.0
      Adapter "socketio" : 4.2.0 , installed 4.2.0
      Adapter "telegram" : 1.15.2 , installed 1.14.1 [Updatable]
      Adapter "tr-064" : 4.2.17 , installed 4.2.16 [Updatable]
      Adapter "unifi" : 0.5.10 , installed 0.5.10
      Adapter "vis" : 1.4.15 , installed 1.4.15
      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter "web" : 4.3.0 , installed 4.3.0
      Adapter "worx" : 2.0.3 , installed 1.5.5 [Updatable]
      Adapter "ws" : 1.3.0 , installed 1.3.0
      Adapter "yr" : 5.3.0 , installed 5.3.0
      Objects and States
      Objects: 10385
      States: 9203
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists... Done
      Pending Updates: 2
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 231046491 22365/iobroker.js-c
      tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 109 14589 319/mongod
      tcp 0 0 10.20.0.11:12010 0.0.0.0:* LISTEN 1001 231046750 22517/io.hm-rpc.2
      tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 15035 572/smbd
      tcp 0 0 10.20.0.11:18701 0.0.0.0:* LISTEN 1001 231043059 22476/io.hm-rpc.0
      tcp 0 0 127.0.0.1:28017 0.0.0.0:* LISTEN 109 16559 319/mongod
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 209297948 28986/sshd
      tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 231047246 22593/io.shelly.0
      tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 15034 572/smbd
      tcp 0 0 10.20.0.11:12001 0.0.0.0:* LISTEN 1001 231046046 22495/io.hm-rpc.1
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 231046498 22365/iobroker.js-c
      tcp6 0 0 :::139 :::* LISTEN 0 15033 572/smbd
      tcp6 0 0 :::8081 :::* LISTEN 1001 231045916 22383/io.admin.0
      tcp6 0 0 :::8082 :::* LISTEN 1001 231049562 22734/io.web.0
      tcp6 0 0 :::22 :::* LISTEN 0 209297950 28986/sshd
      tcp6 0 0 :::445 :::* LISTEN 0 15032 572/smbd
      udp 0 0 0.0.0.0:54670 0.0.0.0:* 108 209299717 29210/avahi-daemon:
      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15790 504/dhcpcd
      udp 0 0 10.20.0.255:137 0.0.0.0:* 0 15018 505/nmbd
      udp 0 0 10.20.0.11:137 0.0.0.0:* 0 15017 505/nmbd
      udp 0 0 0.0.0.0:137 0.0.0.0:* 0 15007 505/nmbd
      udp 0 0 10.20.0.255:138 0.0.0.0:* 0 15020 505/nmbd
      udp 0 0 10.20.0.11:138 0.0.0.0:* 0 15019 505/nmbd
      udp 0 0 0.0.0.0:138 0.0.0.0:* 0 15008 505/nmbd
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 209299715 29210/avahi-daemon:
      udp6 0 0 :::58468 :::* 108 209299718 29210/avahi-daemon:
      udp6 0 0 :::5353 :::* 108 209299716 29210/avahi-daemon:
      MarvinH
      Ok, danke!
      MarvinH
      @crunchip
      Danke,
      das curl-Kommando hatte ich ausgeführt. Als es danach mit npm nicht ging, hatte ich, glaube ich, dieses manuell geupdatet.
      Nun habe ich das von dir zitierte Kommando erneut ausgeführt:
      pi@raspberrypi4-iob:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
      ## Installing the NodeSource Node.js 16.x repo...
      ## Populating apt-get cache...
      + apt-get update
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
      ## Confirming "buster" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
      ## Adding the NodeSource signing key to your keyring...
      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
      gpg: WARNUNG: Unsicheres Besitzverhältnis des Home-Verzeichnis `/home/pi/.gnupg'
      ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
      ## Running `apt-get update` for you...
      + apt-get update
      ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
      ## You may also need development tools to build native addons:
          sudo apt-get install gcc g++ make
      ## To install the Yarn package manager, run:
          curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
          echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
          sudo apt-get update && sudo apt-get install yarn
      pi@raspberrypi4-iob:~ $ sudo apt install -y nodejs
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
       jsvc libboost-filesystem1.58.0 libboost-program-options1.58.0 libboost-system1.58.0 libboost-thread1.58.0 libcommons-daemon-java libpcap0.8 libsnappy1v5 libv8-3.14.5 mongodb-clients mongodb-server
       rpi-eeprom-images
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden Pakete werden aktualisiert (Upgrade):
       nodejs
      1 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
      Es müssen 24,2 MB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 171 kB Plattenplatz zusätzlich benutzt.
      Holen:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24,2 MB]
      Es wurden 24,2 MB in 2 s geholt (12,2 MB/s).
      apt-listchanges: Changelogs werden gelesen...
      (Lese Datenbank ... 61389 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
      Entpacken von nodejs (16.19.0-deb-1nodesource1) über (16.18.1-deb-1nodesource1) ...
      nodejs (16.19.0-deb-1nodesource1) wird eingerichtet ...
      Trigger für man-db (2.8.5-2) werden verarbeitet ...
      pi@raspberrypi4-iob:~ $ nodejs -v
      v16.19.0
      pi@raspberrypi4-iob:~ $ npm -v
      8.19.3
      Dann Admin-Update mit --debug wie oben. Selbe Fehlermeldung wie oben. Update wird durchgeführt aber Adapter bleibt in alter Version.
      Dann das Kommando aus dem verlinkten Forenbeitrag:
      pi@raspberrypi4-iob:~ $ cd /opt/iobroker/
      pi@raspberrypi4-iob:/opt/iobroker $ npm ls | grep -E 'github|ERR'
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-23T18_03_28_542Z-debug-0.log
      Aha, da fehlt irgendein Paket. Auf gut Glück installiert:
      pi@raspberrypi4-iob:/opt/iobroker $ iob install simple-api
      NPM version: 8.19.3
      Installing iobroker.simple-api@2.7.2... (System call)
      host.raspberrypi4-iob Cannot install iobroker.simple-api@2.7.2: 1
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker list adapters
      system.adapter.simple-api              : simple-api     - v2.4.6
      Installation hat geklappt. Problem leider immer noch nicht gelöst.
      Dann einmal iobroker fix probiert - Keine Fehler angezeigt.
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker fix
      library: loaded
      Library version=2022-12-09
         Welcome to the ioBroker installation fixer!
         Script version: 2022-12-22
         Installing prerequisites (1/4)
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Installed gcc-c++
         Checking ioBroker user and directory permissions (2/4)
         Database maintenance (3/4)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
         Checking autostart (4/4)
      Enabling autostart...
      Autostart enabled!
         Your installation was fixed successfully
         Run iobroker start to start ioBroker again!
      MarvinH
      @crunchip
      NodeJs habe ich doch installiert in Version v16.18.1.
      Na ja, gelesen hatte ich schon einiges. Die Frage ist, was. Vor einigen Wochen hatte ich diesen Artikel durchgearbeitet: https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition Da stand nur etwas von npm Version < 7 bei JSController < 4...
      Bislang war mir nicht bewusst, dass es Paare aus npm und nodejs-Versionen gibt.
      Habe anhand dieser Liste https://nodejs.org/en/download/releases/ eine passende Version installiert.
       sudo npm install -g npm@8.19.2
      Damit selbes Ergebnis wie zuvor.
      Hier der Output zu dem angeforderten Kommando:
      pi@raspberrypi4-iob:~ $ iob upgrade admin --debug
      -> 6.3.5:
      -> 6.3.4:
      -> 6.3.3:
      -> 6.3.2:
      NPM version: 8.19.2
      npm ERR! notsup Actual:   {"npm":"8.19.2","node":"v16.18.1"}
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-23T17_39_00_176Z-debug-0.log
      Der in den Fehlermeldungen erwähnte Adapter nightscout ist längst nicht mehr installiert. Jedenfalls taucht er nicht unter der Instanzliste auf.
      MarvinH
    • [gelöst] Adapter-Update funktioniert nicht - ohne Fehler
      Ich kann leider keine Adapter mehr aktualisieren und auch den JSController nicht. Weder über die Admin-Oberfläche noch über SSH.
      Dabei erhalte ich keine Fehlermeldung. Der Updateprozess einzelner Adapter beendet im Admin mit Code 0. Die Adapterversionen ändern sich dadurch aber leider nicht. Es werden nach dem Update immer noch die alten Versionen angezeigt.
      Anbei meine Logs aus Putty. Man sieht zuanfangs die zu aktualisierenden Adapter, danach die Installation und zum Schluss das Ergebnis (dieselben Versionen wie vor dem Update). Ganz am Ende noch ein paar Versionen.
      npm cache clean –force
      habe ich bereits probiert:
      login as: pi
      pi@10.20.0.11's password:
      Linux raspberrypi4-iob 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7        l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun Dec 11 12:55:50 2022 from 10.40.0.161
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      pi@raspberrypi4-iob:~ $ iobroker stop
      pi@raspberrypi4-iob:~ $ iobroker update
      pi@raspberrypi4-iob:~ $ iobroker upgrade
      This upgrade of "tr-064" will introduce the following changes:
      -> 4.2.17:
      Prevent duplication of entries in configuration
      Make sure active status of devices in jsonDeviceList is correct
      Would you like to upgrade tr-064 from @4.2.16 to @4.2.17 now? [(y)es, (n)o]: y
      Update tr-064 from @4.2.16 to @4.2.17
      NPM version: 9.2.0
      Installing iobroker.tr-064@4.2.17... (System call)
      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
      -> 6.3.5:
      -> 6.3.4:
      -> 6.3.3:
      -> 6.3.2:
      NPM version: 9.2.0
      This upgrade of "worx" will at least introduce the following changes:
      -> 2.0.3:
      Add manual refresh. Fix empty status and firmware format. Reduce info logs.
      -> 2.0.2:
      Fix MQTT connection for Kress, Landxcape and Ferrex
      -> 2.0.1:
      Adapter rewritten. Added product info and activity log. rawMqtt values improved and compatible with Node v18.
      -> 1.7.0:
      Login Fixed
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade worx from @1.5.5 to @2.0.3 now? [(y)es, (n)o]: y
      Update worx from @1.5.5 to @2.0.3
      NPM version: 9.2.0
      Installing iobroker.worx@2.0.3... (System call)
      upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
      upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/style.css style.css text/css
      upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/words.js words.js application/javascript
      upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
      upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx_ada2.png worx_ada2.png image/png
      This upgrade of "telegram" will introduce the following changes:
      -> 1.15.2:
      Make sure the userid is a string to show warnings in the log
      Added ukrainian language
      -> 1.15.0:
      Fixed custom component (user name was missing)
      Translated all objects
      Updated GUI packages and corrected build process
      Would you like to upgrade telegram from @1.14.1 to @1.15.2 now? [(y)es, (n)o]: y
      Update telegram from @1.14.1 to @1.15.2
      host.raspberrypi4-iob Adapter "system.adapter.telegram.0" is stopped.
      NPM version: 9.2.0
      Installing iobroker.telegram@1.15.2... (System call)
      Update "system.adapter.telegram.0"
      upload [52] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
      upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
      upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_react_index_js.44097ea5.chunk.js.map custom/static/js/node_modules_react_index_js.44097ea5.chunk.js.map application/json
      upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.7d6c2204.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.7d6c2204.chunk.js.map application/json
      upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js application/javascript
      upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js.map custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js.map application/json
      upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js application/javascript
      upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js.map custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js.map application/json
      upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js application/javascript
      upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js.map application/json
      upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js application/javascript
      upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js.map application/json
      upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js application/javascript
      upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js.map custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js.map application/json
      upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js application/javascript
      upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js.map application/json
      upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js application/javascript
      upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js.map application/json
      upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js application/javascript
      upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js.map application/json
      upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonConfig.json jsonConfig.json application/json
      upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
      upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
      upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
      host.raspberrypi4-iob Adapter "system.adapter.telegram.0" is started
      This upgrade of "shelly" will introduce the following changes:
      -> 6.0.0:
      Important: The adapter now requires at least Node.js 14.5
      * Added Shelly TRV (beta)
      * Just publish data to Shelly device, if value changed
      * **Breaking**: Configuration is only working in the new Admin 5 UI
      * **Breaking**: Uptime is now a number (seconds since boot)
      Would you like to upgrade shelly from @5.3.2 to @6.0.0 now? [(y)es, (n)o]:
      No upgrade of "shelly" desired.
      This upgrade of "javascript" will at least introduce the following changes:
      -> 6.1.4:
      Corrected small error in rules
      Tried to fix debug mode
      -> 6.1.3:
      Prevent adapter crash when script could not be compiled
      -> 6.1.2:
      Added ukrainian translation
      -> 6.1.0:
      Add a configurable check for number of setStates per Minute to prevent scripts from taking down ioBroker. Default are 1000 setState per minute. Only stops if the number is reached 2 minutes in a row!
      Add createAlias method to create aliases for states
      Add setStateDelayed to selector
      Add options to exec command
      Fix issues with cancelling schedules when stopping scripts
      Corrected debug mode
      -> 6.0.3:
      Downgrade Typescript to prevent errors with global typescript scripts
      -> 6.0.2:
      -> 6.0.1:
      Fixed the wizard schedule
      Done small fixes on GUI
      Would you like to upgrade javascript from @5.7.0 to @6.1.4 now? [(y)es, (n)o]: y
      Update javascript from @5.7.0 to @6.1.4
      NPM version: 9.2.0
      Installing iobroker.javascript@6.1.4... (System call)
      Update "system.adapter.javascript.0"
      upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.a42c4e84.js static/js/runtime-main.a42c4e84.js application/javascript
      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
      This upgrade of "ical" will introduce the following changes:
      -> 1.13.2:
      fix strange log messages by downgrading RRule again
      Would you like to upgrade ical from @1.13.1 to @1.13.2 now? [(y)es, (n)o]: y
      Update ical from @1.13.1 to @1.13.2
      NPM version: 9.2.0
      Installing iobroker.ical@1.13.2... (System call)
      Update "system.adapter.ical.0"
      upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
      upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
      upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
      upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
      This upgrade of "history" will at least introduce the following changes:
      -> 2.2.4:
      Update for future js-controller versions
      -> 2.2.3:
      Fix error in history2db converter script
      -> 2.2.1:
      Fix crash cases reported by Sentry
      -> 2.2.0:
      make sure getHistory works for all cases
      Add option to add comment and user info to results
      -> 2.1.7:
      Allow to remove a configuration value for "round" in config again
      -> 2.1.6:
      When not count is provided for aggregate "none" or "onchange" then the limit (default 2000) is used as count to define the number of data to return.
      -> 2.1.5:
      Ignore errors from forked process after response was sent for GetHistory
      Would you like to upgrade history from @1.11.1 to @2.2.4 now? [(y)es, (n)o]: y
      Update history from @1.11.1 to @2.2.4
      NPM version: 9.2.0
      Installing iobroker.history@2.2.4... (System call)
      Update "system.adapter.history.0"
      upload [15] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
      upload [14] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
      upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
      upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
      upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
      This upgrade of "backitup" will at least introduce the following changes:
      -> 2.5.9:
      dependencies dropbox-v2-api updated
      Fix Zigbee Restore
      Fix Yahka Restore
      Fix Javascript Restore
      Fix Dropbox Error Messages
      -> 2.5.8:
      Fix iobroker Backup
      dependencies updated
      -> 2.5.7:
      Axios 1.1.3 added
      -> 2.5.6:
      Fix Grafana Backup
      Fix Downloadserver
      Translation updated
      -> 2.5.5:
      Design Fix
      Docker DB Support added
      -> 2.5.4:
      Fix maxBuffer for DB-Backups
      Docu updated
      Fix Dropbox error messages
      Grafana self signed Certificates added
      -> 2.5.3:
      Would you like to upgrade backitup from @2.4.6 to @2.5.9 now? [(y)es, (n)o]: y
      Update backitup from @2.4.6 to @2.5.9
      host.raspberrypi4-iob Adapter "system.adapter.backitup.0" is stopped.
      NPM version: 9.2.0
      Installing iobroker.backitup@2.5.9... (System call)
      Update "system.adapter.backitup.0"
      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      host.raspberrypi4-iob Adapter "system.adapter.backitup.0" is started
      pi@raspberrypi4-iob:~ $ node -v
      v16.18.1
      v16.18.1
      pi@raspberrypi4-iob:~ $ cat /etc/os-release
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      Was kann ich tun?
      MarvinH
    • RE: Shelly 2.5 im Rollladenmodus - Tastendruck detektieren?
      @mickym Danke, deine Antwort hat mich auf den richtigen Weg gebracht:
      Obwohl bei den Relay-Knoten (im Rollladenmodus) im Objektbaum alles inaktiv zu sein scheint, springt das Child-"Input"-Objekt auf False, während der Taster am Eingang gedrückt ist und springt beim Loslassen wieder auf True. Das passiert nicht, wenn ich den Shelly über das Webinterface oder mein Script ansteuere. Problem gelöst, danke!
      MarvinH
