    2. Lone Baggie
    Lone Baggie
    @Lone Baggie
    Lone Baggie Follow
    Latest posts made by Lone Baggie
    • RE: Ikea Tradfri bulbs and Lovelace
      @Garfonso
      Still not working. Turning bulb on and off is working OK . I have the following.
      Device setup
      Light alias works dimmer alias fails.
      This is what it looks like in the objects
      This is the tradfri objects
      This is lovelace configuration
      Lights turn off and on Ok , but only show friendly name not state . dimmer is missing entirely
      posted in Visualization
      Lone Baggie
      Lone Baggie
      @Garfonso
      Thank you for your help.
      I'm running the latest distro so versions are
      Lovelace is 1.0.16
      tradfri 2.6.2
      Manage devices 0.3.6
      My issue is however I set the alias of a Tradfri bulb in the manage devices I cannot get Lovelace to recognise the attributes
      If I set the alias to device type light and use the light bulb state. Lovelace can switch the bulb on and off correctly and works
      However, if I try any other device type Dimmer, RGB, Hue light, colour temperature, nothing works.
      Do you have an example of an alias of a Tradfri bulb that the Lovelace adaptor can recognise the brightness or the colour hue ?
      Lone Baggie
      Lone Baggie
    • Ikea Tradfri bulbs and Lovelace
      Hello I am very new ioBroker.
      I want to use my Ikea bulbs within the Lovelace visualisation. I have a lot of experience with Home Assistant and I'm trying to replicate my frontend.
      I have installed the Lovelace, Devices and Ikea adaptors. Using the Devices adaptor, I can create simple aliases using the bulb device type. Lovelace recognizes the bulb and will allow me to turn it off and on.
      How do I create the hue and brightness options? I have tried mapping using the Dimmer and Hue device types within the device's adaptor, but Lovelace does not recognize the attributes. Do I need to manually change the alias to map the Tradfri bulbs correctly?
      Lone Baggie
      Lone Baggie
