    2. Maximilian Klie
    Maximilian Klie
    @Maximilian Klie
    Maximilian Klie Follow
    Latest posts made by Maximilian Klie
    • RE: Google Home/Assistant ioBroker einrichten/nutzen
      @tombox said in Google Home/Assistant ioBroker einrichten/nutzen:
      @Maximilian-Klie Der schnellste Weg dein Problem zu fixen ist Sensor.2 manuell zu löschen und durch deconz neuerzeugen lassen und dann wie beschrieben dem Device Sensors.2 ein Raum und Funktion zu weisen und nicht dem State temperature
      Heya! Danke, werde ich testen. Das Ergebnis teile ich hier mit.
      Maximilian Klie
      Maximilian Klie
      @tombox Verzeihung. Hier isse: deconz.0.Sensors.2.json
      Maximilian Klie
      Maximilian Klie
      @tombox
      Hier bitte:
        "deconz.0.Sensors.2": {
          "type": "device",
          "common": {
            "name": "Bad oben Temp",
            "role": "sensor",
            "smartName": false
          "native": {
            "ep": 1,
            "etag": "1cc6a3fe67a5e3502457af81c184ceae",
            "id": "2",
            "manufacturername": "LUMI",
            "modelid": "lumi.weather",
            "swversion": "20161129",
            "type": "ZHATemperature",
            "uniqueid": "00:15:8d:00:03:f0:55:74-01-0402"
          "from": "system.adapter.deconz.0",
          "user": "system.user.admin",
          "ts": 1574276560696,
          "_id": "deconz.0.Sensors.2",
          "acl": {
            "object": 1636
        "deconz.0.Sensors.2.battery": {
          "type": "state",
          "common": {
            "name": "Multisensor battery",
            "type": "number",
            "role": "indicator.battery",
            "read": true,
            "write": false
          "native": {},
          "ts": 1574276560720,
          "_id": "deconz.0.Sensors.2.battery",
          "acl": {
            "object": 1636,
            "state": 1636
        "deconz.0.Sensors.2.lastupdated": {
          "type": "state",
          "common": {
            "name": "lastupdated",
            "type": "string",
            "role": "state",
            "read": true,
            "write": false
          "native": {},
          "ts": 1574276615079,
          "_id": "deconz.0.Sensors.2.lastupdated",
          "acl": {
            "object": 1636,
            "state": 1636
        "deconz.0.Sensors.2.offset": {
          "type": "state",
          "common": {
            "name": "Multisensor offset",
            "type": "number",
            "role": "state",
            "read": true,
            "write": true,
            "smartName": false
          "native": {},
          "from": "system.adapter.iot.0",
          "ts": 1577399877048,
          "_id": "deconz.0.Sensors.2.offset",
          "acl": {
            "object": 1636,
            "state": 1636
        "deconz.0.Sensors.2.on": {
          "type": "state",
          "common": {
            "name": "Multisensor on",
            "type": "boolean",
            "role": "state",
            "read": true,
            "write": true,
            "smartName": false
          "native": {},
          "ts": 1574276560746,
          "_id": "deconz.0.Sensors.2.on",
          "acl": {
            "object": 1636,
            "state": 1636
        "deconz.0.Sensors.2.reachable": {
          "type": "state",
          "common": {
            "name": "Multisensor reachable",
            "type": "boolean",
            "role": "state",
            "read": true,
            "write": false
          "native": {},
          "_id": "deconz.0.Sensors.2.reachable",
          "acl": {
            "object": 1636,
            "state": 1636
        "deconz.0.Sensors.2.temperature": {
          "type": "state",
          "common": {
            "name": "Sensor Bad oben",
            "type": "number",
            "role": "value.temperature",
            "unit": "°C",
            "read": true,
            "write": true,
            "smartName": false,
            "enums": [
                "_id": "enum.functions.infos",
                "common": {
                  "name": "Infos",
                  "icon": "",
                  "color": false
                "_id": "enum.rooms.bad_oben",
                "common": {
                  "name": "Bad oben",
                  "icon": "",
                  "color": false
          "native": {},
          "ts": 1577541459184,
          "_id": "deconz.0.Sensors.2.temperature",
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
            "state": 1636
      Ich will nicht ausschließen, dass ich irgendwo Mist gemacht hab. Das ist jetzt auch nur ein Sensor exemplarisch. Danke schon mal!
      Maximilian Klie
      Maximilian Klie
      Hi!
      Nachdem ich jetzt nun in den letzten Wochen mehrere Stunden damit zugebracht habe, hier zu lesen und auszuprobieren, wo das Problem liegt, muss ich einfach hier noch mal fragen.
      Ich habe Aqara Sensoren (Temperatur und Fenster) und will die in meiner GHome-App angezeigt bekommen. Ich bekomme es einfach nicht hin, weil ich die richtige Kombination von Type/Trait/Attribut irgendwie nicht herausfinden kann. Kann mir hier jemand mal für absolute Idioten erklären, wie das geht? Ich bin durchaus bereit komplett von vorne anzufangen 🙂
      Mein Setup: Raspberry 3B+ mit RaspBee Aufsatz von Dresden Elektronik, drei Temperatur-Sensoren und zwei Fenster-Sensoren von Xiaomi/Aqara
      Maximilian Klie
      Maximilian Klie
