  4. YAHKA Installation unter Windows ioBroker
    5.9k
3 Beiträge 3 Kommentatoren 1.3k Aufrufe
  • K Offline
    KroKoFox
    hat jemande diesen Homekit Adapter unter Windows am laufen? Bräuchte da mal etwas Hilfe.
    Komme anhand dieser Fehlermeldungen nicht wirklich weiter.
    ! c:\iobroker> iobroker add yahka
    ! c:\iobroker>node node_modules/iobroker.js-controller/iobroker.js add yahka
    ! npm install iobroker.yahka –production --prefix "c:/iobroker" (System call)
    ! gyp: C:\WINDOWS\system32\config\systemprofile.node-gyp\8.9.4\include\node\common.gypi not found (cwd: c:\iobroker\node_modules\iobroker.yahka\node_modules\mdns) while reading includes of binding.gyp while trying to load binding.gyp
    ! gyp
    ! ERR! configure error
    ! gyp
    ! ERR! stack Error: gyp failed with exit code: 1
    ! gyp ERR! stack at ChildProcess.onCpExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:336:16)
    ! gyp ERR! stack at emitTwo (events.js:126:13)
    ! gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    ! gyp ERR!
    ! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    ! gyp ERR!
    ! System Windows_NT 10.0.16299
    ! gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    ! gyp
    ! ERR! cwd c:\iobroker\node_modules\iobroker.yahka\node_modules\mdns
    ! gyp ERR! node -v v8.9.4
    ! gyp ERR!
    ! node-gyp -v v3.6.2
    ! gyp ERR! not ok
    ! npm
    ! ERR! code ELIFECYCLE
    ! npm ERR! errno
    ! 1
    ! npm
    ! ERR! mdns@2.3.4 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR!
    ! Failed at the mdns@2.3.4 install script.
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:
    ! npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2018-01-08T10_14_40_557Z-debug.log
    ! host.HHW5SRV01 install adapter yahka
    ! npm install iobroker.yahka --production --prefix "c:/iobroker" (System call)
    ! gyp
    ! gyp
    ! ERR! stack
    ! Error: gyp failed with exit code: 1
    ! gyp
    ! ERR! stack at ChildProcess.onCpExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:336:16)
    ! gyp ERR!
    ! gyp
    ! ERR! stack
    ! at ChildProcess.emit (events.js:214:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    ! gyp
    ! ERR! System Windows_NT 10.0.16299
    ! gyp ERR!
    ! gyp
    ! gyp ERR!
    ! node -v v8.9.4
    ! gyp ERR! node-gyp -v
    ! v3.6.2
    ! gyp
    ! ERR! not ok
    ! npm
    ! npm ERR! errno 1
    ! npm
    ! npm ERR!
    ! npm ERR!
    ! npm
    ! ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2018-01-08T10_14_44_924Z-debug.log
    ! gyp
    ! gyp
    ! ERR!
    ! gyp ERR!
    ! gyp ERR!
    ! gyp ERR! System Windows_NT 10.0.16299
    ! gyp
    ! ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    ! gyp ERR! cwd
    ! c:\iobroker\node_modules\iobroker.yahka\node_modules\mdns
    ! gyp ERR! node -v
    ! v8.9.4
    ! gyp ERR! node-gyp -v v3.6.2
    ! gyp ERR! not ok
    ! npm
    ! npm ERR! errno 1
    ! npm
    ! npm ERR!
    ! npm
    ! ERR! Failed at the mdns@2.3.4 install script.
    ! npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2018-01-08T10_14_49_268Z-debug.log
    ! host.HHW5SRV01 Cannot install yahka
    ! c:\iobroker>
    • I Offline
      I Offline
      ind
      hast Du das Problem lösen können? Ich kämpfe mit der gleichen Problematik, bin für jeden Hinweis dankbar!!
      Vielen Dank vorab!
      • apollon77A Offline
        Die Suche is your friend:
        http://forum.iobroker.net/viewtopic.php … 55#p125241
        ... erst ein Tag her ...
