RegEx Probleme
ich bin dran den rpi Adapter umzuschreiben auf mein System (Debian VM) auf Synology Nas.
"native": { "c_cpu": true, "c_raspberry": false, "c_memory": true, "c_network": true, "c_sdcard": true, "c_swap": true, "c_temperature": true, "c_uptime": true, "c_wlan": true, "interval": 60000, "cpu": { "cpu_frequency": { "command": "cat /proc/cpuinfo", "regexp": "cpu\\sMHz\\s+:\\s(\\d+).\\d+", "post": "$1" }, "load1,load5,load15": { "command": "cat /proc/loadavg", "regexp": "^(\\S+)\\s(\\S+)\\s(\\S+)", "post": "" }, "scaling_governor": { "command": "cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor", "regexp": "(.*)", "post": "" } }, cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 92 model name : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz stepping : 9 microcode : 0x1 cpu MHz : 1497.610 cache size : 1024 KB physical id : 0 siblings : 2 core id : 0 cpu cores : 2 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes rdrand hypervisor lahf_lm 3dnowprefetch tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms mpx rdseed smap clflushopt bugs : bogomips : 2995.22 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management: processor : 1 vendor_id : GenuineIntel cpu family : 6 model : 92 model name : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz stepping : 9 microcode : 0x1 cpu MHz : 1497.610 cache size : 1024 KB physical id : 0 siblings : 2 core id : 1 cpu cores : 2 apicid : 1 initial apicid : 1 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 cx16 sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes rdrand hypervisor lahf_lm 3dnowprefetch tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms mpx rdseed smap clflushopt bugs : bogomips : 2995.22 clflush size : 64 cache_alignment : 64 address sizes : 40 bits physical, 48 bits virtual power management:Im Broker kommt:
rpi2.0 2017-12-15 10:49:48.010 error No Value found for cpu_frequency
Wer hat eine Ahnung warum das nicht funktioniert?
Im Regex Tester funtioniert es.
Viele Grüße
Marcel Jaud
Ich habe mal den Code in Code-Tags gesetzt.
Was bitte machst du da?
und wie genau gehst du vor?
Rainer
Also oben der Code ist vom rpi2 json File.
"cpu_frequency": {
"regexp": "cpu\sMHz\s+:\s(\d+).\d+",
"post": "$1"
Da versuche ich die CPU Frequenz aus der cpuinfo auszulesen und per Regex zu bekommen.
Aber ich bekomme ein Fehler in iobroker.
Danke und viele Grüße
Marcel Jaud
