  4. Fehler SQL-Adapter nach Update auf 2.29.23
    5.8k
5 Beiträge 2 Kommentatoren 723 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    sql.0	2017-12-12 23:00:10.615	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1584, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1584-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.608	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1583, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1583-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.606	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1582, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1582-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.604	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1581, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1581-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.597	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1580, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1580-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.595	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1578, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1578-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:10.592	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1579, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1579-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.755	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1577, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1577-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.751	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1575, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1575-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.750	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1576, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1576-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.735	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1574, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1574-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.734	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1573, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1573-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.732	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1572, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1572-1970001' for key 'PRIMARY'
    sql.0	2017-12-12 23:00:09.730	error	Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1571, 1970001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1571-1970001' for key 'PRIMARY'
    es scheint, das das Datum auf 1970 steht für ein paar Datenpunkte. Der Fehler kommt alle 10 Minuten.
    MfG
    Sissi
    • apollon77A Offline
      Welche Datenpunkte sind das denn? Hatte so etwas auch schonmal gesehen mit 1970 bei irgendwelchen speziellen Alarm datenpunkten oder so.
      Und nach welchem Update ist das gekommen?
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        sind DUTYCYCLE_ALARM Datenpunkte
        MfG
        Sissi
          Ja di ehaben ggf so ein Datum wenn es noch nie Probleme gab und daher keinen Wert.
          Nochmal die Frage: Seit welchem Update kam das denn dazu? Was ist auf "2.29.23" geupdatet? Meinst Du die CCU?
            Welche Version des SQL-Adapters wird genutzt?
