  4. Zigbee2MQTT Beitritt erlauben startet nicht
    6.0k
1 Beiträge 1 Kommentatoren 179 Aufrufe 1 Beobachtet
    matrose65
    • Adaptername: Zigbee2MQTT
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 3.0.9
    • js-controller Version: 7.0.7
    • Admin Version: ...
    • Hardwaresystem: Proxmox LXC Intel NUC
    • Arbeitsspeicher: 8 GB
    • Festplattenart: SSD
    • Betriebssystem: linux
    • Nodejs-Version: 22.21.0
    • NPM-Version: 10.9.4
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: ...
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.4-1-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i7-8559U CPU @ 2.70GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:58:00 up 12 days,  1:11,  0 users,  load average: 0.11, 0.08, 0.08
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-12-29 17:58:00 CET
               Universal time: Mon 2025-12-29 16:58:00 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    uwe
    HOME=/home/uwe
    GROUPS=uwe sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/uwe
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.6G        1.5G        6.0G        4.2M        1.1G        7.0G
    Swap:           536M          0B        536M
    Total:          9.1G        1.5G        6.5G
    Active iob-Instances:   21
             8192 M total memory
             1472 M used memory
             1565 M active memory
              806 M inactive memory
             5678 M free memory
                0 M buffer memory
             1045 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 17:58:00 up 12 days,  1:11,  0 users,  load average: 0.11, 0.08, 0.08
    Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   5677.0 free,   1473.4 used,   1045.6 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6718.6 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       32G  4.0G   26G  14% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs     6.3G  100K  6.3G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs      16G  4.0M   16G   1% /tmp
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    462M    /var/
    276M    /var/cache
    272M    /var/cache/apt
    181M    /var/cache/apt/archives
    161M    /var/lib
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    88M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    488M    /opt/iobroker/iobroker-data/
    344M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    12M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2521)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.netatmo-crawler@1.1.0 (git+ssh://git@github.com/Bart1909/ioBroker.netatmo-crawler.git#a0ab57da18dc7c1a8dd01ecf229fddd79371e3a0)
    Adapter State
    + system.adapter.ankersolix2.0            : ankersolix2           : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
    + system.adapter.brightsky.0              : brightsky             : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.21:6638
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bmw"          : 4.3.2    , installed 4.3.2
    Adapter    "brightsky"    : 0.6.6    , installed 0.6.6
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "vis-2-widgets-inventwo": 0.3.9, installed 0.3.9
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:        8363
    States:         7037
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org trixie-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20063980   59719/io.zigbee2mqt
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19979729   58315/io.shelly.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19977233   57901/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19977238   57901/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7100       1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14611      255/master
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       19979825   58375/io.sonos.0
    tcp6       0      0 :::3010                 :::*                    LISTEN      1001       19980150   58457/io.fullybrows
    tcp6       0      0 :::111                  :::*                    LISTEN      0          7102       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13674      1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19982297   58591/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19975946   58013/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14612      255/master
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          7101       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19986698   58561/io.wled.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19978196   58345/io.shelly.2
    udp6       0      0 :::111                  :::*                                0          7103       1/init
    2025-12-29 17:43:08.590  - info: zigbee2mqtt.0 (59719) || Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
    2025-12-29 17:43:08.590  - info: zigbee2mqtt.0 (59719) || Use Kelvin: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use ColorTemperature ColorSync: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use BrightnessMove OnOff: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use BrightnessStep OnOff: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Event In Desc: yes
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Device Icons: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Simple Hold/Release State: yes
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Simple Move/Stop State: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Simple Press/Release State: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Use Automatic Coordinator Check: no
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Coordinator Check Loglevel: info
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) || Coordinator Check Cron : 0 3 * * *
    2025-12-29 17:43:08.591  - info: zigbee2mqtt.0 (59719) ==================================================================================
    2025-12-29 17:43:08.647  - info: zigbee2mqtt.0 (59719) Statring DummyMQTT-Server on IP 0.0.0.0 and Port 1885
    2025-12-29 17:43:10.149  - info: zigbee2mqtt.0 (59719) Connect to Zigbee2MQTT over websocket connection.
    2025-12-29 17:44:38.296  - info: admin.0 (58013) ==> Connected system.user.admin from ::ffff:192.168.1.121
    2025-12-29 17:45:01.111  - info: admin.0 (58013) ==> Connected system.user.admin from ::ffff:192.168.1.121
    2025-12-29 17:47:24.548  - info: zigbee2mqtt.0 (59719) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1767026844547,"os":{"load_average":[0.05,0.08,0.11],"memory_used_mb":74.22,"memory_percent":14.4964},"process":{"uptime_sec":1803,"memory_used_mb":97.09,"memory_percent":18.9621},"mqtt":{"connected":true,"queued":0,"published":14,"received":8},"devices":{}}'
    2025-12-29 17:49:06.011  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.8" started with pid 59784
    2025-12-29 17:49:06.495  - info: daswetter.0 (59784) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.7
    2025-12-29 17:49:07.510  - info: daswetter.0 (59784) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-12-29 17:49:08.013  - info: daswetter.0 (59784) cleaned everything up...
    2025-12-29 17:49:08.020  - info: host.iobroker instance system.adapter.daswetter.0 having pid 59784 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-29 17:57:24.548  - info: zigbee2mqtt.0 (59719) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1767027444547,"os":{"load_average":[0.2,0.09,0.08],"memory_used_mb":74.77,"memory_percent":14.6034},"process":{"uptime_sec":2403,"memory_used_mb":97.09,"memory_percent":18.9621},"mqtt":{"connected":true,"queued":0,"published":16,"received":9},"devices":{}}'
    iob diag has finished.
    ich habe zigbee2mqtt installiert, weil ich gern von Zigbee darauf umsteigen möchte.
    Nach anfänglichen Problemen ist der Adapter grün. Ich kann das Web Frontend aufrufen und im Log kommen auch keine Fehler.
    Wenn ich aber im Frontent auf Beitritt erlauben klicke, startet nichts.
    Ja es läuft auch noch der Zugbee Adapter, aber auf einem anderen Koordinator.
    Beide sind per LAN im System. Auch wenn das Zigbee gestoppt ist, funktioniert das Anlernen nicht.
    Hier noch die Meldungen im LOG nach dem Start
    zigbee2mqtt.0
    	2025-12-29 18:07:24.549	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1767028044548,"os":{"load_average":[0.19,0.1,0.09],"memory_used_mb":74.57,"memory_percent":14.5653},"process":{"uptime_sec":3003,"memory_used_mb":97.09,"memory_percent":18.9621},"mqtt":{"connected":true,"queued":0,"published":18,"received":9},"devices":{}}'
    zigbee2mqtt.0
    	2025-12-29 17:57:24.548	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1767027444547,"os":{"load_average":[0.2,0.09,0.08],"memory_used_mb":74.77,"memory_percent":14.6034},"process":{"uptime_sec":2403,"memory_used_mb":97.09,"memory_percent":18.9621},"mqtt":{"connected":true,"queued":0,"published":16,"received":9},"devices":{}}'
    zigbee2mqtt.0
    	2025-12-29 17:47:24.548	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1767026844547,"os":{"load_average":[0.05,0.08,0.11],"memory_used_mb":74.22,"memory_percent":14.4964},"process":{"uptime_sec":1803,"memory_used_mb":97.09,"memory_percent":18.9621},"mqtt":{"connected":true,"queued":0,"published":14,"received":8},"devices":{}}'
    zigbee2mqtt.0
    	2025-12-29 17:43:10.149	info	Connect to Zigbee2MQTT over websocket connection.
    zigbee2mqtt.0
    	2025-12-29 17:43:08.647	info	Statring DummyMQTT-Server on IP 0.0.0.0 and Port 1885
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	==================================================================================
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Coordinator Check Cron : 0 3 * * *
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Coordinator Check Loglevel: info
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Automatic Coordinator Check: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Simple Press/Release State: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Simple Move/Stop State: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Simple Hold/Release State: yes
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Device Icons: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use Event In Desc: yes
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use BrightnessStep OnOff: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use BrightnessMove OnOff: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.591	info	|| Use ColorTemperature ColorSync: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Use Kelvin: no
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Debug Log: deactivated
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Dummy MQTT Port: 1885
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Dummy MQTT IP-Bind: 0.0.0.0
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Websocket Dummy MQTT-Server: activated
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Websocket Auth-Token: unused
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Websocket Port: 8080
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Websocket Server: 192.168.1.23
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Websocket Scheme: ws
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Connection Type: ws
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Frontend Port: 8080
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Frontend Server: 192.168.1.23
    zigbee2mqtt.0
    	2025-12-29 17:43:08.590	info	|| Zigbee2MQTT Frontend Scheme: http
    zigbee2mqtt.0
    	2025-12-29 17:43:08.589	info	================================= Adapter Config =================================
    zigbee2mqtt.0
    	2025-12-29 17:43:08.584	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v22.21.0, js-controller: 7.0.7
    zigbee2mqtt.0
    	2025-12-29 17:43:02.878	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
