  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Windows
    5.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
100 Beiträge 13 Kommentatoren 40.6k Aufrufe
  • I Offline
    I Offline
    instalator
    #81
    @bondrogeen:
    ! > iobroker@0.5.6 install C:\Program Files\ioBroker\node_modules\iobroker
    ! > node lib/setup.js
    ! npm install iobroker.js-controller –production --prefix "C:/Program Files/ioBro
    ! ker"
    ! gyp ERR! configure error
    ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYT
    ! HON env variable.
    ! gyp ERR! stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\nod
    ! e_modules\node-gyp\lib\configure.js:103:14)
    ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node
    ! -gyp\lib\configure.js:64:11
    ! gyp ERR! stack at FSReqWrap.oncomplete (evalmachine.<anonymous>:99:15)
    ! gyp ERR! System Windows_NT 6.1.7601
    ! gyp ERR! command "node" "C:\Program Files\nodejs\node_modules\npm\node_modu
    ! les\node-gyp\bin\node-gyp.js" "rebuild"
    ! gyp ERR! cwd C:\Program Files\ioBroker\node_modules\iobroker.js-controller\node_
    ! modules\socket.io\node_modules\engine.io\node_modules\ws\node_modules\bufferutil
    ! gyp ERR! node -v v0.12.0
    ! gyp ERR! node-gyp -v v1.0.2
    ! gyp ERR! not ok
    ! HON env variable.
    ! modules\socket.io\node_modules\engine.io\node_modules\ws\node_modules\utf-8-vali
    ! date
    ! gyp ERR! not ok
    ! npm WARN optional dep failed, continuing bufferutil@1.1.0
    ! npm WARN optional dep failed, continuing utf-8-validate@1.1.0
    ! HON env variable.
    ! modules\socket.io-client\node_modules\engine.io-client\node_modules\ws\node_modu
    ! les\utf-8-validate
    ! gyp ERR! not ok
    ! HON env variable.
    ! les\bufferutil
    ! gyp ERR! not ok
    ! npm install iobroker.admin --production --prefix "C:/Program Files/ioBroker"
    ! HON env variable.
    ! gyp ERR! cwd C:\Program Files\ioBroker\node_modules\iobroker.admin\node_modules
    ! socket.io\node_modules\engine.io\node_modules\ws\node_modules\bufferutil
    ! gyp ERR! not ok
    ! HON env variable.
    ! socket.io\node_modules\engine.io\node_modules\ws\node_modules\utf-8-validate
    ! gyp ERR! not ok
    ! HON env variable.
    ! socket.io\node_modules\socket.io-client\node_modules\engine.io-client\node_modul
    ! es\ws\node_modules\bufferutil
    ! gyp ERR! not ok
    ! HON env variable.
    ! es\ws\node_modules\utf-8-validate
    ! gyp ERR! not ok
    ! Write "iobroker start" to start the ioBroker
    ! npm install node-windows --production --prefix "C:\Program Files\ioBroker\node_m
    ! odules\iobroker\lib/../../../"
    ! ^</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    Решил установить iobroker, не получается. `
    Снеси node.js и поставь версию 0.10.25
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
      bondrogeen
      #82
      ! npm http GET https://registry.npmjs.org/json3/3.2.6
      ! npm http GET https://registry.npmjs.org/debug/0.7.4
      ! npm http GET https://registry.npmjs.org/component-emitter/1.1.2
      ! npm http GET https://registry.npmjs.org/isarray/0.0.1
      ! npm http 200 https://registry.npmjs.org/benchmark/1.0.0
      ! npm http 200 https://registry.npmjs.org/json3/3.2.6
      ! npm http 304 https://registry.npmjs.org/debug/0.7.4
      ! npm http 304 https://registry.npmjs.org/isarray/0.0.1
      ! npm http GET https://registry.npmjs.org/benchmark/-/ … -1.0.0.tgz
      ! npm http GET https://registry.npmjs.org/json3/-/json3-3.2.6.tgz
      ! npm http 304 https://registry.npmjs.org/component-emitter/1.1.2
      ! npm http 200 https://registry.npmjs.org/benchmark/-/ ... -1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/json3/-/json3-3.2.6.tgz
      ! npm http GET https://github.com/component/global/arc ... 0.1.tar.gz
      ! npm http GET https://registry.npmjs.org/arraybuffer.slice/0.0.6
      ! npm http GET https://registry.npmjs.org/after/0.8.1
      ! npm http GET https://registry.npmjs.org/base64-arraybuffer/0.1.2
      ! npm http GET https://registry.npmjs.org/has-binary/0.1.5
      ! npm http GET https://registry.npmjs.org/blob/0.0.2
      ! npm http GET https://registry.npmjs.org/utf8/2.0.0
      ! npm http 200 https://registry.npmjs.org/arraybuffer.slice/0.0.6
      ! npm http 200 https://registry.npmjs.org/after/0.8.1
      ! npm http 200 https://registry.npmjs.org/base64-arraybuffer/0.1.2
      ! npm http 200 https://registry.npmjs.org/blob/0.0.2
      ! npm http 200 https://registry.npmjs.org/has-binary/0.1.5
      ! npm http GET https://registry.npmjs.org/arraybuffer. ... er.slice-0.
      ! 0.6.tgz
      ! npm http GET https://registry.npmjs.org/after/-/after-0.8.1.tgz
      ! npm http GET https://registry.npmjs.org/has-binary/- ... -0.1.5.tgz
      ! npm http GET https://registry.npmjs.org/base64-array ... raybuffer-
      ! 0.1.2.tgz
      ! npm http GET https://registry.npmjs.org/options
      ! npm http GET https://registry.npmjs.org/ultron
      ! npm http 200 https://registry.npmjs.org/utf8/2.0.0
      ! npm http GET https://registry.npmjs.org/bufferutil
      ! npm http GET https://registry.npmjs.org/utf-8-validate
      ! npm http GET https://registry.npmjs.org/blob/-/blob-0.0.2.tgz
      ! npm http GET https://registry.npmjs.org/utf8/-/utf8-2.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/after/-/after-0.8.1.tgz
      ! npm http 200 https://registry.npmjs.org/base64-array ... raybuffer-
      ! 0.1.2.tgz
      ! npm http 200 https://registry.npmjs.org/arraybuffer. ... er.slice-0.
      ! 0.6.tgz
      ! npm http 200 https://registry.npmjs.org/has-binary/- ... -0.1.5.tgz
      ! npm http 200 https://registry.npmjs.org/options
      ! npm http 200 https://registry.npmjs.org/ultron
      ! npm http 200 https://registry.npmjs.org/bufferutil
      ! npm http 200 https://registry.npmjs.org/utf-8-validate
      ! npm http 200 https://registry.npmjs.org/blob/-/blob-0.0.2.tgz
      ! npm http GET https://registry.npmjs.org/ultron/-/ultron-1.0.2.tgz
      ! npm http GET https://registry.npmjs.org/options/-/options-0.0.6.tgz
      ! npm http 200 https://github.com/component/global/arc ... 0.1.tar.gz
      ! npm http GET https://registry.npmjs.org/bufferutil/- ... -1.1.0.tgz
      ! npm http GET https://registry.npmjs.org/utf-8-valida ... e-1.1.0.tg
      ! z
      ! npm http 200 https://registry.npmjs.org/utf8/-/utf8-2.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/ultron/-/ultron-1.0.2.tgz
      ! npm http 200 https://registry.npmjs.org/options/-/options-0.0.6.tgz
      ! npm http 200 https://registry.npmjs.org/bufferutil/- ... -1.1.0.tgz
      ! npm http 200 https://registry.npmjs.org/utf-8-valida ... e-1.1.0.tg
      ! z
      ! npm http GET https://registry.npmjs.org/nan
      ! npm http GET https://registry.npmjs.org/bindings
      ! npm http 200 https://registry.npmjs.org/bindings
      ! npm http GET https://registry.npmjs.org/bindings/-/b ... -1.2.1.tgz
      ! npm http 200 https://registry.npmjs.org/nan
      ! npm http GET https://registry.npmjs.org/nan/-/nan-1.8.4.tgz
      ! npm http 200 https://registry.npmjs.org/bindings/-/b ... -1.2.1.tgz
      ! npm http 200 https://registry.npmjs.org/nan/-/nan-1.8.4.tgz
      ! npm http GET https://registry.npmjs.org/express
      ! npm http GET https://registry.npmjs.org/cookie-parser
      ! npm http GET https://registry.npmjs.org/connect-flash
      ! npm http GET https://registry.npmjs.org/passport
      ! npm http GET https://registry.npmjs.org/body-parser
      ! npm http GET https://registry.npmjs.org/passport-local
      ! npm http GET https://registry.npmjs.org/express-session
      ! npm http GET https://registry.npmjs.org/xtend
      ! npm http 200 https://registry.npmjs.org/connect-flash
      ! npm http 200 https://registry.npmjs.org/passport-local
      ! npm http 200 https://registry.npmjs.org/cookie-parser
      ! npm http 304 https://registry.npmjs.org/xtend
      ! npm http 200 https://registry.npmjs.org/body-parser
      ! npm http 200 https://registry.npmjs.org/express-session
      ! npm http GET https://registry.npmjs.org/cookie-parse ... -1.3.5.tgz
      ! npm http GET https://registry.npmjs.org/passport/-/p ... -0.2.2.tgz
      ! npm http GET https://registry.npmjs.org/connect-flas ... -0.1.1.tgz
      ! npm http GET https://registry.npmjs.org/express/-/express-4.13.3.tgz
      ! npm http 200 https://registry.npmjs.org/passport/-/p ... -0.2.2.tgz
      ! npm http 200 https://registry.npmjs.org/cookie-parse ... -1.3.5.tgz
      ! npm http 200 https://registry.npmjs.org/connect-flas ... -0.1.1.tgz
      ! npm http 200 https://registry.npmjs.org/express/-/express-4.13.3.tgz
      ! npm http GET https://registry.npmjs.org/cookie/0.1.3
      ! npm http GET https://registry.npmjs.org/cookie-signature/1.0.6
      ! npm http GET https://registry.npmjs.org/passport-strategy
      ! npm http GET https://registry.npmjs.org/bytes/2.1.0
      ! npm http GET https://registry.npmjs.org/content-type
      ! npm http GET https://registry.npmjs.org/depd
      ! npm http GET https://registry.npmjs.org/crc/3.3.0
      ! npm http GET https://registry.npmjs.org/iconv-lite/0.4.11
      ! npm http GET https://registry.npmjs.org/http-errors
      ! npm http GET https://registry.npmjs.org/on-headers
      ! npm http GET https://registry.npmjs.org/on-finished
      ! npm http GET https://registry.npmjs.org/utils-merge/1.0.0
      ! npm http GET https://registry.npmjs.org/qs/4.0.0
      ! npm http GET https://registry.npmjs.org/parseurl
      ! npm http GET https://registry.npmjs.org/uid-safe
      ! npm http GET https://registry.npmjs.org/raw-body
      ! npm http GET https://registry.npmjs.org/type-is
      ! npm http GET https://registry.npmjs.org/pause/0.0.1
      ! npm http 200 https://registry.npmjs.org/cookie/0.1.3
      ! npm http 200 https://registry.npmjs.org/cookie-signature/1.0.6
      ! npm http 200 https://registry.npmjs.org/passport-strategy
      ! npm http GET https://registry.npmjs.org/accepts
      ! npm http GET https://registry.npmjs.org/array-flatten/1.1.1
      ! npm http GET https://registry.npmjs.org/content-disposition/0.5.0
      ! npm http GET https://registry.npmjs.org/escape-html/1.0.2
      ! npm http GET https://registry.npmjs.org/etag
      ! npm http GET https://registry.npmjs.org/finalhandler/0.4.0
      ! npm http GET https://registry.npmjs.org/fresh/0.3.0
      ! npm http GET https://registry.npmjs.org/merge-descriptors/1.0.0
      ! npm http GET https://registry.npmjs.org/methods
      ! npm http GET https://registry.npmjs.org/proxy-addr
      ! npm http GET https://registry.npmjs.org/range-parser
      ! npm http GET https://registry.npmjs.org/path-to-regexp/0.1.7
      ! npm http GET https://registry.npmjs.org/send/0.13.0
      ! npm http GET https://registry.npmjs.org/serve-static
      ! npm http GET https://registry.npmjs.org/vary
      ! npm http GET https://registry.npmjs.org/cookie/-/cookie-0.1.3.tgz
      ! npm http GET https://registry.npmjs.org/passport-str ... strategy-1.
      ! 0.0.tgz
      ! npm http GET https://registry.npmjs.org/cookie-signa ... nature-1.0.
      ! 6.tgz
      ! npm http 200 https://registry.npmjs.org/crc/3.3.0
      ! npm http GET https://registry.npmjs.org/crc/-/crc-3.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/content-type
      ! npm http 200 https://registry.npmjs.org/depd
      ! npm http 200 https://registry.npmjs.org/bytes/2.1.0
      ! npm http GET https://registry.npmjs.org/content-type ... -1.0.1.tgz
      ! npm http GET https://registry.npmjs.org/depd/-/depd-1.0.1.tgz
      ! npm http GET https://registry.npmjs.org/bytes/-/bytes-2.1.0.tgz
      ! npm http 200 https://registry.npmjs.org/debug
      ! npm http 200 https://registry.npmjs.org/on-headers
      ! npm http GET https://registry.npmjs.org/on-headers/- ... -1.0.0.tgz
      ! npm http GET https://registry.npmjs.org/debug/-/debug-2.2.0.tgz
      ! npm http 200 https://registry.npmjs.org/utils-merge/1.0.0
      ! npm http GET https://registry.npmjs.org/utils-merge/ ... -1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/http-errors
      ! npm http GET https://registry.npmjs.org/http-errors/ ... -1.3.1.tgz
      ! npm http 200 https://registry.npmjs.org/qs/4.0.0
      ! npm http GET https://registry.npmjs.org/qs/-/qs-4.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/parseurl
      ! npm http 200 https://registry.npmjs.org/passport-str ... strategy-1.
      ! 0.0.tgz
      ! npm http 200 https://registry.npmjs.org/uid-safe
      ! npm http 200 https://registry.npmjs.org/cookie/-/cookie-0.1.3.tgz
      ! npm http 200 https://registry.npmjs.org/cookie-signa ... nature-1.0.
      ! 6.tgz
      ! npm http 200 https://registry.npmjs.org/crc/-/crc-3.3.0.tgz
      ! npm http GET https://registry.npmjs.org/parseurl/-/p ... -1.3.0.tgz
      ! npm http GET https://registry.npmjs.org/uid-safe/-/u ... -2.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/depd/-/depd-1.0.1.tgz
      ! npm http 200 https://registry.npmjs.org/raw-body
      ! npm http 200 https://registry.npmjs.org/bytes/-/bytes-2.1.0.tgz
      ! npm http 200 https://registry.npmjs.org/on-headers/- ... -1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/debug/-/debug-2.2.0.tgz
      ! npm http 200 https://registry.npmjs.org/iconv-lite/0.4.11
      ! npm http GET https://registry.npmjs.org/raw-body/-/r ... -2.1.2.tgz
      ! npm http 200 https://registry.npmjs.org/content-type ... -1.0.1.tgz
      ! npm http GET https://registry.npmjs.org/iconv-lite/- ... 0.4.11.tgz
      ! npm http 200 https://registry.npmjs.org/type-is
      ! npm http 200 https://registry.npmjs.org/utils-merge/ ... -1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/pause/0.0.1
      ! npm http 200 https://registry.npmjs.org/http-errors/ ... -1.3.1.tgz
      ! npm http 200 https://registry.npmjs.org/qs/-/qs-4.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/parseurl/-/p ... -1.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/array-flatten/1.1.1
      ! npm http 200 https://registry.npmjs.org/uid-safe/-/u ... -2.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/content-disposition/0.5.0
      ! npm http 200 https://registry.npmjs.org/raw-body/-/r ... -2.1.2.tgz
      ! npm http 200 https://registry.npmjs.org/escape-html/1.0.2
      ! npm http 200 https://registry.npmjs.org/accepts
      ! npm http GET https://registry.npmjs.org/type-is/-/type-is-1.6.7.tgz
      ! npm http GET https://registry.npmjs.org/pause/-/pause-0.0.1.tgz
      ! npm http GET https://registry.npmjs.org/array-flatte ... -1.1.1.tgz
      ! npm http 200 https://registry.npmjs.org/finalhandler/0.4.0
      ! npm http 200 https://registry.npmjs.org/fresh/0.3.0
      ! npm http 200 https://registry.npmjs.org/merge-descriptors/1.0.0
      ! npm http 200 https://registry.npmjs.org/iconv-lite/- ... 0.4.11.tgz
      ! npm http 200 https://registry.npmjs.org/etag
      ! npm http GET https://registry.npmjs.org/escape-html/ ... -1.0.2.tgz
      ! npm http GET https://registry.npmjs.org/content-disp ... dispositio
      ! n-0.5.0.tgz
      ! npm http GET https://registry.npmjs.org/accepts/-/accepts-1.2.12.tgz
      ! npm http 200 https://registry.npmjs.org/methods
      ! npm http 200 https://registry.npmjs.org/range-parser
      ! npm http GET https://registry.npmjs.org/fresh/-/fresh-0.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/path-to-regexp/0.1.7
      ! npm http GET https://registry.npmjs.org/finalhandler ... -0.4.0.tgz
      ! npm http GET https://registry.npmjs.org/merge-descri ... criptors-1.
      ! 0.0.tgz
      ! npm http 200 https://registry.npmjs.org/proxy-addr
      ! npm http 200 https://registry.npmjs.org/on-finished
      ! npm http 200 https://registry.npmjs.org/send/0.13.0
      ! npm http GET https://registry.npmjs.org/etag/-/etag-1.7.0.tgz
      ! npm http 200 https://registry.npmjs.org/vary
      ! npm http GET https://registry.npmjs.org/methods/-/methods-1.1.1.tgz
      ! npm http GET https://registry.npmjs.org/range-parser ... -1.0.2.tgz
      ! npm http GET https://registry.npmjs.org/path-to-rege ... p-0.1.7.tg
      ! z
      ! npm http 200 https://registry.npmjs.org/serve-static
      ! npm http 200 https://registry.npmjs.org/type-is/-/type-is-1.6.7.tgz
      ! npm http GET https://registry.npmjs.org/on-finished/ ... -2.3.0.tgz
      ! npm http GET https://registry.npmjs.org/proxy-addr/- ... -1.0.8.tgz
      ! npm http GET https://registry.npmjs.org/send/-/send-0.13.0.tgz
      ! npm http GET https://registry.npmjs.org/vary/-/vary-1.0.1.tgz
      ! npm http 200 https://registry.npmjs.org/pause/-/pause-0.0.1.tgz
      ! npm http 200 https://registry.npmjs.org/content-disp ... dispositio
      ! n-0.5.0.tgz
      ! npm http 200 https://registry.npmjs.org/array-flatte ... -1.1.1.tgz
      ! npm http 200 https://registry.npmjs.org/escape-html/ ... -1.0.2.tgz
      ! npm http 200 https://registry.npmjs.org/accepts/-/accepts-1.2.12.tgz
      ! npm http GET https://registry.npmjs.org/serve-static ... 1.10.0.tgz
      ! npm http 200 https://registry.npmjs.org/fresh/-/fresh-0.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/finalhandler ... -0.4.0.tgz
      ! npm http 200 https://registry.npmjs.org/merge-descri ... criptors-1.
      ! 0.0.tgz
      ! npm http 200 https://registry.npmjs.org/etag/-/etag-1.7.0.tgz
      ! npm http 200 https://registry.npmjs.org/methods/-/methods-1.1.1.tgz
      ! npm http 200 https://registry.npmjs.org/path-to-rege ... p-0.1.7.tg
      ! z
      ! npm http 200 https://registry.npmjs.org/range-parser ... -1.0.2.tgz
      ! npm http 200 https://registry.npmjs.org/proxy-addr/- ... -1.0.8.tgz
      ! npm http 200 https://registry.npmjs.org/on-finished/ ... -2.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/send/-/send-0.13.0.tgz
      ! npm http 200 https://registry.npmjs.org/vary/-/vary-1.0.1.tgz
      ! npm http 200 https://registry.npmjs.org/serve-static ... 1.10.0.tgz
      ! npm http GET https://registry.npmjs.org/base64-url/1.2.1
      ! npm http 200 https://registry.npmjs.org/base64-url/1.2.1
      ! npm http GET https://registry.npmjs.org/base64-url/- ... -1.2.1.tgz
      ! npm http GET https://registry.npmjs.org/ms/0.7.1
      ! npm http 200 https://registry.npmjs.org/base64-url/- ... -1.2.1.tgz
      ! npm http GET https://registry.npmjs.org/unpipe
      ! npm http GET https://registry.npmjs.org/ee-first/1.1.1
      ! npm http GET https://registry.npmjs.org/ipaddr.js/1.0.1
      ! npm http GET https://registry.npmjs.org/forwarded
      ! npm http 200 https://registry.npmjs.org/ms/0.7.1
      ! npm http GET https://registry.npmjs.org/media-typer/0.3.0
      ! npm http GET https://registry.npmjs.org/negotiator/0.5.3
      ! npm http GET https://registry.npmjs.org/mime-types
      ! npm http GET https://registry.npmjs.org/ms/-/ms-0.7.1.tgz
      ! npm http GET https://registry.npmjs.org/destroy/1.0.3
      ! npm http GET https://registry.npmjs.org/statuses
      ! npm http gyp200 https://registry.npmjs.org/unpipe
      ! npm http 200 https://registry.npmjs.org/ee-first/1.1.1
      ! npm http 200 https://registry.npmjs.org/forwarded
      ! npm http GET https://registry.npmjs.org/unpipe/-/unpipe-1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/media-typer/0.3.0
      ! npm http GET https://registry.npmjs.org/forwarded/-/ ... -0.1.0.tgz
      ! npm http GET https://registry.npmjs.org/ee-first/-/e ... -1.1.1.tgz
      ! npm http 304 https://registry.npmjs.org/mime-types
      ! npm http GET https://registry.npmjs.org/media-typer/ ... -0.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/ms/-/ms-0.7.1.tgz
      ! npm http 200 https://registry.npmjs.org/destroy/1.0.3
      ! npm http 200 https://registry.npmjs.org/negotiator/0.5.3
      ! npm http GET https://registry.npmjs.org/destroy/-/destroy-1.0.3.tgz
      ! npm http GET https://registry.npmjs.org/negotiator/- ... -0.5.3.tgz
      ! npm http 304 https://registry.npmjs.org/http-errors
      ! npm http 200 https://registry.npmjs.org/statuses
      ! npm http GET https://registry.npmjs.org/statuses/-/s ... -1.2.1.tgz
      ! npm http 200 https://registry.npmjs.org/unpipe/-/unpipe-1.0.0.tgz
      ! npm http 200 https://registry.npmjs.org/forwarded/-/ ... -0.1.0.tgz
      ! npm http 200 https://registry.npmjs.org/ee-first/-/e ... -1.1.1.tgz
      ! npm http 200 https://registry.npmjs.org/media-typer/ ... -0.3.0.tgz
      ! npm http 200 https://registry.npmjs.org/negotiator/- ... -0.5.3.tgz
      ! npm http 200 https://registry.npmjs.org/statuses/-/s ... -1.2.1.tgz
      ! npm http 200 https://registry.npmjs.org/destroy/-/destroy-1.0.3.tgz
      ! npm http 200 https://registry.npmjs.org/ipaddr.js/1.0.1
      ! npm http GET https://registry.npmjs.org/ipaddr.js/-/ ... -1.0.1.tgz
      ! npm http 200 https://registry.npmjs.org/ipaddr.js/-/ ... -1.0.1.tgz
      ! npm http GET https://registry.npmjs.org/inherits
      ! npm http GET https://registry.npmjs.org/mime-db
      ! npm http 304 https://registry.npmjs.org/mime-db
      ! npm http 304 https://registry.npmjs.org/inherits
      ! npm http GET https://registry.npmjs.org/unpipe/1.0.0
      ! npm http 200 https://registry.npmjs.org/unpipe/1.0.0
      ! gypnpm http 200 https://registry.npmjs.org/unpipe/-/unpipe-1.0.0.tgz
      ! gypnpm WARN optional dep failed, continuing bufferutil@1.1.0
      ! gypnpm WARN optional dep failed, continuing utf-8-validate@1.1.0
      • I Offline
        I Offline
        instalator
        #83
        @bondrogeen:
        ! 0.6.tgz
        ! 0.1.2.tgz
        ! 0.1.2.tgz
        ! 0.6.tgz
        ! z
        ! z
        ! 0.0.tgz
        ! 6.tgz
        ! 0.0.tgz
        ! 6.tgz
        ! n-0.5.0.tgz
        ! 0.0.tgz
        ! z
        ! n-0.5.0.tgz
        ! 0.0.tgz
        ! z
        ! npm WARN optional dep failed, continuing bufferutil@1.1.0 `
        Это ноду ставишь? Инет работает? Файрволы?
          bondrogeen
          #84
          ! cd %ProgramFiles%\iobroker
          ! node controller.js
          заработало.
            Securbond
            #85
            Доброго времени суток всем. Хотелось бы то же влиться в ряды иоБрокеров и сделать свой дом немного умнее… ну или хотя бы попытаться.
            Попытался делать все по инструкции но что то не получается.
            1. Установил Node.js последней версии.
            2. Начал устанавливать ioBroker
            и тут начались проблемы. Запускаю инсталятор от имени админа. язык- далее- далее...
            когда открывается консоль с черным экраном, сначала долго все висит, потом сыпятся ошибки 939_errorbrok.jpg , консоль закрывается и вроде как все ОК, но разумеется страница брокера не грузится
            Помогите справится с проблемой. (Система Win7 64).
            Спасибо!
              Securbond
              #86
              @Securbond:
              когда открывается консоль с черным экраном, сначала долго все висит, потом сыпятся ошибки filename="errorBrok.JPG" index="1">~~ , консоль закрывается и вроде как все ОК, но разумеется страница брокера не грузится
              папка брокера выглядит так - filename="1111.JPG" index="0">~~
              Спасибо! `
              Итог: поставил node.js версию 0.10.25 , затем удалил iobroker и поставил заново.
              Всё запускать от имени администратора !!!
              Всё установилось, разбираемся дальше.
                rosh_11
                #87
                Тоже есть желание влиться в ряды. Какой из дистрибов Node.js лучше поствить 4й LTS или 5й Stable (https://nodejs.org/en/download/).
                Кстати что за 10ая версия Node.js о которой пишут выше?
                • I Offline
                  I Offline
                  instalator
                  #88
                  @rosh_11:
                  Кстати что за 10ая версия Node.js о которой пишут выше? `
                  У меня 0.10.40 на данный момент https://nodejs.org/download/release/v0.10.40/
                    rosh_11
                    #89
                    Спасибо, попробую с этой версией.
                    Может изменть мануал по установке на сайте или на сайте выложить работающий дистриь node.js? (Сам с наскока попробовал поставить, не получилось… пошел читать форум, выясняется что с самим дистрибом node.js не все гуд).
                    • BluefoxB Offline
                      BluefoxB Offline
                      #90
                      Прописать, что надо использовать 0.12.X ?
                      • K Offline
                        kto
                        #91
                        Ребят, нужна помощь.
                        Что-то сложно у меня идёт щас с установкой.
                        Смог установить ioBroker только на версиях node JS 4.3.0, 0.12.10 и 0.10.40.
                        Последний раз устанавливал уже просто через npm:
                        Стало вроде бы всё ровно, НО!
                        Имею проблему с установкой пакета ZWave, а именно:
                        $ ./iobroker add zwave
                        npm install iobroker.zwave --production --prefix "C:/Program Files/ioBroker" (System call)
                        npm
                         ERR! Windows_NT 10.0.10586npm ERR! argv "C:\\Program Files (x86)\\nodejs\\\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.zwave" "--production" "--prefix" "C:/Program Files/ioBroker"
                        npm ERR! node v0.12.10npm ERR! npm  v2.14.9
                        npm
                         ERR! code EBADPLATFORM
                        npm ERR! notsup Unsupported
                        npm ERR! notsup Not compatible with your operating system or architecture: iobroker.zwave@0.2.5
                        npm ERR! notsup Valid OS:    darwin,linux
                        npm ERR! notsup Valid Arch:  any
                        npm ERR! notsup Actual OS:   win32
                        npm ERR! notsup Actual Arch: ia32
                        npm ERR! Please include the following file with any support request:npm ERR!     C:\Windows\system32\npm-debug.log
                        ERROR: host.kto Cannot install iobroker.zwave: 1
                        Перепробовал на разных версиях (разве только 0.10.25 не пробовал - засмущали варнинги при установке о несоответствии версии (не ниже 0.10.40)).
                        Может кто-то что-то порекомендует?
                        Ставлю всё это добро на Win 10 x64.
                        • BluefoxB Offline
                          BluefoxB Offline
                          #92
                          zwave поддерживается только под linux подобными системами
                          • K Offline
                            kto
                            #93
                            Опа)
                            Чувствую себя, как минимум, глупо)
                            В логе же это указано)))
                            Окей, спасибо.
                            Вот и повод познакомиться с Linux.
                            С возникшими вопросами перехожу в соответствующую ветку.
                              AvaloncheG
                              #94
                              @Bluefox:
                              Прописать, что надо использовать 0.12.X ? `
                              У меня на 0.12.XX не запустился, на 0.10.40 установился, если не сложно пропишите в разделе "Установка", что бы по форуму не искать в чем проблема.
                              • BluefoxB Offline
                                BluefoxB Offline
                                #95
                                @AvaloncheG:
                                @Bluefox:
                                У меня на 0.12.XX не запустился, на 0.10.40 установился, если не сложно пропишите в разделе "Установка", что бы по форуму не искать в чем проблема. `
                                Вообще-то надо 4.6.0. А где конкретней раздел "Установка"?
                                  AvaloncheG
                                  #96
                                  @Bluefox:
                                  Вообще-то надо 4.6.0. А где конкретней раздел "Установка"? `
                                  http://www.iobroker.net/docu/?page_id=2630&lang=ru
                                  Уже вижу что дописано :)
                                  Я сразу поставил 6.8.1, не заработало, не удаляя установил 0.12…. не помогло, все снес и поставил 0.10.40.
                                  Теперь можно удалить 0.10.40 и поставить 4.6.0?
                                  • G Offline
                                    Gelezako
                                    #97
                                    Помогите с установкой. Пробовал ставить на 2х версиях node.js
                                    node-v0.10.40-x86.msi
                                    и
                                    node-v7.5.0-x64.msi
                                    Но всегда не успешно. В консоли много ошибок и ворнингов, в результате при открытии http://localhost:8081/ всегда вижу
                                    This site can’t be reached
                                    localhost refused to connect.
                                    Всё запускал от имени админа под Win10
                                    ~~![](</s><URL url=)<link_text text="https://4.bp.blogspot.com/-FWkIRhvtmDY/ ... titled.png">https://4.bp.blogspot.com/-FWkIRhvtmDY/WKK16KoWwMI/AAAAAAAAezI/RwhPBW1Gs4YckdI96dYp1kbZs_vy6aJqQCLcB/s1600/Untitled.png</link_text>" />
                                    Спасибо!~~
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      #98
                                      C node.js 7 ещё никто не тестировал. Только с 6.
                                      Но если не хочешь быть бета-тестером поставь лучше node.js 4.x
                                      • X Offline
                                        X Offline
                                        X13
                                        #99
                                        Приветствую.
                                        На последних страницах вроде такой ошибки не нашёл.
                                        Используется XP 32bit.
                                        При попытке установить адаптер:
                                        ! 2017-02-25 10:26:20.936 - [32minfo[39m: host.asgard iobroker.js-controller version 0.15.3 js-controller starting
                                        ! 2017-02-25 10:26:20.936 - [32minfo[39m: host.asgard Copyright © 2014-2016 bluefox, hobbyquaker
                                        ! 2017-02-25 10:26:20.936 - [32minfo[39m: host.asgard hostname: asgard, node: v4.8.0
                                        ! 2017-02-25 10:26:20.952 - [32minfo[39m: host.asgard ip addresses: 192.168.102.105
                                        ! 2017-02-25 10:26:21.858 - [32minfo[39m: inMem-states listening on port 9000
                                        ! 2017-02-25 10:26:21.952 - [32minfo[39m: inMem-objects listening on port 9001
                                        ! 2017-02-25 10:26:21.968 - [32minfo[39m: host.asgard InMemoryDB connected
                                        ! 2017-02-25 10:26:21.983 - [32minfo[39m: host.asgard 1 instance found
                                        ! 2017-02-25 10:26:21.999 - [32minfo[39m: host.asgard starting 1 instance
                                        ! 2017-02-25 10:26:23.374 - [32minfo[39m: host.asgard instance system.adapter.admin.0 started with pid 2828
                                        ! 2017-02-25 10:26:31.593 - [32minfo[39m: admin.0 starting. Version 1.6.11 in D:/Program/ioBroker/node_modules/iobroker.admin, node: v4.8.0
                                        ! 2017-02-25 10:26:31.687 - [32minfo[39m: admin.0 requesting all states
                                        ! 2017-02-25 10:26:31.687 - [32minfo[39m: admin.0 requesting all objects
                                        ! 2017-02-25 10:26:31.687 - [32minfo[39m: admin.0 Request actual repository...
                                        ! 2017-02-25 10:26:31.703 - [32minfo[39m: admin.0 http server listening on port 8081
                                        ! 2017-02-25 10:26:31.703 - [32minfo[39m: admin.0 Use link "http://localhost:8081" to configure.
                                        ! 2017-02-25 10:26:32.343 - [32minfo[39m: admin.0 received all states
                                        ! 2017-02-25 10:26:32.499 - [32minfo[39m: admin.0 received all objects
                                        ! 2017-02-25 10:26:32.702 - [32minfo[39m: host.asgard Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                        ! 2017-02-25 10:26:38.140 - [32minfo[39m: admin.0 Repository received successfully.
                                        ! 2017-02-25 10:26:42.874 - [32minfo[39m: admin.0 Change log subscriber state: true
                                        ! 2017-02-25 10:26:42.874 - [32minfo[39m: admin.0 system.adapter.admin.0: logging true
                                        ! 2017-02-25 10:27:31.515 - [32minfo[39m: iobroker add fritzbox
                                        ! 2017-02-25 10:27:39.374 - [32minfo[39m: iobroker npm install iobroker.fritzbox --production --prefix "D:/Program/ioBroker" (System call)
                                        ! 2017-02-25 10:27:44.265 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! at String.replace (native)
                                        ! at envReplace (C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:424:12)
                                        ! at parseField (C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:400:7)
                                        ! at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:338:17
                                        ! at Array.forEach (native)
                                        ! at Conf.add (C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:337:23)
                                        ! at ConfigChain.addString (C:\Program Files\nodejs\node_modules\npm\node_modules\config-chain\index.js:244:8)
                                        ! at Conf. <anonymous>(C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:325:10)
                                        ! at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:78:16
                                        ! 2017-02-25 10:27:44.280 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:45.890 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! 2017-02-25 10:27:45.905 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:46.311 - [32minfo[39m: iobroker host.asgard install adapter fritzbox
                                        ! 2017-02-25 10:27:46.483 - [32minfo[39m: iobroker npm install iobroker.fritzbox --production --prefix "D:/Program/ioBroker" (System call)
                                        ! 2017-02-25 10:27:47.968 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! 2017-02-25 10:27:47.983 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:49.499 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! 2017-02-25 10:27:49.546 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:49.702 - [32minfo[39m: iobroker host.asgard install adapter fritzbox
                                        ! 2017-02-25 10:27:49.874 - [32minfo[39m: iobroker npm install iobroker.fritzbox --production --prefix "D:/Program/ioBroker" (System call)
                                        ! 2017-02-25 10:27:51.311 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! 2017-02-25 10:27:51.343 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:52.858 - [32minfo[39m: iobroker Error: Failed to replace env in config: ${APPDATA} at C:\Program Files\nodejs\node_modules\npm\lib\config\core.js:429:13
                                        ! 2017-02-25 10:27:52.874 - [32minfo[39m: iobroker
                                        ! 2017-02-25 10:27:53.046 - [32minfo[39m: iobroker host.asgard install adapter fritzbox
                                        ! 2017-02-25 10:27:53.046 - [31merror[39m: iobroker host.asgard Cannot install fritzbox
                                        ! 2017-02-25 10:27:53.280 - [32minfo[39m: iobroker exit 13[/spoiler]</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                                        Папки C:\Program Files\nodejs\node_modules\npm\lib\config\ не существует.
                                        UPD
                                        сделал npm.cmd update
                                        и теперь работает
                                        И ещё, при попытке установить Ноду в любую папку кроме C:\Program Files\nodejs\ и последующей попытке установить ioBroker не находит npm. Как следствие в папке есть только файлы ioBroker.ico, unins000.dat, unins000.exe
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #100
                                          @X13:
                                          Приветствую.
                                          UPD
                                          и теперь работает
                                          Установщик действительно ищет npm только в Program Files/nodejs…
                                          Доступен ли npm сразу после установки в любом месте? Тогда можно поменять этот код
                                          https://github.com/ioBroker/ioBroker.bu ... r.iss#L170 `
