  4. eCharts Datumsformat wird teils ignoriert
    6.1k
1 Beiträge 1 Kommentatoren 185 Aufrufe 1 Beobachtet
  • BertDerKleineB Offline
    BertDerKleine
    Adaptername: echarts
    Link zu Adapterrepository: www.github.com...
    Adapterversion: 0.4.0
    js-controller Version: 7.0.6
    Admin Version: 7.6.17
    Hardwaresystem: Pi4
    Arbeitsspeicher: 8 GB
    Festplattenart: SD-Karte
    Betriebssystem: Bullseye
    Nodejs-Version: 20.19.3
    NPM-Version: 10.8.2
    Installationsart: Manuell
    Image, Docker genutzt: Nein
    Script v.2025-03-08
    *** BASE SYSTEM ***
       Static hostname: iobrokerpi4b
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model : Raspberry Pi 4 Model B Rev 1.5
    Docker : false
    Virtualization : none
    Kernel : aarch64
    Userland : 64 bit
    Systemuptime and Load:
     09:11:15 up 34 min, 2 users, load average: 1.28, 1.36, 1.46
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-07-14 09:11:15 CEST
               Universal time: Mon 2025-07-14 07:11:15 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    PiAdmin
    XDG_CONFIG_HOME=/home/PiAdmin/.config
    HOME=/home/PiAdmin
    GROUPS=PiAdmin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop: LXDE-pi
    Terminal: x11
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
                   total used free shared buff/cache available
    Mem: 7.8G 2.2G 4.0G 73M 1.7G 5.4G
    Swap: 1.0G 0B 1.0G
    Total: 8.8G 2.2G 5.0G
    Active iob-Instances: 20
             7812 M total memory
             2192 M used memory
             2516 M active memory
              833 M inactive memory
             3950 M free memory
              181 M buffer memory
             1487 M swap cache
             1023 M total swap
                0 M used swap
             1023 M free swap
    *** top - Table Of Processes ***
    top - 09:11:16 up 34 min, 2 users, load average: 1.28, 1.36, 1.46
    Tasks: 212 total, 2 running, 210 sleeping, 0 stopped, 0 zombie
    %Cpu(s): 30.0 us, 7.1 sy, 0.0 ni, 62.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
    MiB Mem : 7812.3 total, 3949.9 free, 2192.5 used, 1669.8 buff/cache
    MiB Swap: 1024.0 total, 1024.0 free, 0.0 used. 5384.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 30G 17G 12G 59% /
    devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
    tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
    tmpfs tmpfs 1.6G 1.3M 1.6G 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot
    tmpfs tmpfs 782M 24K 782M 1% /run/user/1000
    [Mon Jul 14 08:37:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:F5:FF:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=891597ea-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jul 14 08:37:01 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul 14 08:37:01 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jul 14 08:37:03 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime
    `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.9G /var/
    1.5G /var/cache/apt
    1.5G /var/cache
    1.4G /var/cache/apt/archives
    1.2G /var/log/journal/f0de918bd30e4ce4bf2ed3f904044603
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    767M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G /opt/iobroker/iobroker-data/
    779M /opt/iobroker/iobroker-data/history
    589M /opt/iobroker/iobroker-data/files
    122M /opt/iobroker/iobroker-data/backup-objects
    114M /opt/iobroker/iobroker-data/files/vis
    48M /opt/iobroker/iobroker-data/objects.jsonl
    41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2692356-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs v20.19.3
    /usr/bin/node v20.19.3
    /usr/bin/npm 10.8.2
    /usr/bin/npx 10.8.2
    /usr/bin/corepack 0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u7 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Hosts:
    iobrokerpi4b iobrokerpi4b (version: 7.0.6, hostname: iobrokerpi4b , alive, uptime: 873)
    Core adapters versions
    js-controller: 7.0.6
    admin: 7.6.17
    javascript: 8.9.2
    nodejs modules from github: 0
    Adapter State
    + system.adapter.admin.0 : admin : iobrokerpi4b - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0 : backitup : iobrokerpi4b - enabled
    + system.adapter.deconz.0 : deconz : iobrokerpi4b - enabled, port: 8090
    + system.adapter.discovery.0 : discovery : iobrokerpi4b - enabled
    + system.adapter.e3oncan.0 : e3oncan : iobrokerpi4b - enabled
    + system.adapter.echarts.0 : echarts : iobrokerpi4b - enabled
    + system.adapter.email.0 : email : iobrokerpi4b - enabled
      system.adapter.flot.0 : flot : iobrokerpi4b - enabled
    + system.adapter.fritzdect.0 : fritzdect : iobrokerpi4b - enabled
    + system.adapter.history.0 : history : iobrokerpi4b - enabled
      system.adapter.icons-icons8.0 : icons-icons8 : iobrokerpi4b - enabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobrokerpi4b - enabled
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobrokerpi4b - enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerpi4b - enabled
      system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobrokerpi4b - enabled
    + system.adapter.javascript.0 : javascript : iobrokerpi4b - enabled
      system.adapter.material.0 : material : iobrokerpi4b - enabled
    + system.adapter.melcloud.0 : melcloud : iobrokerpi4b - enabled
      system.adapter.modbus.0 : modbus : iobrokerpi4b - disabled
    + system.adapter.mqtt.0 : mqtt : iobrokerpi4b - enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0 : netatmo-crawler : iobrokerpi4b - enabled
      system.adapter.openweathermap.0 : openweathermap : iobrokerpi4b - enabled
    + system.adapter.shelly.0 : shelly : iobrokerpi4b - enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sma-em.0 : sma-em : iobrokerpi4b - enabled
    + system.adapter.sourceanalytix.0 : sourceanalytix : iobrokerpi4b - enabled
    + system.adapter.statistics.0 : statistics : iobrokerpi4b - enabled
    + system.adapter.viessmannapi.0 : viessmannapi : iobrokerpi4b - enabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobrokerpi4b - enabled
      system.adapter.vis-bars.0 : vis-bars : iobrokerpi4b - enabled
      system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobrokerpi4b - enabled
      system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokerpi4b - enabled
      system.adapter.vis-history.0 : vis-history : iobrokerpi4b - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokerpi4b - enabled
      system.adapter.vis-icontwo.0 : vis-icontwo : iobrokerpi4b - enabled
    + system.adapter.vis-inventwo.0 : vis-inventwo : iobrokerpi4b - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokerpi4b - enabled
      system.adapter.vis-justgage.0 : vis-justgage : iobrokerpi4b - enabled
      system.adapter.vis-lcars.0 : vis-lcars : iobrokerpi4b - enabled
      system.adapter.vis-material-advanced.0 : vis-material-advanced : iobrokerpi4b - enabled
      system.adapter.vis-material.0 : vis-material : iobrokerpi4b - enabled
      system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokerpi4b - enabled
      system.adapter.vis-plumb.0 : vis-plumb : iobrokerpi4b - enabled
      system.adapter.vis-rgraph.0 : vis-rgraph : iobrokerpi4b - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokerpi4b - enabled
      system.adapter.vis-weather.0 : vis-weather : iobrokerpi4b - enabled
      system.adapter.vis.0 : vis : iobrokerpi4b - enabled
    + system.adapter.web.0 : web : iobrokerpi4b - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    âââââââââââ¬âââââââââââ¬ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââ (index) â name â url â auto upgrade â
    âââââââââââ¼âââââââââââ¼ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââ¤
    â 0 â 'stable' â 'http://download.iobroker.net/sources-dist.json' â false â
    â 1 â 'beta' â 'http://download.iobroker.net/sources-dist-latest.json' â false â
    âââââââââââ´âââââââââââ´ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ´âââââââââââââââInstalled ioBroker-Adapters
    Used repository: stable
    Adapter "admin" : 7.6.17 , installed 7.6.17
    Adapter "backitup" : 3.2.2 , installed 3.2.2
    Adapter "deconz" : 1.6.4 , installed 1.6.4
    Adapter "discovery" : 5.0.0 , installed 5.0.0
    Adapter "e3oncan" : 0.10.9 , installed 0.10.9
    Adapter "echarts" : 1.9.2 , installed 1.9.2
    Adapter "email" : 2.0.4 , installed 2.0.4
    Adapter "flot" : 1.12.0 , installed 1.12.0
    Adapter "fritzdect" : 2.6.2 , installed 2.6.2
    Adapter "history" : 3.0.1 , installed 3.0.1
    Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
    Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1
    Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "javascript" : 8.9.2 , installed 8.9.2
    Controller "js-controller": 7.0.6 , installed 7.0.6
    Adapter "material" : 1.3.1 , installed 1.3.1
    Adapter "melcloud" : 2.0.5 , installed 2.0.5
    Adapter "modbus" : 6.3.2 , installed 6.3.2
    Adapter "mqtt" : 6.1.2 , installed 6.1.2
    Adapter "netatmo-crawler": 1.0.0 , installed 1.0.0
    Adapter "openweathermap": 1.1.2 , installed 1.1.2
    Adapter "shelly" : 10.1.0 , installed 10.1.0
    Adapter "simple-api" : 2.8.0 , installed 2.8.0
    Adapter "sma-em" : 1.2.0 , installed 1.2.0
    Adapter "socketio" : 6.7.1 , installed 6.7.1
    Adapter "statistics" : 2.4.0 , installed 2.4.0
    Adapter "viessmannapi" : 2.3.0 , installed 2.4.0
    Adapter "vis" : 1.5.6 , installed 1.5.6
    Adapter "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
    Adapter "vis-bars" : 0.1.4 , installed 0.1.4
    Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
    Adapter "vis-history" : 1.0.0 , installed 1.0.0
    Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1
    Adapter "vis-icontwo" : 1.12.0 , installed 1.12.0
    Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5
    Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1
    Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
    Adapter "vis-lcars" : 1.1.1 , installed 1.1.1
    Adapter "vis-material" : 0.2.0 , installed 0.2.0
    Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
    Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
    Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
    Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vis-weather" : 2.5.12 , installed 2.5.12
    Adapter "web" : 7.0.8 , installed 7.0.8
    Adapter "ws" : 2.6.2 , installed 2.6.2
    Objects and States
    Objects: 38715
    States: 35952
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://phoscon.de/apt/deconz generic-beta InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 0.0.0.0:8090 0.0.0.0:* LISTEN 1000 14792 407/deCONZ
    tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14916 407/deCONZ
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12091 652/sshd: /usr/sbin
    tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 15547 556/cupsd
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 42187 8520/iobroker.js-co
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 40418 8520/iobroker.js-co
    tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 40752 8674/io.shelly.0
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 40689 8682/io.mqtt.0
    tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15564 584/vncserver-x11-c
    tcp6 0 0 ::1:631 :::* LISTEN 0 15546 556/cupsd
    tcp6 0 0 :::8081 :::* LISTEN 1001 39577 8538/io.admin.0
    tcp6 0 0 :::8082 :::* LISTEN 1001 43140 8798/io.web.0
    tcp6 0 0 :::80 :::* LISTEN 0 16176 576/java
    tcp6 0 0 :::22 :::* LISTEN 0 12093 652/sshd: /usr/sbin
    tcp6 0 0 :::5900 :::* LISTEN 0 15563 584/vncserver-x11-c
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14610 393/avahi-daemon: r
    udp 0 0 0.0.0.0:9522 0.0.0.0:* 1001 42527 8647/io.sma-em.0
    udp 0 0 0.0.0.0:38689 0.0.0.0:* 108 14612 393/avahi-daemon: r
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 39807 8681/io.deconz.0
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14993 407/deCONZ
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16437 569/dhcpcd
    udp6 0 0 :::5353 :::* 108 14611 393/avahi-daemon: r
    udp6 0 0 :::1900 :::* 1001 39808 8681/io.deconz.0
    udp6 0 0 :::48092 :::* 108 14613 393/avahi-daemon: r
      Regelstatus: AKTIV
      Betriebsmodus: LADEN
      Sollleistung: -665.2W
      Istleistung: -1199.8W
      Ãberschuss: 274W
      SOC: 86.6%
      Messwerte: 6 gespeichert
      Letzte Logs: [2025-07-14T07:02:11.332Z] [DEBUG] Steuerbefehl gesendet: -238.8W (nächstes Mal +0.1W)
      [2025-07-14T07:02:41.332Z] [DEBUG] Steuerbefehl gesendet: -407.0W (nächstes Mal Basiswert)
      [2025-07-14T07:03:11.333Z] [DEBUG] Steuerbefehl gesendet: -607.5W (nächstes Mal +0.1W)
    2025-07-14 09:06:46.868 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    2025-07-14 09:07:46.845 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    2025-07-14 09:08:36.327 - info: javascript.0 (8614) script.js.06_Schaltaufgaben.Akku-Steuerung: [2025-07-14T07:08:36.327Z] [INFO] Systemdiagnose:
      Regelstatus: AKTIV
      Sollleistung: -800.0W
      Istleistung: -1123.6W
      Ãberschuss: 48W
      SOC: 88.5%
      Letzte Logs: [2025-07-14T07:07:11.333Z] [DEBUG] Steuerbefehl gesendet: -800.0W (nächstes Mal +0.1W)
      [2025-07-14T07:07:41.334Z] [DEBUG] Steuerbefehl gesendet: -799.9W (nächstes Mal Basiswert)
      [2025-07-14T07:08:11.333Z] [DEBUG] Steuerbefehl gesendet: -800.0W (nächstes Mal +0.1W)
    2025-07-14 09:08:41.333 - info: javascript.0 (8614) script.js.06_Schaltaufgaben.Akku-Steuerung: [2025-07-14T07:08:41.333Z] [INFO] Initiale Debug-Periode beendet - Detaillogs deaktiviert
    2025-07-14 09:09:16.831 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    Insbesondere, wenn man das Zeitfenster auf 1 Monat einstellt, ist der Adapter bockig in bezug auf das Format des Zeitstrahls:
    Es wird der Eintrag in "Zeitformat" ignoriert und immer das Format "dd.mm" verwendet.
    Jemand eine Idee, wie man das hinbekommt?
