  4. Nach Nodejs 22 Update - Adapter nicht updatefähig
    6.7k
21 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • M Online
    M Online
    MCU
    nachdem ich ein Update von Nodejs auf Version 22 durchgeführt habe, werden andere Updates der Adapter nicht mehr umgesetzt.
    Update durchgeführt mit
    iob nodejs-update 22
    Hier der iob diag Auszug
    Script v.2025-03-08
    *** BASE SYSTEM ***
    Static hostname: iobrokerProd
          Icon name: computer-container
            Chassis: container ☐
     Virtualization: lxc
             Kernel: Linux 6.8.12-11-pve
       Architecture: x86-64
    OS is similar to:
    model name      : 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    23:45:39 up 1 day, 12 min,  2 users,  load average: 1.41, 1.40, 1.34
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                  Local time: Thu 2025-06-26 23:45:39 CEST
              Universal time: Thu 2025-06-26 21:45:39 UTC
                    RTC time: n/a
                 NTP service: inactive
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    prox
    HOME=/home/prox
    GROUPS=prox sudo users iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             17G        183M         11G        106K        5.2G         16G
    Swap:           536M        4.1K        536M
    Total:           17G        183M         12G
    Active iob-Instances:   1
           16384 M total memory
             174 M used memory
             253 M active memory
            4734 M inactive memory
           11237 M free memory
               0 M buffer memory
            4971 M swap cache
             512 M total swap
               0 M used swap
             511 M free swap
    top - 23:45:39 up 1 day, 12 min,  2 users,  load average: 1.41, 1.40, 1.34
    Tasks:  24 total,   1 running,  23 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16384.0 total,  11235.9 free,    176.5 used,   4971.7 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.  16207.5 avail Mem
    *** FAILED SERVICES ***
     UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    * iobroker.service        loaded failed failed ioBroker Server
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--150--disk--0 ext4       49G   22G   26G  46% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    //192.168.178.1/FRITZ.NAS        cifs      469G  359G  111G  77% /mnt/FritzNas
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  104K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET          SOURCE                           FSTYPE OPTIONS
    /               /dev/mapper/pve-vm--150--disk--0 ext4   rw,relatime,stripe=16
    `-/mnt/FritzNas //192.168.178.1/FRITZ.NAS        cifs   rw,nosuid,nodev,noexec,relatime,vers=3.0,cache=strict,upcall_target=app,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,iocharset=utf8,soft,nounix,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    859M    /var/
    414M    /var/cache
    410M    /var/cache/apt
    334M    /var/cache/apt/archives
    289M    /var/log/journal/0e88ad35af7a4b138e9b16cc19b4668b
    Archived and active journals take up 42.2M in the file system.
    /opt/iobroker/backups:
    763M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.3G    /opt/iobroker/iobroker-data/
    528M    /opt/iobroker/iobroker-data/backup-objects
    443M    /opt/iobroker/iobroker-data/files
    69M     /opt/iobroker/iobroker-data/files/vis-2
    66M     /opt/iobroker/iobroker-data/files/vis
    1.2G    /opt/iobroker/iobroker-data/states.jsonl
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    21M     /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json
    19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.17.0
    /usr/bin/node           v22.17.0
    /usr/bin/npm            10.9.2
    /usr/bin/npx            10.9.2
    /usr/bin/corepack       0.33.0
    nodejs:
     Installed: 22.17.0-1nodesource1
     Candidate: 22.17.0-1nodesource1
     Version table:
    *** 22.17.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
           100 /var/lib/dpkg/status
        22.16.0-1nodesource1 1001
        22.15.1-1nodesource1 1001
        22.15.0-1nodesource1 1001
        22.14.0-1nodesource1 1001
        22.13.1-1nodesource1 1001
        22.13.0-1nodesource1 1001
        22.12.0-1nodesource1 1001
        22.11.0-1nodesource1 1001
        22.10.0-1nodesource1 1001
        22.9.0-1nodesource1 1001
        22.8.0-1nodesource1 1001
        22.7.0-1nodesource1 1001
        22.6.0-1nodesource1 1001
        22.5.1-1nodesource1 1001
        22.5.0-1nodesource1 1001
        22.4.1-1nodesource1 1001
        22.4.0-1nodesource1 1001
        22.3.0-1nodesource1 1001
        22.2.0-1nodesource1 1001
        22.1.0-1nodesource1 1001
        22.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main amd64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobrokerProd        iobrokerProd (version: 7.0.7, hostname: iobrokerProd  , alive, uptime: 87015)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.1
    javascript:     9.0.6
    nodejs modules from github:     3
    +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#1de8967c7f7150dfdc1c281899adc5d01777b050)
    +-- iobroker.jarvis@3.2.0-rc.17 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#65370bd2ad4617722447bcff04ba4dc6429bed9b)
    +-- iobroker.meross@1.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.meross.git#89166c86e032b777b634e9fbe1e42544de9c9fb0)
    Adapter State
     system.adapter.admin.0                  : admin                 : iobrokerProd                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alexa2.0                 : alexa2                : iobrokerProd                             -  enabled
     system.adapter.awattar.0                : awattar               : iobrokerProd                             -  enabled
     system.adapter.awtrix-light.0           : awtrix-light          : iobrokerProd                             - disabled
     system.adapter.backitup.0               : backitup              : iobrokerProd                             -  enabled
     system.adapter.birthdays.0              : birthdays             : iobrokerProd                             - disabled
     system.adapter.bring.0                  : bring                 : iobrokerProd                             -  enabled
     system.adapter.broadlink2.0             : broadlink2            : iobrokerProd                             -  enabled
     system.adapter.cameras.0                : cameras               : iobrokerProd                             -  enabled, port: 8200, bind: 127.0.0.1
     system.adapter.chromecast.0             : chromecast            : iobrokerProd                             -  enabled
     system.adapter.cloud.0                  : cloud                 : iobrokerProd                             -  enabled
     system.adapter.daswetter.0              : daswetter             : iobrokerProd                             - disabled
     system.adapter.devices.0                : devices               : iobrokerProd                             - disabled
     system.adapter.discovery.0              : discovery             : iobrokerProd                             - disabled
     system.adapter.dwd.0                    : dwd                   : iobrokerProd                             -  enabled
     system.adapter.echarts.0                : echarts               : iobrokerProd                             -  enabled
     system.adapter.email.0                  : email                 : iobrokerProd                             -  enabled
     system.adapter.fahrplan.0               : fahrplan              : iobrokerProd                             - disabled
     system.adapter.flexcharts.0             : flexcharts            : iobrokerProd                             -  enabled
     system.adapter.flot.0                   : flot                  : iobrokerProd                             - disabled
     system.adapter.fritzdect.0              : fritzdect             : iobrokerProd                             -  enabled
     system.adapter.fullybrowser.0           : fullybrowser          : iobrokerProd                             -  enabled
     system.adapter.history.0                : history               : iobrokerProd                             -  enabled
     system.adapter.history.1                : history               : iobrokerProd                             - disabled
     system.adapter.hue-extended.0           : hue-extended          : iobrokerProd                             -  enabled
     system.adapter.hue.0                    : hue                   : iobrokerProd                             - disabled, port: 443
     system.adapter.ical.0                   : ical                  : iobrokerProd                             -  enabled
     system.adapter.iot.0                    : iot                   : iobrokerProd                             -  enabled
     system.adapter.jarvis.0                 : jarvis                : iobrokerProd                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
     system.adapter.jarvis.1                 : jarvis                : iobrokerProd                             -  enabled
     system.adapter.jarvis.2                 : jarvis                : iobrokerProd                             -  enabled
     system.adapter.javascript.0             : javascript            : iobrokerProd                             -  enabled
     system.adapter.lovelace.0               : lovelace              : iobrokerProd                             - disabled, port: 8091, bind: 0.0.0.0, run as: admin
     system.adapter.meross.0                 : meross                : iobrokerProd                             -  enabled
     system.adapter.mqtt-client.0            : mqtt-client           : iobrokerProd                             -  enabled, port: 1883
     system.adapter.mqtt.0                   : mqtt                  : iobrokerProd                             -  enabled, port: 1885, bind: 0.0.0.0
     system.adapter.mqtt.1                   : mqtt                  : iobrokerProd                             - disabled, port: 1883, bind: 0.0.0.0
     system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobrokerProd                             -  enabled
     system.adapter.odl.0                    : odl                   : iobrokerProd                             -  enabled
     system.adapter.onvif.0                  : onvif                 : iobrokerProd                             - disabled, port: 8000
     system.adapter.onvif.1                  : onvif                 : iobrokerProd                             - disabled, port: 8000
     system.adapter.openweathermap.0         : openweathermap        : iobrokerProd                             -  enabled
     system.adapter.parser.0                 : parser                : iobrokerProd                             - disabled
     system.adapter.pegelalarm.0             : pegelalarm            : iobrokerProd                             - disabled
     system.adapter.ping.0                   : ping                  : iobrokerProd                             -  enabled
     system.adapter.proxmox.0                : proxmox               : iobrokerProd                             -  enabled, port: 8006
     system.adapter.proxy.0                  : proxy                 : iobrokerProd                             -  enabled
     system.adapter.pushover.0               : pushover              : iobrokerProd                             -  enabled
     system.adapter.pvforecast.0             : pvforecast            : iobrokerProd                             - disabled
     system.adapter.rest-api.0               : rest-api              : iobrokerProd                             -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.ring.0                   : ring                  : iobrokerProd                             -  enabled
     system.adapter.roadtraffic.0            : roadtraffic           : iobrokerProd                             - disabled
     system.adapter.rssfeed.0                : rssfeed               : iobrokerProd                             - disabled
     system.adapter.shelly.0                 : shelly                : iobrokerProd                             -  enabled, port: 1882, bind: 0.0.0.0
     system.adapter.simple-api.0             : simple-api            : iobrokerProd                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
     system.adapter.slideshow.0              : slideshow             : iobrokerProd                             -  enabled
     system.adapter.slideshow.1              : slideshow             : iobrokerProd                             -  enabled
     system.adapter.smartcontrol.0           : smartcontrol          : iobrokerProd                             - disabled
     system.adapter.snmp.0                   : snmp                  : iobrokerProd                             -  enabled
     system.adapter.sonoff.0                 : sonoff                : iobrokerProd                             -  enabled, port: 1883, bind: 0.0.0.0
     system.adapter.spotify-premium.0        : spotify-premium       : iobrokerProd                             - disabled
     system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerProd                             -  enabled
     system.adapter.telegram.0               : telegram              : iobrokerProd                             -  enabled, port: 8443, bind: 0.0.0.0
     system.adapter.telegram.1               : telegram              : iobrokerProd                             -  enabled, port: 8443, bind: 0.0.0.0
     system.adapter.terminal.0               : terminal              : iobrokerProd                             - disabled, port: 8088, bind: 0.0.0.0, run as: admin
     system.adapter.tr-064.0                 : tr-064                : iobrokerProd                             -  enabled
     system.adapter.trashschedule.0          : trashschedule         : iobrokerProd                             -  enabled
     system.adapter.tuya.0                   : tuya                  : iobrokerProd                             - disabled
     system.adapter.tvprogram.0              : tvprogram             : iobrokerProd                             - disabled
     system.adapter.tvspielfilm.0            : tvspielfilm           : iobrokerProd                             - disabled
     system.adapter.twinkly.0                : twinkly               : iobrokerProd                             -  enabled
     system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobrokerProd                             - disabled
     system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobrokerProd                             -  enabled
     system.adapter.vis-2.0                  : vis-2                 : iobrokerProd                             -  enabled
     system.adapter.vis-metro.0              : vis-metro             : iobrokerProd                             - disabled
     system.adapter.vis.0                    : vis                   : iobrokerProd                             -  enabled
     system.adapter.web.0                    : web                   : iobrokerProd                             -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.web.1                    : web                   : iobrokerProd                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
     system.adapter.wifilight.0              : wifilight             : iobrokerProd                             -  enabled
     system.adapter.wled.0                   : wled                  : iobrokerProd                             -  enabled
     system.adapter.zigbee.0                 : zigbee                : iobrokerProd                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.1    , installed 7.7.1
    Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.3    , installed 3.3.0  [Updatable]
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "bring"        : 1.9.1    , installed 1.9.1
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "devices"      : 1.2.7    , installed 1.2.7
    Adapter    "echarts"      : 2.0.6    , installed 2.0.6
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
    Adapter    "flexcharts"   : 0.4.1    , installed 0.4.1
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.5.2    , installed 3.5.0  [Updatable]
    Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.17
    Adapter    "javascript"   : 9.0.6    , installed 9.0.6
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.0    , installed 5.0.0
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
    Adapter    "odl"          : 5.0.0    , installed 5.0.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "openweathermap": 1.3.0   , installed 1.3.0
    Adapter    "parser"       : 2.3.1    , installed 2.3.1
    Adapter    "pegelalarm"   : 1.3.8    , installed 1.3.8
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "roadtraffic"  : 1.2.0    , installed 1.2.0
    Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
    Adapter    "shelly"       : 10.0.0   , installed 10.0.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "slideshow"    : 0.2.1    , installed 0.2.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
    Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
    Adapter    "vis-2"        : 2.12.10  , installed 2.12.10
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 7.0.9    , installed 7.0.6  [Updatable]
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "zigbee"       : 3.0.1    , installed 2.0.4  [Updatable]
    Objects and States
    Objects:        31681
    States:         24572
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          195711636  327/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          195717258  1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          195717260  1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          195711637  327/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          195714986  1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          195717259  1/init
    udp6       0      0 :::111                  :::*                                0          195717261  1/init
    2025-06-26 23:43:29.518  - info: host.iobrokerProd instance system.adapter.trashschedule.0 terminated with code null ()
    2025-06-26 23:43:29.518  - warn: host.iobrokerProd instance system.adapter.twinkly.0 terminated due to SIGKILL
    2025-06-26 23:43:29.518  - info: host.iobrokerProd instance system.adapter.twinkly.0 terminated with code null ()
    2025-06-26 23:43:29.542  - info: host.iobrokerProd instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
    2025-06-26 23:43:29.543  - info: host.iobrokerProd instance system.adapter.jarvis.1 terminated with code 0 (NO_ERROR)
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.web.0 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.web.0 terminated with code null ()
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.web.1 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.web.1 terminated with code null ()
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.slideshow.0 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.slideshow.0 terminated with code null ()
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.telegram.0 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.telegram.0 terminated with code null ()
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.telegram.1 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.telegram.1 terminated with code null ()
    2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.backitup.0 terminated due to SIGKILL
    2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.backitup.0 terminated with code null ()
    2025-06-26 23:43:29.549  - info: host.iobrokerProd instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2025-06-26 23:43:29.591  - warn: host.iobrokerProd instance system.adapter.jarvis.2 terminated due to SIGKILL
    2025-06-26 23:43:29.591  - info: host.iobrokerProd instance system.adapter.jarvis.2 terminated with code null ()
    2025-06-26 23:43:29.632  - info: host.iobrokerProd instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2025-06-26 23:43:31.804  - info: meross.0 (782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-26 23:43:32.339  - info: host.iobrokerProd instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-06-26 23:43:32.339  - info: host.iobrokerProd All instances are stopped.
    2025-06-26 23:43:32.426  - info: host.iobrokerProd terminated
    iob diag has finished.
    [/s]
    Kennt jemand das Problem?
    • M MCU
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                      RTC time: n/a
               RTC in local TZ: no
      prox
      HOME=/home/prox
      Desktop:
      Terminal:
      *** MEMORY ***
      Total:           17G        183M         12G
               174 M used memory
               253 M active memory
             11237 M free memory
                 0 M buffer memory
              4971 M swap cache
               512 M total swap
                 0 M used swap
               511 M free swap
      *** FILESYSTEM ***
      /var:
      859M    /var/
      414M    /var/cache
      410M    /var/cache/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.1
      javascript:     9.0.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        31681
      States:         24572
      Pending Updates: 0
      [/s]
      @mcu
      iob update
      iob upgrade
      sagt?
        @mcu
        iob update
        iob upgrade
        sagt?
        M Online
        M Online
        MCU
        Linux iobrokerProd 6.8.12-11-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-11 (2025-05-22T09:39Z) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Wed Jun 25 23:33:06 CEST 2025 on tty1
        prox@iobrokerProd:~$ iob update
        prox@iobrokerProd:~$ iob upgrade
        This upgrade of "zigbee" will introduce the following changes:
        -> 3.0.1:
        Fix for Ikea SOMRIG configuration raising 'definition.endpoint is not a function' error.
        Access to 'zigbee2mqtt options as settings in zigbee adapter (ALPHA Stage !)
        Fix for 'error: zigbee.0 (1118300) zigbee.0 already running' at adapter start (Alpha Stage)
        Updated hardware configuration panel - exchanged text buttons for buttons with icons.
        Limited states on device tiles to states which are read only or which can be modified sensibly via the device tile.
        -> 3.0.0:
        Breaking change: Start of zigbee subsystem requires configuration entry !!!
        Hardware configuration panel
        Update for external converter - detect /dist/ subfolder
        Update device image: use of icons defined in external converter (beta)
        -> 2.0.5:
        ZHC 23.6.0
        ZH 3.3.x
        removed extra logging
        fixed memory issue.
        Configure on Message - 5 attempts.
        update transmitPower
        fix crash in ZigbeeController.ByteArrayToString
        device designation for  devices without mapped model (allows use in groups and bindings)
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade zigbee from @2.0.4 to @3.0.1 now? [(y)es, (n)o]:
        Nach Neustart vom System erhalte ich bei Update vom backitup
        $ iobroker upgrade backitup@3.3.3 --debug
        Update backitup from @3.3.0 to @3.3.3
        host.iobrokerProd Adapter "system.adapter.backitup.0" is stopped.
        NPM version: 10.9.2
        Installing iobroker.backitup@3.3.3... (System call)
        npm error code EBADENGINE
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_07_15_821Z-debug-0.log
        Updating objects from io-package.json for adapter "backitup" with version "3.3.0"
        upload [96] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/asset-manifest.json asset-manifest.json application/json
        upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/assets/zigbee2mqtt-tDEKhm15.png assets/zigbee2mqtt-tDEKhm15.png image/png
        upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js application/javascript
        upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/emotion-serialize.esm-BUa21YfQ.js custom/assets/emotion-serialize.esm-BUa21YfQ.js application/javascript
        upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/index-DHRZ46WI.js custom/assets/index-DHRZ46WI.js application/javascript
        upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/virtualExposes-Bgb1mEhK.js custom/assets/virtualExposes-Bgb1mEhK.js application/javascript
        upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
        upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/history.jsonConfig.json5 history.jsonConfig.json5 application/json5
        upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/influxdb.jsonConfig.json5 influxdb.jsonConfig.json5 application/json5
        upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/iob.jsonConfig.json5 iob.jsonConfig.json5 application/json5
        upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
        upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
        upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
        host.iobrokerProd Adapter "system.adapter.backitup.0" is started
        Process exited with code 0
        • M MCU
          -> 3.0.1:
          -> 3.0.0:
          -> 2.0.5:
          ZHC 23.6.0
          ZH 3.3.x
          fixed memory issue.
          NPM version: 10.9.2
          @mcu
          Läuft doch...
          M 2 Antworten Letzte Antwort
            @mcu
            Läuft doch...
            M Online
            M Online
            MCU
            @thomas-braun siehe oben
              @mcu
              Läuft doch...
              M Online
              M Online
              MCU
              @thomas-braun Updateversuch auf der console
              This upgrade of "backitup" will introduce the following changes:
              -> 3.3.3:
              Translation updated
              Fix Grafana Backup & Restore
              Docu updated
              dependencies updated
              -> 3.3.2:
              Base Topic for z2m Remote Backup added
              -> 3.3.1:
              Fix z2m Remote Backup
              Would you like to upgrade backitup from @3.3.0 to @3.3.3 now? [(y)es, (n)o]: y
              NPM version: 10.9.2
              upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
              upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
              upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
              upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
              upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
              upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
              upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
              upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
              upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
              upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
              upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
              upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
              upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
              prox@iobrokerProd:~$ iob version backitup
              3.3.0
              • M MCU
                -> 3.3.3:
                Translation updated
                Docu updated
                -> 3.3.2:
                -> 3.3.1:
                NPM version: 10.9.2
                3.3.0
                @mcu
                Bitte immer vollständige Ein- wie Ausgaben zeigen.
                Und bitte auf die Spoiler verzichten, die Klickerei nervt.
                  @mcu
                  M Online
                  M Online
                  MCU
                  @thomas-braun Hab bei iob upgrade die anderen Adapter mit N nicht upgegradet`, nur bei backitup mit Y.
                  Habe nochmal
                  iob stop
                  iob fix
                  laufen lassen, dann
                  3.3.0
                  prox@iobrokerProd:~$ iob upgrade backitup@3.3.3
                  -> 3.3.3:
                  Translation updated
                  Docu updated
                  -> 3.3.2:
                  -> 3.3.1:
                  NPM version: 10.9.2
                  3.3.0
                  • M MCU
                    Habe nochmal
                    iob stop
                    iob fix
                    laufen lassen, dann
                    3.3.0
                    -> 3.3.3:
                    Translation updated
                    Docu updated
                    -> 3.3.2:
                    -> 3.3.1:
                    NPM version: 10.9.2
                    3.3.0
                    @mcu
                    cd /opt/iobroker
                    npm ls
                    npm i --dry-run
                      @mcu
                      cd /opt/iobroker
                      npm ls
                      npm i --dry-run
                      M Online
                      M Online
                      MCU
                      @thomas-braun sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                      npm ls
                      prox@iobrokerProd:~$ cd /opt/iobroker
                      prox@iobrokerProd:/opt/iobroker$ npm ls
                      [sudo] password for prox:
                      iobroker.inst@3.0.0 /opt/iobroker
                      +-- @emnapi/runtime@1.3.1 extraneous
                      +-- @iobroker-javascript.0/axios@npm:axios@1.10.0
                      +-- @iobroker-javascript.0/cheerio@npm:cheerio@1.1.0
                      +-- @iobroker-javascript.0/decompress-targz@npm:decompress-targz@4.1.1
                      +-- @iobroker-javascript.0/decompress@npm:decompress@4.2.1
                      +-- @iobroker-javascript.0/form-data@npm:form-data@4.0.3
                      +-- @iobroker-javascript.0/html-pdf@npm:html-pdf@3.0.1
                      +-- @iobroker-javascript.0/html2json@npm:html2json@1.0.2
                      +-- @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
                      +-- @iobroker-javascript.0/jsdom@npm:jsdom@26.1.0
                      +-- @iobroker-javascript.0/node-ipc@npm:node-ipc@12.0.0
                      +-- @iobroker-javascript.0/puppeteer@npm:puppeteer@24.10.2
                      +-- @iobroker-javascript.0/uuid@npm:uuid@11.1.0
                      +-- @iobroker-javascript.0/xml2js@npm:xml2js@0.6.2
                      +-- @iobroker-javascript.0/xmldom@npm:xmldom@0.6.0
                      +-- iobroker.admin@7.7.1
                      +-- iobroker.alexa2@3.26.7
                      +-- iobroker.awattar@1.0.6
                      +-- iobroker.awtrix-light@2.0.0
                      +-- iobroker.backitup@3.3.0
                      +-- iobroker.birthdays@4.0.0
                      +-- iobroker.bring@1.9.1
                      +-- iobroker.broadlink2@2.3.0
                      +-- iobroker.cameras@2.1.2
                      +-- iobroker.chromecast@4.0.0
                      +-- iobroker.cloud@5.0.1
                      +-- iobroker.daswetter@3.2.3
                      +-- iobroker.devices@1.2.7
                      +-- iobroker.discovery@5.0.0
                      +-- iobroker.dwd@2.8.5
                      +-- iobroker.echarts@2.0.6
                      +-- iobroker.email@2.0.4
                      +-- iobroker.fahrplan@1.4.1
                      +-- iobroker.flexcharts@0.4.1
                      +-- iobroker.flot@1.12.0
                      +-- iobroker.fritzdect@2.6.2
                      +-- iobroker.fullybrowser@3.1.1
                      +-- iobroker.history@3.0.1
                      +-- iobroker.hue@3.16.2
                      +-- iobroker.ical@1.16.2
                      +-- iobroker.iot@3.5.0
                      +-- iobroker.javascript@9.0.6
                      +-- iobroker.js-controller@7.0.7
                      +-- iobroker.lovelace@5.0.0
                      +-- iobroker.mqtt-client@3.0.0
                      +-- iobroker.mqtt@6.1.4
                      +-- iobroker.notificationforandroidtv@3.0.4
                      +-- iobroker.odl@5.0.0
                      +-- iobroker.onvif@1.1.4
                      +-- iobroker.openweathermap@1.3.0
                      +-- iobroker.parser@2.3.1
                      +-- iobroker.pegelalarm@1.3.8
                      +-- iobroker.ping@1.7.9
                      +-- iobroker.proxmox@2.4.0
                      +-- iobroker.proxy@1.3.2
                      +-- iobroker.pushover@4.1.0
                      +-- iobroker.pvforecast@5.0.0
                      +-- iobroker.rest-api@3.0.1
                      +-- iobroker.ring@6.3.0
                      +-- iobroker.roadtraffic@1.2.0
                      +-- iobroker.rssfeed@3.5.2
                      +-- iobroker.shelly@10.0.0
                      +-- iobroker.simple-api@3.0.7
                      +-- iobroker.slideshow@0.2.1
                      +-- iobroker.smartcontrol@2.0.1
                      +-- iobroker.snmp@3.2.0
                      +-- iobroker.socketio@7.0.8
                      +-- iobroker.sonoff@3.2.1
                      +-- iobroker.spotify-premium@1.5.3
                      +-- iobroker.tankerkoenig@3.4.0
                      +-- iobroker.telegram@4.1.0
                      +-- iobroker.terminal@1.0.0
                      +-- iobroker.tr-064@4.3.0
                      +-- iobroker.trashschedule@3.3.0
                      +-- iobroker.tuya@3.17.0
                      +-- iobroker.tvprogram@4.0.0
                      +-- iobroker.tvspielfilm@2.1.0
                      +-- iobroker.twinkly@1.0.14
                      +-- iobroker.virtualpowermeter@1.5.0
                      +-- iobroker.vis-2-widgets-material@1.4.10
                      +-- iobroker.vis-2@2.12.10
                      +-- iobroker.vis-metro@1.2.0
                      +-- iobroker.vis@1.5.6
                      +-- iobroker.web@7.0.6
                      +-- iobroker.wifilight@2.0.3
                      +-- iobroker.wled@0.7.3
                      +-- iobroker.ws@3.0.19
                      `-- iobroker.zigbee@2.0.4
                      prox@iobrokerProd:/opt/iobroker$ npm i --dry-run
                      npm error engine Unsupported engine
                      npm error engine Not compatible with your version of node/npm: ring-client-api@13.1.0
                      npm error notsup Not compatible with your version of node/npm: ring-client-api@13.1.0
                      npm error notsup Required: {"node":"^18 || ^20"}
                      npm error notsup Actual:   {"npm":"10.9.2","node":"v22.17.0"}
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_35_49_020Z-debug-0.log
                      Problem wurde auch gemeldet
                      https://github.com/iobroker-community-adapters/ioBroker.ring/issues/820
                      T OliverIOO 2 Antworten Letzte Antwort
                      • M MCU
                        npm ls
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        @mcu
                        Hab’s nicht ganz gelesen, bei meinem Update auf 22 hab ich yahka entfernen müssen da backitup sich nicht updaten lies wenn es installiert ist - da ist ein veraltetes packet in den deps von yahka. Frag mich nicht wieso das was mit backitup zutun hat.😅
                        Spenden
                        Thomas BraunT ? 2 Antworten Letzte Antwort
                        • T ticaki
                          @mcu
                          @ticaki sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                          Nichts direkt. Allerdings macht der Paketmanager npm nichts mehr, wenn da eine nicht auflösbare Konstellation auftaucht.
                          Also Trouble bei yahaka verhindert ein Update von backitup (oder anderen Adaptern).
                          • T ticaki
                            @mcu
                            @ticaki
                            Downgrade Yahka auf die 1.0.3 und es läuft unter node 22
                              @ticaki
                              M Online
                              M Online
                              MCU
                              Fazit?
                              Wenn ein Adapter nicht für die aktuelle Nodejs Version (hier:22) aktuell gehalten wird, kann man ioBroker-Adapter nicht mehr updaten?
                              Der nicht korrekte Adapter muss dann deinstalliert werden!
                              Habe es mal bei chatGPT eingegeben:
                              ⚙️ Warum schlägt ein einzelnes Adapter-Upgrade unter Node.js 22 fehl?
                              📦 Hintergrund: Node.js + native Module
                              Viele ioBroker-Adapter (z. B. modbus, zigbee, mqtt, shelly) nutzen sogenannte native Node-Module (geschriebene C++-Addons). Diese Module sind kompiliert gegen eine bestimmte Node-ABI-Version, z. B. für Node.js 18 oder 20.
                              Wenn du ein Adapter-Update machst, dann passiert:
                              ioBroker nutzt npm → installiert Adapter inkl. package.json
                              npm prüft automatisch:
                              alle Abhängigkeiten
                              ob native Addons kompiliert werden müssen
                              Ist ein Abhängigkeitsmodul nicht kompatibel mit Node.js 22 → npm install schlägt fehl → Adapter-Update komplett abgebrochen
                              Und dabei prüft npm nicht nur das Zielmodul, sondern auch die Abhängigkeiten des gesamten Adapter-Trees, inklusive aller peer dependencies oder optionals.
                              💥 Typisches Beispiel:
                              Du willst hm-rega updaten, aber:
                              ein indirektes Abhängigkeitsmodul wie node-serialport ist noch nicht kompatibel mit Node.js 22
                              npm kann es nicht bauen → npm install schlägt komplett fehl → Adapter wird nicht aktualisiert
                              🔐 Warum kann ioBroker das nicht umgehen?
                              ioBroker selbst verwendet keine eigene Abhängigkeitsverwaltung – er nutzt npm install nativ. Das ist gewollt, da ioBroker-Adapter auf package.json-Basis gepflegt werden.
                              Der Update-Prozess ist also immer so etwas wie:
                              cd /opt/iobroker/node_modules/iobroker.adaptername
                              npm install iobroker.adaptername@latest
                              Wenn das fehlschlägt (egal bei welchem Modul), stoppt der gesamte Update-Prozess.
                              🧩 Lösungsideen (theoretisch):
                              📦 Adapter in isolierte Container packen (→ wäre Overhead)
                              💡 Adapter einzeln in eigene node_modules-Kontexte installieren (aber npm unterstützt das nicht gut)
                              🛠 iobroker könnte ein eigenes Paketmanagement nutzen (aber aktuell zu aufwendig)
                              EDIT
                              Da wäre dann die Frage, kann man das vorher durch einen Befehl prüfen lassen , bevor man das nodejs-update macht?
                              Bzw. Info an die Entwickler immer nur >={letzte geprüfte Nodejs-Version} in der packgae.json zu verwenden und nicht spezielle Angaben =20 || = 22.
                              • M MCU
                                npm ls
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @mcu
                                Das bedeutet halt es ist nur 18 oder 20 zulässig.
                                Sonst nix
                                Meine Adapter und Widgets
                                Links im Profil
                                • OliverIOO OliverIO
                                  @mcu
                                  Sonst nix
                                  M Online
                                  M Online
                                  MCU
                                  @oliverio Wäre ja auch für einen Adapter (hier: ring) dann ok. Aber das dadurch auch das Update für andere Adapter scheitert, ist mir neu.
                                  EDIT
                                  Bedeutet dann, wenn die Abhängigkeiten aller genutzten Adapter nicht gepflegt wird, mit deren genutzten Abhängigkeiten, APIs usw., kann man ioBroker, in der ,für jeden unterschiedlichen, Ausprägung, nicht mehr komplett nutzen.
                                  • M MCU
                                    EDIT
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @mcu
                                    Wir hatten da letztens schon einen komischen Fall. Ich glaube das was @ticaki erwähnte. Das müsste sich mal jemand anschauen der viel Ahnung von npm hat.
                                    Links im Profil
                                    HomoranH T 2 Antworten Letzte Antwort
                                      @mcu
                                      @oliverio sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                                      @mcu
                                      muss mal suchen, wenn es interessiert.
                                      @thomas-braun hatte sich da durch die npm Abhängigkeiten durchgekämpft
                                        @mcu
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        @mcu
                                        Ja das war ich, der das ansprochen hatte. Ist halt blöd das man nicht sofort beim nodejs-update eine Fehlermeldung bekommt, sondern irgendwann später mal.
                                        Spenden
                                        • T ticaki
                                          @mcu
                                          Im aktuellen Code (aber noch nicht released) ist zumindest ein rudimentärer Check drin.
                                          Da wird nach dem nodejs-Ugrade ein
                                          cd /opt/iobroker
                                          npm i --dry-run
                                          ausgeführt und Fehler/Inkompaibilitäten werden dann ausgespuckt. Sieht dann im günstigsten Fall so aus:
                                          echad@chet:/opt/iobroker $ npm i --dry-run
                                          up to date in 6s
                                          248 packages are looking for funding
                                            run `npm fund` for details
                                          Im ungünstigen Fall kannst du eine ellenlange Liste mit Meldungen bekommen.
