  4. Seltsames Verhalten MQTT-Adapter
    6.7k
2 Beiträge 1 Kommentatoren 288 Aufrufe 1 Beobachtet
  • MatzebhvM Offline
    MatzebhvM Offline
    Matzebhv
    schrieb am zuletzt editiert von Matzebhv
    Moin,
    das folgende Verhalten tritt machmal auf. Ein Adapter-Neustart hilft dann eine Weile.
    Das bringt leider alle möglichen Scripte durcheinander. Hat da jemand eine Idee? Es ist hier nicht nur der Sigenstor betroffen sondern alle möglichen MQTT-Clients.
    mqtt.0
    2025-06-15 21:24:26.191	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_plant_power_factor_adjustment_target_value.state" from "string" to "number"
    mqtt.0
    2025-06-15 21:24:23.661	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_plant_phase_b_q_s_fixed_adjustment_target_value.state" from "number" to "string"
    influxdb.0
    2025-06-15 21:24:20.855	info	changed history configuration to pin detected datatype for mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state
    influxdb.0
    2025-06-15 21:24:20.853	info	enabled logging of mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state, Alias=false
    influxdb.0
    2025-06-15 21:24:20.850	warn	Add mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state to conflicting Points (8 now)
    influxdb.0
    2025-06-15 21:24:20.850	warn	Error on writePoint("{"value":"[0, -26398]","time":"2025-06-15T19:24:20.830Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"partial write: field type conflict: input field \"value\" on measurement \"mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state\" is type string, already exists as type float dropped=1"} / "{\"error\":\"partial write: field type conflict: input field \\\"value\\\" on measurement \\\"mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state\\\" is type string, already exists as type float dropped=1\"}\n""
    influxdb.0
    2025-06-15 21:24:20.829	info	enabled logging of mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state, Alias=false
    mqtt.0
    2025-06-15 21:24:20.821	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_temperature.state" from "string" to "number"
    ring.0
    2025-06-15 21:23:45.418	debug	Device 200421625 ("Haustür"): Update Health Callback
    ring.0
    2025-06-15 21:23:45.058	debug	Device 200421625 ("Haustür"): Received Update
    mqtt.0
    2025-06-15 21:23:23.069	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_power_factor.state" from "string" to "number"
    mqtt.0
    2025-06-15 21:23:23.029	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_insulation_resistance.state" from "number" to "string"
    mqtt.0
    2025-06-15 21:23:03.139	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_inverter_1_power_factor.state" from "number" to "string"
    mqtt.0
    2025-06-15 21:22:28.068	info	Server: Changed type of "mqtt.0.sigenergy2mqtt.sigen_0_plant_power_factor_adjustment_target_value.state" from "number" to "string"
    Matze
    MatzebhvM 1 Antwort Letzte Antwort
    • MatzebhvM Matzebhv
      Moin,
      mqtt.0
      mqtt.0
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      mqtt.0
      ring.0
      ring.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      Matze
      MatzebhvM Offline
      MatzebhvM Offline
      Matzebhv
      Adapter 6.1.4
