  4. [gelöst] Problem mit Ansicht der Protokolle
1 Beiträge 1 Kommentatoren 242 Aufrufe 1 Beobachtet
  • H Offline
    homecineplexx
    schrieb am zuletzt editiert von homecineplexx
    hallo
    ich hab an und für sich nichts an meiner ioBroker Installation geändert, aber wenn ich auf die "Protokolle" Seite geh, bekomm ich einen Error View:
    Access to fetch at 'https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0' from origin 'http://192.168.1.8:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.Fehler nachvollziehenAI
    sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0:1
           Failed to load resource: net::ERR_FAILEDFehler nachvollziehenAI
    6Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was receivedFehler nachvollziehenAI
    :8081/#tab-objects:1 Access to fetch at 'https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0' from origin 'http://192.168.1.8:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.Fehler nachvollziehenAI
    socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399762660&name=admin' failed:
    (anonym) @ socket.io.js:140Fehler nachvollziehenAI
    socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399763885&name=admin' failed:
    socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399766885&name=admin' failed:
    socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399770885&name=admin' failed:
    :8081/static/js/6552.0a447e18.chunk.js:1
           Failed to load resource: the server responded with a status of 404 (Not Found)Fehler nachvollziehenAI
    5056.9247882b.chunk.js:2 ChunkLoadError: Loading chunk 6552 failed.
    (error: http://192.168.1.8:8081/static/js/6552.0a447e18.chunk.js)
        at Object.j (main.1a310c87.js:1:14222)
        at main.1a310c87.js:1:1162
        at Array.reduce (<anonymous>)
        at Function.e (main.1a310c87.js:1:1140)
        at 4684.31dece60.chunk.js:1:1657648
        at P (4905.33747b16.chunk.js:2:3345)
        at xi (5096.3a6e8bdb.chunk.js:2:120729)
        at bs (5096.3a6e8bdb.chunk.js:2:109361)
        at vs (5096.3a6e8bdb.chunk.js:2:109289)
        at gs (5096.3a6e8bdb.chunk.js:2:109152)
        at is (5096.3a6e8bdb.chunk.js:2:106268)
        at Hl (5096.3a6e8bdb.chunk.js:2:46915)
        at 5096.3a6e8bdb.chunk.js:2:103865
    (anonym) @ 5056.9247882b.chunk.js:2Fehler nachvollziehenAI
    4684.f5525d8f.chunk.css:1
    was kann ich tun?
    Edit: Browsercache geleert und neu geladen...funktioniert wieder
