  4. Backitup: index.js fehlt
    1.0k
    6.1k
3 Beiträge 2 Kommentatoren 542 Aufrufe
  • L Offline
    lessthanmore
    beim Versuch die Liste der Backups zu öffnen bzw. einfach nur beim Klick auf Backitup im Menü kommt folgende Meldung:
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-4-pve
        Architecture: x86-64
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:48:48 up 4 days, 20:05,  2 users,  load average: 0.15, 0.08, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2024-12-03 13:48:48 CET
               Universal time: Tue 2024-12-03 12:48:48 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael tty dialout sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        2.4G        5.3G        192K        921M        6.2G
    Swap:           4.3G         20K        4.3G
    Total:           12G        2.4G        9.6G
    Active iob-Instances: 	17
             8192 M total memory
             2242 M used memory
              790 M active memory
             2201 M inactive memory
             5070 M free memory
                0 M buffer memory
              878 M swap cache
             4096 M total swap
                0 M used swap
             4095 M free swap
    top - 13:48:48 up 4 days, 20:05,  2 users,  load average: 0.15, 0.08, 0.02
    Tasks:  55 total,   1 running,  54 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 50.0 id, 50.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   5068.9 free,   2244.7 used,    878.6 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   5947.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * certbot.service                      loaded failed failed Certbot
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    4 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       15G  7.1G  6.9G  51% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       96G   61G   31G  67% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  120K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    632M	/var/
    525M	/var/lib
    274M	/var/lib/redis
    143M	/var/lib/apt/lists
    143M	/var/lib/apt
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    1.3G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    76M	/opt/iobroker/iobroker-data/
    74M	/opt/iobroker/iobroker-data/node-red
    73M	/opt/iobroker/iobroker-data/node-red/node_modules
    9.8M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email
    9.7M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules
    2.0M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/js/app.min.js
    620K	/opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.js
    616K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/css/app.min.css
    600K	/opt/iobroker/iobroker-data/backitup/backitup.0.log
    544K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules/imap/deps/encoding/encoding-indexes.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.1
    /usr/bin/node 		v20.18.1
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 417898)
    Core adapters versions
    js-controller: 	7.0.3
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	1
    +-- iobroker.bmw@2.9.0 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#3caf730cbdf4e3a3d27b6a51f852a5c97f7aa16c)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 10.0.1.11
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.10
    Objects and States
    Objects: 	4123
    States: 	4136
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.1.11:8080          0.0.0.0:*               LISTEN      1001       5247193    524/node
    tcp        0      0 127.0.0.1:33797         0.0.0.0:*               LISTEN      1000       5234655    571/io.yahka.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5247690    830/master
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        5239408    152/redis-server 12
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          5247626    703/nginx: master p
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5239232    1/init
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          5247628    703/nginx: master p
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       5247190    505/io.zigbee2mqtt.
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       10983295   5199/node-red
    tcp6       0      0 :::80                   :::*                    LISTEN      0          5247627    703/nginx: master p
    tcp6       0      0 :::111                  :::*                    LISTEN      0          5239234    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5241038    1/init
    tcp6       0      0 :::34353                :::*                    LISTEN      1000       5234609    571/io.yahka.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5247691    830/master
    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        5239409    152/redis-server 12
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       5242364    586/io.simple-api.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5249524    556/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5241170    213/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       5247329    601/io.lovelace.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5239233    1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        5227294    105/avahi-daemon: r
    udp        0      0 0.0.0.0:44712           0.0.0.0:*                           110        5227296    105/avahi-daemon: r
    udp        0      0 10.0.1.11:54653         0.0.0.0:*                           1000       10987170   5199/node-red
    udp6       0      0 :::111                  :::*                                0          5239235    1/init
    udp6       0      0 :::5353                 :::*                                110        5227295    105/avahi-daemon: r
    udp6       0      0 :::50422                :::*                                110        5227297    105/avahi-daemon: r
    2024-12-03 13:46:50.610  - error: backitup.0 (354) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
    2024-12-03 13:46:55.388  - error: backitup.0 (354) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
    			v.2024-10-19
      Virtualization: lxc
    Installation: 		lxc
    Kernel: 		x86_64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1001
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.6G        2.4G        5.2G        192K        1.1G        6.2G
    Swap:           4.3G         20K        4.3G
    Total:           12G        2.4G        9.5G
    ioBroker Core: 		js-controller 		7.0.3
    			admin 			7.1.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: redis
    States  type: redis
    Objects: 		4123
    States: 		4136
    Size of iob-Database:
    136K	/opt/iobroker/iobroker-data/objects.json.bak
    12K	/opt/iobroker/iobroker-data/states.json.bak
    Gibt es eine Möglichkeit die Datei zu erstellen/ erstellen zu lassen ohne Neuinstallieren des Adapters?
    Danke vorab.Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
    Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
    DANKE
    Bitte ausfüllen:
    • Adaptername: ...
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: ...
    • js-controller Version: ...
    • Admin Version: ...
    • Hardwaresystem: NUC, Pi4 ...
    • Arbeitsspeicher: ...xGB
    • Festplattenart: SD-Karte, SSD, HDD, ...
    • Betriebssystem: ...
    • Nodejs-Version: ...
    • NPM-Version: ...
    • Installationsart: Skript oder Manuell ?
    • Image, Docker genutzt: Ja - Nein
    • Ort, Name der Imagedatei: ...
    Linux User bitte hier den Output von iob diag einfügen.Hi,
    Script v.2024-10-19
    *** BASE SYSTEM ***
      Virtualization: lxc
    OS is similar to:
    Docker          : false
    Kernel          : x86_64
    Userland        : 64 bit
    CPU threads: 4
                     RTC time: n/a
              RTC in local TZ: no
    michael
    HOME=/home/michael
    iobroker
    HOME=/home/iobroker
    Desktop:
    Terminal:
    *** MEMORY ***
    Swap:           4.3G         20K        4.3G
             8192 M total memory
             2242 M used memory
              790 M active memory
             5070 M free memory
                0 M buffer memory
              878 M swap cache
             4096 M total swap
                0 M used swap
             4095 M free swap
    *** FILESYSTEM ***
    /var:
    632M	/var/
    525M	/var/lib
    274M	/var/lib/redis
    143M	/var/lib/apt
    USB-Devices by-id:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    nodejs:
      Version table:
    ioBroker Status
    Objects type: redis
    States  type: redis
    Hosts:
    admin: 		7.1.5
    javascript: 	8.8.3
    Adapter State
    + instance is alive
    Objects and States
    Objects: 	4123
    States: 	4136
    Pending Updates: 0
    			v.2024-10-19
      Virtualization: lxc
    Installation: 		lxc
    Kernel: 		x86_64
    Userland: 		64 bit
    User-ID: 		1001
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    MEMORY:
    Swap:           4.3G         20K        4.3G
    			admin 			7.1.5
    Objects type: redis
    States  type: redis
    Objects: 		4123
    States: 		4136
    Danke vorab.
    • L lessthanmore
      Script v.2024-10-19
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      michael
      HOME=/home/michael
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.3G         20K        4.3G
               8192 M total memory
               2242 M used memory
                790 M active memory
               5070 M free memory
                  0 M buffer memory
                878 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /var:
      632M	/var/
      525M	/var/lib
      274M	/var/lib/redis
      143M	/var/lib/apt
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin: 		7.1.5
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4123
      States: 	4136
      Pending Updates: 0
      			v.2024-10-19
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1001
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      MEMORY:
      Swap:           4.3G         20K        4.3G
      			admin 			7.1.5
      Objects type: redis
      States  type: redis
      Objects: 		4123
      States: 		4136
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • NPM-Version: ...
      Script v.2024-10-19
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      michael
      HOME=/home/michael
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.3G         20K        4.3G
               8192 M total memory
               2242 M used memory
                790 M active memory
               5070 M free memory
                  0 M buffer memory
                878 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /var:
      632M	/var/
      525M	/var/lib
      274M	/var/lib/redis
      143M	/var/lib/apt
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin: 		7.1.5
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4123
      States: 	4136
      Pending Updates: 0
      			v.2024-10-19
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1001
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      MEMORY:
      Swap:           4.3G         20K        4.3G
      			admin 			7.1.5
      Objects type: redis
      States  type: redis
      Objects: 		4123
      States: 		4136
      Danke vorab.
      @lessthanmore
      Versuche es mit
      iob upload backitup
      L 1 Antwort Letzte Antwort
        @lessthanmore
        Versuche es mit
        iob upload backitup
        lessthanmore
        @paul53 Leider keine Änderung.
