  4. Fehlermeldung bei publishOnSubscribe
    5.1k
1 Beiträge 1 Kommentatoren 188 Aufrufe 1 Beobachtet
    Peter c
    Ich habe einen Flow unter Node Red der mir Verbrauchsdaten vom Tibber Pulse an einen Inverter schickt um die Power zu regeln. Das hat jetzt lange funktioniert. Seit geraumer Zeit verhält sich der Client der die Daten erhalten soll nicht mehr wie er soll. (siehe Anhang)
    2024-11-07 16:16:26.641 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.NotAus"
    2024-11-07 16:16:26.647 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.WaitSekunden"
    2024-11-07 16:16:26.656 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.MaxPower"
    2024-11-07 16:16:26.834 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:26.842 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:26.847 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:26.856 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:38.444 - warn: mqtt.0 (15082) Client [SOYO_e3d1d4] Message 5720 deleted after 11 retries
    2024-11-07 16:16:39.173 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] connection closed: Error: read ECONNRESET
    2024-11-07 16:16:40.686 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] connected with secret 1730992600685_3913
    2024-11-07 16:16:40.696 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.L1L2L3"
    2024-11-07 16:16:40.709 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.NotAus"
    2024-11-07 16:16:40.716 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.WaitSekunden"
    2024-11-07 16:16:40.724 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] subscribes on "mqtt.0.Soyosource.SOYO_e3d1d4.MaxPower"
    2024-11-07 16:16:40.898 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:40.910 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:40.916 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    2024-11-07 16:16:40.925 - info: mqtt.0 (15082) Client [SOYO_e3d1d4] publishOnSubscribe
    Er wird zwar immer wieder gestartet, aber der Error kommt und die Verbindung wird gekappt. Ist da was mit dem MQQT - Ablauf falsch?
