  4. Zigbee Adapter Brightness wird nicht gesendet
    1.0k
    6.1k
1 Beiträge 1 Kommentatoren 240 Aufrufe 1 Beobachtet
    andre1000
    Moin,
    ich habe ein Problem mit dem Zigbee Adapter. Es werden keine Brightness Befehle an Dimmer umgesetzt. Habe dies mit unterschiedlichen Zigbee Dimmern probiert. Es ist jeweils das gleiche Problem
    Zigbee Adpter: v1.10.3
    Zigbee Dimmer: TS0052_2 und QS-Zigbee-D02-TRIAC-2C-LN
    Log File:
    zigbee.0  2024-10-10 21:43:27.999	debug	Stack trace for null: Error: At least one of "brightness" or "state" must have a value: '{"brightness_l1":43}' at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1063:23) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:52 at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0  2024-10-10 21:43:27.998	error	Send command to 0xa4c138bb20d870fa failed with no error code (undefined)
    zigbee.0  2024-10-10 21:43:27.997	debug	convert brightness_l1, 43, {"brightness_l1":17,"transition_time":5,"brightness_l2":0,"transition":5,"brightness":43}
    zigbee.0  2024-10-10 21:43:27.996	debug	publishFromState : 0xa4c138bb20d870fa TS0052_2 [{"stateDesc":{"id":"brightness_l1","name":"Brightness l1","role":"level.dimmer","write":true,"read":true,"type":"number","min":0,"max":100,"inOptions":true,"epname":"l1","setattr":"brightness","readable":true,"writable":true},"value":17,"index":0,"timeout":0}]
    zigbee.0  2024-10-10 21:43:27.994	debug	Change state 'brightness_l1' at device 0xa4c138bb20d870fa type 'TS0052_2'
    zigbee.0  2024-10-10 21:43:27.900	debug	User stateChange zigbee.0.a4c138bb20d870fa.brightness_l1 {"val":17,"ack":false,"ts":1728589407899,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728589407899}
    zigbee.0  2024-10-10 21:43:27.897	debug	SetState_typed : converting "17" for zigbee.0.a4c138bb20d870fa.brightness_l1 from string to number
    Im letzten Jahr hat es funktioniert. Ich weiß leider nicht mehr, welche Version ich da hatte.
    Vielen Dank für die Hilfe,
    André
