  3. Einsteigerfragen
  4. Fehler in meinem Javascript
    5.4k
6 Beiträge 3 Kommentatoren 314 Aufrufe 2 Beobachtet
    Mico
    Hallo alle zusammen,
    Ich bekomme immer wieder im Protokoll diese Fehlermeldung angezeigt.:
    2024-06-04 20:00:00.024 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh_Berechnung" has to be type "string" but received type "number"
    2024-06-04 20:00:00.065 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh/h" has to be type "string" but received type "number"
    2024-06-04 20:00:00.065 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Büro.Buero_Computer_kWh_Verbrauswert" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumlüfter_kWh/Berechnung" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumentlüfter_kWh/h" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Raumentlüfter.Raumentlüfter_kWh/Verbrauchswert" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Berechnung" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/h" has to be type "string" but received type "number"
    2024-06-04 20:00:00.066 - info: javascript.0 (1572) State value to set for "0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Verbrauchswert" has to be type "string" but received type "number"
    2024-06-04 20:00:00.899 - info: ical.0 (12260) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
    Was hat das für mich zu bedeuten. Die DP sind alle String das heißt doch das sie sowohl Zahlen wie Buchstaben verarbeiten oder ?
    mico
    • M Mico
      mico
      @mico sagte in Fehler in meinem Javascript:
      Oder!
      Deswegen ja die Fehlermeldung.
      String ist String und Number ist Number.
        Oder!
        Mico
        Das heißt ich müsste nur String in Nummer ändern und alles ist gut
        • M Mico
          wo?
          den Typ des Datenpunktes!
          mit String lässt sich nämlich auch schlecht rechnen.
          "1" + "1" = "11"
            wo?
            "1" + "1" = "11"
            Mico
            schrieb am zuletzt editiert von Mico
            in der o Usherdata die DP die ich angelegt hatte.
            Ich dachte immer wenn ich Zahlen sende muss die Gegenstelle auch Zahlen annehmen. und nicht aus einer 1 einfach "1" machen. Meine Logik trifft Computer HiHi
            • M Mico
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @mico
              darauf versucht dich die Meldung hinzuweisen.
              1 ist number
              "1" ist string
              dein skript (welches wir nicht kennen) schreibt werte vom typ number
              in einen datenpunkt vom typ string.
              wenn du den wert dennoch als string schreiben möchtest, dann kannst du bspw folgendes machen
              setState("0_userdata.0.Stromwerteberechnung.Stube.Stuben_Fernseher_kWh/Berechnung",value.toString());
              Meine Adapter und Widgets
              Links im Profil
