  4. Amazon Dash Button Instanz will nicht…
    6.4k
19 Beiträge 6 Kommentatoren 3.0k Aufrufe
  • V Offline
    V Offline
    volker1078
    Hallo meine Dash Button Instanz möchte nicht….
    Hier ist der Log. Vielleicht kann jemand damit was anfangen.....
    host.bananapi	2017-09-02 21:24:02.819	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.bananapi	2017-09-02 21:24:02.817	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    host.bananapi	2017-09-02 21:23:58.385	info	instance system.adapter.amazon-dash.0 started with pid 3248
    host.bananapi	2017-09-02 21:23:28.349	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.bananapi	2017-09-02 21:23:28.347	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Object.Module._extensions..js (module.js:579:10)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Module._compile (module.js:570:32)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Object. (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at require (internal/module.js:20:19)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Module.require (module.js:497:17)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Function.Module._load (module.js:438:3)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at tryModuleLoad (module.js:446:12)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Module.load (module.js:487:32)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Object.Module._extensions..node (module.js:597:18)
    amazon-dash.0	2017-09-02 21:23:27.631	error	at Error (native)
    amazon-dash.0	2017-09-02 21:23:27.631	error	Error: Module version mismatch. Expected 48, got 14.
    amazon-dash.0	2017-09-02 21:23:27.580	error	uncaught exception: Module version mismatch. Expected 48, got 14.
    Gruß Volker
    geändert: Code in Code-Tags; Homoran (Mod)
    • apollon77A Offline
      Welche nodejs Version nutzt du? Hast du die in letzter Zeit aktualisiert nachdem du den Adapter installiert hast?
      • V Offline
        V Offline
        volker1078
        Ich habe iobroker neu auf meinen Bananapi installiert und dann von der v0.12.6 die v6.11.2 geupdatet. Die Amazon Dash Button Instanz wurde erst danach Installiert.
        Gruß Volker
          Marwin
          Hallo Volker
          Hast du vor der Installation des Adapters auch libpcap-dev installiert? (apt-get install libpcap-dev)
          Gruß, Marwin
          • V Offline
            V Offline
            volker1078
            Das war es leider nicht….. denke hat vielleicht was mit der node Version zu tun.....
            __pi@bananapi:~$ sudo apt-get install libpcap-dev
            [sudo] password for pi:
            libpcap-dev ist schon die neueste Version.__
            Gruß Volker
              Installier den Adapter nochmal. Von github oder so damit er neu. Installiert wird.
                Ist "node -v" und "nodejs -v" das gleiche?
                  @apollon77:
                  Ist "node -v" und "nodejs -v" das gleiche? `
                  Wie meinen?
                  Rainer
                    Hatten wir nicht schon mal Fälle wo irgendwie zwei Node versionen parallel da waren ?!
                      Ja!
                      ich hatte schon befürchtest du fragtest das für dich? :D
                      Also sollte die Frage an @volker1078 gehen, ob beide Befehle das selbe herausgeben ;-?
                      Rainer
                        Na klar sollte die Frage an volker gehen
                        • V Offline
                          V Offline
                          volker1078
                          das kommt bei mir raus:
                          pi@bananapi:~$ nodejs -v
                          v6.11.2
                          pi@bananapi:~$ node -v
                          v6.11.2
                          Gruß Volker
                            Dann Versuch wirklich mal Adapter neu installieren vom github. Und dann log schicken bitte
                            • V Offline
                              V Offline
                              volker1078
                              UPDATE: Jetzt klappt es doch nachdem ich die Instanz nochmals Installiert habe…..
                              Gruß Volker
                              hab ihn versucht von github zu installieren... scheint aber nicht geklappt zu haben. Jedenfalls ist keine Instanz zu sehn.
                              host.bananapi	2017-09-03 14:28:59.083	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                              iobroker	2017-09-03 14:28:58.405	info	exit 0
                              iobroker	2017-09-03 14:28:56.457	info	upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
                              iobroker	2017-09-03 14:28:53.742	info	upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
                              iobroker	2017-09-03 14:28:53.710	info	got /opt/iobroker/node_modules/iobroker.amazon-dash/admin
                              iobroker	2017-09-03 14:28:30.830	info	^
                              iobroker	2017-09-03 14:28:30.830	info	info.GetReturnValue().Set(cons->NewInstance());
                              iobroker	2017-09-03 14:28:30.830	info	../pcap_session.cc: In static member function 'static void PcapSession::New(const Nan::FunctionCallbackInfo&)':../pcap_session.cc:46:49: warning: 'v8::Local v8::Function::NewIn
                              iobroker	2017-09-03 14:27:55.306	info	^
                              iobroker	2017-09-03 14:27:55.306	info	info.GetReturnValue().Set(cons->NewInstance());
                              iobroker	2017-09-03 14:27:55.306	info	../socket_watcher.cpp: In static member function 'static void SocketWatcher::New(const Nan::FunctionCallbackInfo&)':../socket_watcher.cpp:104:49: warning: 'v8::Local v8::Functi
                              iobroker	2017-09-03 14:27:25.935	info	WARN lifecycle iobroker.amazon-dash@0.2.2~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.2 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.am
                              iobroker	2017-09-03 14:27:25.902	info	npm
                              iobroker	2017-09-03 14:26:07.408	info	npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --prefix "/opt/iobroker" (System call)
                              iobroker	2017-09-03 14:26:06.496	info	install https://github.com/PArns/ioBroker.amazon-dash/tarball/master
                              iobroker	2017-09-03 14:26:02.666	info	url "https://github.com/PArns/ioBroker.amazon-dash"
                                Bei Github Installs werden Instanzen nicht automatisch angelegt. Musst Du, wie schon festgestellt, manuell machen,
                                Aber die Installation war nicht ganz vollständig! bei amazon-dash muss die Installation als Root ausgeführt werden!!
                                • liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  hi appolon
                                  habe meinen eintrag gelöscht, da gelöst
                                  habe git im admin probiert - nütze nix
                                  habe dann git und gulp installiert
                                  danach über console npm install ….
                                  jetzt läuft es wieder rund
                                  was und warum genau wirkte, weiß ich nicht
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    und natürlich danke für die antwort
                                    • H Offline
                                      heitau
                                      ich habe auch ein Proble mit dem Adapter für Amazon Dash Button. Ich habe versucht den Adapter normal über den ioBorker Admin zu installieren, leider gab es viele Fehlermeldungen und es hatte keinen Erfolg. Dann habe ich es noch mal über den Button "Katze" (Installieren aus eigener URL) versucht mit dem gleichen Ergebnis.
                                      Zum Schuss habe ich mich über Putty angemeldet und folgende Eingaben gemacht:
                                      iobroker stop
                                      sudo iobroker add amazon-dash
                                      Auch hier die gleichen Fehler. Was ist hier der Fehler, oder was muss ich machen um diesen Adapter zu instllieren?
                                      Habe ich nicht genügend Rechte auf dem Verzeichnis:
                                      info: iobroker user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN
                                      Was muss ich tun um das zu beheben?
                                      Admin Version 3.5.10
                                      Node.js: v6.10.0
                                      NPM: 3.10.10
                                      Log:
                                      2018-11-13 20:02:37.235 - info: iobroker add amazon-dash --host ioBroker-RasPi
                                      2018-11-13 20:02:41.038 - info: iobroker NPM version: 3.10.10
                                      2018-11-13 20:02:42.154 - info: iobroker npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                                      2018-11-13 20:03:44.814 - info: iobroker npm
                                      2018-11-13 20:03:44.835 - info: iobroker WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                      2018-11-13 20:03:46.682 - info: iobroker gyp
                                      2018-11-13 20:03:46.685 - info: iobroker
                                      2018-11-13 20:03:46.686 - info: iobroker WARN
                                      2018-11-13 20:03:46.689 - info: iobroker EACCES
                                      2018-11-13 20:03:46.690 - info: iobroker user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN
                                      2018-11-13 20:03:46.692 - info: iobroker EACCES
                                      2018-11-13 20:03:46.693 - info: iobroker attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
                                      2018-11-13 20:03:55.694 - info: iobroker gyp
                                      2018-11-13 20:03:55.698 - info: iobroker
                                      2018-11-13 20:03:55.699 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/authenticate-pam/.node-gyp"
                                      2018-11-13 20:03:58.829 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                                      compilation terminated.
                                      2018-11-13 20:04:00.183 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
                                      2018-11-13 20:04:00.185 - info: iobroker gyp
                                      2018-11-13 20:04:00.191 - info: iobroker ERR! build error
                                      2018-11-13 20:04:00.200 - info: iobroker gyp
                                      2018-11-13 20:04:00.241 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      gyp ERR! stack at emitTwo (events.js:106:13)
                                      gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                                      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                      gyp ERR! System Linux 4.4.50-v7+
                                      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                      gyp ERR! node -v v6.10.0
                                      gyp ERR! node-gyp -v v3.4.0
                                      gyp ERR! not ok
                                      2018-11-13 20:04:02.020 - info: iobroker gyp
                                      2018-11-13 20:04:02.023 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/pcap/.node-gyp"
                                      2018-11-13 20:04:05.074 - info: iobroker ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:04:05.130 - info: iobroker compilation terminated.
                                      2018-11-13 20:04:05.223 - info: iobroker make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
                                      2018-11-13 20:04:05.225 - info: iobroker gyp
                                      2018-11-13 20:04:05.226 - info: iobroker ERR! build error
                                      2018-11-13 20:04:05.233 - info: iobroker gyp
                                      2018-11-13 20:04:05.236 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      gyp
                                      2018-11-13 20:04:05.269 - info: iobroker
                                      2018-11-13 20:04:05.278 - info: iobroker ERR! stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                                      gyp ERR! cwd /opt/iobroker/node_modules/pcap
                                      gyp ERR! not ok
                                      2018-11-13 20:04:07.960 - info: iobroker npm
                                      2018-11-13 20:04:07.961 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                                      2018-11-13 20:04:07.964 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      2018-11-13 20:04:07.975 - info: iobroker npm
                                      2018-11-13 20:04:07.976 - info: iobroker ERR! Linux 4.4.50-v7+
                                      2018-11-13 20:04:07.979 - info: iobroker npm
                                      2018-11-13 20:04:07.981 - info: iobroker ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"
                                      2018-11-13 20:04:07.982 - info: iobroker npm
                                      2018-11-13 20:04:07.984 - info: iobroker ERR! node v6.10.0
                                      2018-11-13 20:04:07.985 - info: iobroker npm ERR! npm v3.10.10
                                      2018-11-13 20:04:07.987 - info: iobroker npm ERR! code ELIFECYCLE
                                      2018-11-13 20:04:07.988 - info: iobroker npm ERR! pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1
                                      npm ERR!
                                      2018-11-13 20:04:07.989 - info: iobroker npm ERR! Failed at the pcap@2.1.0 install script 'node-gyp rebuild'.
                                      npm ERR! Make sure you have the latest version of node.js and npm installed.
                                      npm ERR! If you do, this is most likely a problem with the pcap package,
                                      npm ERR! not with npm itself.
                                      npm ERR! Tell the author that this fails on your system:
                                      npm
                                      2018-11-13 20:04:07.991 - info: iobroker ERR! node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with:
                                      npm ERR! npm bugs pcap
                                      npm ERR! Or if that isn't available, you can get their info via:
                                      npm ERR! npm owner ls pcap
                                      npm ERR!
                                      2018-11-13 20:04:07.992 - info: iobroker There is likely additional logging output above.
                                      2018-11-13 20:04:08.092 - info: iobroker
                                      2018-11-13 20:04:08.095 - info: iobroker npm ERR! Please include the following file with any support request:npm ERR!
                                      2018-11-13 20:04:08.100 - info: iobroker /opt/npm-debug.log
                                      2018-11-13 20:04:08.179 - info: iobroker host.ioBroker-RasPi install adapter amazon-dash
                                      2018-11-13 20:04:10.621 - info: iobroker NPM version: 3.10.10
                                      2018-11-13 20:04:10.623 - info: iobroker npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                                      2018-11-13 20:05:11.413 - info: iobroker npm WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                      2018-11-13 20:05:13.282 - info: iobroker gyp
                                      2018-11-13 20:05:13.286 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
                                      2018-11-13 20:05:21.970 - info: iobroker gyp
                                      2018-11-13 20:05:21.974 - info: iobroker
                                      2018-11-13 20:05:21.975 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/authenticate-pam/.node-gyp"
                                      2018-11-13 20:05:24.996 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:05:24.998 - info: iobroker compilation terminated.
                                      2018-11-13 20:05:26.281 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1gyp ERR!
                                      2018-11-13 20:05:26.292 - info: iobroker build error
                                      2018-11-13 20:05:26.299 - info: iobroker gyp
                                      2018-11-13 20:05:26.304 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      gyp ERR!
                                      2018-11-13 20:05:26.307 - info: iobroker node-gyp -v
                                      2018-11-13 20:05:26.309 - info: iobroker v3.4.0gyp ERR! not ok
                                      2018-11-13 20:05:28.082 - info: iobroker gyp
                                      2018-11-13 20:05:28.087 - info: iobroker
                                      2018-11-13 20:05:28.088 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/pcap/.node-gyp"
                                      2018-11-13 20:05:30.806 - info: iobroker ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:05:30.807 - info: iobroker compilation terminated.
                                      2018-11-13 20:05:30.951 - info: iobroker make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
                                      2018-11-13 20:05:30.954 - info: iobroker gyp
                                      2018-11-13 20:05:30.956 - info: iobroker ERR! build error
                                      2018-11-13 20:05:30.964 - info: iobroker gyp
                                      2018-11-13 20:05:30.965 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      2018-11-13 20:05:30.969 - info: iobroker gyp ERR! System Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! not ok
                                      2018-11-13 20:05:33.479 - info: iobroker npm
                                      2018-11-13 20:05:33.480 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                                      2018-11-13 20:05:33.482 - info: iobroker npm
                                      2018-11-13 20:05:33.483 - info: iobroker WARN
                                      2018-11-13 20:05:33.485 - info: iobroker optional
                                      2018-11-13 20:05:33.486 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm
                                      2018-11-13 20:05:33.488 - info: iobroker WARN
                                      2018-11-13 20:05:33.489 - info: iobroker optional
                                      2018-11-13 20:05:33.492 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      2018-11-13 20:05:33.502 - info: iobroker npm
                                      2018-11-13 20:05:33.503 - info: iobroker ERR!
                                      2018-11-13 20:05:33.504 - info: iobroker Linux 4.4.50-v7+
                                      2018-11-13 20:05:33.506 - info: iobroker npm
                                      2018-11-13 20:05:33.507 - info: iobroker ERR! argv
                                      2018-11-13 20:05:33.509 - info: iobroker "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"npm
                                      2018-11-13 20:05:33.511 - info: iobroker ERR!
                                      2018-11-13 20:05:33.512 - info: iobroker node
                                      2018-11-13 20:05:33.514 - info: iobroker v6.10.0
                                      2018-11-13 20:05:33.515 - info: iobroker npm
                                      2018-11-13 20:05:33.517 - info: iobroker ERR!
                                      2018-11-13 20:05:33.519 - info: iobroker npm v3.10.10
                                      2018-11-13 20:05:33.520 - info: iobroker npm
                                      2018-11-13 20:05:33.522 - info: iobroker ERR!
                                      2018-11-13 20:05:33.523 - info: iobroker code
                                      2018-11-13 20:05:33.525 - info: iobroker ELIFECYCLE
                                      2018-11-13 20:05:33.526 - info: iobroker npm
                                      2018-11-13 20:05:33.528 - info: iobroker ERR!
                                      2018-11-13 20:05:33.529 - info: iobroker pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1
                                      npm ERR!
                                      2018-11-13 20:05:33.531 - info: iobroker npm
                                      2018-11-13 20:05:33.532 - info: iobroker ERR! Failed at the pcap@2.1.0 install script 'node-gyp rebuild'.
                                      2018-11-13 20:05:33.534 - info: iobroker npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the pcap package,
                                      npm ERR! node-gyp rebuild
                                      npm ERR!
                                      2018-11-13 20:05:33.536 - info: iobroker You can get information on how to open an issue for this project with:npm ERR! npm bugs pcap
                                      npm ERR!
                                      2018-11-13 20:05:33.537 - info: iobroker npm owner ls pcap
                                      2018-11-13 20:05:33.540 - info: iobroker npm ERR!
                                      2018-11-13 20:05:33.542 - info: iobroker There is likely additional logging output above.
                                      2018-11-13 20:05:33.655 - info: iobroker
                                      2018-11-13 20:05:33.656 - info: iobroker npm
                                      2018-11-13 20:05:33.657 - info: iobroker ERR!
                                      2018-11-13 20:05:33.659 - info: iobroker Please include the following file with any support request:npm
                                      2018-11-13 20:05:33.660 - info: iobroker ERR!
                                      2018-11-13 20:05:33.663 - info: iobroker /opt/npm-debug.log
                                      2018-11-13 20:05:33.703 - info: iobroker host.ioBroker-RasPi install adapter amazon-dash
                                      2018-11-13 20:05:35.928 - info: iobroker NPM version: 3.10.10
                                      2018-11-13 20:05:35.929 - info: iobroker npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                                      2018-11-13 20:06:38.136 - info: iobroker npm
                                      2018-11-13 20:06:38.159 - info: iobroker WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                      2018-11-13 20:06:39.942 - info: iobroker gyp
                                      2018-11-13 20:06:39.945 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"
                                      2018-11-13 20:06:39.946 - info: iobroker gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
                                      2018-11-13 20:06:48.607 - info: iobroker gyp
                                      2018-11-13 20:06:48.611 - info: iobroker
                                      2018-11-13 20:06:48.612 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/authenticate-pam/.node-gyp"
                                      2018-11-13 20:06:51.664 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:06:52.944 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1gyp ERR! build error
                                      2018-11-13 20:06:52.951 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      2018-11-13 20:06:52.955 - info: iobroker gyp ERR! System Linux 4.4.50-v7+gyp
                                      2018-11-13 20:06:52.956 - info: iobroker ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                      gyp ERR! not ok
                                      2018-11-13 20:06:54.712 - info: iobroker gyp
                                      2018-11-13 20:06:54.773 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/pcap/.node-gyp"
                                      2018-11-13 20:06:57.512 - info: iobroker ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:06:57.657 - info: iobroker make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
                                      2018-11-13 20:06:57.660 - info: iobroker gyp
                                      2018-11-13 20:06:57.662 - info: iobroker ERR!
                                      2018-11-13 20:06:57.666 - info: iobroker build error
                                      2018-11-13 20:06:57.675 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      2018-11-13 20:06:57.677 - info: iobroker gyp ERR! System
                                      2018-11-13 20:06:57.680 - info: iobroker Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! not ok
                                      2018-11-13 20:07:00.408 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                                      2018-11-13 20:07:00.418 - info: iobroker npm ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--save" "--prefix" "/opt/iobroker"
                                      npm ERR! node v6.10.0
                                      2018-11-13 20:07:00.424 - info: iobroker npm ERR! code ELIFECYCLE
                                      npm ERR!
                                      npm ERR! There is likely additional logging output above.
                                      2018-11-13 20:07:00.508 - info: iobroker npm ERR! Please include the following file with any support request:
                                      npm
                                      2018-11-13 20:07:00.509 - info: iobroker ERR!
                                      2018-11-13 20:07:00.511 - info: iobroker /opt/npm-debug.log
                                      2018-11-13 20:07:00.607 - info: iobroker host.ioBroker-RasPi install adapter amazon-dash
                                      2018-11-13 20:07:00.611 - error: iobroker host.ioBroker-RasPi Cannot install amazon-dash
                                      2018-11-13 20:07:00.639 - info: iobroker exit 13
                                      2018-11-13 20:07:36.725 - info: iobroker url "https://github.com/PArns/ioBroker.amazon-dash/tarball/master" amazon-dash --debug
                                      2018-11-13 20:07:37.962 - info: iobroker install https://github.com/PArns/ioBroker.amazon-dash/tarball/master
                                      2018-11-13 20:07:39.614 - info: iobroker npm install https://github.com/PArns/ioBroker.amazon-dash/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                      2018-11-13 20:08:43.947 - info: iobroker npm
                                      2018-11-13 20:08:43.950 - info: iobroker WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
                                      2018-11-13 20:08:44.003 - info: iobroker > socketwatcher@0.3.0 install /opt/iobroker/node_modules/socketwatcher
                                      > node-gyp rebuild
                                      2018-11-13 20:08:45.742 - info: iobroker gyp
                                      2018-11-13 20:08:45.745 - info: iobroker
                                      2018-11-13 20:08:45.746 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
                                      2018-11-13 20:08:48.427 - info: iobroker make: Entering directory '/opt/iobroker/node_modules/socketwatcher/build'
                                      2018-11-13 20:08:48.430 - info: iobroker CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
                                      2018-11-13 20:08:51.832 - info: iobroker SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
                                      2018-11-13 20:08:52.111 - info: iobroker COPY Release/socketwatcher.node
                                      2018-11-13 20:08:52.130 - info: iobroker make: Leaving directory '/opt/iobroker/node_modules/socketwatcher/build'
                                      2018-11-13 20:08:52.352 - info: iobroker > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                                      > node-gyp rebuild
                                      2018-11-13 20:08:54.111 - info: iobroker gyp
                                      2018-11-13 20:08:54.166 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/authenticate-pam/.node-gyp"
                                      2018-11-13 20:08:56.852 - info: iobroker make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
                                      2018-11-13 20:08:56.857 - info: iobroker CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                                      2018-11-13 20:08:57.273 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:08:58.543 - info: iobroker authenticate_pam.target.mk:92: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failedmake: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
                                      2018-11-13 20:08:58.545 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
                                      2018-11-13 20:08:58.546 - info: iobroker gyp
                                      2018-11-13 20:08:58.548 - info: iobroker ERR! build error
                                      2018-11-13 20:08:58.556 - info: iobroker gyp
                                      2018-11-13 20:08:58.557 - info: iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      2018-11-13 20:08:58.560 - info: iobroker gyp ERR! System Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      2018-11-13 20:08:58.562 - info: iobroker gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp
                                      2018-11-13 20:08:58.564 - info: iobroker ERR! node -v v6.10.0gyp ERR! node-gyp -v v3.4.0
                                      gyp ERR! not ok
                                      2018-11-13 20:08:58.590 - info: iobroker > pcap@2.1.0 install /opt/iobroker/node_modules/pcap
                                      > node-gyp rebuild
                                      2018-11-13 20:09:00.398 - info: iobroker gyp
                                      2018-11-13 20:09:00.404 - info: iobroker
                                      2018-11-13 20:09:00.405 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/pcap/.node-gyp"
                                      2018-11-13 20:09:02.950 - info: iobroker make: Entering directory '/opt/iobroker/node_modules/pcap/build'
                                      2018-11-13 20:09:02.954 - info: iobroker CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                                      2018-11-13 20:09:03.023 - info: iobroker ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include
                                      2018-11-13 20:09:03.026 - info: iobroker compilation terminated.
                                      2018-11-13 20:09:03.168 - info: iobroker pcap_binding.target.mk:93: recipe for target 'Release/obj.target/pcap_binding/pcap_binding.o' failedmake: Leaving directory '/opt/iobroker/node_modules/pcap/build'
                                      2018-11-13 20:09:03.171 - info: iobroker make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1gyp ERR! build error
                                      2018-11-13 20:09:03.185 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                      2018-11-13 20:09:03.190 - info: iobroker gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
                                      2018-11-13 20:09:05.742 - info: iobroker npm
                                      2018-11-13 20:09:05.744 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                                      2018-11-13 20:09:05.754 - info: iobroker npm
                                      2018-11-13 20:09:05.755 - info: iobroker ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/PArns/ioBroker.amazon-dash/tarball/master" "--production" "--save" "--prefix" "/opt/iobroker"
                                      2018-11-13 20:09:05.757 - info: iobroker npm ERR! node v6.10.0
                                      2018-11-13 20:09:05.758 - info: iobroker npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE
                                      2018-11-13 20:09:05.760 - info: iobroker npm ERR! pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1
                                      npm ERR!
                                      2018-11-13 20:09:05.762 - info: iobroker npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the pcap package,
                                      2018-11-13 20:09:05.864 - info: iobroker
                                      2018-11-13 20:09:05.865 - info: iobroker npm ERR! Please include the following file with any support request:npm ERR!
                                      2018-11-13 20:09:05.869 - info: iobroker /opt/npm-debug.log
                                      2018-11-13 20:09:05.996 - error: iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                      2018-11-13 20:09:06.023 - info: iobroker exit 0
                                      2018-11-13 20:09:11.958 - info: host.ioBroker-RasPi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                      Danke!
                                      Heiko
                                      3153_dash-button.txt
                                        Na dann versuchen wir den Holzhammer :-)
                                        Ins ioBroker-Verzeichnis gehen, dort
                                        sudo npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" --unsafe-perms
                                        ausführen. Wenn das tut dann noch ein
                                        iobroker upload amazon-dash
                                        danach.
                                        Dann manuell im Admin eine Instanz anlegen
