  4. [Gelöst] Installation Logitech Harmony Adapter
    5.7k
3 Beiträge 2 Kommentatoren 970 Aufrufe
  • E Offline
    eurohulos
    Guten Abend,
    Die Installation von ioBroker 1.1.3 auf win32 hat funktioniert und auch der HUE Adapter funktioniert. Leider schlug aber die Installation des Logitech Harmony Adapter fehl. Dem Log verstehe ich so, dass gewisse Komponenten fehlen, komme da aber nicht weiter:
    $ ./iobroker add harmony
    npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
    npm
     WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
    npm
    WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
    npm WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)
    npm WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)
    npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16
    npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5
    npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5
    npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:264:29
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
    npm WARN
    addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
    npm WARN
    addRemoteGit
         at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)npm
    WARN addRemoteGit
         at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16npm WARN
    npm
    WARN
    addRemoteGit
         at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    npm
     ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR!
    npm
     ERR! Windows_NT 10.0.15063
    npm
    ERR! argv
     "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
    npm ERR! node
     v6.11.2
    npm
    ERR! npm  v3.10.10
    npm
    ERR! code ENOGIT
    npm
     ERR! not found: gitnpm ERR!
    npm ERR! Failed using git.
    npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    npm ERR! Please include the following file with any support request:npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log
    host.TV-BOX install adapter harmony
    npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
    npm
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)npm
    WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:14:12)
    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    npm
    ERR!
    npm
    npm
     ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
    npm ERR! node v6.11.2npm ERR! npm  v3.10.10
    npm
    ERR! code ENOGIT
    npm ERR! not found: gitnpm ERR!
    npm
    npm
    npm
    WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:69:19)npm WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:81:29)
    npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
    npm
    WARN addRemoteGit
    npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:90:16npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\index.js:44:5
    npm
     WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\node_modules\isexe\windows.js:29:5npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:264:29
    npm
    npm
     ERR! Windows_NT 10.0.15063npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.harmony" "--production" "--prefix" "C:/ioBroker"
    npm
    ERR! node
    npm ERR! code ENOGIT
    npm
    npm ERR!
    npm
    ERROR: host.TV-BOX Cannot install harmony
    ERROR: process exited with code 13</https:></https:></https:>
    3415_npm-debug.log
    Danke für die Hilfe!
      Hallo und Willkommen im Forum!
      @eurohulos:
      Dem Log verstehe ich so, dass gewisse Komponenten fehlen `
      Wie recht du hast.
      @eurohulos:
      ERR! code ENOGIT `
      Ich kenne mich bei Windows nicht aus, aber irgendwo im Forum steht wie.
      (Git nicht github!)
      http://forum.iobroker.net/viewtopic.php … ren#p50835
      Rainer
      • E Offline
        eurohulos
        Und schon funktionierts.
        Danke!
