  4. Hm-rpc Callback-Adresse
    6.3k
9 Beiträge 3 Kommentatoren 13.9k Aufrufe
    Eben meckert mich eine aus einem backup installierte hm-rpc an, ich solle eine Callback IP eingeben.
    Lt. github wird das nur für docker gebraucht.
    Allerdings gehen beide hm-rpc (rfd und CuxD) ständig rot - grün.
    gestern hatte ich ein anderes backup eingespielt da wurde da nicht nach gefragt.
    log:
    hm-rpc.1	2017-08-20 13:08:51.643	info	binrpc -> 192.168.138.52:8701 init ["xmlrpc_bin://192.168.138.74:8701",""]
    hm-rpc.1	2017-08-20 13:08:51.639	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    hm-rpc.1	2017-08-20 13:08:51.639	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    hm-rpc.1	2017-08-20 13:08:51.639	error	at net.js:1404:9
    hm-rpc.1	2017-08-20 13:08:51.639	error	at listen (net.js:1294:10)
    hm-rpc.1	2017-08-20 13:08:51.639	error	at Server._listen2 (net.js:1245:19)
    hm-rpc.1	2017-08-20 13:08:51.639	error	at exports._exceptionWithHostPort (util.js:1043:20)
    hm-rpc.1	2017-08-20 13:08:51.639	error	at Object.exports._errnoException (util.js:1020:11)
    hm-rpc.1	2017-08-20 13:08:51.639	error	Error: listen EADDRNOTAVAIL 192.168.138.74:8701
    hm-rpc.1	2017-08-20 13:08:51.638	error	uncaught exception: listen EADDRNOTAVAIL 192.168.138.74:8701
    hm-rpc.1	2017-08-20 13:08:51.573	info	binrpc client is trying to connect to 192.168.138.52:8701 with ["xmlrpc_bin://192.168.138.74:8701","hm-rpc.1"]
    hm-rpc.1	2017-08-20 13:08:51.567	info	binrpc server is trying to listen on 192.168.138.74:8701
    hm-rpc.1	2017-08-20 13:08:51.014	info	starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.2
    und der andere:
    hm-rpc.0	2017-08-20 13:09:11.630	info	binrpc -> 192.168.138.52:2001 init ["xmlrpc_bin://192.168.138.74:2001",""]
    hm-rpc.0	2017-08-20 13:09:11.626	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    hm-rpc.0	2017-08-20 13:09:11.626	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    hm-rpc.0	2017-08-20 13:09:11.626	error	at net.js:1404:9
    hm-rpc.0	2017-08-20 13:09:11.626	error	at listen (net.js:1294:10)
    hm-rpc.0	2017-08-20 13:09:11.626	error	at Server._listen2 (net.js:1245:19)
    hm-rpc.0	2017-08-20 13:09:11.626	error	at exports._exceptionWithHostPort (util.js:1043:20)
    hm-rpc.0	2017-08-20 13:09:11.626	error	at Object.exports._errnoException (util.js:1020:11)
    hm-rpc.0	2017-08-20 13:09:11.626	error	Error: listen EADDRNOTAVAIL 192.168.138.74:2001
    hm-rpc.0	2017-08-20 13:09:11.625	error	uncaught exception: listen EADDRNOTAVAIL 192.168.138.74:2001
    hm-rpc.0	2017-08-20 13:09:11.576	info	binrpc client is trying to connect to 192.168.138.52:2001 with ["xmlrpc_bin://192.168.138.74:2001","hm-rpc.0"]
    hm-rpc.0	2017-08-20 13:09:11.571	info	binrpc server is trying to listen on 192.168.138.74:2001
    hm-rpc.0	2017-08-20 13:09:10.560	info	starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.2
    Rainer
      :oops: :oops: Habe es herausgefunden :(
      das Backup war von einer anderen Installation, daher hatte sich in der hm-rpc Konfiguration die Adapter-Adresse auf 0.0.0.0 gestellt.
      Dabei steht in der Doku ganz deutlich:
      ~~@[url=http://www.iobroker.net/docu/?page_id=2829⟨=de#Adapter_Adresse:~~
      ~~Doku"]~~Standard ist ipv4 0.0.0.0; allerdings muss hier eine von außen (von der anzusprechenden CCU aus) erreichbare Adresse wie 192.168.xxx.yyy eingegeben werden, da die CCU bei der Kommunikation die Ereignisse an diese Adresse sendet. `
      die falsche IP-Adresse im log war mir gar nicht aufgefallen, da das auch eine gültige ioBroker Testinstallation ist.
      Rainer
        tomg1970
        Was ist die Adaper Callback Adresse?
        Ich habe gerade auch aktuell das Probelm, dass ich RPD/REGA nicht zum laufen bekomme?
          @tomg1970:
          Was ist die Adaper Callback Adresse? `
          Die Adaapter Callback-Adresse wird (nur) gebraucht, wenn ioBroker in einer VM läuft.
          Damit die CCU weiß wohin sie die abonnierten States schicken muss.
          Rainer
            tomg1970
            OK vielen DANK Rainer.
            RPC wird jetzt grün.
            Allerdings kommt im REGA immer noch die Fehlermeldung wenn ich auf speichern gehe:
            "Please select rpc adapter for enabled service or install one first"
              Du hast ja einen Haken bei HM-IP und dafür wohl noch keine hm-rpc Instanz angelegt.
              Rainer
                tomg1970
                Jep das war das Problem. Vielen Dank dafür
                  tomg1970
                  Problem gelöst. Für Homematic-IP war noch keine Instanz angelegt.
                    Artjom
                    Vielen Dank an @Homoran und @tomg1970
                    Ich habe eben das gleiche Problem. :roll:
