  3. Einsteigerfragen
  4. Fehler nach js-controller update
    1.6k
    2.3k
8 Beiträge 5 Kommentatoren 953 Aufrufe 4 Beobachtet
    andi_grafa
    schrieb am zuletzt editiert von andi_grafa
    beim update des Adapters js-controller kam es zu einem Fehler, leider startet iobroker nicht mehr.
    iob diag bringt folgende Meldung:
                            v.2023-10-10
     Static hostname: raspi-MUG
           Icon name: computer
              Kernel: Linux 6.1.0-rpi8-rpi-v8
        Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module 'follow-redirects'
    Require stack:
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
    - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
    - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Module.require (node:internal/modules/cjs/loader:1225:19)
        at require (node:internal/modules/helpers:177:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
        at Module._compile (node:internal/modules/cjs/loader:1356:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        at Module.load (node:internal/modules/cjs/loader:1197:32)
        at Module._load (node:internal/modules/cjs/loader:1013:12)
        at Module.require (node:internal/modules/cjs/loader:1225:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
        '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.19.1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                            /usr/bin/node           v18.19.1
                            /usr/bin/npm            10.2.4
                            /usr/bin/npx            10.2.4
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            952M        382M        153M        204K        484M        570M
    Swap:           1.1G        260M        813M
    Total:          2.0G        642M        966M
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    Active iob-Instances:   0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    ioBroker Core:          js-controller
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
                            admin
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    ioBroker Status:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    Objects:                0
    States:                 0
    Size of iob-Database:
    4.8M    /opt/iobroker/iobroker-data/objects.jsonl
    192K    /opt/iobroker/iobroker-data/states.jsonl
    Wie könnte ich iob wieder zum Laufen bringen?
    Andreas
    wendy2702W apollon77A 2 Antworten Letzte Antwort
    • A andi_grafa
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               arm64
      User-ID:                1000
      X-Server:               false
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
      MEMORY:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
                              admin
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      ioBroker Status:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      Objects:                0
      States:                 0
      Andreas
      wendy2702W Online
      wendy2702W Online
      wendy2702
      @andi_grafa
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iob stop
      iob fix
      iob start
      iob update
      A 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        @andi_grafa
        cd /opt/iobroker
        iob stop
        iob fix
        iob start
        iob update
        andi_grafa
        @wendy2702
        vielen Dank für deine schnelle Antwort.
        Ist sudo wirklich beabsichtigt....ich dachte immer, es sollte keine sudo im Zusammenhang mit iob verwendet werden.
        Ich möchte nur sicher gehen.
        GlasfaserG HomoranH 2 Antworten Letzte Antwort
        • A andi_grafa
          @wendy2702
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @andi_grafa sagte in Fehler nach js-controller update:
          das ist kein Befehl iobroker , sondern der Benutzer iobroker
          • A andi_grafa
            @wendy2702
            nein!
            nur due Befehle, die mit iobroker.... beginnen dürfen nicht mit sudo gestartet werden.
            Woanders natürlich auch "sparsam " mit sudo umgehen, aber apt benötigt sudo
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              dem was @Glasfaser und @Homoran geschrieben haben ist nichts mehr hinzuzufügen
                andi_grafa
                @wendy2702
                super, vielen Dank!!
                • A andi_grafa
                                          v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               arm64
                  User-ID:                1000
                  X-Server:               false
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                                          /usr/bin/npm            10.2.4
                                          /usr/bin/npx            10.2.4
                  MEMORY:
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                                          admin
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                  ioBroker Status:
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.19.1
                  Objects:                0
                  States:                 0
                  Andreas
                  @andi_grafa der Fehler den es beim Update selbst gab wäre ja gut zu wissen. Weil da ist ggf das Problem zu sehen. Der Fehler danach heißt nur „js-Controller ist nicht korrekt installiert“. Frage ist warum
                  83.2k
