  4. [Gelöst] Adapter Updates in Liste anzeigen
    6.0k
21 Beiträge 8 Kommentatoren 2.7k Aufrufe 10 Beobachtet
  • DJMarc75D DJMarc75
    Eben festgestellt dass die Abfrage der Listenlänge auch weg kann:
     <variables>
       <variable id="rP{a|eu}2/U(2%YfvLO^">json</variable>
       <variable id="TOC57z`*`7eGmxbFS-:h">updateliste</variable>
       <variable id="CUid=kHOy5RBXEU4[!}D">updatejson</variable>
       <variable id="JT52yn~1WVDRD|]6)~f]">i</variable>
       <variable id="%Tg~cn!H=|@vi9M%DCjv">adapter</variable>
     </variables>
     <block type="on_ext" id="^2c-iIL#(amcW/Kl9sTp" x="63" y="-112">
       <value name="OID0">
         <shadow type="field_oid" id="X;:)n=I~w1^8IU4(T1R(">
           <field name="oid">admin.0.info.updatesList</field>
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="variables_set" id="-#s]aV=U1oOLLJe3=~sV">
           <field name="VAR" id="rP{a|eu}2/U(2%YfvLO^">json</field>
           <value name="VALUE">
             <block type="lists_create_with" id="l1hpxzG5oEx4~AE]bTeN">
               <mutation items="0"></mutation>
             </block>
           </value>
           <next>
             <block type="variables_set" id="8_pk2}Xx=Tk/k*J9Fwl2">
               <field name="VAR" id="TOC57z`*`7eGmxbFS-:h">updateliste</field>
                 <block type="lists_split" id="Z%rwV6Wm.u@7E4saEPw8">
                   <mutation mode="SPLIT"></mutation>
                   <field name="MODE">SPLIT</field>
                   <value name="INPUT">
                     <block type="text_replace" id="Oo!}a5#@dT_Do,EBVu?E">
                       <value name="FROM">
                         <shadow type="text" id="-M8n=5?gUe==S.6VT_;o">
                           <field name="TEXT">x</field>
                         </shadow>
                         <block type="text" id="QMUh6%-i2%0F4`4/.$#D">
                           <field name="TEXT"> </field>
                         </block>
                       </value>
                       <value name="TO">
                         <shadow type="text" id="j(=:a%S.a:)ZX(eGXhAU">
                           <field name="TEXT">y</field>
                         </shadow>
                         <block type="text" id="R5T7u.E|6=UuV,R8cTFC">
                           <field name="TEXT"></field>
                         </block>
                       </value>
                       <value name="TEXT">
                         <shadow type="text" id="NfIO^?sLex[!.[%`)OxA">
                         </shadow>
                         <block type="on_source" id="#?6G9=I5/Q3=`L9QL))H">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="DELIM">
                     <shadow type="text" id="Z/1)5cf,Tx8M@$)v,M8q">
                       <field name="TEXT">,</field>
                     </shadow>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="timeouts_wait" id="`bIHybs9~)Fan,rzI9of">
                   <field name="DELAY">10000</field>
                   <field name="UNIT">ms</field>
                   <next>
                     <block type="variables_set" id=")eSE=bb6fjskakdAvMY]">
                       <field name="VAR" id="CUid=kHOy5RBXEU4[!}D">updatejson</field>
                         <block type="get_value" id="P3$jK(])}hNuP{/t*+hD">
                           <field name="OID">admin.0.info.updatesJson</field>
                         </block>
                       </value>
                       <next>
                         <block type="controls_forEach" id="S|b0;?EHe{4W!UGtj78q">
                           <field name="VAR" id="JT52yn~1WVDRD|]6)~f]">i</field>
                           <value name="LIST">
                             <block type="variables_get" id="B@f[SOAnS?^TjC8[9cYc">
                             </block>
                           </value>
                           <statement name="DO">
                             <block type="variables_set" id=":L[BVFn@{a?CoY0to_Bl">
                               <field name="VAR" id="%Tg~cn!H=|@vi9M%DCjv">adapter</field>
                                 <block type="text_join" id="{kAKV%CsdCKa0nD]#}ti">
                                   <mutation items="7"></mutation>
                                   <value name="ADD0">
                                     <block type="text" id="^rIJNi^+iX/2X,%|t)fu">
                                       <field name="TEXT">{"name":"</field>
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id="Ky).`A#7oG!EH^Sp)xl6">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     <block type="text" id="vDmQA^~#ag=Z.kczU/ZJ">
                                       <field name="TEXT">","installed":"</field>
                                     </block>
                                   </value>
                                   <value name="ADD3">
                                     <block type="get_attr" id="QcpxucK|xe/hBA$LjLFu">
                                       <value name="PATH">
                                         <shadow type="text" id="/c~;=`Vu_6}yRe[Oj@ly">
                                         </shadow>
                                         <block type="text_join" id="R%-)0Lip5n[H]{0654OW">
                                           <value name="ADD0">
                                             <block type="variables_get" id="LLl%?F_vDk9$M|(vLVB{">
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="text" id="`D:XG%[2tFZ^7924q]CQ">
                                               <field name="TEXT">.installedVersion</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="OBJECT">
                                         <block type="variables_get" id="iDX|~]ZQU{^D6Oo%||)_">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="ADD4">
                                     <block type="text" id="HA@c+Xf#W{@AK]{_{J;^">
                                       <field name="TEXT">","available":"</field>
                                     </block>
                                   </value>
                                   <value name="ADD5">
                                     <block type="get_attr" id="qLK`:EV!Mo}Yl#}BQDsu">
                                       <value name="PATH">
                                         </shadow>
                                         <block type="text_join" id="%!do@ZuSW$S+fXsoj[0L">
                                           <value name="ADD0">
                                             <block type="variables_get" id="3-pk3$9qD[iVWP9$*se)">
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="text" id=",}yqpwXX2FLAT+^([Wb{">
                                               <field name="TEXT">.availableVersion</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                         <block type="variables_get" id="p72%x{H4;g=P+7AFc+aK">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="ADD6">
                                     <block type="text" id="RY@Rs+[Skala~`:4%GBD">
                                       <field name="TEXT">"}</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="lists_setIndex" id="s0%R]B4u8%(^i{R:@pnU">
                                   <mutation at="false"></mutation>
                                   <field name="MODE">INSERT</field>
                                   <field name="WHERE">LAST</field>
                                   <value name="LIST">
                                     <block type="variables_get" id="n-Ri;-e/WMt$?|.x~1EO">
                                     </block>
                                   </value>
                                   <value name="TO">
                                     <block type="variables_get" id="InrP93A.d5$9[iQJZ0x}">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="update" id="d-qBn^MZ#Z=a!c{Xk$Il">
                               <field name="OID">0_userdata.0.System.Abfragen.Adapterupdates</field>
                                 <block type="text_join" id="#cUvh5*CvN@ef;_~LfIr">
                                   <value name="ADD0">
                                     <block type="text" id="bxLHtvE.$,lcS5sNKpef">
                                       <field name="TEXT">[</field>
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id="xg_8kI(7LX@fIp6d61@4">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     <block type="text" id="vA$g(,jorTvHcFiBBh0H">
                                       <field name="TEXT">]</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    @djmarc75 sehr cooles Blockly.
    Aber könntest du das Blockly so anpassen, dass ich mir die Updates per Mail senden lassen kann?
    Ich suche einen Weg an die aktuelle und neue Version für jeden zu aktualisierenden Adapter zu kommen.
    Dank dir.
